HID (ballast) problem - please help me
Old 01-30-11 | 08:56 AM
YviE's Avatar
YviE
I somehow missed your thread. Kinda feel stupid now having created another thread for the same problem...
Lucky you, you're just in for new bulbs!!
I want to remove the headlight, remove the ballast and check the internals. Maybe I can service it somehow. Or let it dry if it's wet inside.
Old 01-30-11 | 09:04 AM
jcastaneda's Avatar
jcastaneda
Hopefully you can dry out and everything will work out in your favor!
Old 01-30-11 | 06:15 PM
92sc300nj's Avatar
92sc300nj
yea more than likely your ballast is blown.... sounds like you did all the tests.. i had this same situation not to long ago..
Old 02-02-11 | 04:02 AM
YviE's Avatar
YviE
Did you replace it with an OEM ballast or an aftermarket one?
Old 02-02-11 | 06:56 AM
Mr Jokster's Avatar
Mr Jokster
I really don't think there's an aftermarket option for this unless you chop your factory wires.
Old 02-02-11 | 07:13 AM
YviE's Avatar
YviE
Yeah that's what I figured. Plus, you'd have to seal the hole on the bottom, drill another hole for the lead to go into the housing and attach the ballast somehow...
Old 04-03-11 | 09:52 AM
YviE's Avatar
YviE
Ooohh I'm having so much fun with my car lately... Not...
I had just replaced the passenger side HID ballast and 3 days later the driver side ballast goes out!!!!!!!!
Just needed to vent... I guess things could be worse...
Old 04-04-11 | 04:21 AM
jcastaneda's Avatar
jcastaneda
I sort of feel you pain...my driverside just went out....holding my breathe on the passenger side.
Old 04-04-11 | 07:31 AM
YviE's Avatar
YviE
Yeah, these things go out without a warning... I opened one and they are not servicable. They are completely filled with some sort of silicone to avoid moisture.
Old 06-08-11 | 03:05 AM
sam430's Avatar
sam430
you guys are lucky to know it's a ballast or bulb. For me, it's a lot weirder.
Old 06-08-11 | 03:13 AM
YviE's Avatar
YviE
So you tested the ballast & bulb, and they are fine? Did you check the fuses (low beam fuse)?
wtfsajayte
02-21-14 08:09 AM
xspsi6
07-06-13 08:18 PM
Vibes63
09-06-12 04:47 PM
92 SC400
12-20-09 05:59 AM
Smoothie22
17
12-18-07 09:49 PM
