How do you Un-Connect an O2 Sensor
yeah are you trying to remove the 02 Sensor from the bung (unscrew it) or trying to unplug the electrical connector?
if you have it unscrewed and your trying to unplug it, you just need to follow the wire till you find the connector..
you can search and probably find your answer on here somewhere, or if you post a more detailed question with specifics someone might throw you a bone and give you the exact info you need.
