D2..Weds..Ridetech lol
look at the door cups in here....i LIKE this idea.according to the OP a LONG time member (lightwave) is gonna get some work done, im curious to see what he gets
https://www.clublexus.com/forums/clu...then-some.html
Thanks guys its a work in progress..so hopefully there will be more with time..
I saw the door cups Brian, I'm not sure I want it that bright so instead of SMD's I was thinking of using regular LED's..just want a subtle glow at night.. hmm...same with the outside door handles.. I was just going to tie it to the side mirror LED's.. I'm going to try to do the side mirrors this weekend..maybe try to figure something out with the lights too..and I'm AJ btw..
its brian btw,i dunno bout the center console....but i have been thinking about the door handles (inside and outside) and the foot well + the glove box all these places have inadequate lighting IMHO
Nice aj nice ill be posting up shortly also. Hope you dont mind me posting this info
My Lex is going with a similar setup. I have had the kit for about 2 months now.
If anyone needs the contact for Ridetech Please contact me directly over me PM Or Zeb Magsi.
We are Authorized dealer for RideTech and also our cars are Sponsored by them directly.
Thank you so much.
Thank you so much.
Thanks guys, qphoton you have pm..
Not a problem Kam, when you get the D2 coil on bags and install them make sure at your ride height the wheels dont rub the bags. When I setup Steve's D2 airride his wheels rubbed against the bags slightly when it would hit a dip in the road, causing wear on the bag and eventually causing the bag to leak, and Steve's is a 10.5" wheel, the issue is fixed now though. With your wheel size, dependent on your offset, if it sits further in than Steve's you might have issues too. If it does you would probably need Fig's LCA to go more positive camber to fix the issue. Fig's and I have worked together to create a new design on his LCA to encompass an RCA feature which will lower your ride and in retrospect give you more shock travel and also let you run increased pressure and of course the obvious fix to pull your wheel in and help reduce negative camber.
I've been working with Figs, D2 and ridetech for awhile now and am a dealer as well, also am a dealer for Weds wheels and Super Star wheels. The air ride setup is application specific. I've had to customize my D2 coilovers, ridetech parameter etc to achieve ride height, quality etc. So each kit I would put together would depend on your wheel width, how low your ride height would be, supporting mods like Fig's control arms, toe links, bump stops etc.
Thank you so much.
Thank you so much.
pleased to meet ya
Hells yeah man..Ridetech FTW.. how do u like the airforce bags and struts setup?
