Glove box light problem
02-08-11 | 06:40 PM
My light was working perfectly fine. I pull out the bulb to replace it to an LED one and it didn't work. So I turn the bulb around and nothing. So I was like forget it, I put back the OEM bulb and now that doesn't work. Has anyone had this problem? If so what did you do? Any help will be appreciated.
02-08-11 | 06:47 PM
Check to see of you're getting juice (power).
02-08-11 | 06:59 PM
No sir. I put my DMM to the plug and no power.
02-08-11 | 07:14 PM
It gets 12V when you turn on the tails and gets ground when the glove box switch is triggered. Any other switch indicators off?
02-08-11 | 08:44 PM
As in the trunk or doors? When I open the door the dome and the door light turns on. Do you happen to know where the fuse is? Where else can I check?
02-08-11 | 10:45 PM
You have to have the headlights on for the glovebox light to turn on.
02-09-11 | 12:28 AM
^^ Exactly!!
I had the same problem. It took me a while to figure out the light only works when you switch on the parking lights/headlights.
02-09-11 | 12:33 AM
i had this same problem... hmmm interesting now i have to go and put my headlights on lol
02-09-11 | 03:41 PM
It work!!! You have to turn your headlight on too, not just the running light. Thanks guys for all your help
WLGS01
Lighting
02-28-15 05:06 PM
pizdets17
11-09-10 11:01 AM
JohnnyCake
02-13-09 02:40 PM
TJW98LS
05-15-08 10:32 PM
