Do you have a vibration at highway cruising speeds? Mine's fixed!
Old 04-15-09, 04:45 PM
  #226
AristoKing
AristoKing's Avatar
Originally Posted by PR FIEBRU
no need to rent the tool
just make it yourself
check this link out
https://www.clublexus.com/forums/gs-...djustment.html
Originally Posted by sakataj
i made a better tool....so u can still use your ratchet wrench ....its also in your DIY link....
https://www.clublexus.com/forums/gs-...ml#post4067747
Very interesting tools guys..... I will try this on my GS.
Old 04-16-09, 12:13 PM
  #227
sakataj
sakataj's Avatar
yeah i couldnt find anything else to fit inside there and its a old mechanic trick i knew of. it worked out well
Old 05-06-09, 09:57 PM
  #228
TomLee
TomLee's Avatar
I gotta try this. This first post is everything that I have done. I just got back from alignment haha.
Old 05-06-09, 11:19 PM
  #229
tom steele
tom steele's Avatar
all i am going to say is daizen bushings upper lower control arm and castor arm bushings
the castor arm bushings clear most of it up but if you do all of them its great i went through all of those fixs to come to this are bushings are crap and go out after 60-75 thousand miles only draw back this is not a diy not for most at least i have done everything on my car but getting those damn bushings out and the new castor arm one in are a pain in the butt. this is well worth paying for this one
Old 05-06-09, 11:52 PM
  #230
TomLee
TomLee's Avatar
how much for them replced? are you in socal?
Old 09-23-22, 02:30 PM
  #231
CurlyG
CurlyG's Avatar
I just found the cause of my steering wheel shaking when I drive over 70 mph. It happened during a 600 mile drive. A day before returning, I had the tires rotated and balanced, which did nothing to prevent the steering wheel vibration, which became progressively worse over the 600 mile drive back home. I found the cause to be stuck/frozen brake caliper pins on the front brakes. This caused the brake pads to stay pushed against the rotor with just enough force to heat up the rotor, which in turn warped the rotor, which generated the vibration in the steering wheel, and to the chassis. Small chucks of steel were missing from the front right brake rotor.
I cleaned and greased the caliper pins, and the problem is %95 gone (barely perceptible). Next step: new front rotors, bleed the calipers, and a install a pin rebuild kit.
QLex300 (09-26-22)
Old 09-26-22, 04:36 AM
  #232
QLex300
QLex300's Avatar
Thanks for the Update
Old 12-31-23, 10:09 AM
  #233
CurlyG
CurlyG's Avatar
Default I finally solved my soul-crushing steering wheel shake at highway speeds
After the problem re-occurred, I recently solved my soul-crushing steering wheel vibration at highway speeds, after doing a lot of work on my 2GS. Please read my 2 recent posts:
My front end shake solution
Solution: Steering Wheel Shaft Movement/Rattle
ILOVEGIRLS (12-31-23)
OkNowWhat
05-10-17 08:43 AM
finny76
ES - 6th Gen (2013-2018)
45
05-07-16 07:11 PM
toystry
10-04-13 09:32 PM
RXSF
02-07-07 11:39 AM
DaveG
Suspension and Brakes
10-27-03 02:26 PM
Quick Reply: Do you have a vibration at highway cruising speeds? Mine's fixed!
