gs300 won't start after replacing battery
Old 08-10-18, 05:54 PM
burteboy
burteboy's Avatar
If the lights go dimwhen u try to start recheck your ground connection .or both terminals .. You may have a bad connection somewhere. Try jump starting .
Old 08-10-18, 05:57 PM
burteboy
burteboy's Avatar
With an immobiliser problem your car still cranks. Easy check with your key in the ignition the security light shuold go out. If the security light still flashes with the key in the ign then its immobiliser.
Old 08-11-18, 12:05 AM
TW99GS300
TW99GS300's Avatar
The 3GS uses a smart key. If the remote battery gets low you would need to put the key against the start button. Not sure if that's your issue, otherwise try the 3GS forum
brit_lex
01-10-24 06:32 PM
acheparev
HS 250h Model (2010-2012)
22
07-25-17 06:59 PM
99BlueMica
06-06-17 06:26 AM
BoyOhBoy
07-18-14 12:54 PM
tatewu
RX - 1st Gen (1999-2003)
24
10-28-12 11:31 AM
Quick Reply: gs300 won't start after replacing battery
