Rack & Pinion Leak
Rack & Pinion Leak
I went to get my wheels balanced yesterday because I was a getting some steering wheel shake on the highway and while the mechanics had my car on the lift they saw that my Rack & Pinion was leaking slightly. He said it was not leaking very much so it wasn't really an issue, but it would have to be addressed down the road. I am not sure if his diagnosis is correct because I had my oil changed just before, so the guys who changed my oil could have gotten some fluid around the bottom of the car. Regardless, I was wondering if any of you guys have come across this problem. I searched and found almost nothing. I only found one thread about a rack & pinion leak, but the line had broke, not the actual rack and pinion. I saw a rack and pinion seal kit on RockAuto, I was wondering if this would help. The mechanic told me that the only way to fix the rack and pinion would be to get a new one. Any advice? Thanks a lot guys.
By the way my car felt great on the highway after the balance... but only for 50 miles then it started shaking again. I need to re torque the lug nuts and hopefully it will be good. If that fails I'm going to try and remove the rust on the hub.
Other Information:
Mileage: 145,000
My steering is lose and my car wanders a bit on the highway (I thought this was just my Steering Rack Bushings, and other suspension parts wearing down).
Other Information:
Mileage: 145,000
you may think you can just replace the boot thats leaking but thats not the correct way to fix it. I suggest you get the rack and pinion rebuilt. Here in cali, i got a rebuilt one for less than 300. You just need to look up where around your area would exchange yours for a rebuilt one. Also check your power steering pump, are you topping off fluid every month?
I need to check my Power Steering Fluid, and I was going to drain and refill all my Power Steering Fluid this Summer anyway because this winter when my car was cold it would make a screeching sound until it warmed up. I think something may have gotten into my Power Steering Fluid. Thanks for the suggestion. I was looking at re manufactured Rack and Pinions, they look like a good deal if I end up needing one.
Yeah, idk what I'm going to do yet. The mechanic told me its not really a problem yet, but it will become one in the future. That is if he diagnosed it right. I'll figure things out when I get back home from school this Summer. Thanks for all the advice guys
