Wrong Fluid in Power Steering reservoir??
As in the other DIY threads, it's mentioned it's a tradeoff of pros/cons.
If you just suck from the top,
pro: easy, each procedure takes less time, less messy.
con: removes less fluid per procedure, so wastes fluid and overall time to change is longer (to do repeated suck/fills)
If you go from the bottom
pro: more complete job, reduces wasted fluid, "done" quicker as more fluid is exchanged per procedure.
con: technically more difficult, requires more time/expertise/equipment to complete the procedure, more potential for a mess as well as goofing up.
It's your choice.
Oh and the level is fine, still looks a little dark though...
RuninRoach
12-04-14 05:13 PM
