car doesnt want to idle....thinking if its the idle control valve help
i have a problem with rough start.the car doesnt idle i gotta rev it up but then it die,shut off.but i believe its the idle control valve,someone help..how much would this cost.
I'm new to this forum but i just had a similar problem and had to change the sensor on the throttle lever assembly which was about $250 but it could be the throttle position sensor in the front which is under a hundred < i changed this one first and was still having the same problem so i changed the sensor in the back of the Throttle body and, She fired up and was running fine..... Hope this helps
Cure
Performance & Maintenance
08-08-14 09:04 AM
