2jzgtte conversion!!! Tach not working still
Old 05-14-11 | 11:25 AM
2jzgttegs's Avatar
2jzgttegs
Default 2jzgtte conversion!!! Tach not working still
Does anyone has the diagram for the cluster on a 2000 GS300. My tachometer is not working because I did the 2jzgte vvti conversion.
Old 05-14-11 | 11:37 AM
2jzgttegs's Avatar
2jzgttegs
I found this. Which black & yellow wire is he talking about
Quote:
Originally Posted by Burton
How much is it worth to know
If you look at the ignighter there is a blank hole in the connector with no wire in it. Pull a pin and wire out of your olf harnes and run it to the wire in the ECU box that feeds signal to the tach. I don't remember the wire off the top of my head, but if you have a schematic for the GS300 you sould be able to find it.
Ben
Yes. The empty pin from the ignitor should be pinned and the wire routed to junction connector EA3 (in the ecu box). Splice it into pin 2 (black/yellow) wire and presto...dash tacho works!
Well, we finally got Dex's car back into the schedule after months of hold ups (waiting for parts/other cars/short staffed). Everything works! Return fuel system is operating perfectly. No engine light (so far ).
I'm gonna jump the turbo system to parallel operation and adjust the shift linkage tomorrow. Should be back in his hands by the w/e.
Thanks for the help everyone.
05ls430518
02-12-18 11:23 AM
Micdizo
04-22-13 12:03 PM
supra_trd
03-20-09 03:48 PM
owali
11-19-07 02:30 AM
webbuster
Lighting
10-12-05 10:25 AM
