Dumpage...
Thanks guys for the props! I still got a long way to go!
Installation took my brother and I about 45min (car was on a lift @ my brother's shop) But setting it to you liking took awhile (2-3hrs). What was wierd when I was adjusting the ride height in the back one side was lower then the other. I did all the measurements to where it was even. Now to make it even, the ride height adjustment on one side had to be raised?! (Anybody else had to do that?)
I bought mine from CircuitMS. Best deal you can get and they're really quick to respond if you have any questions. From FL to CA 1 week
They're BC Racing Coilovers. PM the guys @ CircuitMS. Best deal around! They'll hook you up!
I had to raise it up a tad. Just got done with it about an hour ago. The height is set @ 24" in the back & 23" in the front (measured from the peak of the fender, lined up with the center cap to the ground) Current shock settings are 16 in the rear, 22 in the front.
Originally Posted by Samoastyle
Nice ride! If you don't mind me asking, how much did you get the buddy clubs for? And I'm planning to do coil overs also. Not a fan of bags...
Originally Posted by fuzzzz
Looks good man. But .. thats hella low man! Would be hard to get around
Originally Posted by GS6SEVEN1
nice..... hope u can drive through nor cal roads.... i had to lift mine up a little. exhaust is smash...
just need some wheels to lift it up just a little..
Originally Posted by whytry
Pix of it now??
Love it nice and low, where in NorCal are you?
Originally Posted by 4eign
i assume that you got the extreme drop kit? how is the ride now that you have lowered it?
did you get it with rubber mounts?
Looks sick!
Looks sick!
As far as the ride goes after making all my final adjustments, it's pretty smooth. No funny noises (so far), no bumpsteer. The car is sitting @ 25" (about 1 finger gap) from the peak of the fender to the ground with new tires installed yesterday. (Getting alignment done this sunday)
As much as I would like to go lower, I can't or I'll end up teetering on the speed bump in front of my house. So the height I set it to is just enough to clear it with a scraping.
Cptnslo
06-07-19 05:21 PM
