OBX header -- GS3
wow nice dean....
did OBX headers throw you with check engine light????
i just got the megan mid pipe and i was going to get cat-back and intake....
maybe i'll consider the header work too.
and you still have to pick up the wrench for the coilover from me ^^.
I completely forgot about the wrench, I do need to swing out there and get it from you and talk to you about some carbon fiber stuff....
No check engine light using the spark plug non-fouler trick (two stacked foulers in the O2 hole and then the O2 into the fouler). That effectively removed the O2 sensor (SECONDARY sensors) from the exhaust stream. I'm still running the stock mid-pipe for a couple of reasons.
i see so what do you need to buy other then the header???? also don't obx comes with mid pipes???? what are the reasons to not to use them... i just got only midpipe from megan due to check engine light thingy. i heard about the O2foullers to not get the light on but never used them before so i was kinda curious about it. now you have the SRT intake and header how is it runs??? planing to get exhaust pretty soon????
