Remanufactured Starter durability?
Old 05-04-11, 07:52 AM
OutlawTita
OutlawTita's Avatar
Default Remanufactured Starter durability?
I had the starter on my GS400 replaced at 89K miles with a remanufactured starter. How long can I expect to go before replacing this starter? Since this is a labor intensive repair I may not want to go through this again. I have another 48K miles since last replacing and wonder if I can get another year or two before having to do this again.
Appreciate any feedback if you have experience or knowledge in this area.
Old 05-04-11, 12:39 PM
Chumacher
Chumacher's Avatar
It should be good for at least another 100k miles. As long as you replaced the plunger and contacts you should be fine.
Old 05-04-11, 03:58 PM
vwynn
vwynn's Avatar
ive ran reman starters... and from my exp.. ide go with OEM.
ive notice reman starters sound different.. and the one i have now (which im sure is a reman) makes a wizzing sound on startup sometimes.. like it didnt disengage the flywheel or something
edit: woops didnt read your post fully. no set life.. its a matter of how many times you crank on your motor.
Alphaman19
05-21-14 08:09 AM
Tuske427
09-22-13 03:18 PM
danmm7
GX - 1st Gen (2003-2009)
09-11-13 08:11 AM
jerryparks
08-01-12 12:24 PM
reefguy
Performance
05-18-05 09:30 PM
Quick Reply: Remanufactured Starter durability?
