warning light on but everythings fine?
I have a 99 GS3 at 145k and when i was parking today that warning light that shows an orange car with like a light beam behind it just came on. I think that means a tail light, brake light or reverse light is bad right? Well I had my friend sit in the driver seat and press the brake and turn the lights on and off and all the lights were working perfectly fine. What could this mean?
Every light worked, even the side lights on the tails. Could it be a trunk light causing this? I reset the ecu by disconnecting the battery it was on, went off and then went back on and now is staying on. Is there anyway to turn the light off? Is it possible its a defective sensor or something?
I think I found which one it is, on the brake light in the rear window there is about 5 lights that makes the horizontal strip, one of them was out.
I had same thing, and was gonna tell you to look for those on the 3rd center brake light, but you already got it...FYI the light bulb number in the manual didn't match what was actually there, I had to take one out and take it to the parts store to get it right.
I recently put LED's in my license plate and i still get bulb out code..i heard LED's use less wattage so the warning system doesn't recognize the bulb being there
ROFl, i have this same problem but it turns on from time to time and it turned on when i mounted my taillights back on after i did the amber removal.. bulb might not be on tight enough idk D:
