Bulb Warning Light
your question is not dumb maybe u asked the wrong way. I have the same problem; the yellow indicator comes on whenever i press the brake; that means there is a problem with one or more of the rear lights. I replaced all the light bulbs with new ones, yet this light keeps coming on. you are right, its quite irritating seeing the light on all the time.
the OP actually was asking about the green light that turns on when your headlights are on or off...the yellow one you have IS a indicator bulb meaning you have a bulb out. when you said you replaced all the light bulbs with new ones, did you do your third brake light also? i had one that seemed to light up fine in my 3rd brake light but it indeed was the culprit...since i now have all LED's in my tails i ended up just pulling this bulb from my cluster
so were trying to get our side of the forum back together all lovie dovie like and EVERY post from you lately is hindering this....
read this man post man
https://www.clublexus.com/forums/gs-...-gs-forum.html
get on board or get out
everything? meaning ALL brake lights? i had changed most of mine and thought i fixed mine but then one day i noticed i had a brake light that would sometimes light up and sometimes wouldn't. have someone help you look, you have a bulb out someplace
ACTIV
01-15-07 12:55 PM
