There's a first for everything....stuck rear door
I need help with an issue I'm sure no one has come across.
I am changing out the door handles on my 99 GS and one of the doors is stuck closed.
The back driver side door did not link up correctly and I did not test it before putting the panel back on. The child lock was engaged during the process cause I am not able to open it from the inside either.
Any I ideas short of destroying the door panel????
Ok guess..I calmed down and solved my own problem.
So if this ever happens to you take a slim jim and slip it down on the inside of the main window you will have to work around the window track and there is a lever on the handle that you can push down on with the slim jim and....bam the door opens.
I will post a picture of this lever once I get home.
mr nut
SC- 1st Gen (1992-2000)
12
09-25-07 05:37 PM
