Max wide REAR wheels for performance tires ...
YaKuZa_GS, thank you very much, man!
I think you right .. also HOOSIERs not like any street 315 width tires, it has very flexible side walls when starting .. i will think ...
305/25-20 on 20x11.5, cut fenders.
Anything bigger will be a serious challenge. Some 315s might run on the narrow side, but the 305/25-20 Yokohama Advan Sport I had were w-i-d-e.
But he never mentioned if he cut/rolled his fenders. As I mentioned in my previous post if you run 11j you will need a offset between 30-40 so JeffTsai is right in that case. but when he said...
I believe this is wrong information and I am 100% sure this will touch the rear suspension.
I sell wheels and tires for a living so believe me when I say I know what I'm talking about and I eat, breath and sleep about offsets and sizing LOL. If you want a 11" wide rim with the most fender clearance I recommend a +37-40 offset. But you still may need to shave the rear fender because the tire is so wide but I'm not 100% certain, you might get lucky but that is your best shot. I suggest try that first and if the tire still rubs shave the rear, its not a big job or a big deal, just make sure to reseal it to prevent any rusting.
Will be fitting 255/35/20 mt street comp on a 20x9.5 +22 offset for the front and a set of 305/35/20 Mickey Thompson et street radial 2 in the rear on a 20x10.5 +22. Car has a 10mm spacer in the rear currently. Going try to get the rear to fit without too much camber. Fenders have already been pulled some. Going to make it work one way or another..pics coming soon. Wish me luck.
Why are you all running such tall tires? A 275/35/20 and a 305/35/20? Both of those are too tall for the vehicle. I run a 20x11 +30 with a 275/30 with shaved fenders and don't have any clearance issues.
The specific tire compound I wanted was only offered in that size for the rear...drag radials. I think my fronts will fit.. It will probably look ridiculous if I get it to fit in the rear but going to try. They are great tires..
