Well, it looks like I'm going on coils. Slammed members on coils chime in please
#36
#38
I was talking to Zach in regards to making my own cause I didnt want to spend the $200 for another kit cause I was a little hasty when I sold them the part below circled, measure it and find some piping of the same size and cut it to size. Technically you only need a pipe that size and dont need the whole mount they made. However, the piping alone would probably make some noise against the bag as well as cause some movement.
Just measure that piping part, get exact size and have someone weld in another inch or however more you want it away from the arm. But remember, the more you add, the less air you're gonna use so be sure you dont go so low that you lose ride quality... if it matters
#39
#40
I do know what you mean though Yes, if he adds any more, he looses dumpability, but nothing a set of RCA's can make up for However, in actuality the kit seats you at the same height you would if using the factory/KYB mount. Because the top mount of thiers is flush on the bottom (and the factory one has about an inch below it) the one inch spacer they moved to the bottom makes the setup exact height with stock setup.
I too was told that the kit changed the height of factory (thus the reason I sold them) that incorrect information, that I shouldnt have listened to, made me sell something I needed and now cant get so now have to make my own.
