GS400 with diesel sound
Everyone,
After you've done a cam seal change and your car engine now sounds like a diesel, make sure you check out this solution:
http://v-eight.com/tech_forum/viewtopic.php?t=1921
set the anti lash gear right on the exhaust cam.
if not your car will sound like the one in the above link.
I have the same problem with the exact same sound after a timing belt and cam seal change. I saw several threads on here about our engines having a diesel sound but this is the first solution I found on this.
Hope this helps someone.
-vaki2-
-vaki2-
wickedt
12-26-23 12:29 PM
