The only thing good about those Fogs are the Clear lens. if glass, i would swap them into OEM fogs FTW.
other than that Completely useless, and only for Rice Shows.
9006 Led bulbs have little to No Output, hence no shields.
if you put a halogen 9006 or HID 9006 in lieu of the LED 9006, you will blind everyone as light will be scattered all over, and probably not where you really need it.
Audi LEDs ..Played out, IMHO
agreed on every aspect. these look cheep and the led "strip" i bet will burn out very quick
even if it will work, these are not oem quality LED's and therefore they will probably not burn bright enough to be seen unless being upclose, same concept with the Autozone led strips, plus the regular bulb that goes in there will be scattered as ****-adkt said before
