whats your RPM on cold start?
I have a 99 GS3 with 145k and im just wondering because before changing my spark plugs to NGK iridiums, im guessing the original platinum plugs were in there, i noticed when my cars cold the rpms would go a little over 1 and eventually drop down, ever since changing the plugs i dont know if its just me but i noticed my RPMS staying at 1.5 to even 1-8 almost 2 for a while until it warms up, once i put the car in drive and put it back in park its back to normal. My mechanic cleaned the throttle body which was VERY dirty, i was wondering if the cleaning or different plugs causes this or am i just paranoid? I also feel like with these plugs the car takes a tad longer to start then it did before even though i usually never have to hold the key down for more then 2 seconds before it starts. any opinions appreciated, thanks CL
I dont think thats normal. My rpms at either cold or warm start were always at 800 before a mechanic cleaned out my throttle body. Now its between 1500-2000. Then it drops back down. Sometimes lower than 800. I read somewhere on this forum that we might have to reset the tps sensor.
AHA I KNEW the throttle body cleaning caused the RPMs to be higher, I KNEW i wasnt seeing things I always thought it started up with the RPMS usually lower. How do we reset the TPS which is the throttle position sensor correct?
I think it just depends how cold the car is when you start it. On a very cold day my car will start up and rev over 1k for a bit before dropping down. However, if it is decent outside and I start the car it will rev right around 1k, then drop to around 800 rpms. I have also cleaned my TB and MAF in the past (I need to do it again this Summer).
I remember my GS3 behaving oddly after changing the plugs (OE Platinums replaced by NGK Iridiums). At startup the engine would rev at 1800-2000rpm, instead of the 1200rpm usually.
I took off the throttle cable, put it back on to check whether it was seated correctly and reset the ECU. Haven't had a problem since.
I don't remember exactly, but it's easy to do. Just rotate the throttle wheel so that you get some clearance on the cable. You also need to remove a bolt to get the cable out of the bracket. That's about it. It'll only take you a couple of minutes.
The cable sits on the back of the throttle body, towards the firewall.
Hope this helps.
Hope this helps.
