Oil leaks
Thats what I thought, but I didnt' want to hear - but thanks for the honesty - do you think if I could match up the oring and find one like it, then I could get another 100K out of them? I would like this to get fixed sooner than later, but if I can save $560 on parts and time to ship them, etc, then it may be all I need.
The inner wear ring is fairly large not sure you are gonna find it, but if you can down the car for awhile and pull the cam gear apart and do some R&D maybe you will find something that works. I heard tell in previous posts the cam gears run around $160 for the VVTI gear. Maybe you could do a little wrenching and save the $ at that. GL to both of ya in this thread.
Think I got it. Cam seals will show behind the belt running down the Front side of the heads and block.
VVTI inner seal will puddle up on the inside of outer gear and I know what leaky valve covers look like.
What pisses me off is they did timing belt and water pump at the 90,000 mile service. It has 110,000 on it now. Figured they may of saw something. Owell.
They also carry a 24 month warranty on parts/labor which is unheard of. Needless to say I'm going with the $960 price just for piece of mind since they work on GS all the time. After reading that Toyota 90K replacement thread....I'm going to stay away.
Do you have any burning oil smell?
Just wondering if you have any oil burning smell coming into the cabin when stop at the traffic light? Outside air mode is on and slow fan speed is on too by the way. I have no visible oil leak, except for the rear main seal. That doesn't come in contact with the exhaust or manifold, but I have this oil burning smell. The car is at 98K miles
That is what I was quoted too
yeah you have to make sure that they changed it or they won't. It's best to change it even if it isn't leaking due to labor. The local Toyota dealer quoted me $760 for only replacing TB, WP, Serp Belt, and fluid change (no cam or crank seals replacement). Then there is a local Lexus Independent shop that quoted me $960 to replace cam/crank seals, TB, WP, Serp belt, fluid change, cabin & air filter, and full brake fluid replacement...basically everything listed under the 90k replacement. Since my WP isn't leaking and my Serp belt has less than 5k on it, I will tell them to put my old WP and serp belt in a box and I will keep them. No way I'm going to allow them to keep a good WP and serp belt lol.
where are you at mileage wise? I'm at 100k and I don't plan on doing this job until the summer comes. I've read multiple threads where people have changed them at 150-160k and the belt still looks good. That's actually what a Lexus tech told me myself that's the mileage to think about changing it. 90k is oversold...
The mileage is at 97K miles rite now
I don't you should skim on this particular part
Here is the link
http://lexus.sewellparts.com/oem-cat...S300-2001.html
I have a friend who is a used car dealer have a 2001 GS300. And he told me not to worry to much about it. He have saw lots and lots of Japanese car engine. His wife been driving the car for years and it got around 150K miles. He hasn't done the T/B yet. Three out of four Lexus/Toyota shop I talked with just asked me" Why do you want to replace the Water/P if it doesn't broke. One guy actually told me, most of the time " THEY ONLY DO HALF A JOB ON THE WATER PUMP" (My Jaw just dropped and look really confused). The timing belt at 100K is a security deposit he said, the mechanic. I am thinking just replacing the T/B, cam seals, crank seal valve cover gasket and flushing all the fuilds. I meant all fluid and major tune up. Just don't forget, The GS 300 have an INTERFERENCE ENGINE. something valve can bend if timing belt headed south.
