intake
i'm planing to get srt intake
i have few questions
1.is it ok to get used one? (will i lose any performance)?
2.whats the difference between old and new ecu
3.is it worth to upgrade to new ecu if it comes with old?
4.any ideas how much should it cost? (new/old/used) w/ old/new ecu
thanks
thanks
I was too scared to modify the ECU on my car, so I bought the Injen for $225. Your questions are covered in several places on the board, but they did have a dyno and the SRT did the worst (without an ECU, however.)
Guest
Posts: n/a
(1) You will lose the performance with used one unless the intake filter is dirty. You can either buy a cleaner or a new filter. Not expansive at all.
(2) what the hell are you talking about? list one company that sells new ECU and I'm not talking about steering ECU.
(3) once again, nobody makes replacement ECU for GS4, yet.
(4) same reason. see above.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
RA, A1 is talking about the SRT Race ECU vs regular ECU.
Used one will be fine, try and find with with the race ECU and save $100. Clean the filter.
IMO it's worth it for the new one. Do a search on 'race ECU' and you'll find the answers you want on old vs new.
You can get a used SRT Intake with the old type ECU. I would recommend upgrading to the Race ECU v.2 though since it gives a little more power at the lower RPM band. Here is the link to SRT's ECU swap As far as costs, I have no idea. Check out the classified section and see what used intakes are going for. Good luck
Originally posted by enginyr
Isn't the SRT intake notorious for loosing horsepower???
Originally posted by lex400sc
Is the SRT a sealed cold air intake?
If it's just a open filter with a heat shield then you will lose power once the engine warms up. As far as power gain on an aftermarket intake, alone, it will do very little if anything at all. This is true of any intake put a half-decent engineered car.
I thought the Injen was the best intake on the shootout, if so then why buy SRT?
Having said all that, I think the SRT intake gains aren't bad at high rpm but it may well lose some power/torque at low rpms.
I think combining the TC and SRT intake makes up for any loss their may be from the SRT intake at low RPMs. From my sig, you can see what I have at the wheels with just the intake and a TC. Enough to beat a GS400 with the same combo, hehe
, as evidenced from the dyno graphs when my car was compared to a GS400's with similiar setup @ SRT. I will try and get to the track in the next few weeks to get some #s finally.
Originally posted by liazon
paid $380 for a used one myself....then, exchanging the older ecu for the race ecu, which hasn't gotton to me yet. (it's been over 2 weeks). so, that'll cost me an additional $100.
the filter is a lifetime filter. it never needs replacing...just cleaning.
