Low RPM's
one more thought is pcv valve which might affect the idle if you haven't switched it, although i think a stuck one would typically cause high idle, not low idle. It's inexpensive to change out, worth a try before you get into expensive tests
I changed the PCV valve and I'm still having the same problem.
When I first start the car the idle is fine. It just goes low when i'm coming to a stop.
I found out what the problem was. The CEL came on again and it was telling me that my O2 sensors were bad. But I had just changed them out like a week ago. So I took the O2 sensors off and took them back to the store and told them that they were defective so that they could replace them. When putting the new ones in I discovered small cracks in the air intake connector. I took it off and at the bottom of it there was a big hole. I order a new on from the dealership, put it on and my car is running as good as new.
