Help on INNER TIE ROD END
I'm at the shop now and they said they will tighten anything that's loose meaning both inner and outer tie rod's ! so let's see if this corrects everything, one good thing is the shake has stoped do to the new inner's
so i got the alignment and the steering is straight it feels way better on the bumps but i still have a constant steering wheel shake, what can it be now!! used tires, bad rotors and for some reason i hear this grinding noise from the rear right wheel, right before i come to a complete stop i can here this mettle type grinding noise ! idk what it can be
gtstcactus
02-12-14 10:07 PM
