need suspension help
This is a newbie question im sure but what kind of suspension parts do I need to run to Achieve negative camber.
I am use to s chassis and all you need there is adjustable upper control arms to dial in your desired camber what does a gs300 require to achieve this.
Thanks in advance for the help.
Well you should be able to achieve a small amount of negative camber by using the cam bolt located on the distal end of the rear lower control arm. You might also want to make sure you use the search function because there are alot of suspensio write ups. GL witht he car.
Ill search for ya this time lol
https://www.clublexus.com/forums/sus...e-bushing.html
^^^shows you the bolt that can be adjusted moving the cam angle inward pushing the bolt through hole outward giving some negative *
Andrew123
Suspension and Brakes
02-18-18 04:15 PM
