Coolant splashed all under the hood on my GS400
Old 05-11-11, 05:47 PM
Salil022
Salil022's Avatar
Default Coolant splashed all under the hood on my GS400
I was sitting at the red light and noticed steam coming out of my hood, so i pulled over and opened the hood...Noticed coolant splashed all around radiator area, checked radiator & reservoir cap and it's tight.
What could it be guys....Car currently has 270k miles and doesn't overheat at all and never did, timing belt was last done around 190k.
Could it be water pump is leaking or thermostat?
Old 05-11-11, 06:19 PM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
cracked radiator - check the housing on the top. get someone to rev your engine while your hood is popped or your hose has a crack in it.
Old 05-11-11, 06:25 PM
mrjaydm
mrjaydm's Avatar
either your radiator end tanks, or your hoses sprung a leak.
Old 05-11-11, 06:32 PM
Salil022
Salil022's Avatar
def. not the hose...i've looked at it closely
Here is the pic
Attached Thumbnails Coolant splashed all under the hood on my GS400-photo-3-.jpg
Old 05-11-11, 06:35 PM
Salil022
Salil022's Avatar
Another one
Attached Thumbnails Coolant splashed all under the hood on my GS400-img_9803.jpg
Old 05-11-11, 09:18 PM
lexybaby77
lexybaby77's Avatar
Its going to be a challenge to see the leak if the coolant is all over the engine. I would clean it out first if I were you and make sure its dry. Then visually check everything from radiator, hoses, cap, water pump etc. Make sure you have proper lighting. Have someone rev the car for you while you inspect. My best guess its the radiator.
Old 05-12-11, 12:03 AM
sam430
sam430's Avatar
educate me...is that what they call, "the golden shower" ?
on a serious note, looks like it's coming from the radiator based on the trajectory.
Old 05-12-11, 12:33 AM
mex lex
mex lex's Avatar
Are you sure its not the rad cap? I had to replace mine not that long ago. The spring contraption breaks over time.
Old 05-12-11, 04:26 AM
aEO 37
aEO 37's Avatar
look at the top of the radiator carefully again. there might be a small crack in it. I had it happened to me before
Old 05-12-11, 04:49 AM
GS671
GS671's Avatar
I'd say its your radiator. The ends are made of plastic.
Old 05-12-11, 06:39 AM
starfyrels
starfyrels's Avatar
You have to clean that area down before you can tell where its coming from. You will not be able to tell 100%. From the looks of things it looks like its coming from the driverside of the top or upper part of the radiator.
Clean it, make sure its completely dry, then have someone rev the engine.
Old 05-12-11, 06:43 AM
chuckb
chuckb's Avatar
that looks like a huge crack on plastic in this pic.
Old 05-12-11, 07:18 AM
Salil022
Salil022's Avatar
Thanks everyone...to me it also seems radiator as the radiator area is more wet...Water pump area seems dry.
I'll order a new one...Should i get OEM from sewell or aftermarket?
Old 05-12-11, 08:28 AM
oysgs430
oysgs430's Avatar
Pressure test will solve the problem.
Old 05-12-11, 09:04 AM
lexybaby77
lexybaby77's Avatar
My recommendation, if you can afford OEM go for it. If you would like aftermarket, go for the brand Koyo. Almost exactly the same as OEM. Should be around $135. Here's a link of where I bought mine before. http://www.go-part.com/9805-lexus-gs...2-p-23510.html. If you can find it cheaper in your area go for it. Change your hoses and cap too. Should be a real easy install about 15 mins. Finally, dispose the old part properly. Good luck.
Quick Reply: Coolant splashed all under the hood on my GS400
