fast left blinker - which bulbs
Hi
I have a fast front left blinker, however, there also appears to be no light in the left rear either (not even blinking).
I've read that one can cause the other to stop - my question is, are both bad and which bulbs do I order? (eBay?)
Sorry for the question, but rather not take both front and back off to find I only need to replace one of the bulbs - thanks
It's the left rear (encased in yellow) turn signal light bulb, Autozone has the 7440ST or 7440LL (any preference?)
I'll need to take it out myself and replace - quick instructions? few screws?
I got the less expensive ones, I don't need turn signal to be uber bright
I see a screw in front, and also 2 in back, I suppose removing those 3 should do it, hopefully
I think the stop light is 7443
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
What great advice guys - I didn't erroeneously change thge fast blinking front bulb, and quickly changed both 7440 rear bulbs by removing ony 2 exterior screws and 2 interior 10 mm bolts.
Love the feeling of a successful DIY!
Actually, I changed the turn signal and whatever else was a 7440 (reverse?) - hope I didn't change out a good 7443 like the brake light (are the fittings the same?)
