Need help- oem 01+ radio installed in a 2000 gs300?
Is there a walk through our guide on how to install a 2001-2005 oem radio in a 1998-2000 gs300? Should i stick with Pioneer or can i use a Mark Levision?
I like the factory system, don't want to rewire and add a amp for a aftermarket head-unit.
I have seen older post telling people to contact a member who makes the harness but he is no longer active on the forums.
So what harness do i need? Tips Pics suggestions please.
Also can you add steering wheel controls to a 2000 Gs? Is it as simple as buying a gs430 wheel with controls(plug n play)?
I'm wondering if just switching out the applifier to a 01-05 apm to match the radio would simply resolve the issue.
He probably has the same reason as I do, whcih is because of the fact that the 98-00 models did not come with RDS. My radio is broken and I have to replace it anyway, so might as well replace it with a newer OEM radio while at the same time gaining the benefit of RDS.
Moving
12
11-11-10 03:44 AM
