Heart Beat Sound Coming from Car
So I noticed today when I was driving that my car was making a heart beat sound. The sound gets louder and the pace increase as I speed up. I think it may be a wheel bearing gone bad. Any ideas? I know that a couple of my rims aren't perfectly round so I was thinking it could be that, too.
Alright so I took my car to Firestone to get an opinion. They said that the noise is coming from my tires because they have uneven wear. Also, there is a nail in my front left tire (on the inside shoulder of the tire. I'm guessing this nail is making the heart beat noise. They are saying that the uneven tire wear is a result of the upper ball joints being loose. What do you guys think? And is there a DIY for Upper Ball joints? I know there is one for the lower ones. They said if they were to replace the Control Arm with the Ball Joints it would be 681 in total for both of the fronts.
Also, I found the Upper Control Arms at RockAuto: http://www.rockauto.com/catalog/moreinfo.php?pk=2001878
They are only $120 a piece? Does anyone have experience with Beck Arnley
So i guess you will be glad to have those new tires and rims you bought from me. I drove them on the car at 80mph from virginia to florida. I can tell you they ride pretty good balanced as is but, if you have a fire stone close and since they are being shipped I would have the set balanced again before installing. GL with the fixes.
The only visual/hands on check you can do is check the rubber boot make sure its not cracked and if you have everything apart then you can do the lateral side to side and up and down check neither should produce any viable movement. Also the joint movement itself should not be all to loose. A nice tight yet smooth movement is desired.
Thanks for the advice. I just switched out the wheel that had a nail in it with a my spare. I was hoping the nail was the cause of the heartbeat noise but unfortunately the noise is still there. When I get the 17 inch wheels I'm going to put all of them on and see if the noise goes way. If it doesn't I'm going to go find another opinion because I can't find any threads that say the UCA would cause the kind of sound I'm getting from my car.
Alright, so I went to another place and they said my front left wheel bearing was in pretty bad shape which is just as I thought. I recognize that my UCS might also have troubles, but that is not the cause of the noise. This place quoted me $500 for a single wheel bearing? Isn't this really steep. I looked up wheel bearing diy's on here and it looks like a job that I could get done without spending too much. The wheel bearing is $50 and
I found this:
Remove the upper control arms and lower control arms off the car along with the traction rod. Then remove brake caliper and parking brake if it's the rear. Then remove cotter pin that secures the axle nut onto the hub. Then remove axle nut while slightly tapping the axle off the hub with a rubber mallet and pull everything off.
I could just take off the hug my self and take it some where to get pressed and save a ton of money.
What do you guys think about the quote and do the instructions above seem to cover everything?
I found this:
So I got it checked out again today and they actually pulled off the wheel and checked the bearing. It's in perfect condition... They said it might just be the upper ball joint that is making the sound. So I am going to get those replaced in 2 weeks and see if the noise goes aways once I get them fixed.
