Helpppp!!!!
Old 04-22-11, 07:38 AM
kevwats01
kevwats01's Avatar
Default Helpppp!!!!
WHEN I'M DRIVING THIS KEEPS COMES AN STAYS ON, UNTIL I RESTART CAR .
Old 04-22-11, 09:59 AM
GS4_Fiend
GS4_Fiend's Avatar
I got the same problem.
Old 04-22-11, 10:12 AM
redlinezak
redlinezak's Avatar
There are lots of threads about this which i found helpful. I had the problem a little while ago. I think the fix i used was to short 2 pins out on the OBD socket under the drivers side dash but i didnt save the thread. Search VSC lights on and im sure you will find the thread with a diagram and instructions on what to do.
Old 04-22-11, 11:22 AM
818GS
818GS's Avatar
I'm pretty sure that's your speed sensor. Same three lights came on back when I had my gs300 and the mechanic told me it was the speed sensor.
Old 04-22-11, 11:31 AM
Dscustoms
Dscustoms's Avatar
Do they all come on at the same time, and is there anything that doesn't work in the cluster ?
All lights on is a malfunction that causes the ABS / traction / vsc systems to be turned off, so it's important to fix the problem.
Old 04-22-11, 12:14 PM
Dscustoms
Dscustoms's Avatar
Here are the code instructions, if you don't have access to a scanner.
Old 04-22-11, 07:03 PM
ThomasGS4
ThomasGS4's Avatar
Get ready to open your wallet.
Old 04-23-11, 10:37 AM
corkycal
corkycal's Avatar
take off both front wheels and see if the speed sensor wires are mashed or worn. you can take off the sensors also to test them with an ohm reader. do a search on this.
Old 04-23-11, 11:07 AM
GS4_Fiend
GS4_Fiend's Avatar
Do you have how to clear ABS light?
vwynn
09-27-22 02:43 PM
fuzzflyr
02-25-15 07:59 PM
KingNasGS4
06-27-14 09:19 PM
daniel6155
11-09-10 08:12 AM
1NICESC430
08-26-06 01:32 AM
Quick Reply: Helpppp!!!!
