Help on INNER TIE ROD END
Wasup guy so i finished installing almost all the components to my suspensions including New shocks all im missing now is the inner tie rod ends!! My first question is, are both sides the same? and can someone pleas write me a step by step on how to remove them and instal, Thanks it will really be appreciated i have to do the work tomorrow as i have off work, Thank god lolz so yea hope someone can help me out.
Account under Legal Action - Banned
You're going to need an inner tie rod removal tool. They're expensive ($70) and I dont think auto parts stores rent them out. Once you get in there you'll see what Im talking about. You can go to harborfreight, buy it, use it and then return it. I'd also get a torque wrench with a log handle unless you have a breaker bar already.
Basically you need to remove the outer tie rod end from the inner tie rod.
To test if your inner tie rods are bad all you need to so is move them freely, and make sure that they don't move from the position you've rested them at; i.e. if you move the rod up or around to a certain spot and it stays up or at that spot then you dont need to change them. If they drop from the initial position you rest them at then read on.
Then you need to remove the clips that are holding the inner tie rod boots on.
Next you'll see the exposed inner tie rod. Once you see this you'll see that there is a bent crush washer that is holding the tie rod in place from moving. What you need to do is get a flat head screw driver or chisel and hammer back the bend in the washer so that the washer looks flat. Theres two places; 12 and 6 respectively.
Once thats done; take the inner tie rod removal tool and remove it.
Then inspect the area; and place your new inner rods on the same was as removal. Don't forget the holding washer. once everything is torqued to spec (read up) and in place, take a small wrench or small ratchet etc and hammer the crush washer in so that it locks in place just as it was before (locked position).
Replace everything in reverse order of removal.
Go get your alignment.
dammmn both my inner tie rods move freely they dont stay in place at all and now i need a special tool for this smh, so ill have to wait to do this job anyways Thanks a lot for the info i wll do this as soon as i buy the tool !!
I'm really getting worried about most users/posters that are sharing information about things that they don't know about. Please, if you haven't done this yourself -- CORRECTLY, then do not give other members false information.
You do need the special tool. It's called an inner tie rod removal tool for a reason. There is no way to remove the old rod, you can try a vice grip or plumbers wrench but you won't have clearance and you will run into problems when tightening the new rod. Your steering will suffer (shake/vibrate) and have lots of slop if you do not tighten the rods with the tool. I'd also get a torque wrench and torque to spec as well.
To remove the clips on the boot you can break them of cut them, use pliers or wedge a screwdriver in there and just get a pack of clips from any auto parts stores and replace them. I believe there part on the rod where you can remove the clips and press them back in.
I finilly changed both inner tie rod ends and didn't use the tool! I also removed the clips and put them back on, both tie rods are tightened good but I'll know for sure when I take it for a drive on the highway! I can tell you something right now it's not easy to do and it's a pain in the *** ! The only thing I forgot to do is bend the washer In the lock position on the left side !
