Low RPM's
Old 05-11-11, 04:31 AM
damiendaz
damiendaz's Avatar
Default Low RPM's
When I am driving and I come to a stop the RPM's on my car goes down to 0 causing the car to hesitate on acceleration. What could be the problem?
Old 05-11-11, 06:00 AM
jasonb75
jasonb75's Avatar
Search button is your friend.
Also, if your RPM goes to zero, your car wouldn't be running.
Old 05-11-11, 09:19 AM
lexusben
lexusben's Avatar
Low RPM's at idle are usually caused by a dirty MAF (Mass Air Flow Sensor), and a Dirty Throttle Body. There are tutorials on this. It could also be dirty Oxygen Sensors that aren't throwing codes yet.
Old 05-11-11, 10:03 AM
damiendaz
damiendaz's Avatar
I have changed all of the oxygen sensors, MAF sensor, and the TB sensor. The spark plugs and wires were also changed.
Old 05-11-11, 10:43 AM
oysgs430
oysgs430's Avatar
What do you have 300/400/430 that may help
Old 05-11-11, 11:14 AM
damiendaz
damiendaz's Avatar
I have a gs300
Old 05-11-11, 11:55 AM
dejavu157
dejavu157's Avatar
did u recently spray ur engine bay down?
Old 05-11-11, 12:33 PM
damiendaz
damiendaz's Avatar
The engine has never been sprayed down.
Old 05-11-11, 01:00 PM
AYEmike
AYEmike's Avatar
you sure the spark plug wires are OEM fit? bad fitting can cause rpm drop, as well as ignition coils going bad.
Old 05-11-11, 01:16 PM
lexybaby77
lexybaby77's Avatar
did it happen just right after you've done all those work?
damiendaz
damiendaz's Avatar
The spark plugs are OEM fit. I got them from the dealership.
Old 05-11-11, 01:18 PM
damiendaz
damiendaz's Avatar
It happen before I done all the work that was performed.
Old 05-11-11, 01:20 PM
lexybaby77
lexybaby77's Avatar
Spark plug wires OEM too?
Old 05-11-11, 01:38 PM
damiendaz
damiendaz's Avatar
Yes! Everything was OEM
Old 05-11-11, 02:56 PM
raytseng
raytseng's Avatar
Fuel filter? did you get that done? Search for the DIY on that (and read service manual instructions).
It helped with a very slight lag in my car as it looks like you've done everything else.
Or you can also try resetting your ECU to see if that makes a difference (disconnect battery for 30min). It may take some a short time for ecu to relearn; and fair warning about losing your presets.
One final suggestion, maybe run a tankful of high PEA fuel injector cleaner through(Redline/Gumout/amsoil)
Quick Reply: Low RPM's
