can anyone help with hid's?
Ok so I got aftermarket hid's for my 2001 gs3 and can't figure how to hook up the driver side head light I plugged everything in but I still have and extra wire and can't figure where it plugs into can someone Please Help thanks
there shoud be 2 wires that connect to the bulbs. on the opposite side of the ballast that wire should connect to the oem bulb harness?
unless you have a "wiring harness" to draw power directly from battery then 1 of the ballast will use the connector on the "wiring harness" and will not need to be plugged into the oem harness.
where did you buy the kit from? all aftermarket kits usually have 2 wires (+/-) for the bulbs and a thicker wire that connects to the OEM harness. unless they sent you a wrong harness wire?
upload pics to a external free host site or even the clublexus photo gallery. after all the uploads done click the "insert image" tab back on on top of where you want to reply and copy & paste the link to it when the pop up comes up.
NEbiker10
12-07-11 01:02 PM
RumpRoast
09-20-09 03:48 PM
