guys on air. compressor fail
my compressors fails to turn on after reaching below 165psi. i changed the relay and pressure switch but still the same issue. any ideas.
it just stop working and only turns on once in a while
Does it turn on at all? Get the compressor and hook it directly to the battery and make sure its still functional.
What gauges are you using? Analog or digital. Could be reading wrong pressure.
