valve covers
ok so i got a gs300 and i need to put knew valve cover gaskets on it. but dont know what all needs to come off or where anythin is as far as bolts. i have worked on a 7mgte before but they are different. so if anyone can help or knows were to finds any step by step stuff for me it would be great
You should try to check for an online shop manual that gives a diagram to all the parts. This way, you're not missing a step and accidentally breaking something off.
I would start by removing air box, intake plenum, throttle body, and etc. After you remove all these, it should be easy to access the valve cover bolts. Lift that up and you'll see the gasket underneath.
well i got it done yesterday and all i had to do was take off the intake. then the cruise control cable and trottle cable. then the bolts from the manifold to intake and then u have to get around the egr and that wasnt easy and after that u can get to it all. now i just have to get my egr block offs and im good. so im havin my dad make then at work and i may make some to sell if anyone is lookin
McCloudsZJ
Performance & Maintenance
18
05-15-19 11:28 AM
