Do you have a vibration at highway cruising speeds? Mine's fixed!
Old 10-26-06, 06:30 AM
  #181
gsCrazy
gsCrazy's Avatar
hey Mark,
just wanted to know which dealer in ct you took it to? i live in new york and do not really trust Lexus of Manhattan or the one in Brooklyn. i work in Norwalk, CT though; hopefully the dealer you went to is close by. let me know by PM if you can. thanks much.
Originally Posted by Mark
I just had my steering pretensioner tighten at the dealership. The steering vibration problems seem to be resolved. I love how there is less play in the steering wheel: cool:. My GS even corner much better at high speeds. Talk to the dealership and have do the same to your car--it like night turning into day
just 2 cents.
Old 10-26-06, 06:32 AM
  #182
Mark
Mark's Avatar
I took it to Lexus of Westport. I new the service tec. he did it as a favor.
Old 10-26-06, 06:57 AM
  #183
gsCrazy
gsCrazy's Avatar
Would you be able to get me his name so that I can have him do it for me as well. Let me know. I drive up from NYC every morning to work and this shaking gets on my nerve at times. Anyway, hope all is going well. Do you meet up with any of the Club Lexus guys in CT. Maybe we could all meet up after work one day. =)
Thanks.
Old 11-09-06, 06:44 PM
  #184
ocean350
ocean350's Avatar
the highway vibration is finally gone!!!!!
if you changed your rims or tires, you should have a balance job done at Lexus dealer.
Before, i did a balance job at JustTire and Wheel Work, both of them result in vibration on highway(~75 mph)
Finally, i took it to Fremont Lexus dealer, they rebalanced my wheel+tire. (for less than $200), and the vibration was almost gone. (i think my tire should be accounted for the 'minor' vibration)
the bottom line -- if you haven't done this, have your rim/tires balanced properly at the dealer.
you should notice some major difference.
cheers,
Old 11-09-06, 06:45 PM
  #185
ocean350
ocean350's Avatar
Talking the highway vibration is finally gone!!!!!
cheers,
Old 11-12-06, 02:14 AM
  #186
chinkster
chinkster's Avatar
cheers,
this is what i did too. i think i can still feel SOME vibration but the majority of it is gone. but i might just be thinking i feel some vibration because i had it before tho. the dealership did help it alot.
Old 11-16-06, 06:32 AM
  #187
gs-ireland
gs-ireland's Avatar
I got my hands on the ST003-R equal, the CP-8007 Dated June 98 ' Steering Flutter' and what to do to fix.
It details the following checks:
1. Check tyre radial runout, max 1.4mm, if not fixed:
2. Check unbalance with an on-car balancer, if not fixed:
3. Replace steering rack guide, if not fixed:
4. Adjust steering pre-load (1.9Nm), if not fixed:
5. Replace steering rack grommet.
* Must be done with warm tyres *
If anybody needs any other values or part numbers, just ask
Old 12-26-06, 07:13 PM
  #188
400 Degrez
400 Degrez's Avatar
How do you tighten up the steering rack?
Old 09-15-07, 06:41 AM
  #189
David1969
David1969's Avatar
Just wanted to bring this back to life. The next to the last post has the TSB listed, so if you're having this problem, give the dealer this info so they can lookup the information.
Old 12-16-07, 09:56 AM
  #190
01gs3
01gs3's Avatar
Does anybody know how much this service costs?
Old 12-16-07, 08:30 PM
  #191
lexusscturbo
lexusscturbo's Avatar
I thought you can only tighten up the rack on a 98??
How do you do this if it applies for 99 GS3's?
Old 12-17-07, 08:33 AM
  #192
gs-ireland
gs-ireland's Avatar
I believe it is all GS's from mid-98 on that have this rack. The TSB also states the VIN range, all LHD VIN's from JZS160-0017502->ON have the newer style rack, but as always double check by getting on your knees!!!
Old 12-17-07, 07:26 PM
  #193
qgoat
qgoat's Avatar
Thats what my dealer told me when I kept bugging him about tightening mine. He said that adjustment was for certain 98 models only.
Old 12-18-07, 01:08 AM
  #194
gs-ireland
gs-ireland's Avatar
Look under the car behind the driverside wheel and look to see if your steering rack looks like this:
If it does, go get it tightened.
What it simply does is pretensions a spring that pushes against the main rack to increase the resistance to turn it. If it is too loose you need next to no force to turn the wheel. If its too tight your steering will be very stiff and will not self-center at any speed.
I have it that it is as tight as it can go but will autocenter
Old 12-18-07, 05:22 AM
  #195
lexusscturbo
That's what I thought as well too (it only goes for 98's)?
Quick Reply: Do you have a vibration at highway cruising speeds? Mine's fixed!
