HELP ASAP Spark Plug Wiring Diagram
Hello all,
I just replaced my valve cover gaskets and spark plugs but unfortantley I dont rember the correct order that the spark plug wires need to be in if anyone has a clear diagram or just knows the correct order that the plugs and coil packs (or whatever they are called) go in i would greatly appreciate it.
Also if anyone knows were to get new plastic clips for cheap that attach to the coil packs that would also be greatly appreciated
-Thanks in advance![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Dnelson
-Thanks in advance
Dnelson
One coil goes on the cylinder #1 plug, and the wire runs to the #6 plug. Another coil goes on the #5 plug, and the wire runs to the #2 plug. And the last coil goes on the #3 plug, and the wire runs to the #4 plug.
