2GS Stock Subwoofer Replacement w/ pics
paulr1 (09-13-19)
#32
So I took the old one last night guys. Put the new one. I'm much happier with the sound ☺☺☺. THANK YOU SO MUCH TO THE GUY WHO MADE THIS DIY. You saved me $300+ fees in an hour and 20 mins. Had the tools. Read the DIY correctly then went at it. Putting it back together was the harder task. But not impossible going slow seeing how things work. Here's a pic of the old speaker. Falling apart. Old since 2001 probably hasn't been changed out. Thanks again to this DIY!
![2GS Stock Subwoofer Replacement w/ pics-forumrunner_20140622_111308.png](https://www.clublexus.com/forums/attachments/gs-2nd-gen-1998-2005/333493d1461370033t-2gs-stock-subwoofer-replacement-w-pics-forumrunner_20140622_111308.png)
#38
Just wanted to say THANKS so much "HpyFunBall" for the above information. I just recently purchase a 2004 GS430 with this problems. Thanks to you I save myself over $600 smacker .... Your the BOMB!
#43
I just fixed my blown sub, thanks to the OP for the clear write up. I would highly recommend getting a set of interior trim levers for this sort of work. It makes removing the snaps easy. And inexpensive too, with the ubiquitous 20% off coupon.
https://www.harborfreight.com/5-piec...set-67021.html
Instead of replacing my sub, I repaired it with a new surround. The foam rots after a decade or so, but it's possible to buy a new surround and glue it in place.
10 inch JBL Speaker Foam Surround Repair Kit - Toyota, Lexus, Cadillac, Mark Levinson
After replacement it sounds good as new. What an improvement! Always great when you can do a $600 job for under $25.
#44
#45
My ML sub's foam ring is also separating from the outer edge... rattles and sounds like crap.
I did a lot of reading on the many threads in this section, but they go back YEARS .... and all the recommended replacements on here seem to be discontinued ... :/
We need some UPDATED sub recommendations!!
