Won't shift out of park without using manual release
03-29-11, 07:54 PM
Mechanic said it needs
http://lexus.sewellparts.com/images/...00/841255F.jpg 85903 in picture, part # 85903-30020 is this common it just all of a sudden started on Friday night when leaving Walmart.
03-29-11, 08:14 PM
possible but check your brake lights also
03-29-11, 08:16 PM
Rear indicator light would be on.
03-30-11, 07:02 AM
03-31-11, 02:08 PM
Not a fuse, it's the part mentioned above. Hum.. guess I'm the only one that's had to replace this.
03-31-11, 02:39 PM
The exact thing happened to me with my old land cruiser, ended up being a blown fuse for the brake lights.
03-31-11, 03:05 PM
03-31-11, 11:35 PM
Fuses are fine, my mechanic has been a Toyota/Lexus/Scion tech for years who now has his own shop.
04-01-11, 12:17 AM
04-01-11, 06:21 AM
I'm currently having the same exact problem. I will check my brake light fuse. If that dosen't work I will order that part from Sewell.
04-01-11, 06:25 AM
Part will be here Tuesday and will be installed Wednesday.
04-06-11, 06:50 PM
Part was installed today, 1 hour @ $82 problem solved. I guess I'm the only one with a 2GS thats had to replace this?
04-06-11, 10:01 PM
Quote:
Originally Posted by
98GS400GUY
This happen to me but I just folded some paper and stuck it in the shift release slot and forgot about fixing it... Its been 2 years.
How much was the part?
04-09-11, 04:59 PM
98GS400GUY
Where did you get this part from? This is pretty common for Gs300, you should do a write up about this. It would help many people.
04-09-11, 05:54 PM
Got it from Sewell, my mechanic installed this so I wouldn't be able to offer a DIY. BTW the shifters are the same for GS3 and 4 so it should happen to both.
ckja
SC- 1st Gen (1992-2000)
07-15-11 04:52 AM
Lexusalex
40
06-11-11 01:38 PM
LiqrSicc
RX - 1st Gen (1999-2003)
06-25-07 09:48 AM
kuuligan
11-27-05 07:58 PM
1994 ,
1995 ,
300 ,
85903 ,
95 ,
gear ,
gs ,
gs300 ,
lexus ,
ls400 ,
manual ,
park ,
release ,
shift ,
wont
