camber specs anyone?
my front bumper is about 2.5 in off the ground.. Im on 19s but that shouldn't matter too much. I went and did my alignment 2days ago. my front is -4.5 and my rear is -4 ...toes in spec.
Before
Left Front
Camber : -2.6
Caster : 8.2
Toe : -.12
Right Front
Camber : -2.8
Caster : 8.4
Toe : -.32
Left Rear
Camber : -2.3
Caster :
Toe : .06
Right Rear
Camber : -3.1
Caster :
Toe : .35
Total Toe : .41
Thrust Angle -.15
Current Measurements
Left Front
Camber : -1.8
Caster : 8.6
Toe : .10
Right Front
Camber : -1.9
Caster : 8.7
Toe : .07
Left Rear
Camber : -1.8
Caster :
Toe : -.19
Right Rear
Camber : -2.2
Caster :
Toe : 0.00
Total Toe -.20
Thrust Angle -.10
Left Front
Camber : -2.6
Caster : 8.2
Toe : -.12
Right Front
Camber : -2.8
Caster : 8.4
Toe : -.32
Left Rear
Camber : -2.3
Caster :
Toe : .06
Right Rear
Camber : -3.1
Caster :
Toe : .35
Total Toe : .41
Thrust Angle -.15
Left Front
Camber : -1.8
Caster : 8.6
Toe : .10
Right Front
Camber : -1.9
Caster : 8.7
Toe : .07
Left Rear
Camber : -1.8
Caster :
Toe : -.19
Right Rear
Camber : -2.2
Caster :
Toe : 0.00
Total Toe -.20
Thrust Angle -.10
My bad. Yes, get the rear left camber to match the rear right even if it means you'll have to go more negative on that side. You want to minimize cross camber as much as possible to avoid pulling. Plus you'll wear out the tires more evenly.
The tech sure did put a lot of toe out on the rear though. Most guys run more toe-in in the rear for stability. I've ran toe-out in the rear before and it gets pretty unstable sometimes.
Getting it to spec is no longer valid when you are lowered a few inches. There is no reason to want OEM specifications if you're not using OEM suspension. At this point, getting the left and right side to match up is more important. Reduce toe-in up front if you want a slightly longer tire life. Other than that, the front end looks reasonable.
i just got an alignment today and got the spec sheet in my hand. shop did an excellent job i think.
Here are specs.
Front Left : Actual
Camber : -1.9
Caster : 8.3
Toe : 0.10
SAI : 10.5
Included Angle : 8.6
Front Right : Actual
Camber : -2.1
Caster :8.0
Toe :0.09
SAI : 10.6
Included Angle : 8.4
Rear Left : Actual
Camber : -2.7
Toe : 0.05
Rear Right : Actual
Camber : -2.7
Toe 0.05
How low am i ? to me is low enuff u can barely fit a pinky between fender and tire lol. this is my ride. i dropped it about 1.5 inch more from that pic why ? cause im insane haha on coils btw.
Here are specs.
Front Left : Actual
Camber : -1.9
Caster : 8.3
Toe : 0.10
SAI : 10.5
Camber : -2.1
Caster :8.0
Toe :0.09
SAI : 10.6
Rear Left : Actual
Camber : -2.7
Toe : 0.05
Rear Right : Actual
Camber : -2.7
Toe 0.05
