Weight of Wheels
I am in the process of a major makeover for my GS. So I have been looking into getting some light weight wheels to help performance.
I currently have stern st-2's. Ive had them for 5+ years and have bent 2 in that time and had them repaired. Well I was told that sterns were really heavy but at the time that was all I could afford. Anyway I recently looked into some vellano 3pc wheels. I asked the manufacturer how much they weighed and I was told 31lbs for a 20X9 mesh style wheel.
Well I decided to weigh my wheels and to my surprise, my "super heavy" one piece sterns weigh 30.5 lbs. (I weighed the 20x8.5 wheel) So are the vellano's heavy also?
Does anyone know how much 3pc wheels 20x8.5-11 should weigh? I'm tryin to see if its worth buying 3pc wheels.
My sterns were cheap and in 5+years of driving on crappy LA streets i have only had 2 bends. Less than 100 to fix each. Not bad in my book. Here is a list of my wheels I weighed.
Oem 17" chrome wheel with tire.......51lbs each
stern 20x8.5 with tires...................55lbs
stern 20x9.5 with tires...................60.5lbs
stern 20x8.5 wheel alone................30.5lbs
any opinions or wheel weights would be appreciated
Forgestars make light wheels. So does Weds. They use roll forming type forging to reduce weight and increase strength. same tech used in BBS wheels. Ill prolly be in the market for wheels after we finish our little secret project
but yea..
heres an example
http://www.youtube.com/watch?v=IhkEodr2yhw
but yea..
heres an example
Thats what everyone says, but no one provides actual numbers. I personally weighed these today. The oem wheel I weighed was actually my full size spare that has almost never been used, with original tire. 51 lbs. Thats what it actually weighs. And Vellano themselves told me there 3pc 20" wheel was 30+ lbs.
but yea..
heres an example
but yea..
heres an example
Thanks for posting some real numbers.
I have an entire thread devoted to this about a year ago!!! Search, and check it out. As someone else mentioned Forgestars are GREAT! The lightest I've seen was 21.5lbs! Forgot which model though. They are 1 piece free flow forged design...strong and light. The only reason why I didnt get them was because they didn't offer a wheel design with a lip. So I bought my 2-pc wheels which are hot, always get complements on and are strong as hell but they too are heavy. My fronts are 29 and my rears are 31.5lbs. Keep in mind tire weight is a HUGE factor as well. I didn't look into this when I was buying tires. Unfortunately, I got some of the heaviest damn tires on the market...Bridgestones. They ride great, have tight sidewalls and are strong but my fronts weigh 28 and rears weigh close to 30lbs! So, all in all my entire front weighs 57 per corner and 61.5 per corner. That's A LOT of rotating mass even with my mods. If I would do it again, which I probably will, I would buy those 21.5lb Forgestars and a tire like Michelin PS2's, Toyo T1R's or Continental Extreme DW. All of these tires, through research weigh around 24lbs. Keep in mind all the aforementioned weights are dealing with19'' wheel sizes. So, as you can see if I do decide to go with the above items the new overall weight would be approx. 45.5 per corner...i would see a weight savings of 12 - 16lbs PER CORNER of rotational mass! This could equate your car feeling like you just added 40hp! The car would feel MUCH lighter and more responsive in spirited driving and turning and handling would be improved as well. The kick in the As$ for me was that I spent over $4500 on my wheels and tires and I could have saved over $1000 bucks with going with the above combo...i would have been saving on gas as well. This is why it always pays to research a lot before pulling the trigger. Btw, I notice a HUGE DIFFERENCE when I switch back to my stock wheels and tires in the fall, preparing for the winter. The care is MUCH MUCH faster. I will change this up soon. Pisses me off just writing about it. GL!
Former Sponsor
My 19" RP03s are 19lbs. it feels like im gliding thru..
Also keep in mind, internal inertia has alot to do with the performance aspect.
I.E. a 17" wheel @ 20LBS is going to act different than a 19" @ 20LBS. to get the same inertia you must drop the weight of the 19".
there is an equation but im too Lazy for Math right now..
Thanks for all the help guys. And Rock, i did search clublexus, couldn't find your thread.
Just came across this. Some good info
Name Manufacturing Method Size Weight (lbs.) Weight (kgs.)
562 Fuel Cast 17x7 26.5 12.0201986
562 Kabuki Cast 17x7 27 12.2469948
57Motorsport G07WT Cast 17x7 18 8.1646632
5Zigen 5ZR Copse Cast/Spun 16x7 15.7 7.12140068
5Zigen 5ZR Copse Cast/Spun 17x7 23 10.4326252
5Zigen 5ZR Copse Cast/Spun 17x7.5 23.5 10.6594214
5Zigen 5ZR Copse Cast/Spun 18x10 26 11.7934024
5Zigen Beckets FN-01R Forged 15x7 10.6 4.80807944
5Zigen Beckets FN-01R Forged 16x7 11.7 5.30703108
5Zigen Beckets FN-01R Forged 17x7.5 13.9 6.30493436
5Zigen Beckets FN-01R Forged 17x8 14.7 6.66780828
5Zigen Beckets FN-01R Forged 17x8.5 15.4 6.98532296
5Zigen Beckets FN-01R Forged 17x9 15.6 7.07604144
5Zigen Beckets FN-01R Forged 17x9.5 15.8 7.16675992
5Zigen Copse Cast 15x7 11 4.9895164
5Zigen DIV.3 Cast 15x6.5 12.6 5.71526424
5Zigen Fighter Cast 17x7 17 7.7110708
5Zigen Fireball Cast 17x7 18 8.1646632
5Zigen Fireball Typhoon Cast 17x7.5 21.5 9.7522366
5Zigen Fireball Typhoon Cast 17x8 22 9.9790328
5Zigen Fireball Typhoon Cast 17x9 22.5 10.205829
5Zigen FN01R-C Cast 15x7 14 6.3502936
5Zigen FN01R-C Cast 16x7 15 6.803886
5Zigen FN01R-C Cast 17x10 21.5 9.7522366
5Zigen FN01R-C Cast 17x7 16 7.2574784
5Zigen FN01R-C Cast 17x8 17 7.7110708
5Zigen FN01R-C Cast 17x9 19 8.6182556
5Zigen FN01R-C Cast 18x7.5 18.5 8.3914594
5Zigen FN01R-C Cast 18x8.5 21.5 9.7522366
5Zigen FN01R-C Cast 18x9.5 23 10.4326252
5Zigen Heidfeld Cast 17x7 19 8.6182556
5Zigen Heidfeld Cast 18x7.5 20 9.071848
5Zigen Heidfeld 2-Piece Cast/Spun 17x7.5 24.3 11.02229532
5Zigen Hyper 5ZR Cast 18x7.5 25 11.33981
5Zigen Imperio M05 Cast 17x7 19 8.6182556
5Zigen Imperio M05 Cast 18x7.5 20.5 9.2986442
5Zigen Imperio S08 Cast 16x7 19.8 8.98112952
5Zigen Imperio S08 Cast 17x7 20.5 9.2986442
5Zigen N1R-SP08 Cast 15x6.5 14.1 6.39565284
5Zigen N1R-SP08 Cast 17x7 17.5 7.937867
5Zigen ProRacer GN+ Cast 17x7.5 20 9.071848
5Zigen ProRacer GN+ Cast 17x8.5 20.5 9.2986442
5Zigen ProRacer GN+ Cast 17x9.5 21 9.5254404
5Zigen ProRacer GN+ Cast 18x7.5 21.5 9.7522366
5Zigen ProRacer GN+ Cast 18x8.5 22 9.9790328
5Zigen ProRacer GN+ Cast 18x9.5 22.5 10.205829
5Zigen RSX-6 Cast 17x7 17.7 8.02858548
5Zigen Sports Engine SC3000 Cast 19x8.5 27 12.2469948
5Zigen Sports Engine SC3000 Cast 19x9.5 28 12.7005872
5Zigen Super Six Cast 17x7 19 8.6182556
5Zigen Super Six Cast 18x7.5 19.8 8.98112952
5Zigen Typhoon Cast 17x7.5 21.5 9.7522366
5Zigen Typhoon Cast 17x8 22 9.9790328
5Zigen Typhoon Cast 17x9 22.5 10.205829
6061 A5 Forged 17x7 14.5 6.5770898
6061 A5 Forged 19x7.5 18.5 8.3914594
6061 A5LW Forged 17x7 13.5 6.1234974
6061 A5LW Forged 19x7.5 15 6.803886
6061 AM Forged 19x7.5 16.5 7.4842746
949Racing 6UL Cast 15x7.5 12 5.4431088
949Racing 6UL Cast 15x8 12.8 5.80598272
949Racing 6UL Cast 15x9 13.4 6.07813816
AB-Eintz Type 06 Cast 20x8.5 29 13.1541796
AB-Eintz Type 07 Cast 18x8.5 27.8 12.60986872
AB-Eintz Type 13 Cast 19x9.5 31.3 14.19744212
ABT Sportsline A-10 Cast 18x8 24 10.8862176
ABT Sportsline A-16 Cast 17x8 24.8 11.24909152
ABT Sportsline A-23 Cast 17x7.5 22.5 10.205829
ABT Sportsline New Classic Cast 18x8 26 11.7934024
ABT Sportsline V1 Cast 17x7.5 21.3 9.66151812
AC Schnitzer (front) Forged 20x10 22 9.9790328
AC Schnitzer (rear) Forged 20x10 23.8 10.79549912
AC Schnitzer Type II Forged 17x8.5 21.5 9.7522366
Ace A109 (Formula) Cast 17x7 25 11.33981
Ace A130 (Spyder) Cast 18x10 25 11.33981
Ace A130 (Spyder) Cast 18x8.5 23 10.4326252
Ace A131 (Lola) Cast 17x7 23.5 10.6594214
Ace A132 (Klassik) Cast 19x8.5 28.5 12.9273834
Ace A134 (Turbo) Cast 17x7 20.5 9.2986442
Ace A137 (Flame) Cast 18x8.5 31.5 14.2881606
Ace A151 (Spade) Cast 18x7.5 23 10.4326252
Ace A157 (Monaco) Cast 19x8 27.3 12.38307252
Ace A164 (Desire) Cast 18x8.5 26.5 12.0201986
Ace A184 (Zeus) Cast 18x7.5 25 11.33981
Ace A184 (Zeus) Cast 18x8.5 30 13.607772
Ace A204 (Impact) Cast 17x7 19 8.6182556
Ace A204 (Impact) Cast 19x8 24 10.8862176
Ace A205 (Manta) Cast 18x7.5 23 10.4326252
Ace A205 (Manta) Cast 19x8 26.6 12.06555784
Ace A205 (Manta) Cast 19x8.5 27 12.2469948
Ace C001 (T1) Cast 22x9.5 39 17.6901036
Ace C053 (Trend) Cast 19x8.5 28 12.7005872
Ace C103 (Allure) Cast 18x8 25.5 11.5666062
Ace C808 (Spark) Cast 18x8 26.5 12.0201986
Ace C808 (Spark) Cast 20x8.5 36.5 16.5561226
Ace C808B (Mack) Cast 22x9.5 46.5 21.0920466
Ace C813 (Le Mans) Cast 22x9.5 37 16.7829188
Ace C814 (Slick) Cast 19x11 30 13.607772
Ace D632 (Matrix) Cast 19x8.5 27 12.2469948
Ace D636 (Radium) Cast 18x8 22.5 10.205829
Ace D636 (Radium) Cast 19x8 27 12.2469948
Acura Integra GS 92 Cast 14x5.5 15.5 7.0306822
Acura Integra GS-R 94-95 Cast 15x6 16 7.2574784
Acura Integra GS-R 96 Cast 15x6 15.5 7.0306822
Acura Integra GS-R 97 (00+ LS) Cast 15x6 15 6.803886
Acura Integra GS-R 98-01 Cast 15x6 16.3 7.39355612
Acura Integra Type-R (Euro 5-bolt) Cast 15x6 13 5.8967012
Acura Integra Type-R (JDM 4-bolt) Cast 15x6 12.3 5.57918652
Acura Integra Type-R (JDM 4-bolt) Cast 16x7 17 7.7110708
Acura Integra Type-R (US 5-bolt) Cast 15x6 15.6 7.07604144
Acura NSX Forged 15x6.5 15.2 6.89460448
Acura NSX Forged 16x7 16.8 7.62035232
Acura NSX Forged 16x8 18.9 8.57289636
Acura NSX Forged 17x8.5 20.9 9.48008116
Acura RSX 02-04 Cast 16x6.5 16 7.2574784
Acura RSX 05-06 Cast 17x7 20.7 9.38936268
Acura TSX 04-05 Cast 17x7 21 9.5254404
Adler Racing AR05A Cast 16x7 15.7 7.12140068
Adler Racing AR08 Cast 16x7 15.7 7.12140068
ADR 39 (Intercrew) Cast 17x7 20.3 9.20792572
ADR 42 (M-Classic) Cast 20x8.5 29.8 13.51705352
ADR 43 (X-Factor) Cast 19x8 27.8 12.60986872
ADR Battle Axe Cast 17x7 22.5 10.205829
ADR Cobra Cast 17x9 26 11.7934024
ADR DTM Cast 16x7 19 8.6182556
ADR Hypertek Cast 17x7 19 8.6182556
ADR J-Sprint Cast 17x7 18.8 8.52753712
ADR Kasai Cast 18x8 22.8 10.34190672
ADR Lightning Cast 17x7 25.5 11.5666062
ADR M-Sport Cast 17x7 22.1 10.02439204
ADR M-Sport Cast 18x7.5 23 10.4326252
ADR M-Sport Cast 18x8.5 25 11.33981
ADR M-Sport Cast 18x9.5 26.7 12.11091708
ADR Reaction Cast 16x7 19.9 9.02648876
ADR Reaction Cast 18x7.5 24.3 11.02229532
ADR Revolution Cast 17x7 20.5 9.2986442
ADR RS Limited 17 Shinwa Cast 17x7 20.1 9.11720724
ADR RS Limited Concept Pro Cast 15x6.5 13 5.8967012
ADR RS Limited Concept Pro Cast 16x7 16.5 7.4842746
ADR RS Limited Concept Pro Cast 17x7 18 8.1646632
ADR RS Limited Mase Cast 17x7 17.5 7.937867
ADR RS Limited Mase Cast 18x7.5 19.5 8.8450518
ADR RS Limited Ricochet Cast 17x7 19.4 8.79969256
ADR RS Limited Shinwa Cast 16x7 15 6.803886
ADR RS2000 Cast 17x7 21 9.5254404
ADR RS2000 Cast 18x8 23 10.4326252
ADR Version II Cast 18x8 28.6 12.97274264
Advan Kreuzer Series X Cast 18x8 16.5 7.4842746
Advan Model 5 Cast 18x8 19.8 8.98112952
Advan Model 7 Cast 15x5.5 12.3 5.57918652
Advan Model 7 Cast 19x9 27 12.2469948
Advan Model T6 Cast 18x8 20 9.071848
Advan Racing Oni Cast 15x7 14.5 6.5770898
Advan Racing RA3-DT Cast 17x9.5 18.5 8.3914594
Advan Racing RA3-DT Cast 18x10 20.5 9.2986442
Advan Racing RC II Cast 18x7.5 17 7.7110708
Advan Racing RC Rally Cast 17x7 18.5 8.3914594
Advan Racing RG Cast 14x6 8.9 4.03697236
Advan Racing RG Cast 14x6.5 9.9 4.49056476
Advan Racing RG Cast 15x6.5 10.5 4.7627202
Advan Racing RG Cast 15x7 11.4 5.17095336
Advan Racing RG Cast 15x7.5 12.1 5.48846804
Advan Racing RG Cast 15x8 12.6 5.71526424
Advan Racing RG Cast 16x7 12.7 5.76062348
Advan Racing RG Cast 16x7.5 13.4 6.07813816
Advan Racing RG Cast 16x8 13.8 6.25957512
Advan Racing RG Cast 17x7.5 15.2 6.89460448
Advan Racing RG Cast 17x8.5 16.5 7.4842746
Advan Racing RG Cast 17x9.5 17.9 8.11930396
Advan Racing RG Cast 18x9 19 8.6182556
Advan Racing RG II Cast 16x7 12.9 5.85134196
Advan Racing RG II Cast 17x9 16.7 7.57499308
Advan Racing RG II Cast 18x7.5 17 7.7110708
Advan Racing RG II Cast 18x8 17.4 7.89250776
Advan Racing RG II Cast 18x9 17.9 8.11930396
Advan Racing RS Cast 17x8.5 16.5 7.4842746
Advan Racing RS Cast 17x9 17.5 7.937867
Advan Racing RS Cast 18x9 17.7 8.02858548
Advan Racing RZ Cast 18x8 16.5 7.4842746
Advan Racing T6 Cast 17x8 17 7.7110708
Advan Racing T6 Cast 18x8 17.4 7.89250776
Advan Racing T7 Cast 18x8 17.4 7.89250776
Advan Racing TC Cast 18x7.5 19.8 8.98112952
Advan Racing TC II Cast 18x7.5 17 7.7110708
Advan Racing TC II Cast 18x9.5 17.5 7.937867
Advan Siena Generation II Cast 18x10 25 11.33981
Advan Super Advan Generation II Cast 18x7.5 17.6 7.98322624
Advan Super Advan Generation II Cast 18x8.5 18 8.1646632
Advan Super Advan Racing SA3R Cast 17x8 23.5 10.6594214
Advan Super Advan Racing SA3R Cast 18x9.5 25.5 11.5666062
Advanti Racing 976 Cast 17x7 21.8 9.88831432
Advanti Racing Battle Z Cast 17x7 22 9.9790328
Advanti Racing Jazz Cast 16x7 18.5 8.3914594
Advanti Racing Lightening Cast 17x7 23.5 10.6594214
Advanti Racing Tuner 6 Cast 17x7 18 8.1646632
Aerospeed RS-11 Cast 17x7 21.4 9.70687736
Aerospeed RS-12 Cast 17x7 23.5 10.6594214
Aerospeed RS-14 Cast 17x7 20.5 9.2986442
Aerospeed RS-6 Cast 17x7 23 10.4326252
AEZ Bimo Cast 18x8.5 26.8 12.15627632
AEZ Paron Cast 18x8.5 27.4 12.42843176
AEZ Radon Cast 16x7.5 19 8.6182556
AEZ Simas X Cast 18x8.5 30.5 13.8345682
AFX Ambush 750 Cast 20x8.5 33 14.9685492
AFX Wedge Cast 17x7.5 27.5 12.473791
AG Forged SMK Monoblock AG1-SMK13 Forged 17x9 13.2 5.98741968
AG Forged SMK Monoblock AG3-SMK26 Forged 17x7.5 9.5 4.3091278
AG Forged SMK Monoblock D104 Forged 17x8 16.3 7.39355612
AG Forged SMK Monoblock D104 Forged 18x8 19.2 8.70897408
AG Forged SMK Monoblock D13 Forged 17x8 17.8 8.07394472
AG Forged SMK Monoblock D57 Forged 16x7 12.5 5.669905
AG Forged SMK Monoblock D57 Forged 17x7.5 17.6 7.98322624
AG Forged SMK Monoblock D57 Forged 18x8 16.5 7.4842746
AG Forged SMK Monoblock D74 Forged 18x8 19.7 8.93577028
AG Forged SMK Monoblock D99 Forged 18x8 18.8 8.52753712
AG Forged SMK Monoblock DG Forged 15x6.5 16.6 7.52963384
AK Tires Monza Cast 15x6.5 13 5.8967012
AK Tires Monza Cast 16x6.5 14.5 6.5770898
Akuza 209 Siege Cast 17x7.5 21 9.5254404
Akuza 209 Siege Cast 18x8.5 25.6 11.61196544
Akuza Z18 Sublime Cast 19x8.5 31.8 14.42423832
Alba 530 Cast 18x7.5 27.3 12.38307252
Alba 540 (Lexo) Cast 18x7.5 27.6 12.51915024
Alba 707 (Bertha) Cast 18x7.5 33 14.9685492
Alba 804 (Delta) Cast 18x8.5 33.3 15.10462692
Alba 907(Blaze) Cast 20x8.5 31.5 14.2881606
Alba Helix Cast 17x7.5 26.5 12.0201986
Alba R-510 Cast 17x7.5 22 9.9790328
Alba Wolverine Cast 17x7.5 27 12.2469948
Alessio Arizona Cast 16x7.5 20.8 9.43472192
Alfa Romeo Cast Mg 13x5.5 9 4.0823316
Alfa Romeo 156 Cast 16x6.5 21.7 9.84295508
Alfa Romeo GTV Cast 17x7.5 25.3 11.47588772
ALT 148 Cast 15x6.5 16.5 7.4842746
ALT AT-186 Cast 17x7 24 10.8862176
ALT AT-210 Cast 16x7 15.5 7.0306822
ALT AT-213 Cast 17x7 19 8.6182556
ALT AT-226 (Ciber) Cast 18x7.5 21.6 9.79759584
ALT AT-228 (Fusion) Cast 18x8 25.8 11.70268392
ALT Seven Cast 17x7 23 10.4326252
ALT Slash Cast 17x7 22.3 10.11511052
ALT X-phile Cast 17x7 20.8 9.43472192
Altstadt IV Cast 18x8.5 24.5 11.1130138
Altstadt Mesh Cast 18x8 27.5 12.473791
Aluett Type 10 Cast 15x6 15.9 7.21211916
Aluett Type 03 Cast 15x6 18.9 8.57289636
AME Circlar RS Cast/Spun 17x7 18.1 8.21002244
AME Circlar RS Cast/Spun 17x8 19.1 8.66361484
AME Circlar RS Cast/Spun 17x9 19.9 9.02648876
AME Circlar RS Cast/Spun 18x10 22 9.9790328
AME Circlar RS Cast/Spun 18x7.5 19.6 8.89041104
AME Circlar RS Cast/Spun 18x8 20.1 9.11720724
AME Circlar RS Cast/Spun 18x8.5 20.7 9.38936268
AME Circlar RS Cast/Spun 18x9 21.1 9.57079964
AME Circlar RS Cast/Spun 18x9.5 21.5 9.7522366
AME Circlar Spec M Cast/Spun 19x10 24.8 11.24909152
AME Circlar Spec M Cast/Spun 19x8.5 22.5 10.205829
AME Circlar Spec M Cast/Spun 19x9 23.3 10.56870292
AME Circlar Spec M Cast/Spun 19x9.5 24 10.8862176
AME Tracer Spec M Cast 19x10 24 10.8862176
AME Tracer Spec M Cast 19x8 21.9 9.93367356
AME Tracer Spec M Cast 19x8.5 22.2 10.06975128
AME Tracer Spec M Cast 19x9 23.3 10.56870292
AME Tracer Spec M Cast 19x9.5 23.1 10.47798444
AME Tracer TSSC Cast 15x7 10.2 4.62664248
AME Tracer TSSC Cast 16x7 14.7 6.66780828
AME Tracer TSSC Cast 16x8 14.9 6.75852676
AME Tracer TSSC Cast 17x7 15 6.803886
AME Tracer TSSC Cast 17x8 15.7 7.12140068
AME Tracer TSSC Cast 17x9 15.5 7.0306822
AME Tracer TSSC Cast 18x7.5 17.5 7.937867
AME Tracer TSSC Cast 18x8.5 18.3 8.30074092
AME Tracer TSSC Cast 18x9.5 18.2 8.25538168
American Eagle 077 Cast 17x8 22 9.9790328
American Eagle 112 Cast 20x8.5 34.7 15.73965628
American Eagle 133 Cast 20x8.5 38 17.2365112
American Eagle 135 Cast 17x7.5 20 9.071848
American Eagle 168 (Cobra) Cast 17x9 24 10.8862176
American Racing AR-210 (Zurg) Cast 16x7 19.5 8.8450518
American Racing AR-222 (Pinzetti) Cast 16x7 20 9.071848
American Racing AR-222 (Pinzetti) Cast 17x7 22.5 10.205829
American Racing AR-245 (Twisted Tuner) Cast 16x7 21.5 9.7522366
American Racing AR-245 (Twisted Tuner) Cast 18x7 24 10.8862176
American Racing AR-50 Cast 16x7 17.5 7.937867
American Racing AR-55 (Spyder) Cast 14x6 15 6.803886
American Racing AR-55 (Spyder) Cast 15x7 15.9 7.21211916
American Racing AR-55 (Spyder) Cast 16x7 17 7.7110708
American Racing AR-95 (Estrella) Cast 14x6 13.5 6.1234974
American Racing AR-95 (Estrella) Cast 15x7 18 8.1646632
American Racing AR-95 (Estrella) Cast 16x7 20 9.071848
American Racing Libre Cast 13x5.5 12.8 5.80598272
American Racing Libre Cast 14x5.5 13.5 6.1234974
American Racing Muscle Razor Cast 16x7.5 20 9.071848
American Racing Muscle Razor Cast 17x7.5 22 9.9790328
AMG 170 Cast/Spun 17x7.5 25.6 11.61196544
AMG 170 Cast/Spun 18x7.5 27.3 12.38307252
AMG 171 Cast 17x7.5 25.1 11.38516924
AMG 171 Cast 18x7.5 26.9 12.20163556
AMG 203 Cast/Spun 18x7.5 32.6 14.78711224
AMG Monoblock Cast 17x7.5 27.5 12.473791
AMG Monoblock Cast 17x8.5 28 12.7005872
Anterra Type 145 Cast 17x7 25 11.33981
Anterra Type 161 Cast 17x7 29 13.1541796
Anterra Type 163 Cast 18x8 33 14.9685492
Anterra Type 165 Cast 18x7.5 24.2 10.97693608
Anterra Type 183 Cast 18x8 30.8 13.97064592
Anterra Type 309 Cast 18x8 27.4 12.42843176
Anzio Ultra Cast 18x8 26.5 12.0201986
Arbet III Cast 17x7 25 11.33981
Arbet V Cast 15x7 21 9.5254404
Arceo Eurostar Cast 18x7.5 23.8 10.79549912
Arceo Megastar Cast 19x8 29.8 13.51705352
Arelli Bling-Bling (Type 101) Cast 20x8.5 34 15.4221416
Arelli Czar Cast 18x7.5 27.5 12.473791
Arelli DeLemma Cast 20x8.5 38.8 17.59938512
Arelli Hang Tyme Cast 20x10 56 25.4011744
Arelli Hang Tyme Cast 22x10 65 29.483506
Arelli Kaz'mir Cast 18x8.5 30 13.607772
Arelli Pulse Cast 17x7 24 10.8862176
Arelli Q Cast 17x7 26 11.7934024
Arelli Sensei Cast 20x8.5 33.8 15.33142312
Arelli Tranz Cast 18x8.5 26.5 12.0201986
Arelli Type 170 Cast 17x7.5 26 11.7934024
Arospeed RS11 Cast 17x7 18.5 8.3914594
Arospeed RS17 Cast 17x7 20.2 9.16256648
Arospeed RS23 Cast 17x7 18 8.1646632
Arospeed RS-GT Cast 18x7.5 22.8 10.34190672
ASA AR1 Cast 15x6.5 15.9 7.21211916
ASA AR1 Cast 16x7 18.1 8.21002244
ASA AR1 Cast 17x7 20.5 9.2986442
ASA AR1 Cast 17x8 21.2 9.61615888
ASA AR1 Cast 18x7.5 22 9.9790328
ASA AR1 Cast 18x8.5 23.5 10.6594214
ASA AR1 Cast 19x8.5 27.8 12.60986872
ASA AR2 Cast 17x7 21 9.5254404
ASA AR2 Cast 18x7.5 22.2 10.06975128
ASA AR2 Cast 18x8 23 10.4326252
ASA AR7 Cast 19x8 27 12.2469948
ASA AR9 Cast 18x8 23.5 10.6594214
ASA AR9 Cast 19x8.5 26.5 12.0201986
ASA EM9 Cast 15x7 19 8.6182556
ASA EM9 Cast 16x7 19.5 8.8450518
ASA EM9 Cast 17x7 21 9.5254404
ASA FR1 Forged 17x7 16.5 7.4842746
ASA FR1 Forged 17x8 18 8.1646632
ASA JH2 Cast 18x7.5 24.3 11.02229532
ASA JH3 Cast 16x7 19.8 8.98112952
ASA JH3 Cast 17x7.5 23.8 10.79549912
ASA JH3 Cast 18x8 25.5 11.5666062
ASA JH6 Cast 16x7 18 8.1646632
ASA JH6 Cast 17x7 19 8.6182556
ASA JH8 Cast 17x7.5 20.2 9.16256648
ASA JH8 Cast 18x7.5 21.8 9.88831432
ASA JH8 Cast 18x8.5 22.8 10.34190672
ASA JH8 Cast 19x8.5 25 11.33981
ASA JH9 Cast 18x8 28.5 12.9273834
ASA JH9 Cast 19x8 30.5 13.8345682
ASA JS1 Cast 15x7 17 7.7110708
ASA JS1 Cast 16x7 18 8.1646632
ASA JS1 Cast 17x7 20.5 9.2986442
ASA JS5 Cast 15x7 18 8.1646632
ASA JS5 Cast 16x7.5 20 9.071848
ASA JS5 Cast 17x7 21.5 9.7522366
ASA JS5 Cast 18x7.5 23 10.4326252
ASA JS5 Cast 18x8 23 10.4326252
ASA JS6 Cast 15x7 19.5 8.8450518
ASA JS6 Cast 16x7 20.5 9.2986442
ASA JS6 Cast 17x7 22.5 10.205829
ASA KA3 Cast 17x7.5 23.4 10.61406216
ASA LS5 Cast 16x7 17 7.7110708
ASA LS5 Cast 17x7 17.4 7.89250776
ASA LW5 Cast 15x7 14.5 6.5770898
ASA LW5 Cast 16x7.5 16 7.2574784
ASA LW5 Cast 17x7.5 17.2 7.80178928
ASA ST2 Cast 18x8 26.5 12.0201986
ASA ST3 Cast 18x8 25.6 11.61196544
ASA ST4 Cast 17x8 25.6 11.61196544
ASA ST4 Cast 18x8 24.7 11.20373228
ASA ST4 Cast 19x8.5 26.9 12.20163556
ASA ZR2 Cast/Spun 18x8 27 12.2469948
ASA ZR2 Cast/Spun 19x8.5 28.8 13.06346112
AT Italia 10 Razze Cast 16x7.5 20.5 9.2986442
AT Italia 10 Razze Cast 17x7.5 22 9.9790328
AT Italia 9 Razze Cast 18x8 28.5 12.9273834
AT Italia 9 Razze Cast 19x8.5 30.2 13.69849048
AT Italia Alp Cast 16x7.5 23.5 10.6594214
AT Italia Alp Cast 17x7.5 25.8 11.70268392
AT Italia Alp Cast 18x8 27 12.2469948
AT Italia Flash Cast 17x8 25.4 11.52124696
AT Italia Flash Cast 18x8 27 12.2469948
AT Italia Inox Cast 17x7.5 26 11.7934024
AT Italia Nido Cast 18x8 26 11.7934024
AT Italia Nido Cast 18x8.5 27 12.2469948
AT Italia Nido Cast 19x8.5 29 13.1541796
AT Italia Propeller Cast 18x8 27 12.2469948
AT Italia Propeller Cast 18x8.5 28.5 12.9273834
AT Italia Riva Cast/Spun 16x7.5 23.5 10.6594214
AT Italia Riva Cast/Spun 17x8 26 11.7934024
AT Italia Riva Cast/Spun 18x8 27 12.2469948
AT Italia S5 Cast 17x7.5 26 11.7934024
AT Italia S5 Cast 18x8 27 12.2469948
AT Italia Spider Cast/Spun 17x7.5 22.4 10.16046976
AT Italia Spider Cast/Spun 18x8 25.8 11.70268392
AT Italia Spider Cast/Spun 18x8.5 26.2 11.88412088
AT Italia Spider Cast/Spun 19x8.5 28 12.7005872
ATA H10 Cast 17x7.5 28.5 12.9273834
ATA H20 Cast 17x7.5 25 11.33981
ATA H20 Cast 18x8.5 28.8 13.06346112
ATA H30 Cast 18x7.5 28.4 12.88202416
A-Tech Finalspeed Cast 15x7 13 5.8967012
A-Tech Finalspeed Cast 17x7 17 7.7110708
ATP 5 Razze Cast 16x7 23.3 10.56870292
ATP Flashsports Cast 18x8 26 11.7934024
ATP PT5 Cast 17x7.5 28.3 12.83666492
ATP Spa Cast 17x7 24.5 11.1130138
ATP Spa Cast 17x8.5 25.8 11.70268392
ATS 2000 DTM Cast 17x7.5 20.8 9.43472192
ATS Cetus Cast 18x8 26.5 12.0201986
ATS Cup Cast 15x7 17 7.7110708
ATS DTC Comp Lite Cast 15x8 13.8 6.25957512
ATS DTC Comp Lite Cast 17x7.5 15.5 7.0306822
ATS DTC Motorsport Cast 15x7 12.3 5.57918652
ATS DTC Motorsport Cast 15x8 13.2 5.98741968
ATS DTC Motorsport Cast 17x7.5 18.9 8.57289636
ATS DTC Motorsport Cast 17x9 19.4 8.79969256
ATS DTC Motorsport Cast 18x8.5 19.8 8.98112952
ATS DTC Superlight Cast 17x7.5 16.3 7.39355612
ATS DTM Comp Cast 17x7 20.8 9.43472192
ATS DTM Comp Cast 17x7.5 21.8 9.88831432
ATS DTM Comp Cast 17x9 24.9 11.29445076
ATS DTM Comp Cast 18x7 23.3 10.56870292
ATS DTM Comp Cast 18x8 22.4 10.16046976
ATS DTM Comp Racing Cast 17x7.5 19.4 8.79969256
ATS DTM Comp Racing Cast 17x9 20.2 9.16256648
ATS DTM Comp Racing Cast 18x7 19.1 8.66361484
ATS DTM Comp Racing Cast 18x8 19.8 8.98112952
ATS Epsilon Cast 17x8 21.4 9.70687736
ATS Planet Cast 16x7 18.8 8.52753712
ATS Planet Cast 18x8 25 11.33981
Audi A3 97 Cast 15x6 13.3 6.03277892
Audi A3 97 Cast 15x7 15.5 7.0306822
Audi A4 5-spoke Cast 16x7 20 9.071848
Audi A4 7-spoke Cast 16x7 20.6 9.34400344
Audi A8 Forged 17x8 21 9.5254404
Audi A8 9-spoke Cast 20x8.5 28.6 12.97274264
Audi RS4 mk1 9-spoke Cast 18x8 19.5 8.8450518
Audi RS4 Cast 19x9 33 14.9685492
Audi R8 (Front) Cast 19x8.5 30 13.607772
Audi S4 92-94 Forged 16x8 18 8.1646632
Audi S4 Avus Cast 17x7.5 28 12.7005872
Audi S8 Avus Cast 18x8 27.2 12.33771328
Audi TT Cast 16x7 18.5 8.3914594
Audi TT Forged 17x7.5 21.5 9.7522366
Audi TT Cast 17x7.5 29 13.1541796
Autobahn International C2 Cup Cast 17x7.5 21.5 9.7522366
Autobahn International Twisted Spoke Cast 18x9.5 31.5 14.2881606
Axis Crux Cast 17x7 19.8 8.98112952
Axis Crux Cast 18x7.5 21.6 9.79759584
Axis Crux Cast 19x8 25 11.33981
Axis Decade Cast 18x8 22.5 10.205829
Axis GT-R Cast 20x10.5 31.5 14.2881606
Axis GT-R Cast 20x9 27 12.2469948
Axis Hiro Cast 18x8.5 22.4 10.16046976
Axis Hiro Cast 19x10.5 26.9 12.20163556
Axis Hiro Cast 19x8.5 26.8 12.15627632
Axis Hiro Cast 19x9.5 27 12.2469948
Axis Kent Cast 22x10 42 19.0508808
Axis Mach V Cast 16x7 20 9.071848
Axis Mach V Cast 18x7.5 26 11.7934024
Axis Mag-Lite Cast 15x7 12.6 5.71526424
Axis Mag-Lite Cast 17x7 15.6 7.07604144
Axis Mesh Cast 16x7 20 9.071848
Axis Mesh Cast 17x7 22.5 10.205829
Axis Milano Plus Cast 19x8.5 25 11.33981
Axis Milano Plus Cast 19x9.5 26 11.7934024
Axis Milano Plus Cast 20x8.5 28 12.7005872
Axis Milano Plus Cast 20x9.5 28.5 12.9273834
Axis MOD Cast 18x7.5 20.8 9.43472192
Axis MOD Cast 19x8 25.5 11.5666062
Axis MOD Cast 20x10 28.1 12.74594644
Axis MOD Cast 20x9 26.1 11.83876164
Axis Mulliner Cast 22x10.5 39.4 17.87154056
Axis Mulliner Cast 22x9 35.8 16.23860792
Axis Ne-O Cast 17x7 20.8 9.43472192
Axis Ne-O Cast 19x8 26.3 11.92948012
Axis Orden Cast 20x10 29.7 13.47169428
Axis Orden Cast 20x8.5 29.5 13.3809758
Axis Orden Cast 22x10.5 38.6 17.50866664
Axis Orden Cast 22x9 38 17.2365112
Axis Penta Cast 19x8.5 24.8 11.24909152
Axis Penta Cast 19x9.5 25.4 11.52124696
Axis Phin Cast 19x8.5 23 10.4326252
Axis Phin Cast 19x9.5 25 11.33981
Axis Regulator Cast 15x7.5 17.3 7.84714852
Axis Regulator Cast 16x9 19.6 8.89041104
Axis Regulator Cast 17x10 23.2 10.52334368
Axis Reverb Cast 17x7.5 18 8.1646632
Axis Reverb Cast 18x10.5 22 9.9790328
Axis Reverb Cast 18x7.5 19 8.6182556
Axis Reverb Cast 18x8.5 20 9.071848
Axis Reverb Cast 18x9.5 22.6 10.25118824
Axis Reverb Cast 20x7.5 21.5 9.7522366
Axis Seven Cast 19x8 24.3 11.02229532
Axis Speed Six Cast 19x8 26 11.7934024
Axis Starz Cast 17x7 21.8 9.88831432
Axis TC Evo Cast 18x7.5 23 10.4326252
Axis TC Evo Cast 19x8 24.6 11.15837304
Axis Titan Cast 20x9 34.5 15.6489378
Axis Titan Cast 22x9 41 18.5972884
Axis Touring Cup Cast 16x7 20 9.071848
Axis Touring Cup Cast 18x7 23 10.4326252
Axis VIP Cast 20x8.5 28.2 12.79130568
Axis VIP Cast 20x9.5 28.5 12.9273834
Axis Warlock Cast 17x10 26.1 11.83876164
Axis Warlock Cast 20x10 38.5 17.4633074
Axis WSM2 Cast 17x7 20.2 9.16256648
Azev Type H Cast 18x8 27.5 12.473791
Azev Type LS Cast 18x8.5 27.6 12.51915024
Azev Type M Cast 18x8.5 32.4 14.69639376
Azul Speed 5 Cast 17x7 17 7.7110708
Azul Speedmesh Cast 18x8 23.5 10.6594214
Azul Sprint 5 Cast 17x7 17 7.7110708
Azzur Matrix Cast 20x8.5 33 14.9685492
BBS CH Cast 17x7.5 20.2 9.16256648
BBS CH Cast 17x8.5 22 9.9790328
BBS CH Cast 18x8 24 10.8862176
BBS CH Cast 18x8.5 24.5 11.1130138
BBS CH Cast 19x10 28.2 12.79130568
BBS CH Cast 19x8.5 26 11.7934024
BBS CK Cast 18x8 23.5 10.6594214
BBS CV Cast 17x7.5 22.5 10.205829
BBS CV Cast 18x7.5 26 11.7934024
BBS DTM Forged 17x7.5 17.9 8.11930396
BBS DTM Forged 17x8 18.3 8.30074092
BBS DTM Forged 17x9 19.6 8.89041104
BBS DTM Forged 18x10.5 23.8 10.79549912
BBS DTM Forged 18x7.5 19.8 8.98112952
BBS DTM Forged 18x8.5 21.4 9.70687736
BBS DTM Forged 18x9.5 21.8 9.88831432
BBS DTM Forged 19x10.5 25.8 11.70268392
BBS DTM Forged 19x9.5 24.7 11.20373228
BBS Elise (sector 111) Forged 16x7 13.5 6.1234974
BBS Elise (sector 111) Forged 17x8 17.8 8.07394472
BBS GTII Forged/Spun 18x10 21.2 9.61615888
BBS GTII Forged/Spun 18x11 22.9 10.38726596
BBS GTII Forged/Spun 18x8 20.3 9.20792572
BBS GTII Forged/Spun 18x8.5 20.7 9.38936268
BBS GTII Forged/Spun 18x9 21 9.5254404
BBS GTII Forged/Spun 18x9.5 21.8 9.88831432
BBS LM Forged/Spun 17x7 19.1 8.66361484
BBS LM Forged/Spun 17x7.5 19.9 9.02648876
BBS LM Forged/Spun 17x8 20.2 9.16256648
BBS LM Forged/Spun 17x9 20.5 9.2986442
BBS LM Forged/Spun 18x10 21.1 9.57079964
BBS LM Forged/Spun 18x10.5 22.7 10.29654748
BBS LM Forged/Spun 18x11 26.9 12.20163556
BBS LM Forged/Spun 18x13 29.4 13.33561656
BBS LM Forged/Spun 18x7.5 20.5 9.2986442
BBS LM Forged/Spun 18x8 21.1 9.57079964
BBS LM Forged/Spun 18x8.5 21.6 9.79759584
BBS LM Forged/Spun 18x9 22.4 10.16046976
BBS LM Forged/Spun 18x9.5 23.3 10.56870292
BBS LM Forged/Spun 19x10 25.1 11.38516924
BBS LM Forged/Spun 19x8.5 24 10.8862176
BBS LM Forged/Spun 19x9 24.2 10.97693608
BBS LM Forged/Spun 19x9.5 24.6 11.15837304
BBS LM Forged/Spun 20x10 26.2 11.88412088
BBS LM Forged/Spun 20x8.5 25.7 11.65732468
BBS LM Forged/Spun 20x9.5 26.6 12.06555784
BBS Primadonna Forged/Spun 17x8 20 9.071848
BBS Primadonna Forged/Spun 18x10 22.7 10.29654748
BBS Primadonna Forged/Spun 18x8 22.4 10.16046976
BBS Primadonna Forged/Spun 18x9 22.9 10.38726596
BBS Primadonna Forged/Spun 19x8.5 23.3 10.56870292
BBS Primadonna Forged/Spun 19x9.5 24 10.8862176
BBS RC Cast (soft) 16x7 15 6.803886
BBS RC Cast (soft) 16x7.5 16 7.2574784
BBS RC Cast (soft) 17x7 16 7.2574784
BBS RC Cast (soft) 17x8 16.4 7.43891536
BBS RC Cast (soft) 17x9 18.4 8.34610016
BBS RC Cast (soft) 18x10 19.5 8.8450518
BBS RC Cast (soft) 18x8 19.5 8.8450518
BBS RC Cast (soft) 18x8.5 18.7 8.48217788
BBS RCJ Forged 18x8 17.9 8.11930396
BBS RCJ Forged 18x9 18.7 8.48217788
BBS RD Cast 17x7 20.6 9.34400344
BBS RE Forged 18x10 21.8 9.88831432
BBS RE Forged 18x7.5 18.7 8.48217788
BBS RE Forged 18x8 20.2 9.16256648
BBS RE Forged 18x8.5 20.5 9.2986442
BBS RE Forged 18x9 20.9 9.48008116
BBS RE Forged 18x9.5 21.3 9.66151812
BBS RE Forged 20x10.5 24.9 11.29445076
BBS RE Forged 20x8.5 23.1 10.47798444
BBS RE Forged 20x9.5 23.3 10.56870292
BBS RE-Mg Forged Mg 18x10 16.5 7.4842746
BBS RE-Mg Forged Mg 18x11 18.5 8.3914594
BBS RE-Mg Forged Mg 18x8.5 15.4 6.98532296
BBS RE-Mg Forged Mg 18x9.5 16.7 7.57499308
BBS RG F1-Racing (Japan Only) Forged 15x6.5 9.9 4.49056476
BBS RG F1-Racing (Japan Only) Forged 15x7 10.2 4.62664248
BBS RG F1-Racing (Japan Only) Forged 16x7 12.6 5.71526424
BBS RG II Forged 18x8 20.2 9.16256648
BBS RG II Forged 18x9 21.3 9.66151812
BBS RG II / Open Forged 15x6.5 11.4 5.17095336
BBS RG II / Open Forged 16x7 12.8 5.80598272
BBS RG-F Forged 15x5.5 9 4.0823316
BBS RG-F Forged 15x6 9.2 4.17305008
BBS RG-F Forged 15x6.5 9.9 4.49056476
BBS RG-F Forged 15x7 10.2 4.62664248
BBS RG-F Forged 16x7 12.8 5.80598272
BBS RG-R Forged 17x7 16.5 7.4842746
BBS RG-R Forged 17x7.5 17 7.7110708
BBS RG-R Forged 17x8 16.9 7.66571156
BBS RG-R Forged 17x8.5 17.8 8.07394472
BBS RG-R Forged 17x9 17.2 7.80178928
BBS RG-R Forged 17x9.5 17.8 8.07394472
BBS RG-R Forged 18x10 19.8 8.98112952
BBS RG-R Forged 18x7.5 17.8 8.07394472
BBS RG-R Forged 18x8 18 8.1646632
BBS RG-R Forged 18x8.5 18.3 8.30074092
BBS RG-R Forged 18x9 18.9 8.57289636
BBS RG-R Forged 18x9.5 19.4 8.79969256
BBS RG-R Forged 19x10 21.8 9.88831432
BBS RG-R Forged 19x8.5 20.5 9.2986442
BBS RG-R Forged 19x9 20.7 9.38936268
BBS RG-R Forged 19x9.5 20.9 9.48008116
BBS RK Cast 15x7 14.2 6.44101208
BBS RK Cast 16x7 15.3 6.93996372
BBS RK Cast 16x8 15.9 7.21211916
BBS RK Cast 17x7 16.2 7.34819688
BBS RK Cast 17x8 16.5 7.4842746
BBS RK Cast 18x7.5 18.2 8.25538168
BBS RK II Cast 17x7.5 20.7 9.38936268
BBS RK II Cast 17x8 21.5 9.7522366
BBS RK II Cast 17x9 22.1 10.02439204
BBS RK II Cast 18x10 24.6 11.15837304
BBS RK II Cast 18x8.5 23 10.4326252
BBS RM II Cast/Spun 17x8 24 10.8862176
BBS RR Forged/Spun 17x7.5 18.7 8.48217788
BBS RR Forged/Spun 17x8 20.2 9.16256648
BBS RR Forged/Spun 17x9 20.7 9.38936268
BBS RR Forged/Spun 18x10 24.9 11.29445076
BBS RR Forged/Spun 18x7.5 21.3 9.66151812
BBS RR Forged/Spun 18x8 22.1 10.02439204
BBS RR Forged/Spun 18x8.5 23.1 10.47798444
BBS RR Forged/Spun 18x9.5 23.3 10.56870292
BBS RS Forged/Spun 16x7 16 7.2574784
BBS RS II Forged/Cast 17x8 23 10.4326252
BBS RS II Forged/Cast 18x10 25.4 11.52124696
BBS RS II Forged/Cast 18x8.5 24 10.8862176
BBS RS II Forged/Cast 20x10 28.3 12.83666492
BBS RS II Forged/Cast 20x9 27.4 12.42843176
BBS RS-GT Forged 17x7 17.5 7.937867
BBS RS-GT Forged 17x7.5 18.3 8.30074092
BBS RS-GT Forged 17x8 18.7 8.48217788
BBS RS-GT Forged 17x8.5 18.9 8.57289636
BBS RS-GT Forged 17x9 19.8 8.98112952
BBS RS-GT Forged 18x10 22 9.9790328
BBS RS-GT Forged 18x11 24.4 11.06765456
BBS RS-GT Forged 18x8 19.9 9.02648876
BBS RS-GT Forged 18x8.5 20 9.071848
BBS RS-GT Forged 18x9 20.2 9.16256648
BBS RS-GT Forged 18x9.5 21.1 9.57079964
BBS RS-GT Forged 19x10 22.9 10.38726596
BBS RS-GT Forged 19x8.5 21.8 9.88831432
BBS RS-GT Forged 19x9 22.4 10.16046976
BBS RS-GT Forged 19x9.5 22 9.9790328
BBS RS-GT Forged 20x8.5 22.7 10.29654748
BBS RS-GT Forged 20x9.5 22.9 10.38726596
BBS RT II Delta Cast/Spun 17x9.5 29.2 13.24489808
BBS RT II Delta Cast/Spun 18x10 33.4 15.14998616
BBS RV Cast 14x6 12.7 5.76062348
BBS RV Cast 15x7 15.5 7.0306822
BBS RV Cast 16x7 16 7.2574784
BBS RV Cast 16x8 18.2 8.25538168
BBS RV Cast 17x7.5 18.4 8.34610016
BBS RV Cast 17x8 21.1 9.57079964
BBS RV-F Forged 17x7 14.7 6.66780828
BBS RV-F Forged 17x7.5 15.4 6.98532296
BBS RW Cast 15x7 18 8.1646632
BBS RW II Cast/Spun 17x7.5 22.6 10.25118824
BBS RW II Cast/Spun 17x8 23.9 10.84085836
BBS RW II Cast/Spun 18x10 26.3 11.92948012
BBS RW II Cast/Spun 18x8.5 25.3 11.47588772
BBS RX Cast 14x6 12.5 5.669905
BBS RX Cast 15x7 14.7 6.66780828
BBS RX Cast 16x7 20.1 9.11720724
BBS RX Cast 16x8 22 9.9790328
BBS RX Cast 17x7.5 20.9 9.48008116
BBS RX Cast 17x8 23.3 10.56870292
BBS RX Cast 18x8 23.5 10.6594214
BBS RX Cast 18x8.5 25.1 11.38516924
BBS RX II Cast/Spun 14x5.5 13.3 6.03277892
BBS RX II Cast/Spun 14x6 13.9 6.30493436
BBS RX II Cast/Spun 17x7.5 21.2 9.61615888
BBS RX II Cast/Spun 17x8 23.6 10.70478064
BBS RX II Cast/Spun 18x8.5 26.3 11.92948012
BBS RZ Cast 17x7 21.8 9.88831432
BBS Super-RS Forged/Spun 17x8 20 9.071848
BBS Super-RS Forged/Spun 18x10 22.7 10.29654748
BBS Super-RS Forged/Spun 18x8 22.4 10.16046976
BBS Super-RS Forged/Spun 18x9 22.6 10.25118824
BBS Super-RS Forged/Spun 19x8.5 23.3 10.56870292
BBS Super-RS Forged/Spun 19x9.5 24 10.8862176
BBS SX Cast 18x8 25 11.33981
BBS VZ Cast 16x7.5 17 7.7110708
BBS VZ Cast 17x7.5 22 9.9790328
BBS VZ Cast 17x8 23 10.4326252
BBS VZ Cast 18x8 25 11.33981
Beyern Type 5 Cast 18x8.5 23.8 10.79549912
Billet Specialties E1 Cast 17x7 23.3 10.56870292
Billet Specialties SLX 21 Cast 18x7 22.4 10.16046976
Billet Specialties SLX 30 Cast 18x7 26.2 11.88412088
Black Racing Phantom Cast 15x6.5 14.3 6.48637132
Black Racing Pro N1 Cast 17x7.5 20 9.071848
Black Racing Pro N1 Cast 17x8 20.5 9.2986442
Black Racing Pro N1 Cast 17x9 21.2 9.61615888
Blitz Technospeed Z1 Forged/Spun 18x10 25.8 11.70268392
Blitz Technospeed Z1 Forged/Spun 19x10 28.5 12.9273834
Blitz Technospeed Z1 Forged/Spun 19x9 25.8 11.70268392
Blitz Technospeed Z2 Forged/Spun 18x9 24 10.8862176
Blitz Type 01 Forged/Spun 17x8 20.3 9.20792572
Blitz Type 01 Forged/Spun 17x9 20.5 9.2986442
Blitz Type 01R Forged 16x7 16.8 7.62035232
Blitz Type 02 Forged/Spun 15x7 13 5.8967012
Blitz Type 03 Forged/Spun 18x8 22.5 10.205829
Blitz Type 03 Forged/Spun 18x9 26.8 12.15627632
BMW 3 Series Steel 15x6.5 18 8.1646632
BMW 320i Cast 13x6 10.8 4.89879792
BMW 328is Cast 16x7 19 8.6182556
BMW E30 M3 Cast 15x7 16 7.2574784
BMW E30 M3 (BBS RS003) Cast/Spun 16x7 16 7.2574784
BMW E34 M5 ""Throwing Stars"" Forged 17x8 19.5 8.8450518
BMW E36 M3 Contour Cast 17x7.5 22.3 10.11511052
BMW E36 M3 Contour Cast 17x8.5 23.4 10.61406216
BMW E36 M3 Doublespoke I (Motorsport) Cast 17x7.5 21.3 9.66151812
BMW E36 M3 Doublespoke I (Motorsport) Cast 17x8.5 22.3 10.11511052
BMW E36 M3 Doublespoke II Cast 17x7.5 20.7 9.38936268
BMW E36 M3 Doublespoke II Cast 17x8.5 21.9 9.93367356
BMW E36 M3 Forged Forged 17x7.5 19.7 8.93577028
BMW E36 M3 Forged Forged 17x8.5 20.9 9.48008116
BMW E36 M3 LTW Forged 17x7.5 19.5 8.8450518
BMW E36 M3 LTW Forged 17x8.5 20.7 9.38936268
BMW E39 M5 Forged 18x8 23.6 10.70478064
BMW E39 M5 Forged 18x9.5 25.6 11.61196544
BMW E46 CSL Cast 19x8.5 27.8 12.60986872
BMW E46 CSL Cast 19x9.5 30.5 13.8345682
BMW E46 M135 Cast 18x8 28.5 12.9273834
BMW E46 M135 Cast 18x8.5 29 13.1541796
BMW E46 M3 Compeition Cast 19x8 24 10.8862176
BMW E46 M3 Compeition Cast 19x9.5 25.5 11.5666062
BMW E46 MZ4 224M Cast 18x8 28 12.7005872
BMW E46 MZ4 224M Cast 18x9 30 13.607772
BMW E46 Style 44 Cast 17x8 23.1 10.47798444
BMW E46 Style 45 Cast 16x7 20.1 9.11720724
BMW E46 Style 68 Cast 17x7.5 21 9.5254404
BMW E46 Style 71 Forged/Spun 18x8 21 9.5254404
BMW E46 Style 71 Forged/Spun 18x8.5 22 9.9790328
BMW E90 Style 162 Cast 18x8 30 13.607772
BMW E90 Style 162 Cast 18x8.5 32.2 14.60567528
BMW Parallels Forged 18x8 23 10.4326252
Bogart 13x5.5 15.3 6.93996372
Borbet Type B Cast 15x6.5 16.5 7.4842746
Borbet Type B Cast 15x7 17.5 7.937867
Borbet Type B Cast 16x7.5 19 8.6182556
Borbet Type C Cast 15x7 16.5 7.4842746
Borbet Type C Cast 17x7.5 24 10.8862176
Borbet Type C2T Cast 17x7.5 28 12.7005872
Borbet Type C2T Cast 17x9 30 13.607772
Borbet Type C2T (Porsche OE) Cast 17x7.5 22 9.9790328
Borbet Type C2T (Porsche OE) Cast 17x9 23.5 10.6594214
Borbet Type CA Cast 15x6.5 19 8.6182556
Borbet Type CA Cast 16x7 21.6 9.79759584
Borbet Type CA Cast 18x7.5 27.3 12.38307252
Borbet Type E Cast 15x7 17.5 7.937867
Borbet Type E Cast 17x7 21 9.5254404
Borbet Type E Cast 17x8 23.6 10.70478064
Borbet Type F Cast 16x7 19 8.6182556
Borbet Type FS Cast 17x7 20.1 9.11720724
Borbet Type FS Cast 17x8 21 9.5254404
Borbet Type FS Cast 18x7.5 23 10.4326252
Borbet Type FS Cast 18x8.5 24.7 11.20373228
Borbet Type H Cast 15x7 18.5 8.3914594
Borbet Type LS Cast 15x6.5 18.5 8.3914594
Borbet Type LS Cast 16x7 22 9.9790328
Borbet Type LS Cast 17x7 22.5 10.205829
Borbet Type LS Cast 18x8 26.5 12.0201986
Borbet Type LV4 Cast 17x7 20.5 9.2986442
Borbet Type LV4 Cast 18x7 21.5 9.7522366
Borbet Type LV5 Cast 17x7 22.5 10.205829
Borbet Type M Cast 16x7 23 10.4326252
Borbet Type M Cast 17x8 27.5 12.473791
Borbet Type R Cast 17x8 20.5 9.2986442
Borbet Type R Cast 18x8 23 10.4326252
Borbet Type S Cast 15x7 15.5 7.0306822
Borbet Type S Cast 17x7 21 9.5254404
Borbet Type S Cast 18x8 22.5 10.205829
Borbet Type T Cast 14x6 14.2 6.44101208
Borbet Type T Cast 15x7 17.5 7.937867
Borbet Type T Cast 16x7.5 21 9.5254404
Borbet Type T Cast 17x7 22.5 10.205829
Borbet Type TD Cast 18x8 25 11.33981
Borbet Type TS Cast 18x8.5 26.9 12.20163556
Borbet Type VS Cast 18x8 24 10.8862176
Borbet Type XL Cast 17x7.5 22 9.9790328
Borbet Type XL Cast 18x8 23.5 10.6594214
Boss 307 Cast 20x8.5 33.8 15.33142312
Brabus Mono III Cast 17x8 29 13.1541796
Branzach BZ-11 Cast 18x8 28 12.7005872
Branzach BZ-12 (Zeo) Cast 18x7.5 24.2 10.97693608
Breyton Inspiration Cast 17x7 23.5 10.6594214
Breyton Magic Cast 18x7 26 11.7934024
Breyton Magic Cast 18x8.5 28 12.7005872
Breyton Softline Cast 17x8 24 10.8862176
Bridgestone Super R.A.P. Cast 14x6 10 4.535924
BRIG Magline 10 Forged 17x7 15.3 6.93996372
BRIG Magline 5 Forged 15x6.5 9.9 4.49056476
BRIG Magline 5 Forged 17x7 14.6 6.62244904
BRIG Magline 8 Forged 15x6.5 10.6 4.80807944
BRIG Magline 8 Forged 17x7 14.5 6.5770898
BRIG Proline 7 Cast 15x6.5 17.4 7.89250776
Brock B13 Cast 17x7.5 20.3 9.20792572
BSA 248 Cast 18x7.5 23.2 10.52334368
BSA 259 Cast 18x7.5 24.4 11.06765456
BSA 333 Cast 17x7 19.5 8.8450518
BSA 341 Cast 17x7 19.5 8.8450518
BSA Octopus Cast 16x7 19.5 8.8450518
Buddy Club P1 Racing II Cast/Spun 19x10 24.3 11.02229532
Buddy Club P1 Racing II Cast/Spun 19x9 22 9.9790328
Buddy Club P1 Racing QF Forged 15x7 10.1 4.58128324
Buddy Club P1 Racing QF Forged 16x7 11.1 5.03487564
Buddy Club P1 Racing QF Forged 17x7.5 12.9 5.85134196
Buddy Club P1 Racing QF Forged 17x8 13.6 6.16885664
Buddy Club P1 Racing QF Forged 17x9 14.5 6.5770898
Buddy Club P1 Racing QF Forged 17x9.5 15.1 6.84924524
Buddy Club P1 Racing QF Forged 18x10 16.1 7.30283764
Buddy Club P1 Racing QF Forged 18x9 14.8 6.71316752
Buddy Club P1 Racing SF Cast 15x6.5 13.7 6.21421588
Buddy Club P1 Racing SF Cast 17x7 17.4 7.89250776
Budnik Gasses Forged 17x8 20 9.071848
Budnik Grid Forged 17x7 21.5 9.7522366
Budnik GT-5 Lite Forged 18x7 23 10.4326252
Budnik Pentacle FL Forged 17x8 25.2 11.43052848
Budnik Prism Forged 18x8 21 9.5254404
CAM 1 (Challenge) Cast 16x7 18 8.1646632
CAM 1 (Challenge) Cast 17x7 21 9.5254404
CAM 2 (Trophy) Cast 16x7 16.5 7.4842746
Carlsson Design 1/16 Ultra Light Forged 19x8.5 21.2 9.61615888
Carlsson Design 1/5 Cast 18x8.5 29.3 13.29025732
Carlsson Design 1/6 EVO Cast 19x8.5 33.3 15.10462692
Carlsson Design 2/5 Cast 18x8.5 33 14.9685492
Carusi Type 62 Cast 17x7 28 12.7005872
CCW (not hub or lug-centric) Forged/Spun 17x10 18.6 8.43681864
CCW (not hub or lug-centric) Forged/Spun 17x9.5 18 8.1646632
CCW (not hub or lug-centric) Forged/Spun 18x10 22 9.9790328
CEC Techart Daytona Cast 18x11 27.8 12.60986872
CEC Type 139 Cast 17x7 25 11.33981
CEC Type 149 Cast 18x8 25 11.33981
CEC Type 169 Cast 18x8.5 33 14.9685492
CEC Type 185 (Antera) Cast 17x7.5 27 12.2469948
CEC Type 971 (Valbrem) Cast 16x7 23 10.4326252
CEC Type 992 Cast 17x7.5 21 9.5254404
CEC Type H (Azev) Cast 17x7.5 26 11.7934024
Centerline Convo-Pro Forged 15x15 14.5 6.5770898
Centerline Impulse Forged 17x7 11.8 5.35239032
Centerline Neutron Forged 15x7 14 6.3502936
Centerline Neutron Forged 17x7 17.5 7.937867
Centerline RPM Forged 17x7 13.5 6.1234974
Centerline RPM Forged 18x8.5 15 6.803886
Centerline RPM Forged 19x7.5 15.6 7.07604144
Centerline Thruster 806 Cast 17x9.5 22 9.9790328
Champion Motorsport RS98 Forged 19x10 19.4 8.79969256
Champion Motorsport RS98 Forged 19x11.5 20.5 9.2986442
Champion Motorsport RS98 Forged 19x8.5 18.1 8.21002244
Champion Motorsport stellaCORSE Forged 16x7 13.9 6.30493436
Champion Motorsport stellaCORSE Forged 17x8 16 7.2574784
Chaparral S 15 Cast 15x7 15.3 6.93996372
Chevrolet Corvette Z06 01 Forged 17x9.5 19.6 8.89041104
Chevrolet Corvette Z06 01 Forged 18x10.5 21.4 9.70687736
Chevrolet Corvette Z06 01 - CCW skeletal mod Forged 17x9.5 17.8 8.07394472
Chevrolet Corvette Z06 01 - CCW skeletal mod Forged 18x10.5 19.8 8.98112952
Chevrolet Corvette Z06 02 Cast/Spun 17x9.5 19.2 8.70897408
Chevrolet Corvette Z06 02 Cast/Spun 18x10.5 21 9.5254404
Chevrolet Sprint / Geo Metro / Suzuki Steel 12x4 10 4.535924
Circlar GTA Cast 18x8.5 21.6 9.79759584
Circle Racing Series 01 Steel 13x5.5 15 6.803886
Circle Racing Series 01 Steel 13x7 16.5 7.4842746
Circle Racing Series 01 Steel 15x10 31.5 14.2881606
Circle Racing Series 01 Steel 15x7 24.5 11.1130138
Circle Racing Series 01 Steel 15x8 26 11.7934024
Circle Racing Series 02 Steel 13x5.5 15 6.803886
Circle Racing Series 02 Steel 13x7 16.5 7.4842746
Circle Racing Series 02 Steel 15x10 31.5 14.2881606
Circle Racing Series 02 Steel 15x7 24.5 11.1130138
Circle Racing Series 02 Steel 15x8 26 11.7934024
Circle Racing Series 11 Spun 13x10 15.5 7.0306822
Circle Racing Series 11 Spun 13x6 12.5 5.669905
Circle Racing Series 11 Spun 13x7 13 5.8967012
Circle Racing Series 11 Spun 13x8 14 6.3502936
Circle Racing Series 12 Spun 13x10 15.5 7.0306822
Circle Racing Series 12 Spun 13x6 12.5 5.669905
Circle Racing Series 12 Spun 13x7 13 5.8967012
Circle Racing Series 12 Spun 13x8 14 6.3502936
Circle Racing Series 13 Spun 13x10 15.5 7.0306822
Circle Racing Series 13 Spun 13x6 12.5 5.669905
Circle Racing Series 13 Spun 13x7 13 5.8967012
Circle Racing Series 13 Spun 13x8 14 6.3502936
Circle Racing Series 22 Steel 15x10 25.5 11.5666062
Circle Racing Series 22 Steel 15x8 24.5 11.1130138
Circle Racing Series 23 Steel 15x10 25.5 11.5666062
Circle Racing Series 23 Steel 15x8 24.5 11.1130138
Circle Racing Series 25 Steel 15x10 21.5 9.7522366
Circle Racing Series 25 Steel 15x7 18.5 8.3914594
Circle Racing Series 25 Steel 15x8 19.5 8.8450518
Circle Racing Series 26 Steel 15x10 21.5 9.7522366
Circle Racing Series 26 Steel 15x7 18.5 8.3914594
Circle Racing Series 26 Steel 15x8 19.5 8.8450518
Circle Racing Series 27 Steel 15x10 21.5 9.7522366
Circle Racing Series 27 Steel 15x7 18.5 8.3914594
Circle Racing Series 27 Steel 15x8 19.5 8.8450518
Circle Racing Series 28 Steel 15x10 21.5 9.7522366
Circle Racing Series 28 Steel 15x7 18.5 8.3914594
Circle Racing Series 28 Steel 15x8 19.5 8.8450518
Circle Racing Series 29 Steel 15x10 21.5 9.7522366
Circle Racing Series 29 Steel 15x7 18.5 8.3914594
Circle Racing Series 29 Steel 15x8 19.5 8.8450518
Circle Racing Series 30 Steel 15x10 21.5 9.7522366
Circle Racing Series 30 Steel 15x7 18.5 8.3914594
Circle Racing Series 30 Steel 15x8 19.5 8.8450518
Circle Racing Series 31 Spun 13x6 12 5.4431088
Circle Racing Series 31 Spun 13x7 13 5.8967012
Circle Racing Series 31 Spun 13x8 14.5 6.5770898
Circle Racing Series 32 Spun 13x6 12 5.4431088
Circle Racing Series 32 Spun 13x7 13 5.8967012
Circle Racing Series 32 Spun 13x8 14.5 6.5770898
Circle Racing Series 33 Spun 13x6 12 5.4431088
Circle Racing Series 33 Spun 13x7 13 5.8967012
Circle Racing Series 33 Spun 13x8 14.5 6.5770898
Circle Racing Series 34 Spun 13x6 12 5.4431088
Circle Racing Series 34 Spun 13x7 13 5.8967012
Circle Racing Series 34 Spun 13x8 14.5 6.5770898
Circle Racing Series 35 Steel 15x10 22 9.9790328
Circle Racing Series 35 Steel 15x7 18.5 8.3914594
Circle Racing Series 35 Steel 15x8 19.5 8.8450518
Circle Racing Series 36 Steel 15x10 22 9.9790328
Circle Racing Series 36 Steel 15x7 18.5 8.3914594
Circle Racing Series 36 Steel 15x8 19.5 8.8450518
Circle Racing Series 37 Steel 15x10 22 9.9790328
Circle Racing Series 37 Steel 15x7 18.5 8.3914594
Circle Racing Series 37 Steel 15x8 19.5 8.8450518
Circle Racing Series 38 Steel 15x10 21.5 9.7522366
Circle Racing Series 38 Steel 15x7 18.5 8.3914594
Circle Racing Series 38 Steel 15x8 19.5 8.8450518
Circle Racing Series 39 Steel 15x10 21.5 9.7522366
Circle Racing Series 39 Steel 15x7 18.5 8.3914594
Circle Racing Series 39 Steel 15x8 19.5 8.8450518
Circle Racing Series 40 Steel 15x10 21.5 9.7522366
Circle Racing Series 40 Steel 15x7 18.5 8.3914594
Circle Racing Series 40 Steel 15x8 19.5 8.8450518
Circle Racing Series 41 Spun 15x10 21.5 9.7522366
Circle Racing Series 41 Spun 15x8 17.1 7.75643004
Circle Racing Series 42 Spun 15x10 21.5 9.7522366
Circle Racing Series 42 Spun 15x8 17.1 7.75643004
Circle Racing Series 43 Spun 15x10 19 8.6182556
Circle Racing Series 43 Spun 15x8 17.1 7.75643004
Circle Racing Series 44 Spun 15x10 19 8.6182556
Circle Racing Series 44 Spun 15x8 17.1 7.75643004
Circle Racing Series 51 Spun 15x10 17.7 8.02858548
Circle Racing Series 51 Spun 15x8 13.8 6.25957512
Circle Racing Series 52 Spun 15x10 17.7 8.02858548
Circle Racing Series 52 Spun 15x8 13.8 6.25957512
Circle Racing Series 53 Spun 15x10 17.7 8.02858548
Circle Racing Series 54 Spun 15x10 17.7 8.02858548
Circle Racing Series 55 Spun 15x10 17.7 8.02858548
Circle Racing Series 55 Spun 15x8 13.8 6.25957512
Circle Racing Series 56 Spun 15x10 17.7 8.02858548
Circle Racing Series 56 Spun 15x8 13.8 6.25957512
Circle Racing Series 57 Spun 15x10 17.7 8.02858548
Circle Racing Series 57 Spun 15x8 13.8 6.25957512
Circle Racing Series 61 Steel 15x9.5 27 12.2469948
Circle Racing Series 82 Spun 13x5.5 7.7 3.49266148
Circle Racing Series 82 Spun 13x6 8 3.6287392
Circle Racing Series 82 Spun 13x7 8.7 3.94625388
Circle Racing Series 82 Spun 13x8 9.7 4.39984628
Circle Racing Series 82 Spun 14x7 11.5 5.2163126
Circle Racing Series 82 Spun 15x10 15.3 6.93996372
Circle Racing Series 82 Spun 15x7 12.2 5.53382728
Circle Racing Series 82 Spun 15x8 13.7 6.21421588
Circle Racing Series 82 Spun 16x7 13.2 5.98741968
Circle Racing Series 82 Spun 16x8 14.4 6.53173056
Circle Racing Series 82 Spun 16x9.5 15.8 7.16675992
Circle Racing Series 84 Spun 13x5.5 8.2 3.71945768
Circle Racing Series 84 Spun 13x6 8.8 3.99161312
Circle Racing Series 84 Spun 13x8 9.2 4.17305008
Cirlce Racing Series 21 Steel 15x10 25.5 11.5666062
Cirlce Racing Series 21 Steel 15x8 24.5 11.1130138
Club Linea Special Cast 18x8 25 11.33981
Cobb Tuning CT-One Cast 17x7.5 22 9.9790328
Compomotive ML Cast 13x10 15.4 6.98532296
Compomotive ML Cast 13x5.5 13.2 5.98741968
Compomotive ML Cast 13x6 13.6 6.16885664
Compomotive ML Cast 13x7 14.3 6.48637132
Compomotive ML Cast 13x8 14.5 6.5770898
Compomotive ML Cast 13x9 14.7 6.66780828
Compomotive ML Cast 14x6 13.6 6.16885664
Compomotive ML Cast 15x5.5 16.5 7.4842746
Compomotive ML Cast 15x6 18 8.1646632
Compomotive ML Cast 15x7 20.9 9.48008116
Compomotive ML Cast 15x8 22 9.9790328
Compomotive MO Cast 14x5.5 15 6.803886
Compomotive MO Cast 14x6 15 6.803886
Compomotive MO Cast 15x6 17.2 7.80178928
Compomotive MO Cast 15x7 18.7 8.48217788
Compomotive MO Cast 15x8 18.9 8.57289636
Compomotive MO Cast 16x5.5 16.5 7.4842746
Compomotive MO Cast 16x6 16.9 7.66571156
Compomotive MO Cast 16x6.5 17.4 7.89250776
Compomotive MO Cast 16x7 19.6 8.89041104
Compomotive MO Cast 16x7.5 21.8 9.88831432
Compomotive MO Cast 16x8 20.9 9.48008116
Compomotive MO Cast 17x7 21.3 9.66151812
Compomotive MO Cast 17x7.5 22.4 10.16046976
Compomotive MO Cast 17x8 24 10.8862176
Compomotive MO Cast 18x8 26.4 11.97483936
Compomotive PS Cast 17x10 20.5 9.2986442
Compomotive TH Cast 13x5 11.2 5.08023488
Compomotive TH Cast 13x5.5 11.4 5.17095336
Compomotive TH Cast 14x5 12.8 5.80598272
Compomotive TH Cast 14x5.5 15 6.803886
Compomotive TH Cast 14x6 15.6 7.07604144
Compomotive TH Cast 15x5 16.1 7.30283764
Compomotive TH Cast 15x5.5 16.3 7.39355612
Compomotive TH Cast 15x6 16.6 7.52963384
Compomotive TH Cast 15x6.5 17.8 8.07394472
Compomotive TH Cast 15x7 18.3 8.30074092
Compomotive TH Cast 15x7.5 19.1 8.66361484
Compomotive TH Cast 15x8 20 9.071848
Compomotive TH Cast 16x5.5 20 9.071848
Compomotive TH Cast 16x6 20.5 9.2986442
Compomotive TH Cast 16x7 20.9 9.48008116
Compomotive TH Cast 16x7.5 20.5 9.2986442
Compomotive TH Cast 16x8 20.9 9.48008116
Compomotive TH2 Cast 15x5.5 18.1 8.21002244
Compomotive TH2 Cast 15x6 16.9 7.66571156
Compomotive TH2 Cast 15x6.5 17.9 8.11930396
Compomotive TH2 Cast 15x7 18.1 8.21002244
Compomotive TH2 Cast 16x6.5 18.1 8.21002244
Compomotive TH2 Cast 17x7.5 21.2 9.61615888
Compomotive TH2 Cast 18x8 24.1 10.93157684
Concept Neeper Dagg Cast 20x8.5 33 14.9685492
Concept Neeper Fly Cast 20x8.5 32 14.5149568
Concept Neeper Haaz Cast 18x8.5 30.3 13.74384972
Concept Neeper N170 Cast 20x8.5 30.3 13.74384972
Concept Neeper Sideburn Cast 18x7 35.6 16.14788944
Concord Racing Cast 15x7 24 10.8862176
Cray Scorpion Cast 19x10.5 32.8 14.87783072
Cromodora Ego Cast 16x7 22 9.9790328
Cromodora Mg Cast Mg 13x5.5 8.8 3.99161312
Dale Earnhardt Jr Knuckle Cast 17x7.5 20 9.071848
Datsun 200SX 80-83 (16-spoke) Cast 14x5.5 15 6.803886
Datsun 200SX 80-83 (32-spoke) Cast 14x5.5 16 7.2574784
Datsun 200SX 80-83 (disk) Cast 14x5.5 14 6.3502936
Datsun 280Z 79-80 Cast 14x6 18 8.1646632
Datsun 280ZX 81-83 Cast 14x6 13 5.8967012
Datsun 280ZX Turbo 81 Cast 15x6 17 7.7110708
Datsun 280ZX Turbo 82-83 Cast 15x6 14 6.3502936
Datsun 810/Maxima 81-84 Cast 14x5.5 15 6.803886
DAZZ Camus Cast 19x9.5 27.3 12.38307252
DAZZ Matrix Cast 19x9.5 28 12.7005872
Decorsa Arch Cast 19x8.5 27.5 12.473791
Decorsa DC5 Cast 18x7.5 31 14.0613644
Decorsa DC6 Cast 22x9.5 37 16.7829188
Decorsa Flex Cast 22x9.5 42.5 19.277677
Decorsa Fusion Cast 18x8 25.5 11.5666062
Decorsa Magnum Cast 18x7.5 22.5 10.205829
Decorsa Maze Cast 19x8 26 11.7934024
Decorsa Phantom Cast 20x8.5 32.5 14.741753
Decorsa Polaris 5 Cast 18x8.5 23 10.4326252
Decorsa Polaris 6 Cast 22x9.5 33 14.9685492
Decorsa Stellar Cast 20x8.5 30.5 13.8345682
Desmond Rega Master EVO Forged 15x6.5 8.6 3.90089464
Desmond Rega Master EVO Forged 16x7 11.9 5.39774956
Desmond Rega Master EVO Forged 16x8 12.9 5.85134196
Desmond Rega Master EVO Forged 17x7 15 6.803886
Detata DT-105 Cast 17x8 26 11.7934024
Detata DT-109 Cast 17x7.5 28.3 12.83666492
Detata DT-111 Cast 17x7.5 24 10.8862176
Diamond Racing Spun Steel 13x6 11 4.9895164
Diamond Racing Spun Steel 13x8 13.6 6.16885664
Diamond Racing Spun Steel 15x7 18.8 8.52753712
Dinan BMW (Fiske) Forged/Spun 18x9 18 8.1646632
Dinan BMW D750 Forged 19x10 20 9.071848
Dinan BMW D750 Forged 19x9 20 9.071848
Dodge Challenger 78-83 Cast 14x5.5 15 6.803886
Dodge Colt 88-90 Cast 14x5.5 13 5.8967012
Dodge Conquest 84-85 (large vents) Cast 15x6.5 14 6.3502936
Dodge Conquest 84-86 Cast 14x6 15 6.803886
Dodge Conquest 84-87 (all others) Cast 15x6.5 16 7.2574784
Dodge Neon ACR 02 Cast 15x6 16.5 7.4842746
Dodge Viper - 01 Cast 18x10 28.4 12.88202416
Dodge Viper - 01 Cast 18x13 32.3 14.65103452
Dotz Brands Hatch Cast 15x6.5 21.8 9.88831432
Dotz Daytona Cast 15x6.5 19.2 8.70897408
Dotz Daytona Cast 17x7.5 20.8 9.43472192
DPE GT7 Forged 18x8 19 8.6182556
DPE R05 Variant S Forged 19x8 24 10.8862176
Drag Wheels DR16 Cast 16x7 16.5 7.4842746
Drag Wheels DR20 Cast 15x7 15.2 6.89460448
Drag Wheels DR21 Cast 15x7 12.9 5.85134196
Drag Wheels DR23 Cast 15x6.5 16.5 7.4842746
Drag Wheels DR9 Cast 15x7 12.3 5.57918652
Drive Mach 5 Cast 20x8.5 34.3 15.55821932
Drive Zila Cast 20x8.5 42.5 19.277677
Dronell CA-05 Cast 20x8.5 30.6 13.87992744
Dronell D-06 Cast 19x8 27.8 12.60986872
Dronell M-10 Forged 19x8.5 18.5 8.3914594
Dronell TS-05 Cast 17x7 18 8.1646632
Dronell TS-06 Cast 17x7 20.8 9.43472192
Dronell Type II Cast 19x7.5 28.8 13.06346112
DTM FS-01 Cast 15x6.5 14.8 6.71316752
DTM FS-02 Cast 15x6.5 14.7 6.66780828
DTM FS-02 Cast 17x7 21 9.5254404
Ducatro Daytona Cast/Spun 15x6.5 14.8 6.71316752
Duralight Cast 17x10 18 8.1646632
Dymag Motorsport Cast Mg 15x6 10.8 4.89879792
Dymag Motorsport Cast Mg 16x7 13 5.8967012
Dymag Motorsport Forged Mg/Carbon Fiber 17x8 12.9 5.85134196
Dymag Motorsport Forged Mg/Carbon Fiber 18x10.5 15.9 7.21211916
Dymag Motorsport Forged Mg/Carbon Fiber 18x9 14 6.3502936
Dymag Motorsport Forged Mg/Carbon Fiber 20x12 18.2 8.25538168
Dymag Motorsport (Mosler MT900) Forged Mg/Carbon Fiber 19x10 14 6.3502936
Dymag Motorsport (Mosler MT900) Forged Mg/Carbon Fiber 20x12.5 17.5 7.937867
Elite 726 Rockport Cast 16x7 20 9.071848
Elite Barb Cast 18x7 28.4 12.88202416
Elite Indis Cast 20x8.5 36.5 16.5561226
EMO 502 (Ozone) Cast 15x7 22 9.9790328
EMO 702 (Obelix) Cast 15x7 20.6 9.34400344
EMPI 5-spoke Cast 15x5.5 20 9.071848
Enkei 5+ Cast 17x7 19 8.6182556
Enkei Aegis Cast 17x7 20.7 9.38936268
Enkei Aegis Cast 17x8 21.9 9.93367356
Enkei Aegis Cast 17x9 22.1 10.02439204
Enkei Aegis Cast 18x10 24.3 11.02229532
Enkei Aegis Cast 18x8 23.1 10.47798444
Enkei Aegis Cast 18x8.5 23.3 10.56870292
Enkei Aegis Cast 18x9.5 23.7 10.75013988
Enkei Aegis Cast 19x8.5 24.8 11.24909152
Enkei Aegis Cast 19x9.5 24.9 11.29445076
Enkei Aka Cast 17x7.5 28.2 12.79130568
Enkei Aka Cast 18x7.5 30 13.607772
Enkei Aka Cast 20x8.5 37.4 16.96435576
Enkei Arashi Cast 17x7 19 8.6182556
Enkei C.R.A.N.K. Cast 17x7.5 27.1 12.29235404
Enkei CDR9 Cast 15x6.5 16.7 7.57499308
Enkei CDR9 Cast 16x7 18.9 8.57289636
Enkei CDR9 Cast 17x7 21.6 9.79759584
Enkei CDR9 Cast 18x7 23.1 10.47798444
Enkei CTM-3 Cast 15x10 28.3 12.83666492
Enkei CTM-3 Cast 15x8 24.6 11.15837304
Enkei CTM-3 Cast 16x8 27.1 12.29235404
Enkei CTM-4 Cast 16x8 28.4 12.88202416
Enkei CTM-5 Cast 15x10 25 11.33981
Enkei CTM-5 Cast 15x8 24 10.8862176
Enkei CTM-5 Cast 16x8 24.5 11.1130138
Enkei DM-5 Cast 16x7 17.4 7.89250776
Enkei Duji Cast 17x7 23 10.4326252
Enkei EM5 Cast 17x7 21.5 9.7522366
Enkei EM5 Cast 18x7.5 23.5 10.6594214
Enkei ERO-1 Cast 15x7 17.2 7.80178928
Enkei ERO-1 Cast 16x7 18 8.1646632
Enkei ES6 Cast 16x7 19.5 8.8450518
Enkei ES6 Cast 17x7 21 9.5254404
Enkei ES6 Cast 18x7.5 23 10.4326252
Enkei ES-Gravel Cast 14x6 12.9 5.85134196
Enkei ES-Tarmac Cast 14x6 8.7 3.94625388
Enkei ES-Tarmac Cast 14x6.5 8.9 4.03697236
Enkei ES-Tarmac Cast 15x6.5 10.7 4.85343868
Enkei ES-Tarmac Cast 15x7 11 4.9895164
Enkei ES-Tarmac Cast 15x7.5 11.6 5.26167184
Enkei ES-Tarmac Cast 16x7 13.7 6.21421588
Enkei ES-Tarmac Cast 16x7.5 14.3 6.48637132
Enkei ES-Tarmac Cast 17x7.5 14.8 6.71316752
Enkei Etoria Cast 15x6 17 7.7110708
Enkei EUM5 Cast 15x6.5 16 7.2574784
Enkei EUM5 Cast 16x7 18 8.1646632
Enkei EVO 5 Cast 17x7 18.5 8.3914594
Enkei EVO 5 Cast 18x7.5 20.5 9.2986442
Enkei EVO 6 Cast 17x7 18.5 8.3914594
Enkei EVO 6 Cast 18x7.5 20.5 9.2986442
Enkei Exocent Cast 19x9.5 31 14.0613644
Enkei Fubuki Cast 17x7 23.2 10.52334368
Enkei Gattling Cast 18x10 27 12.2469948
Enkei GTC01 Cast 17x7 17.5 7.937867
Enkei GTC01 Cast 17x8 18 8.1646632
Enkei GTC01 Cast 18x8 20 9.071848
Enkei GTC01 Cast 18x8.5 21 9.5254404
Enkei GTV Cast 18x8 24.3 11.02229532
Enkei Inazuma Cast 17x7 21.7 9.84295508
Enkei J10 Cast 17x7 21 9.5254404
Enkei JS M Cast 15x6.5 12.1 5.48846804
Enkei JS M Cast 17x7.5 15.4 6.98532296
Enkei J-Speed III Cast/Spun 14x5 11 4.9895164
Enkei J-Speed III Cast/Spun 14x6 11.2 5.08023488
Enkei J-Speed III Cast/Spun 14x6.5 11.5 5.2163126
Enkei J-Speed III Cast/Spun 14x7 11.7 5.30703108
Enkei J-Speed III Cast/Spun 15x6 12.6 5.71526424
Enkei J-Speed III Cast/Spun 15x6.5 12.8 5.80598272
Enkei J-Speed III Cast/Spun 15x7 13.2 5.98741968
Enkei J-Speed III Cast/Spun 15x7.5 13.4 6.07813816
Enkei J-Speed III Cast/Spun 16x7 15 6.803886
Enkei J-Speed III Cast/Spun 16x7.5 15.4 6.98532296
Enkei J-Speed III Cast/Spun 16x8 16.1 7.30283764
Enkei Kriminal Cast 23x10 60 27.215544
Enkei LF-10 Cast 18x7.5 26 11.7934024
Enkei Liberty Cast 17x9 32.8 14.87783072
Enkei Liberty Cast 18x9 33.6 15.24070464
Enkei LS-5 Cast 18x7.5 25 11.33981
Enkei NP03 Cast 16x7 17.6 7.98322624
Enkei NP03 Cast 18x7 19.3 8.75433332
Enkei NT03 M Cast 17x7.5 17.4 7.89250776
Enkei NT03 M Cast 17x8 18.9 8.57289636
Enkei NT03 M Cast 17x9.5 20.1 9.11720724
Enkei NT03 M Cast 18x10 20.5 9.2986442
Enkei NT03 M Cast 18x10.5 21 9.5254404
Enkei NT03 M Cast 18x7.5 18.5 8.3914594
Enkei NT03 M Cast 18x8 19.4 8.79969256
Enkei NT03 M Cast 18x8.5 19.6 8.89041104
Enkei NT03 M Cast 18x9.5 19.9 9.02648876
Enkei OR52 Cast 16x7 16 7.2574784
Enkei OR52 Cast 17x7 18 8.1646632
Enkei OR52 Cast 18x7.5 20.5 9.2986442
Enkei OR52 Cast 18x8.5 21 9.5254404
Enkei Phalenx Cast 17x7 21.9 9.93367356
Enkei Phalenx Cast 17x8 23 10.4326252
Enkei Phalenx Cast 17x9 23.3 10.56870292
Enkei Phalenx Cast 18x10 26.2 11.88412088
Enkei Phalenx Cast 18x7 23.1 10.47798444
Enkei Phalenx Cast 18x8 23.8 10.79549912
Enkei Phalenx Cast 18x9 24.2 10.97693608
Enkei Phalenx Cast 19x10 29.6 13.42633504
Enkei Phalenx Cast 19x8.5 28.5 12.9273834
Enkei RC5 Cast 17x7 18 8.1646632
Enkei RC5 Cast 18x9 19.5 8.8450518
Enkei RCT-1 Cast 15x7 14.5 6.5770898
Enkei RCT-1 Cast 16x7 16.7 7.57499308
Enkei RCT-1 Cast 17x7 17.8 8.07394472
Enkei RCT-4 Cast 18x9 19.6 8.89041104
Enkei RF1 Cast 16x7 16.5 7.4842746
Enkei RF-1 Cast 15x7 15.9 7.21211916
Enkei RF-1 Cast 16x7 16.5 7.4842746
Enkei RF-1 Cast 17x7 18.1 8.21002244
Enkei RMR Cast 17x7.5 20 9.071848
Enkei RP-F1 Cast 19x8.5 19.9 9.02648876
Enkei RP-F1 Cast 15x7 9.8 4.44520552
Enkei RP-F1 Cast 16x7 13.5 6.1234974
Enkei RP-F1 Cast 16x8 14.9 6.75852676
Enkei RP-F1 Cast 17x10 17 7.7110708
Enkei RP-F1 Cast 17x7 15 6.803886
Enkei RP-F1 Cast 17x7.5 15.3 6.93996372
Enkei RP-F1 Cast 17x8 15.6 7.07604144
Enkei RP-F1 Cast 17x8.5 15.8 7.16675992
Enkei RP-F1 Cast 17x9 16 7.2574784
Enkei RP-F1 Cast 17x9.5 16.5 7.4842746
Enkei RP-F1 Cast 18x7.5 17 7.7110708
Enkei RP-F1 Cast 18x8 17.8 8.07394472
Enkei RP-F1 Cast 18x8.5 18.3 8.30074092
Enkei RP-F1 Cast 18x9.5 17.2 7.80178928
Enkei RP-F1 Cast 19x10 20.7 9.38936268
Enkei RP-F1 Cast 19x8 18.7 8.48217788
Enkei RP-F1 Cast 19x9.5 19.6 8.89041104
Enkei RP-F1 RC Cast/Spun 18x10 23.6 10.70478064
Enkei RP-F1 RC Cast/Spun 18x8.5 22 9.9790328
Enkei RP-F1 RC Cast/Spun 18x9 22.9 10.38726596
Enkei RP-F1 RC Cast/Spun 18x9.5 22.7 10.29654748
Enkei RP-F1 RC Cast/Spun 19x10 25.4 11.52124696
Enkei RP-F1 RC Cast/Spun 19x9 24.7 11.20373228
Enkei RPM-2 Cast 17x7 16.9 7.66571156
Enkei RPM-2 Cast 17x8 17.4 7.89250776
Enkei RPM-2 Cast 17x9 18.7 8.48217788
Enkei RPM-2 Cast 18x7.5 18.9 8.57289636
Enkei RPM-2 Cast 18x8 19.4 8.79969256
Enkei RPM-2 Cast 18x9 21.1 9.57079964
Enkei RPO-1 Cast 15x7 14.3 6.48637132
Enkei RPO-1 Cast 16x6.5 14.5 6.5770898
Enkei RPO-1 Cast 16x7 15.8 7.16675992
Enkei RPO-1 Cast 17x7 17.6 7.98322624
Enkei RPO-1 Cast 17x7.5 18 8.1646632
Enkei RPO-1 Cast 17x8 18.2 8.25538168
Enkei RPO-1 Cast 17x9 20 9.071848
Enkei RPO-1 Cast 18x8.5 20.7 9.38936268
Enkei RPO-1 Cast 18x9 21.3 9.66151812
Enkei RPO-1 Cast 18x9.5 23.4 10.61406216
Enkei RPO-2 Cast 15x5 14.1 6.39565284
Enkei RPO-2 Cast 15x7 15.2 6.89460448
Enkei RPO-2 Cast 16x7 17 7.7110708
Enkei RPO-2 Cast 16x8 17.5 7.937867
Enkei RPO-2 Cast 17x7 18.5 8.3914594
Enkei RPO-2 Cast 17x7.5 19.1 8.66361484
Enkei RPO-2 Cast 17x8 19.8 8.98112952
Enkei RPO-2 Cast 17x9 20.3 9.20792572
Enkei RPO-2 Cast 18x7.5 20.8 9.43472192
Enkei RPO-2 Cast 18x8 21.3 9.66151812
Enkei RPO-2 Cast 18x9 21.9 9.93367356
Enkei RPO-2J Cast 15x7 13 5.8967012
Enkei RPO-3 Cast 17x10 21.4 9.70687736
Enkei RPO-3 Cast 17x7 16.8 7.62035232
Enkei RPO-3 Cast 17x8 17.5 7.937867
Enkei RPO-3 Cast 17x8.5 19.1 8.66361484
Enkei RPO-3 Cast 17x9.5 19.6 8.89041104
Enkei RPO-3 Cast 18x10 21.5 9.7522366
Enkei RPO-3 Cast 18x7.5 19.2 8.70897408
Enkei RPO-3 Cast 18x8 20.2 9.16256648
Enkei RPO-3 Cast 18x8.5 20.9 9.48008116
Enkei RPO-3 Cast 18x9 21 9.5254404
Enkei RPO-3 Cast 18x9.5 21.3 9.66151812
Enkei RPO-3 Cast 19x10 23.1 10.47798444
Enkei RPO-3 Cast 19x8 20.5 9.2986442
Enkei RPO-3 Cast 19x8.5 20.6 9.34400344
Enkei RPO-3 Cast 19x9 21.8 9.88831432
Enkei RPO-3 Cast 19x9.5 22.2 10.06975128
Enkei RPO-3 RC Cast 18x8.5 21.5 9.7522366
Enkei RPO-5 Cast 17x7 20 9.071848
Enkei RPO-5 Cast 17x8 21 9.5254404
Enkei RPO-5 Cast 18x7 21.8 9.88831432
Enkei RPO-5 Cast 18x8 22.1 10.02439204
Enkei RPO-7 Cast 18x7 20 9.071848
Enkei RPO-7 Cast 19x7.5 21 9.5254404
Enkei RPOM Cast 17x7 19.5 8.8450518
Enkei RPOM Cast 18x7 21 9.5254404
Enkei RS Evolution Cast 16x7 17 7.7110708
Enkei RS Evolution Cast 17x7 19.4 8.79969256
Enkei RS+M Cast 15x5 11.7 5.30703108
Enkei RS+M Cast 15x6.5 14 6.3502936
Enkei RS+M Cast 15x7 14.8 6.71316752
Enkei RS+M Cast 16x7 14.8 6.71316752
Enkei RS+M Cast 17x7 15.6 7.07604144
Enkei RS+M Cast 17x8 16.1 7.30283764
Enkei RS+M Cast 18x7.5 17.5 7.937867
Enkei RS+M Cast 18x8.5 19.3 8.75433332
Enkei RS-05 Cast 17x7 17.5 7.937867
Enkei RS-05 Cast 18x7.5 18.5 8.3914594
Enkei RS-05 Cast 18x8.5 19.5 8.8450518
Enkei RS-5 Cast 15x6.5 15.4 6.98532296
Enkei RS-5 Cast 16x7 17.6 7.98322624
Enkei RS-5 Cast 17x7 19.8 8.98112952
Enkei RS-5 Cast 18x7 21.6 9.79759584
Enkei RS-6 Cast 15x6.5 17.5 7.937867
Enkei RS-6 Cast 16x7 19.6 8.89041104
Enkei RS-6 Cast 17x7 20.2 9.16256648
Enkei RS-6 Cast 18x7 23.3 10.56870292
Enkei RS-7 Cast 17x7 17.9 8.11930396
Enkei RS-E Cast 16x7 18.1 8.21002244
Enkei RS-E Cast 17x7 19.4 8.79969256
Enkei RS-E Cast 17x8 20 9.071848
Enkei RSF-2 Cast 15x6.5 16.3 7.39355612
Enkei RSF-2 Cast 16x7 18.1 8.21002244
Enkei RSF-2 Cast 17x7 19.8 8.98112952
Enkei RSF-2 Cast 18x7 21.8 9.88831432
Enkei RSV Cast 17x7 17.5 7.937867
Enkei RSV Cast 18x7.5 20 9.071848
Enkei RT6 Cast 17x8 24.6 11.15837304
Enkei RT6 Cast 18x8.5 26.1 11.83876164
Enkei RTO-1 Cast 16x7 16 7.2574784
Enkei RTS Cast 16x8 22.1 10.02439204
Enkei RTS Cast 17x8 23.9 10.84085836
Enkei RZ-5 Cast 15x6.5 16.5 7.4842746
Enkei RZ-5 Cast 16x7 20.5 9.2986442
Enkei RZ-5 Cast 17x7 22.5 10.205829
Enkei RZ-5 Cast 18x7.5 24.5 11.1130138
Enkei RZ-5 Cast 18x8.5 25.5 11.5666062
Enkei RZ-5 Cast 18x9.5 26 11.7934024
Enkei SC-03 Cast 16x7 19 8.6182556
Enkei SC-03 Cast 17x7 20.5 9.2986442
Enkei SC-05 Cast 17x7 20.5 9.2986442
Enkei SC-05 Cast 17x8 21.5 9.7522366
Enkei SC-05 Cast 18x7.5 23.5 10.6594214
Enkei SC-05 Cast 18x8 24.5 11.1130138
Enkei Shogun Cast 17x7 24.9 11.29445076
Enkei Shutoko Cast 17x7 23.7 10.75013988
Enkei Silverstar Cast 17x9 29.7 13.47169428
Enkei Silverstar Cast 18x9 30.6 13.87992744
Enkei SS6A Cast 15x6.5 15.8 7.16675992
Enkei Suzuka Cast 17x7 21.5 9.7522366
Enkei Tarmac Cast 18x8 27 12.2469948
Enkei Tarmac Cast 18x9.5 28 12.7005872
Enkei Tarmac Cast 19x8.5 29.5 13.3809758
Enkei Tarmac Cast 19x9.5 30 13.607772
Enkei Tatonka Cast 17x8 28.5 12.9273834
Enkei Tatonka Cast 18x9 30.3 13.74384972
Enkei TBS1 Cast 16x7 18.3 8.30074092
Enkei TBS1 Cast 17x7 20 9.071848
Enkei TBS11 Cast 16x7 18.3 8.30074092
Enkei TBS11 Cast 17x7 20 9.071848
Enkei Tuscarora Cast 16x8 26.7 12.11091708
Enkei Tuscarora Cast 17x8 28.4 12.88202416
Enkei Tuscarora Cast 18x9 32.5 14.741753
Enkei V-1 Cast 17x8 23.8 10.79549912
Enkei V-1 Cast 17x8.5 23.9 10.84085836
Enkei V-1 Cast 17x9 24.2 10.97693608
Enkei V-1 Cast 17x9.5 25 11.33981
Enkei V-1 Cast 18x10 27.4 12.42843176
Enkei V-1 Cast 18x8 26 11.7934024
Enkei V-1 Cast 18x8.5 26.6 12.06555784
Enkei V-1 Cast 18x9 26.7 12.11091708
Enkei V-1 Cast 18x9.5 27 12.2469948
Enkei Valor Cast 17x9 30 13.607772
Enkei Valor Cast 18x9 30.3 13.74384972
Enkei Valor Cast 20x9 33.8 15.33142312
Enkei Victory Cast 17x9 30 13.607772
Enkei Victory Cast 18x9 31.2 14.15208288
Enkei Victory Cast 20x9 33.9 15.37678236
Enkei WDM Cast 16x7 20 9.071848
Enkei WDM Cast 17x7 23.5 10.6594214
Enkei WDM Cast 18x7.5 26 11.7934024
Enkei Zenkei Cast 17x7 26 11.7934024
Enkei Zoku Cast 17x7 19.8 8.98112952
Enkei ZR1 Cast 17x7.5 18 8.1646632
Enkei ZR1 Cast 18x8 20.5 9.2986442
Enkei ZR2 Cast 17x7 19 8.6182556
Enkei ZR2 Cast 18x7.5 21.5 9.7522366
Enkei ZXC Cast 17x8.5 21.4 9.70687736
Enkei ZXC Cast 18x9 23.8 10.79549912
Enzo Cup Cast 17x8 28.8 13.06346112
Enzo M Cast 16x7.5 23.5 10.6594214
Enzo V Cast 16x7 22 9.9790328
Epic Laguna Cast 16x7.5 24.5 11.1130138
Epic Series 73 (Aero) Cast 17x7 26 11.7934024
Esses SpeedMaster SM-058 Cast 15x7 15.4 6.98532296
Falken Atlantic City Cast 20x8.5 33.2 15.05926768
Falken Atlantic City Cast 22x9 35.6 16.14788944
Falken Atlantic City Cast 23x10 40 18.143696
Falken Circuit Spec Cast 17x7 22.5 10.205829
Falken Circuit Spec Cast 18x7 26.5 12.0201986
Falken Circuit Spec Cast 19x7.5 26 11.7934024
Falken Circuit Spec Cast 19x8 27.5 12.473791
Falken Explicit Cast 17x7.5 17 7.7110708
Falken Explicit Cast 18x7.5 19 8.6182556
Falken Explicit Cast 20x8.5 31 14.0613644
Falken Hanabi Cast 15x7 11.5 5.2163126
Falken Hanabi Cast 17x7.5 17 7.7110708
Falken Hanabi Cast 18x7.5 19 8.6182556
Falken Hanabi Cast 18x8.5 20 9.071848
Falken Koblenz Cast 18x8 25.1 11.38516924
Falken Koblenz Cast 18x9 26.6 12.06555784
Falken Koblenz Cast 19x10.5 32.5 14.741753
Falken Koblenz Cast 19x8.5 25.8 11.70268392
Falken Koblenz Cast 19x9.5 31.7 14.37887908
Falken Koblenz Cast 20x8.5 33.3 15.10462692
Falken Roid Cast 20x8.5 31.3 14.19744212
Falken Roid Cast 22x9.5 34.5 15.6489378
Falken Roid Cast 23x10 37.5 17.009715
Falken Spine Cast 20x8.5 28.8 13.06346112
Falken Spine Cast 22x9.5 36 16.3293264
Falken Spine Cast 23x10 37.7 17.10043348
Falken Torque 5 Cast 17x7 24 10.8862176
Falken Torque 5 Cast 18x7 25 11.33981
Falken Torque 5 Cast 18x8 26.8 12.15627632
Falken Torque 5 Cast 19x7.5 26.5 12.0201986
Falken Torque 5 Cast 19x8 28.5 12.9273834
Fast Wheels 13x5.5 14 6.3502936
Fast Wheels Techno Cast 17x7 18.5 8.3914594
Fikse ARO Forged/Spun 17x10 18.9 8.57289636
Fikse FM-10 Forged/Spun 17x10 18.5 8.3914594
Fikse FM-10 Forged/Spun 18x8 20.8 9.43472192
Fikse FM-10 Forged/Spun 18x9.5 20.9 9.48008116
Fikse FM-5 Forged/Spun 17x10 18.5 8.3914594
Fikse FM-5 Forged/Spun 17x8 16 7.2574784
Fikse FM-5 Forged/Spun 17x8.5 17.5 7.937867
Fikse FM-5 Forged/Spun 18x8.5 18 8.1646632
Fikse Mach 5 Forged/Spun 17x10 18.5 8.3914594
Final Speed Forged Forged 17x7.5 13 5.8967012
Fittipaldi 500 SS Cast 17x7 23.3 10.56870292
Fittipaldi 916 SP Cast 18x8 23.3 10.56870292
Fittipaldi Argus Cast 20x8.5 31 14.0613644
Fittipaldi AV3 Cast 17x8 27 12.2469948
Fittipaldi Avus Cast 17x8 27 12.2469948
Fittipaldi Fin Cast 18x8.5 29.4 13.33561656
Fittipaldi Flame Cast 17x7 20 9.071848
Fittipaldi Polaris Cast 17x8 28.5 12.9273834
Fittipaldi Tubolare Cast 18x8 33 14.9685492
Fittipaldi Vela Cast 18x8 23.3 10.56870292
Flik Apex Cast 15x6.5 11.9 5.39774956
Flik Apex Cast 16x7 15 6.803886
Flik Apex2 Cast 16x7 14.8 6.71316752
Flik Artic Cast 17x7 18 8.1646632
Flik Artic Cast 18x8.5 23 10.4326252
Flik Blast Cast 15x6.5 11.9 5.39774956
Flik Bullet Cast 15x6.5 12.5 5.669905
Flik Bullet Cast 17x7 17 7.7110708
Flik Ftd Cast 16x7 16 7.2574784
Flik Ftd Cast 17x7 17 7.7110708
Flik Ftd Cast 17x8.5 18.5 8.3914594
Flik Fuel Cast 15x6.5 12 5.4431088
Flik Fuel Cast 17x7 17 7.7110708
Flik Hornet Cast 16x7 16.5 7.4842746
Flik Hornet Cast 17x7 17 7.7110708
Flik Hornet Cast 17x8 18 8.1646632
Flik Hornet Cast 18x8 20 9.071848
Flik Justice Cast 17x8 22 9.9790328
Flik Justice Cast 18x8 25 11.33981
Flik Lex Cast 17x7 18 8.1646632
Flik Lex Cast 17x8 19 8.6182556
Flik Lex Cast 18x8 22 9.9790328
Flik Titan Cast 17x7 18 8.1646632
Flik Wasp Cast 17x7 19 8.6182556
Flik Wasp Cast 18x7.5 22 9.9790328
Focal F1 (Type 173) Cast 18x7 25.6 11.61196544
Focal F10 Cast 18x7 26.3 11.92948012
Focal F5 (Type 165) Cast 17x7 23.5 10.6594214
Focal F5 (Type 165) Cast 18x7 25.8 11.70268392
Focal F7 (Type 168) Cast 18x7 24.3 11.02229532
Focal G7 Cast 18x7 27.3 12.38307252
Focal R3 Cast 18x7 26.3 11.92948012
Focal SD5 Cast 18x7 26 11.7934024
Fondmetal Tech 4 Cast 18x8 27.8 12.60986872
Fondmetal Type 5700 Cast 15x7 16.8 7.62035232
Fondmetal Type 6500 Cast 17x7 24 10.8862176
Fondmetal Type 6700 Cast 16x7 22.2 10.06975128
Fondmetal Type 6800 Cast 16x7 22.6 10.25118824
Fondmetal Type 9a Cast 17x7 24.6 11.15837304
Ford Cobra 03-04 Cast 17x9 25 11.33981
Ford Focus ZTS and Wagon Cast 15x6 15.2 6.89460448
Ford Focus ZX3 Cast 16x6 19.1 8.66361484
Ford Mustang - Roush (made by Prime) Cast 17x8 26.5 12.0201986
Ford Taurus SHO Cast 16x6.5 18.8 8.52753712
Forgeline LS Forged/Spun 17x8 19.5 8.8450518
Forgeline LS Forged/Spun 17x9.5 18.5 8.3914594
Forgeline RS Forged/Spun (brittle) 16x8 17.2 7.80178928
Forgeline RS Forged/Spun (brittle) 17x9.5 18.5 8.3914594
Forgeline RS Forged/Spun (brittle) 18x9.5 22.5 10.205829
Forge-Tec FT15 Forged 20x8.5 24 10.8862176
Formula F1 (TE-37 copy) Cast 15x6.5 13.5 6.1234974
Formula F1 (TE-37 copy) Cast 16x7 15.5 7.0306822
Formula F1 (TE-37 copy) Cast 17x7 18.5 8.3914594
Formula F1 (TE-37 copy) Cast 18x7 19.5 8.8450518
G.MAX M078 Cast 18x7.5 21 9.5254404
G.MAX M078 Cast 18x8.5 22 9.9790328
GAB Sports Cast 16x7 15 6.803886
GAB Sports Cast 16x8 16.3 7.39355612
G-games 77w Cast 17x7 18 8.1646632
G-games Sidewinder 1-piece Cast 18x7.5 21 9.5254404
Gianelle 5 (Twin) Cast 18x7.5 24.2 10.97693608
Gianelle 6 (Oval) Cast 18x8.5 27.2 12.33771328
Giovanna Akita Cast 18x7.5 20 9.071848
Giovanna Anzio Cast 18x7.5 22.8 10.34190672
Giovanna Anzio Cast 22x9.5 37 16.7829188
Giovanna Barletta Cast 20x8.5 46 20.8652504
Giovanna Berlin Cast 20x10 42 19.0508808
Giovanna Boizano Cast 20x8.5 37 16.7829188
Giovanna Chiba Cast 18x7.5 24.5 11.1130138
Giovanna Kobe Cast 18x7.5 24.3 11.02229532
Giovanna Kuji Cast 18x7.5 26.3 11.92948012
Giovanna Kyoto Cast 18x7.5 25 11.33981
Giovanna Mito Cast 18x7.5 22.6 10.25118824
Giovanna Nagano Cast 18x7.5 23 10.4326252
Giovanna Rio Cast 18x8.5 29.5 13.3809758
Giovanna Suzu Cast 15x6.5 12.5 5.669905
GMC Syclone/Typhoon (Front) Cast/Spun 16x8 21.2 9.61615888
GMC Syclone/Typhoon (Rear) Cast/Spun 16x8 21.8 9.88831432
Gram Lights 57C Cast 15x7 13.5 6.1234974
Gram Lights 57C Cast 16x7 15.4 6.98532296
Gram Lights 57C Cast 17x7.5 18 8.1646632
Gram Lights 57F Forged 17x7.5 15 6.803886
Gram Lights 57F Forged 18x8.5 20 9.071848
Gram Lights 57Maximum Cast 15x6.5 13 5.8967012
Gram Lights 57Maximum Cast 16x7 15 6.803886
Gram Lights 57Maximum Cast 17x7 17.5 7.937867
Gram Lights 57Maximum Cast 18x7.5 20.3 9.20792572
Gram Lights 57Optomize Cast 16x6.5 15.5 7.0306822
Gram Lights 57Optomize Cast 17x7.5 17.5 7.937867
Gram Lights 57Optomize Cast 18x7.5 19.3 8.75433332
Gram Lights 57Pro Cast 15x7.5 16.8 7.62035232
Gram Lights 57Pro Cast 17x7 19.5 8.8450518
Gram Lights 57S Cast 16x7 16 7.2574784
Gram Lights 57S Cast 17x7.5 17.5 7.937867
Gram Lights 57S Cast 18x7.5 19.5 8.8450518
Gram Lights 57S Cast 18x8.5 20 9.071848
Gram Lights T57-RC Cast 17x7 18.5 8.3914594
Gram Lights T57-RC Cast 17x8 20 9.071848
Gram Lights T57-RC Cast 18x7.5 20 9.071848
Hamann Magnesium Forged 19x8.5 18 8.1646632
Hart Sport Diablo Cast 17x10 21 9.5254404
Hart Sport Mirage Cast 17x10 21 9.5254404
Hart Sport Odyssey Cast 17x10 21 9.5254404
Hartge Classic Cast 19x8 24 10.8862176
Hartge Classic Cast 19x9 26 11.7934024
Hartge Classic Cast 19x9.5 30 13.607772
Hartge Design-E Forged/Spun 17x7.5 18.8 8.52753712
Hartge Design-E Forged/Spun 17x8.5 19.8 8.98112952
Hartge Nova 3 Cast 18x8.5 25 11.33981
Hartge Nova 5 Cast 19x9.5 31 14.0613644
Hayashi Street Fin Cast 14x8 9.4 4.26376856
Hayashi Street Wheel Type STF Cast 15x6.5 13.2 5.98741968
Hayashi Street Wheel Type STF Cast 15x7 13.9 6.30493436
Hickock Sprint Forged 18x11 18 8.1646632
Hickock Sprint Forged 18x9.5 17 7.7110708
Hokuto Racing Miyabi Cast 17x7 21.5 9.7522366
Honda Accord Steel 15x6.5 17.7 8.02858548
Honda Accord Type R (Euro) Cast 17x7 21.8 9.88831432
Honda Civic Steel 15x6 20.2 9.16256648
Honda Civic 88-91 Steel 13x5 16 7.2574784
Honda Civic EX 06-07 Cast 16x6.5 19.5 8.8450518
Honda Civic EX/Si 92+ Cast 14x5 18 8.1646632
Honda Civic HX 96-97 Cast 14x5.5 11.75 5.3297107
Honda Civic Si 02-04 Cast 15x6 22.2 10.06975128
Honda Civic Si 05+ HFP Cast 17x7 20 9.071848
Honda Civic Si 99-00 Cast 15x6 18 8.1646632
Honda Civic Type R 02 Cast 17x7 20.2 9.16256648
Honda Civic Vi-RS 99-00 Cast 15x6.5 16.8 7.62035232
Honda Civic VX Cast 13x5 9.7 4.39984628
Honda CRX Si 86-87 Cast 14x5 15.4 6.98532296
Honda CRX Si 90 Cast 14x5 16 7.2574784
Honda Del Sol 97 ""Fat 5"" Cast 14x5.5 15 6.803886
Honda Prelude 97-99 Cast 16x6.5 19 8.6182556
Honda Prelude 97-99 SH Cast 16x6.5 19.7 8.93577028
Honda Prelude VTEC 93 Cast 15x6.5 22.5 10.205829
Honda Prelude VTEC/Si 95-96 Cast 15x6.5 17 7.7110708
Honda S2000 Cast 16x6.5 17.5 7.937867
Honda S2000 Cast 16x7.5 18.6 8.43681864
Honda S2000 04+ Cast 17x7 17.6 7.98322624
Honda S2000 04+ Cast 17x8.5 20.5 9.2986442
Honda S2000 JDM (BBS) Forged 16x6.5 13.3 6.03277892
Honda S2000 JDM (BBS) Forged 16x7.5 14.3 6.48637132
HP Racing Avalanche Cast 17x7.5 23 10.4326252
HP Racing Flight Cast 18x8 22 9.9790328
HP Racing Fusion Cast 17x7 21.2 9.61615888
HP Racing Hurricane Cast 17x7 18.5 8.3914594
HP Racing Lightning Cast 17x7 19.8 8.98112952
HP Racing Shadow Cast 18x8 25 11.33981
HP Racing Vortex Cast 18x7.5 25.8 11.70268392
HRE 445 Forged/Spun 18x10 20.4 9.25328496
HRE 447 Forged/Spun 18x10 25.3 11.47588772
HRE 504 Forged/Spun 17x11 19.5 8.8450518
HRE 504 Forged/Spun 17x9.5 18 8.1646632
HRE 504 Forged/Spun 18x7.5 16.5 7.4842746
HRE 535 Forged/Spun 17x10 22 9.9790328
HRE 540 Forged/Spun 17x10 24 10.8862176
HRE 540 Forged/Spun 17x8.5 23 10.4326252
HRE 540 Forged/Spun 18x10 26 11.7934024
HRE 545 Forged/Spun 17x10 25 11.33981
HRE 545 Forged/Spun 18x10 27 12.2469948
HRE 546 Forged/Spun 18x8.5 20 9.071848
HRE 546 Forged/Spun 20x9 27 12.2469948
HRE 547 Forged/Spun 17x10 23 10.4326252
HRE 547 Forged/Spun 18x10 23 10.4326252
HRE 835 Forged/Spun 17x10 18 8.1646632
HRE C21 Forged 19x8.5 18.8 8.52753712
HRE C21 Forged 19x9.5 19.8 8.98112952
IFG A5 Forged 17x8 18.5 8.3914594
IFG A5 Forged 17x9 20 9.071848
iForged Aero Forged 19x10 25 11.33981
iForged Aero Forged 19x10.5 26 11.7934024
iForged Aero Forged 19x11 27 12.2469948
iForged Aero Forged 19x7.5 22 9.9790328
iForged Aero Forged 19x8 22 9.9790328
iForged Aero Forged 19x8.5 23 10.4326252
iForged Aero Forged 19x9 24 10.8862176
iForged Aero Forged 19x9.5 24 10.8862176
iForged Aero Forged 20x10 27 12.2469948
iForged Aero Forged 20x8 25 11.33981
iForged Aero Forged 20x8.5 25 11.33981
iForged Aero Forged 20x9 26 11.7934024
iForged Aero Forged 22x10 35 15.875734
iForged Aero Forged 22x9.5 30 13.607772
iForged Evolution Forged 19x10 25 11.33981
iForged Evolution Forged 19x10.5 26 11.7934024
iForged Evolution Forged 19x11 27 12.2469948
iForged Evolution Forged 19x7.5 22 9.9790328
iForged Evolution Forged 19x8 22 9.9790328
iForged Evolution Forged 19x8.5 23 10.4326252
iForged Evolution Forged 19x9 24 10.8862176
iForged Evolution Forged 19x9.5 24 10.8862176
iForged Evolution Forged 20x10 27 12.2469948
iForged Evolution Forged 20x8 25 11.33981
iForged Evolution Forged 20x8.5 25 11.33981
iForged Evolution Forged 20x9 26 11.7934024
iForged Evolution Forged 22x10 35 15.875734
iForged Evolution Forged 22x9.5 30 13.607772
iForged Flux Forged 19x10 25 11.33981
iForged Flux Forged 19x10.5 26 11.7934024
iForged Flux Forged 19x11 27 12.2469948
iForged Flux Forged 19x7.5 22 9.9790328
iForged Flux Forged 19x8 22 9.9790328
iForged Flux Forged 19x8.5 23 10.4326252
iForged Flux Forged 19x9 24 10.8862176
iForged Flux Forged 19x9.5 24 10.8862176
iForged Flux Forged 20x10 27 12.2469948
iForged Flux Forged 20x8 25 11.33981
iForged Flux Forged 20x8.5 25 11.33981
iForged Flux Forged 20x9 26 11.7934024
iForged Flux Forged 22x10 35 15.875734
iForged Flux Forged 22x9.5 30 13.607772
iForged Marquis Forged 19x10 25 11.33981
iForged Marquis Forged 19x10.5 26 11.7934024
iForged Marquis Forged 19x11 27 12.2469948
iForged Marquis Forged 19x7.5 22 9.9790328
iForged Marquis Forged 19x8 22 9.9790328
iForged Marquis Forged 19x8.5 23 10.4326252
iForged Marquis Forged 19x9 24 10.8862176
iForged Marquis Forged 19x9.5 24 10.8862176
iForged Marquis Forged 20x10 27 12.2469948
iForged Marquis Forged 20x8 25 11.33981
iForged Marquis Forged 20x8.5 25 11.33981
iForged Marquis Forged 20x9 26 11.7934024
iForged Marquis Forged 22x10 35 15.875734
iForged Marquis Forged 22x9.5 30 13.607772
iForged Retro Forged 19x10 25 11.33981
iForged Retro Forged 19x10.5 26 11.7934024
iForged Retro Forged 19x11 27 12.2469948
iForged Retro Forged 19x7.5 22 9.9790328
iForged Retro Forged 19x8 22 9.9790328
iForged Retro Forged 19x8.5 23 10.4326252
iForged Retro Forged 19x9 24 10.8862176
iForged Retro Forged 19x9.5 24 10.8862176
iForged Retro Forged 20x10 27 12.2469948
iForged Retro Forged 20x8 25 11.33981
iForged Retro Forged 20x8.5 25 11.33981
iForged Retro Forged 20x9 26 11.7934024
iForged Retro Forged 22x10 35 15.875734
iForged Retro Forged 22x9.5 30 13.607772
iForged Rev Forged 19x10 25 11.33981
iForged Rev Forged 19x10.5 26 11.7934024
iForged Rev Forged 19x11 27 12.2469948
iForged Rev Forged 19x7.5 22 9.9790328
iForged Rev Forged 19x8 22 9.9790328
iForged Rev Forged 19x8.5 23 10.4326252
iForged Rev Forged 19x9 24 10.8862176
iForged Rev Forged 19x9.5 24 10.8862176
iForged Rev Forged 20x10 27 12.2469948
iForged Rev Forged 20x8 25 11.33981
iForged Rev Forged 20x8.5 25 11.33981
iForged Rev Forged 20x9 26 11.7934024
iForged Rev Forged 22x10 35 15.875734
iForged Rev Forged 22x9.5 30 13.607772
iForged Seneka Forged 19x10 25 11.33981
iForged Seneka Forged 19x10.5 26 11.7934024
iForged Seneka Forged 19x11 27 12.2469948
iForged Seneka Forged 19x7.5 22 9.9790328
iForged Seneka Forged 19x8 22 9.9790328
iForged Seneka Forged 19x8.5 23 10.4326252
iForged Seneka Forged 19x9 24 10.8862176
iForged Seneka Forged 19x9.5 24 10.8862176
iForged Seneka Forged 20x10 27 12.2469948
iForged Seneka Forged 20x8 25 11.33981
iForged Seneka Forged 20x8.5 25 11.33981
iForged Seneka Forged 20x9 26 11.7934024
iForged Seneka Forged 22x10 35 15.875734
iForged Seneka Forged 22x9.5 30 13.607772
iForged Sprint Forged 19x10 25 11.33981
iForged Sprint Forged 19x10.5 26 11.7934024
iForged Sprint Forged 19x11 27 12.2469948
iForged Sprint Forged 19x7.5 22 9.9790328
iForged Sprint Forged 19x8 22 9.9790328
iForged Sprint Forged 19x8.5 23 10.4326252
iForged Sprint Forged 19x9 24 10.8862176
iForged Sprint Forged 19x9.5 24 10.8862176
iForged Sprint Forged 20x10 27 12.2469948
iForged Sprint Forged 20x8 25 11.33981
iForged Sprint Forged 20x8.5 25 11.33981
iForged Sprint Forged 20x9 26 11.7934024
iForged Sprint Forged 22x10 35 15.875734
iForged Sprint Forged 22x9.5 30 13.607772
iForged Swift Forged 19x10 25 11.33981
iForged Swift Forged 19x10.5 26 11.7934024
iForged Swift Forged 19x11 27 12.2469948
iForged Swift Forged 19x7.5 22 9.9790328
iForged Swift Forged 19x8 22 9.9790328
iForged Swift Forged 19x8.5 23 10.4326252
iForged Swift Forged 19x9 24 10.8862176
iForged Swift Forged 19x9.5 24 10.8862176
iForged Swift Forged 20x10 27 12.2469948
iForged Swift Forged 20x8 25 11.33981
iForged Swift Forged 20x8.5 25 11.33981
iForged Swift Forged 20x9 26 11.7934024
iForged Swift Forged 22x10 35 15.875734
iForged Swift Forged 22x9.5 30 13.607772
iForged Technik Forged 19x10 25 11.33981
iForged Technik Forged 19x10.5 26 11.7934024
iForged Technik Forged 19x11 27 12.2469948
iForged Technik Forged 19x7.5 22 9.9790328
iForged Technik Forged 19x8 22 9.9790328
iForged Technik Forged 19x8.5 23 10.4326252
iForged Technik Forged 19x9 24 10.8862176
iForged Technik Forged 19x9.5 24 10.8862176
iForged Technik Forged 20x10 27 12.2469948
iForged Technik Forged 20x8 25 11.33981
iForged Technik Forged 20x8.5 25 11.33981
iForged Technik Forged 20x9 26 11.7934024
iForged Technik Forged 22x10 35 15.875734
iForged Technik Forged 22x9.5 30 13.607772
Import Development Forged 19x10 21 9.5254404
Import Development Forged 19x8 19.5 8.8450518
Import Development Forged 19x8.5 20 9.071848
Impul NS-01R Forged 17x7.5 14.5 6.5770898
Infinity G20 91-97 Cast 14x6 15 6.803886
Infinity M30 90-92 Cast 15x6.5 17 7.7110708
InterMilano RG6 Cast 15x6.5 12 5.4431088
InterMilano RG6 Cast 16x7 16.5 7.4842746
Isuzu Impulse Stylus/Geo Storm 90-93 Stamped Steel 14x5.5 16 7.2574784
Isuzu Impulse Stylus/Geo Storm 90-93 Cast 14x5.5 14 6.3502936
Isuzu Impulse Stylus/Geo Storm 90-93 Cast 15x6 17.4 7.89250776
Jax Light Cast 15x6.5 12.9 5.85134196
Joustmeister Forged 17x7 13 5.8967012
J's Racing PR 6 Forged Mg 17x7.5 13.2 5.98741968
J's Racing PR 6 Forged Mg 17x8.5 13.6 6.16885664
KAD F1 Forged Mg 6x10 4.7 2.13188428
KAD F1 Forged Mg 7x10 5.5 2.4947582
Katana Belajeo Cast 18x7.5 26 11.7934024
Katana Berlini Cast 18x8 26.7 12.11091708
Katana Concept Six Cast 18x7.5 24 10.8862176
Katana Ducati Cast 18x7.5 25 11.33981
Kazera KZ-A Cast 17x7.5 20 9.071848
Kazera KZ-A Cast 18x7.5 22 9.9790328
Kazera KZ-A Cast 18x8.5 23.8 10.79549912
Kazera KZ-A Dual Cast 18x7.5 21.2 9.61615888
Kazera KZ-B Cast 17x7.5 22 9.9790328
Kazera KZ-B Cast 18x7.5 22.5 10.205829
Kazera KZ-C Cast 17x7.5 27.2 12.33771328
Kazera KZ-C Cast 18x7.5 28.2 12.79130568
Kazera KZ-C Cast 19x7.5 30 13.607772
Kazera KZ-F Cast 18x8 24.5 11.1130138
Kazera KZ-L Cast 17x7.5 20.5 9.2986442
Kazera KZ-L Cast 18x8 21 9.5254404
Kazera KZ-R Cast 16x7 17.6 7.98322624
Kazera KZ-R Cast 17x7 18.6 8.43681864
Kazera KZ-R Cast 18x7 19.4 8.79969256
Kazera KZ-S Cast 16x7 18 8.1646632
Kazera KZ-S Cast 17x7 19.4 8.79969256
Kazera KZ-S Cast 18x7 20.5 9.2986442
Kazera KZ-S Cast 19x7.5 24.5 11.1130138
Kazera KZ-T Cast 17x7.5 20.1 9.11720724
Kazera KZ-T Cast 18x7.5 21.2 9.61615888
Kazera KZ-U Cast 16x7 18.5 8.3914594
Kazera KZ-U Cast 17x7 19 8.6182556
Kazera KZ-U Cast 18x7 19.5 8.8450518
Kazera KZ-V Cast 16x7 16.5 7.4842746
Kazera KZ-V Cast 17x7 17.5 7.937867
Kazera KZ-V Cast 18x7 18.8 8.52753712
Kei Racing Flight Cast 15x6.5 16 7.2574784
Kei Racing RSGT Cast 17x7 18.7 8.48217788
Kei Racing Velocity Cast 15x6.5 17.4 7.89250776
Keizer (racing only) Cast 13x8 7.8 3.53802072
Kid's Racing Cast 14x6 9.7 4.39984628
Kid's Racing Cast 15x6.5 10.6 4.80807944
Kinesis K20 Forged/Spun 17x10 20 9.071848
Kinesis K20 Forged/Spun 17x9 19.5 8.8450518
Kinesis K28 Forged/Spun 18x8.5 21.5 9.7522366
Kinesis K28 Forged/Spun 18x9.5 22.5 10.205829
Kinesis K5 Forged/Spun 17x10 18 8.1646632
Kinesis K5 Forged/Spun 17x8.5 17 7.7110708
Kinesis K58 Forged/Spun 18x10 24 10.8862176
Kinesis K58 Forged/Spun 18x8 23 10.4326252
Kinesis K58 Forged/Spun 18x9 23.5 10.6594214
Kinesis Supercup Forged/Spun 17x10 22 9.9790328
KMC Alf Cast 17x7 26 11.7934024
KMC Gear Cast 17x7 24.5 11.1130138
KMC Street Rebel Spyder Cast 17x7 21 9.5254404
KMC Suicide 320 Cast 18x7 20.6 9.34400344
KMC Tarantula Cast 17x7 23.5 10.6594214
KMC Wizdom Cast 18x7 24 10.8862176
KMS Superlight Forged 15x7 10.1 4.58128324
KMS Superlight Forged 16x8 11.9 5.39774956
Kodiak Racing Forged/Spun 16x7 14.5 6.5770898
Kodiak Racing Forged/Spun 17x8 15.4 6.98532296
Konig Absolute Cast 17x7 21.2 9.61615888
Konig Absolute Cast 18x7.5 22.8 10.34190672
Konig Antarres Cast 13x6 15.5 7.0306822
Konig Antarres Cast 16x7.5 21 9.5254404
Konig Appeal Cast 17x7 18.2 8.25538168
Konig Appeal Cast 17x8 20.4 9.25328496
Konig Appeal Cast 17x9.5 22.2 10.06975128
Konig Appeal Cast 18x8 22.2 10.06975128
Konig Appeal Cast 19x8.5 23.8 10.79549912
Konig Appeal Cast 20x8.5 26.3 11.92948012
Konig Arrive Cast 20x8.5 36.3 16.46540412
Konig Blatant Cast 18x8 22.6 10.25118824
Konig Britelite Cast 15x6.5 12 5.4431088
Konig Britelite Cast 15x7 12.5 5.669905
Konig Britelite Cast 16x7 15 6.803886
Konig Burner Cast 15x7 16 7.2574784
Konig Burner Cast 16x7 17.2 7.80178928
Konig Caffeine Cast 15x6.5 16.5 7.4842746
Konig Caffeine Cast 16x7 19 8.6182556
Konig Caffeine Cast 17x7 19.9 9.02648876
Konig Caffeine Cast 17x8 20.1 9.11720724
Konig Caffeine Cast 18x7.5 21.9 9.93367356
Konig Coastal Cast 20x8.5 35.2 15.96645248
Konig Coastal Cast 20x9.5 37.4 16.96435576
Konig Coastal Cast 22x9.5 38.72 17.56309773
Konig Cobra Cast 15x6.5 16 7.2574784
Konig Cobra Cast 16x7 19.5 8.8450518
Konig Cobra Cast 17x7.5 22 9.9790328
Konig Competition Cast 16x7 18.4 8.34610016
Konig Diva Cast 13x5.5 12.5 5.669905
Konig Diva Cast 14x6 13.2 5.98741968
Konig Diva Cast 15x6.5 15.8 7.16675992
Konig Diva Cast 17x7.5 19.5 8.8450518
Konig Diva Cast 18x7.5 22 9.9790328
Konig Drift Cast 17x7 20.2 9.16256648
Konig Drift Cast 18x8 22 9.9790328
Konig DTM Cast 17x7.5 21 9.5254404
Konig Elan Cast 16x7 18 8.1646632
Konig Elan Cast 17x7 20 9.071848
Konig Elan Cast 18x8 21 9.5254404
Konig Featherlite Cast 15x6.5 12.3 5.57918652
Konig Featherlite Cast 16x7 15 6.803886
Konig Featherlite Cast 17x7 17.2 7.80178928
Konig Five-O Cast 16x8 19.2 8.70897408
Konig Five-O Cast 17x8 20.1 9.11720724
Konig Flatline Cast 15x6.5 17.9 8.11930396
Konig Flatline Cast 16x7 19.8 8.98112952
Konig Flatline Cast 17x7 21.1 9.57079964
Konig Flatline Cast 18x7.5 22.6 10.25118824
Konig Flight Cast 15x6.5 17.4 7.89250776
Konig Flight Cast 16x7 18.4 8.34610016
Konig Flight Cast 17x8 20.1 9.11720724
Konig Flight Cast 17x9.5 27.3 12.38307252
Konig Flight Cast 18x7.5 23.5 10.6594214
Konig Flight Cast 18x8 24.9 11.29445076
Konig Freefall Cast 16x7 18.3 8.30074092
Konig Freefall Cast 17x7 20.9 9.48008116
Konig Freefall Cast 18x7.5 22.2 10.06975128
Konig Glide Cast 17x7 22.6 10.25118824
Konig Greenlight Cast 15x6.5 15.4 6.98532296
Konig GT-R Cast 15x6.5 16 7.2574784
Konig GT-R Cast 16x7 17.5 7.937867
Konig GT-R Cast 17x7 19.5 8.8450518
Konig Helium Cast 15x6.5 11.5 5.2163126
Konig Helium Cast 16x7 16.4 7.43891536
Konig Holes Cast 15x6.5 13.8 6.25957512
Konig Holes Cast 16x7 16.1 7.30283764
Konig Holes Cast 17x7 17.8 8.07394472
Konig Holes Cast 18x7.5 21.3 9.66151812
Konig Holes Cast 19x7.5 21.8 9.88831432
Konig Holes Cast 19x8 21.4 9.70687736
Konig Hurry Cast 15x6.5 13.6 6.16885664
Konig Imagine Cast 17x7 22.4 10.16046976
Konig Imagine Cast 18x7.5 25.3 11.47588772
Konig Imagine Cast 18x8.5 28.4 12.88202416
Konig Imagine Cast 19x8 27.5 12.473791
Konig Impact Cast 17x7.5 21 9.5254404
Konig Kilo Cast 15x6.5 11.5 5.2163126
Konig Kolors Cast 15x7 15 6.803886
Konig Kolors Cast 17x7 17.4 7.89250776
Konig LiveWire Cast 17x7 24.9 11.29445076
Konig LiveWire Cast 18x7.5 26.2 11.88412088
Konig Minuz Cast 15x6.5 11.8 5.35239032
Konig Monsoon Cast 15x6.5 16.4 7.43891536
Konig Monsoon Cast 16x7 19.5 8.8450518
Konig Monsoon Cast 17x7 21 9.5254404
Konig Monsoon Cast 17x8 22.6 10.25118824
Konig Monsoon Cast 17x9.5 24 10.8862176
Konig Monsoon Cast 18x7.5 26 11.7934024
Konig MP3 Cast 17x7.5 23.4 10.61406216
Konig MP3 Cast 18x7.5 24.9 11.29445076
Konig Network Cast 15x7 13.4 6.07813816
Konig Next Cast 15x7 14 6.3502936
Konig Next Cast 17x7 18.7 8.48217788
Konig Next Cast 18x7.5 20.7 9.38936268
Konig Next Cast 19x8 23.3 10.56870292
Konig Next Cast 19x9 25.1 11.38516924
Konig Nrn Cast 16x8 18.4 8.34610016
Konig Nrn Cast 17x8 21 9.5254404
Konig Octane Cast 16x7 19.1 8.66361484
Konig OpenRoad Cast 20x8.5 35.2 15.96645248
Konig OpenRoad Cast 20x9.5 35.2 15.96645248
Konig OpenRoad Cast 22x9.5 37 16.7829188
Konig Prophet Cast 17x7.5 22.5 10.205829
Konig Prophet Cast 18x7.5 22.7 10.29654748
Konig Prophet Cast 18x8 24.3 11.02229532
Konig Prophet Cast 19x8 24.5 11.1130138
Konig Prowler Cast 16x7 24 10.8862176
Konig Rated-R Cast 14x6 14.5 6.5770898
Konig Rated-R Cast 15x6.5 16.5 7.4842746
Konig Rated-R Cast 16x7 17.5 7.937867
Konig Rated-R Cast 17x7 19.2 8.70897408
Konig Rated-R Cast 18x7.5 21.5 9.7522366
Konig Rewind Cast 15x7 14.6 6.62244904
Konig Rhythym Cast 17x7 20.9 9.48008116
Konig Rhythym Cast 18x7.5 22.5 10.205829
Konig Rush Cast 14x6 13.5 6.1234974
Konig Rush Cast 15x6.5 17.7 8.02858548
Konig Rush Cast 16x7 19 8.6182556
Konig Rush Cast 17x7.5 22.8 10.34190672
Konig Rush Cast 18x7.5 24.9 11.29445076
Konig Rush Cast 19x8 26.5 12.0201986
Konig Septor Cast 17x7 21.2 9.61615888
Konig Spec Cast 17x7 21.2 9.61615888
Konig SubZero Cast 15x6.5 12.9 5.85134196
Konig SubZero Cast 17x7.5 16.9 7.66571156
Konig Tantrum Cast 15x6.5 16.5 7.4842746
Konig Tantrum Cast 16x7 17.9 8.11930396
Konig Tantrum Cast 17x7 19.2 8.70897408
Konig Tantrum Cast 17x8 22.9 10.38726596
Konig Tantrum Cast 17x9 23 10.4326252
Konig Tantrum Cast 18x7.5 23.2 10.52334368
Konig Tantrum Cast 18x8 24.9 11.29445076
Konig Tantrum Cast 18x9 25.3 11.47588772
Konig Tantrum Cast 19x8 27 12.2469948
Konig Tantrum 2 Cast/Spun 18x10 23.4 10.61406216
Konig Temperr Cast 17x7.5 20.7 9.38936268
Konig Temperr Cast 18x7.5 22.9 10.38726596
Konig Tequila Cast 17x7 19 8.6182556
Konig Theory Cast 17x7 19.3 8.75433332
Konig Theory Cast 18x7.5 20.3 9.20792572
Konig Theory Cast 18x8 22.4 10.16046976
Konig Theory Cast 19x8 24.5 11.1130138
Konig Toxxin Cast 17x7.5 18.6 8.43681864
Konig Toxxin Cast 18x7.5 19.8 8.98112952
Konig Traffik Cast 18x7.5 20.5 9.2986442
Konig Tremor Cast 17x8.5 23.2 10.52334368
Konig Tremor Cast 20x8.5 28.2 12.79130568
Konig Trouble Cast 15x6.5 16.5 7.4842746
Konig Trouble Cast 16x7 18.7 8.48217788
Konig Trouble Cast 17x7 19.8 8.98112952
Konig Trouble Cast 18x7.5 23.1 10.47798444
Konig Trouble Cast 18x8 24.2 10.97693608
Konig Trouble Cast 19x8 26.4 11.97483936
Konig Trouble Cast 19x9 28.6 12.97274264
Konig Tuner Cast 15x6.5 17 7.7110708
Konig Tuner Cast 16x7 17.5 7.937867
Konig Tuner Cast 17x7 18 8.1646632
Konig Tuner2 Cast 17x7.5 21.6 9.79759584
Konig Tuner2 Cast 18x7.5 27 12.2469948
Konig Tuner2 Cast 19x7.5 26.4 11.97483936
Konig Tuner2 Cast 20x7.5 27.1 12.29235404
Konig Unknöwn Cast 17x7 19.6 8.89041104
Konig Unknöwn Cast 17x8 19.6 8.89041104
Konig Unknöwn Cast 18x7.5 23.1 10.47798444
Konig Unknöwn Cast 18x8 24.4 11.06765456
Konig Unknöwn Cast 19x8 24.9 11.29445076
Konig Unknöwn Cast 19x9.5 25 11.33981
Konig Unknöwn Cast 20x8 25.3 11.47588772
Konig Verdict Cast 15x6.5 19.6 8.89041104
Konig Verdict Cast 16x7 20.7 9.38936268
Konig Verdict Cast 17x7 22.4 10.16046976
Konig Verdict Cast 17x8 23.1 10.47798444
Konig Verdict Cast 18x7.5 27.3 12.38307252
Konig Verdict Cast 18x8 27.5 12.473791
Konig Verdict Cast 19x8 27.5 12.473791
Konig Villian Cast 15x6.5 14.5 6.5770898
Konig Villian Cast 17x8 19.8 8.98112952
Konig Villian Cast 17x9 22.3 10.11511052
Konig Villian Cast 18x8 23.8 10.79549912
Konig Villian Cast 18x9 26.5 12.0201986
Konig Volume Cast 18x7.5 26 11.7934024
Konig V-Racing Cast 16x7 18 8.1646632
Konig Whatever Cast 18x8.5 33.4 15.14998616
Konig Ziege Cast 15x6.5 17.2 7.80178928
Konig Ziege Cast 16x7 18.7 8.48217788
Konig Ziege Cast 17x7 20.2 9.16256648
Konig Ziege Cast 18x7.5 22.9 10.38726596
Kosei Double Racer Cast 17x7 17.7 8.02858548
Kosei GK 11 Cast 15x6.5 14 6.3502936
Kosei JGT Cast 18x7.5 24 10.8862176
Kosei K1 Racing Cast 15x7 13.5 6.1234974
Kosei K1 Racing Cast 15x8 14.5 6.5770898
Kosei K1 Racing Cast 16x7.5 15.5 7.0306822
Kosei K1 Racing Cast 16x8.5 16.2 7.34819688
Kosei K1 Racing Cast 17x7.5 16.7 7.57499308
Kosei K1 Racing Cast 17x8.5 16.7 7.57499308
Kosei K1 TS Cast 14x6 9.8 4.44520552
Kosei K1 TS Cast 15x7 12.6 5.71526424
Kosei K1 TS Cast 17x7 13.9 6.30493436
Kosei K1 TS Cast 17x8 15.4 6.98532296
Kosei K1 TS Cast 18x7.5 16 7.2574784
Kosei K1 TS Cast 18x8 16.8 7.62035232
Kosei K3 Cast 15x6.5 15.3 6.93996372
Kosei K3 Cast 17x7 17.2 7.80178928
Kosei K3 Cast 18x7.5 18.5 8.3914594
Kosei K3 Cast 18x8.5 20 9.071848
Kosei K3 Cast 19x8.5 21.2 9.61615888
Kosei Racer Cast 17x7 17.6 7.98322624
Kosei ROM Cast 18x7 24.5 11.1130138
Kosei RT MAXi Cast 15x7 16.8 7.62035232
Kosei RT MAXi Cast 17x7.5 19 8.6182556
Kosei RT Penta Cast 15x7 13.8 6.25957512
Kosei RT Penta Cast 18x7.5 18.5 8.3914594
Kosei RT Sport Cast 15x6.5 14.6 6.62244904
Kosei RT Sport Cast 17x7 20 9.071848
Kosei RT Sport Cast 17x8 21 9.5254404
Kosei RT Sport Cast 18x8 21.5 9.7522366
Kosei S5R Cast 16x8 23 10.4326252
Kosei S5R Cast 17x7 22 9.9790328
Kosei Seneka Cast 15x6.5 15 6.803886
Kosei Seneka Cast 16x7 19 8.6182556
Kosei Seneka Cast 17x7 21.5 9.7522366
Kosei Seneka RG Cast 18x8 25.3 11.47588772
Kosei Sniper Cast 16x7 18.9 8.57289636
Kosei Sniper Cast 17x8 23.5 10.6594214
Kosei Sniper Cast 18x9 25 11.33981
Kosoku Sports Turismo Cast 17x7 27 12.2469948
Kronix Bio Hazard Cast 17x7.5 25.8 11.70268392
Kronix Insignia 770 Cast 17x7.5 26.2 11.88412088
Kuhl Wheel 4-Spoke Steel 14x5.5 14.1 6.39565284
Kuhl Wheel 5-Spoke Steel 16x7 22.5 10.205829
Kuhl Wheel 6-Spoke Steel 17x7 27.3 12.38307252
Kyoho Tracer Cast 15x7 9.9 4.49056476
Kyoho Tracer Cast 16x7 14.7 6.66780828
Kyoho Tracer Cast 16x8 14.9 6.75852676
Kyoho Tracer Cast 17x7 15.2 6.89460448
Kyoho Tracer Cast 17x8 15.6 7.07604144
Kyoho Tracer Cast 17x9 17.6 7.98322624
Kyoho Tracer Cast 18x7.5 17.6 7.98322624
Kyoho Tracer Cast 18x8.5 18 8.1646632
Kyoho Tracer Cast 18x9.5 18.2 8.25538168
Lada Cast Mg 14x6 10.4 4.71736096
Lenso GT-05 Cast 19x8.5 26 11.7934024
Lenso GTR Cast 16x7 15.9 7.21211916
Lenso VPD Cast 13x7.5 10 4.535924
Lenso VPD Cast 15x6.5 13.1 5.94206044
Lenso VPD Cast 16x7 15 6.803886
Lenso VPD Cast 17x7 17 7.7110708
Lexani Amethist Cast 17x7.5 29 13.1541796
Lexani Iris 2009 Cast 18x8 27.5 12.473791
Lexani Krystal Cast 18x8 34 15.4221416
Lexani Solar Cast 17x7.5 28 12.7005872
Lexani Synergy Cast 18x8 30.8 13.97064592
Lexus ES300 97 Cast 15x6 18 8.1646632
Lexus IS300 Cast 17x7 21 9.5254404
Lexus IS300 (Chrome version) Cast 17x7 22 9.9790328
Lezaro Stiletto Cast 17x7.5 25.4 11.52124696
LimiX Linea BE5-RSK Forged 18x7.5 16.8 7.62035232
Lite Speed Billet/ Spun 17x10 18 8.1646632
LLTek Competition Cast 18x8 24 10.8862176
Lotus Elise 111 Cast 15x5.5 16.7 7.57499308
Lotus Elise 111 Cast 16x7 19 8.6182556
Lotus Elise 111S Cast 15x5.5 15.3 6.93996372
Lotus Elise 111S Cast 16x7.5 20.7 9.38936268
Lotus Elise 160Sport Cast 15x6 18.3 8.30074092
Lotus Elise 160Sport Cast 16x8 22 9.9790328
Lotus Elise LSS Forged 16x6.5 13.2 5.98741968
Lotus Elise LSS Forged 17x7.5 15.1 6.84924524
Lotus Elise US Cast 16x5.5 15.2 6.89460448
Lotus Elise US Cast 17x7.5 21 9.5254404
Lotus Exige 111R Cast 16x6.5 17.6 7.98322624
Lotus Exige 111R Cast 17x7.5 20.7 9.38936268
Lowenhart BR-S Cast 20x9 29.3 13.29025732
Lowenhart BS-5 Cast 18x8.5 29 13.1541796
Lowenhart BS-D Cast 20x10 42 19.0508808
Lowenhart LD-1 Cast 20x10 32.3 14.65103452
Lowenhart LG-M Cast 18x8.5 26 11.7934024
Lowenhart LH-5 Cast 18x8 28 12.7005872
Mackin Gewalt Cast 17x10 23 10.4326252
Mackin Gewalt Cast 17x7 22 9.9790328
Madhi Caesar Cast 19x9 27.4 12.42843176
Manaray SP Cast 17x10 24 10.8862176
Manaray SP Cast 17x8.5 22 9.9790328
Mandrus Regenmeister Cast 17x8 23 10.4326252
MAS Axel Cast 18x8 25 11.33981
MAS Bi Turbo Look Cast 18x8 31 14.0613644
MAS Madel Cast 17x8 29 13.1541796
MAS Majestic Cast 18x8 26.5 12.0201986
MAS MGR Cast 16x7.5 22.5 10.205829
MAS MGR Cast 18x7.5 26 11.7934024
MAS MGR Cast 18x8 26.5 12.0201986
MAS Roger Cast 17x7 22 9.9790328
MAS Roger Cast 18x8 29.5 13.3809758
MAS Sagitta Cast 18x8 24.3 11.02229532
Maxxim Approach Cast 18x7.5 24.2 10.97693608
Maxxim Def-Con 6 Cast 17x7 20 9.071848
Mazda 323 7-spoke Cast 15x5.5 15.3 6.93996372
Mazda 626 83-87 Cast 15x6 16 7.2574784
Mazda 929 93-95 Cast 15x6 12 5.4431088
Mazda Miata 01 Cast 16x6.5 15.5 7.0306822
Mazda Miata 02 SE Cast 16x6.5 19 8.6182556
Mazda Miata 06 Cast 17x7 17 7.7110708
Mazda Miata 90-93 Cast 14x5.5 12.5 5.669905
Mazda Miata 90-97 Steel Stamped Steel 14x5.5 18 8.1646632
Mazda Miata 92C/93LE (BBS) Forged 14x6 10.5 4.7627202
Mazda Miata 94 M-Edition Cast 14x6 10.3 4.67200172
Mazda Miata 94-97 (hollow spokes) Cast 14x6 11.8 5.35239032
Mazda Miata 94-97 (semi-hollow spokes) Cast 14x6 10.9 4.94415716
Mazda Miata 95 M-Edition (BBS) Forged 15x6 11.6 5.26167184
Mazda Miata 96 M-Edition (Enkei) Cast 15x6 14.7 6.66780828
Mazda Miata 97 M-Edition Cast 15x6 14.5 6.5770898
Mazda Miata 99-00 Cast 14x6 12.5 5.669905
Mazda Miata 99-00 Cast 15x6 13.4 6.07813816
Mazda Miata Spare Tire & Wheel (includes tire weight) Stamped Steel 14x4 21.6 9.79759584
Mazda Miata UK Cast 15x6 15 6.803886
Mazda Millenia Cast 15x6 11.5 5.2163126
Mazda Protégé 5 ES Cast 16x6.5 16 7.2574784
Mazda RX7 84-85 Cast 14x5.5 13 5.8967012
Mazda RX7 86-88 Cast 14x5.5 13.5 6.1234974
Mazda RX7 88 10AE Cast 16x7 21.1 9.57079964
Mazda RX7 FD3S Cast 16x8 15.4 6.98532296
Mazda RX7 FD3S - PFD Cast (Brittle) 16x8 13.8 6.25957512
Mazda RX7 TII 89-91 Cast 16x7 17.2 7.80178928
Mazda RX8 06-09 Cast 18x8 22 9.9790328
Mazda Sports Forged 16x7 13.1 5.94206044
Mazdaspeed 6 06 Cast 18x7 23.5 10.6594214
Mazdaspeed MS-01 Forged Mg 18x8 16.2 7.34819688
Mazdaspeed MS-01 Forged Mg 18x8.5 16.6 7.52963384
Mazdaspeed MS-01S Forged 18x8 17.7 8.02858548
Mazdaspeed MS-03 Cast 15x6.5 16.5 7.4842746
Mazdaspeed Z01 Forged 18x7.5 17 7.7110708
MB Motoring 005 Cast 14x6 14 6.3502936
MB Motoring 005 Cast 15x6.5 16.5 7.4842746
MB Motoring 005 Cast 16x7 20.5 9.2986442
MB Motoring 005 Cast 17x7 20.5 9.2986442
MB Motoring 070 Cast 15x10 18 8.1646632
MB Motoring 070 Cast 15x8 16 7.2574784
MB Motoring 070 Cast 16.5x9.8 21 9.5254404
MB Motoring 070 Cast 16x10 20.5 9.2986442
MB Motoring 070 Cast 16x8 16.5 7.4842746
MB Motoring 177 Cast 15x7 21.5 9.7522366
MB Motoring 177 Cast 16x7 23.5 10.6594214
MB Motoring 177 Cast 17x7 26 11.7934024
MB Motoring 747 Cast 13x5 12.5 5.669905
MB Motoring 747 Cast 14x6 15 6.803886
MB Motoring 747 Cast 15x6.5 16.5 7.4842746
MB Motoring 747 Cast 16x7 18.5 8.3914594
MB Motoring 747 Cast 17x7 22.5 10.205829
MB Motoring ABYSS Cast 17x7 24.5 11.1130138
MB Motoring ABYSS Cast 18x7.5 29 13.1541796
MB Motoring ABYSS Cast 18x8 29 13.1541796
MB Motoring ABYSS Cast 18x9 30.5 13.8345682
MB Motoring AMMO Cast 17x7 27 12.2469948
MB Motoring AMMO Cast 18x7.5 30 13.607772
MB Motoring AMMO Cast 20x8.5 38 17.2365112
MB Motoring BLAST Cast 17x7.5 20 9.071848
MB Motoring BLAST Cast 18x7.5 20.5 9.2986442
MB Motoring BLI Cast 15x7 22 9.9790328
MB Motoring BLI Cast 15x8 22.5 10.205829
MB Motoring BLI Cast 16x8 26 11.7934024
MB Motoring BLI Cast 17x8 28 12.7005872
MB Motoring BLI Cast 18x10 39.5 17.9168998
MB Motoring BLI Cast 18x8.5 31.5 14.2881606
MB Motoring BOOST Cast 15x6.5 16 7.2574784
MB Motoring BOOST Cast 16x7 19.5 8.8450518
MB Motoring BOOST Cast 17x7 20.5 9.2986442
MB Motoring BOOST Cast 18x7.5 22 9.9790328
MB Motoring BRU Cast 20x8.5 35 15.875734
MB Motoring BRU Cast 22x9.5 41 18.5972884
MB Motoring BRU Cast 24x10 49 22.2260276
MB Motoring BRUZER Cast 20x8.5 35 15.875734
MB Motoring BRUZER Cast 22x9.5 41 18.5972884
MB Motoring BRUZER Cast 24x10 49 22.2260276
MB Motoring CAN Cast 20x8.5 33.5 15.1953454
MB Motoring CAN Cast 22x9.5 45.5 20.6384542
MB Motoring CAN Cast 24x10 50 22.67962
MB Motoring CATALYST 1 Cast 18x8 33.5 15.1953454
MB Motoring CATALYST 1 Cast 20x8.5 39.5 17.9168998
MB Motoring CATALYST 2 Cast 18x8.5 36.5 16.5561226
MB Motoring CATALYST 2 Cast 20x9 42.5 19.277677
MB Motoring CATALYST 2 Cast 22x9.5 51 23.1332124
MB Motoring CLA Cast 16x7 20 9.071848
MB Motoring CLA Cast 17x7 21 9.5254404
MB Motoring CLA Cast 18x7.5 24.5 11.1130138
MB Motoring Competition Cast 15x7 13.5 6.1234974
MB Motoring Competition Cast 17x7 17 7.7110708
MB Motoring DEE Cast 20x9 38 17.2365112
MB Motoring DEE Cast 22x9.5 44.5 20.1848618
MB Motoring EX5 Cast 18x9 28.5 12.9273834
MB Motoring EX5 Cast 20x9 32 14.5149568
MB Motoring EX5 Cast 22x9.5 38 17.2365112
MB Motoring EX6 Cast 18x9 28.5 12.9273834
MB Motoring EX6 Cast 20x9 32 14.5149568
MB Motoring EX6 Cast 22x9 35 15.875734
MB Motoring EXE Cast 17x7 23 10.4326252
MB Motoring EXE Cast 18x7.5 25 11.33981
MB Motoring EXE II Cast 18x7.5 25 11.33981
MB Motoring EXE II Cast 18x8 25 11.33981
MB Motoring EXE II Cast 18x9 25 11.33981
MB Motoring GEAR Cast 17x7 24.5 11.1130138
MB Motoring GEAR Cast 18x8 28 12.7005872
MB Motoring GU5 Cast 16x8 23 10.4326252
MB Motoring GU5 Cast 17x10 28 12.7005872
MB Motoring GU5 Cast 17x8 27 12.2469948
MB Motoring GU5 Cast 18x10 30 13.607772
MB Motoring GU5 Cast 18x8.5 29.5 13.3809758
MB Motoring GU5 Cast 20x10 32 14.5149568
MB Motoring GU5 Cast 20x8.5 32 14.5149568
MB Motoring GU6 Cast 16x8 23 10.4326252
MB Motoring GU6 Cast 17x10 28 12.7005872
MB Motoring GU6 Cast 17x8 23.5 10.6594214
MB Motoring GU6 Cast 18x10 30 13.607772
MB Motoring GU6 Cast 18x8.5 29.5 13.3809758
MB Motoring GU6 Cast 20x10 32.5 14.741753
MB Motoring GU6 Cast 20x8.5 32 14.5149568
MB Motoring GU8 Cast 16x8 24.5 11.1130138
MB Motoring GU8 Cast 17x8 28.5 12.9273834
MB Motoring GU8 Cast 18x10 32 14.5149568
MB Motoring GU8 Cast 20x10 34 15.4221416
MB Motoring GU8 Cast 20x8.5 33.5 15.1953454
MB Motoring GUNNER 5 Cast 16x8 23 10.4326252
MB Motoring GUNNER 5 Cast 17x10 28 12.7005872
MB Motoring GUNNER 5 Cast 17x8 27 12.2469948
MB Motoring GUNNER 5 Cast 18x10 30 13.607772
MB Motoring GUNNER 5 Cast 18x8.5 29.5 13.3809758
MB Motoring GUNNER 5 Cast 20x10 32 14.5149568
MB Motoring GUNNER 5 Cast 20x8.5 32 14.5149568
MB Motoring GUNNER 6 Cast 16x8 23 10.4326252
MB Motoring GUNNER 6 Cast 17x10 28 12.7005872
MB Motoring GUNNER 6 Cast 17x8 23.5 10.6594214
MB Motoring GUNNER 6 Cast 18x10 30 13.607772
MB Motoring GUNNER 6 Cast 18x8.5 29.5 13.3809758
MB Motoring GUNNER 6 Cast 20x10 32.5 14.741753
MB Motoring GUNNER 6 Cast 20x8.5 32 14.5149568
MB Motoring GUNNER 8 Cast 16x8 24.5 11.1130138
MB Motoring GUNNER 8 Cast 17x8 28.5 12.9273834
MB Motoring GUNNER 8 Cast 18x10 32 14.5149568
MB Motoring GUNNER 8 Cast 20x10 34 15.4221416
MB Motoring GUNNER 8 Cast 20x8.5 33.5 15.1953454
MB Motoring JUM Cast 20x8.5 36 16.3293264
MB Motoring JUM Cast 22x9.5 46.5 21.0920466
MB Motoring KAN Cast 16x8 25 11.33981
MB Motoring KAN Cast 17x8 27 12.2469948
MB Motoring KAN Cast 18x8.5 36 16.3293264
MB Motoring KAN Cast 20x8.5 42.5 19.277677
MB Motoring KAN Cast 22x9.5 47.5 21.545639
MB Motoring LINK Cast 17x7.5 27.5 12.473791
MB Motoring LINK Cast 18x7.5 27.5 12.473791
MB Motoring LINK Cast 20x8.5 35 15.875734
MB Motoring OVE Cast 15x7 17.5 7.937867
MB Motoring OVE Cast 15x8 21.5 9.7522366
MB Motoring OVE Cast 16x10 30 13.607772
MB Motoring OVE Cast 16x8 21 9.5254404
MB Motoring OVE Cast 17x10 25.5 11.5666062
MB Motoring OVE Cast 17x8.5 23 10.4326252
MB Motoring PRD Cast 15x8 24 10.8862176
MB Motoring PRD Cast 16x8 28 12.7005872
MB Motoring PRD Cast 17x8 30.5 13.8345682
MB Motoring PRD Cast 18x10 34 15.4221416
MB Motoring PRD Cast 18x8.5 34 15.4221416
MB Motoring PRD Cast 20x10 41 18.5972884
MB Motoring PRD Cast 20x8.5 38.5 17.4633074
MB Motoring PRE Cast 17x8.5 26.5 12.0201986
MB Motoring PRE Cast 18x9 28.5 12.9273834
MB Motoring PRE Cast 20x10 38 17.2365112
MB Motoring PRE Cast 20x8.5 30 13.607772
MB Motoring PRO Cast 18x9 33 14.9685492
MB Motoring PRO Cast 20x9 37.5 17.009715
MB Motoring RAZ Cast 16x8 26.5 12.0201986
MB Motoring RAZ Cast 17x10 31 14.0613644
MB Motoring RAZ Cast 18x10 34.5 15.6489378
MB Motoring RAZ Cast 18x8.5 32.5 14.741753
MB Motoring RAZ Cast 20x10 40 18.143696
MB Motoring RAZ Cast 22x11 48 21.7724352
MB Motoring REV Cast 15x7 19 8.6182556
MB Motoring REV Cast 15x7 20 9.071848
MB Motoring REV Cast 16x7 22 9.9790328
MB Motoring REV Cast 16x7 23 10.4326252
MB Motoring REV Cast 17x7 22.5 10.205829
MB Motoring REV Cast 17x7 23.5 10.6594214
MB Motoring REV Cast 18x7 23.5 10.6594214
MB Motoring REV Cast 18x8 25.5 11.5666062
MB Motoring REV Cast 18x8 27.5 12.473791
MB Motoring ROC Cast 16x10 25.5 11.5666062
MB Motoring ROC Cast 16x8 22.5 10.205829
MB Motoring ROC Cast 17x10 32 14.5149568
MB Motoring ROC Cast 17x8 24.5 11.1130138
MB Motoring ROC Cast 18x10 32.5 14.741753
MB Motoring ROC Cast 20x10 39 17.6901036
MB Motoring SEN Cast 20x8.5 34.5 15.6489378
MB Motoring SEN Cast 22x9 42.5 19.277677
MB Motoring SHA Cast 20x9 40 18.143696
MB Motoring SHAKER Cast 20x9 40 18.143696
MB Motoring SHIFTER Cast 17x7.5 24 10.8862176
MB Motoring SHIFTER Cast 18x7.5 24.5 11.1130138
MB Motoring SMO Cast 18x9 27.5 12.473791
MB Motoring SMO Cast 20x10 33 14.9685492
MB Motoring SPARK Cast 15x6.5 15.5 7.0306822
MB Motoring SPARK Cast 16x7 18 8.1646632
MB Motoring SPARK Cast 17x7 19.5 8.8450518
MB Motoring VA1 Cast 18x8.5 29 13.1541796
MB Motoring VA1 Cast 20x8.5 32 14.5149568
MB Motoring VA2 Cast 18x8.5 34.5 15.6489378
MB Motoring VA2 Cast 20x8.5 37 16.7829188
MB Motoring VIN Cast 17x8 20.5 9.2986442
MB Motoring VISION Cast 15x6.5 17.5 7.937867
MB Motoring VISION Cast 16x7 20 9.071848
MB Motoring VISION Cast 17x7.5 22.5 10.205829
MB Motoring VISION Cast 18x7.5 24.5 11.1130138
MB Motoring VR1 Cast 17x7 22 9.9790328
MB Motoring VR1 Cast 18x7.5 25 11.33981
MB Motoring VR1 Cast 18x8 25.5 11.5666062
MB Motoring VR1 Cast 18x9 26 11.7934024
MB Motoring VR5S Cast 17x7 22 9.9790328
MB Motoring VR5S Cast 18x7.5 24.5 11.1130138
MB Motoring VR5S Cast 18x8 26 11.7934024
MB Motoring WEAPON Cast 17x7 18 8.1646632
MB Motoring WEAPON Cast 17x8 20 9.071848
MB Motoring WEAPON Cast 17x9 21 9.5254404
MB Motoring WEAPON Cast 18x7.5 21 9.5254404
MB Motoring WEAPON Cast 18x8 22 9.9790328
MB Motoring WEAPON Cast 18x9 23.5 10.6594214
MB Motoring YUM Cast 20x8.5 35 15.875734
MB Motoring YUM Cast 22x9 40.5 18.3704922
MB Motoring YUMA Cast 20x8.5 35 15.875734
MB Motoring YUMA Cast 22x9 40.5 18.3704922
Mercedes Benz AMG SLK (Front) Forged 17x7.5 22.8 10.34190672
Mercedes Benz AMG SLK (Rear) Forged 17x8.5 23.6 10.70478064
Mercedes Benz C32 (Front) Cast 17x7.5 25.6 11.61196544
Mercedes Benz C32 (Rear) Cast 17x8.5 26 11.7934024
Mercedes Benz C55 (Front) Forged 18x8.5 26.4 11.97483936
Mercedes Benz C55 (Rear) Forged 18x9.5 27.2 12.33771328
Mercedes Benz C7 Sport (W203) Cast 17x7.5 24.6 11.15837304
Mercedes Benz CLK230 98-99 Forged 16x7 12.9 5.85134196
Mercedes Benz E-Class W124 (EVO II) Forged 18x8.5 24.7 11.20373228
Mercedes Benz E-Class W124 (15 Hole) Cast 15x6.5 17.9 8.11930396
Mercedes Benz E-Class W124 (8 Hole) Cast 15x6.5 19.6 8.89041104
Mercedes Benz E-Class W124 (8 Hole) Cast 16x8 23.2 10.52334368
Mercedes Benz CLK320 (6 Spoke) Forged 16x7 14.5 6.5770898
Mercedes Benz SL600 (1997) Forged 18x8.5 25.5 11.5666062
Mercedes Benz SL600 (1997) Forged 18x9.5 26.5 12.0201986
MHT Driv Cast 17x7 27.5 12.473791
MHT Qwan Cast 18x8 27 12.2469948
MHT V-10 Cast/Spun 18x7 25 11.33981
MHT V-10 Cast/Spun 20x8.5 30.5 13.8345682
Mille Miglia A3 Cast 15x7 23 10.4326252
Mille Miglia Action Cast 16x7 23 10.4326252
Mille Miglia Action Cast 18x8 25 11.33981
Mille Miglia Action Sport Cast 18x8 23 10.4326252
Mille Miglia Avia Cast 15x6.5 22 9.9790328
Mille Miglia Avia Cast 16x7 21.5 9.7522366
Mille Miglia Avia Cast 18x7.5 26 11.7934024
Mille Miglia Avia II Cast 18x8 25 11.33981
Mille Miglia C2T Cast 17x7.5 24 10.8862176
Mille Miglia C2T Cast 17x9 26 11.7934024
Mille Miglia Cello Cast 15x7 19 8.6182556
Mille Miglia Cello Cast 16x7 20 9.071848
Mille Miglia Cello Cast 18x8 25 11.33981
Mille Miglia Cup 3S Cast 18x8 27 12.2469948
Mille Miglia Emotion SSL Cast 18x8 27 12.2469948
Mille Miglia Evo Cast 17x7 23.3 10.56870292
Mille Miglia Evo Cast 18x8 27 12.2469948
Mille Miglia EV-R Cast 18x8 29 13.1541796
Mille Miglia F20 Cast 17x7 24.4 11.06765456
Mille Miglia HT3 Cast 15x7 17.5 7.937867
Mille Miglia HT3 Cast 17x7 22 9.9790328
Mille Miglia HT3 Cast 17x8 24 10.8862176
Mille Miglia HT3 Cast 18x7 23.5 10.6594214
Mille Miglia HT3 Cast 18x8 26.5 12.0201986
Mille Miglia Max F Forged 20x8.5 23.8 10.79549912
Mille Miglia Max F Forged 22x10 31.1 14.10672364
Mille Miglia MM 11 Sport Cast 16x7 16.5 7.4842746
Mille Miglia MM 11 Sport Cast 17x8.5 22 9.9790328
Mille Miglia MM 11-2 Cast 17x7 23 10.4326252
Mille Miglia MM 11-2 Cast 18x8 25 11.33981
Mille Miglia MM 11-3 Cast 17x7 22.9 10.38726596
Mille Miglia Sfera Cast 16x7 21.8 9.88831432
Mille Miglia Spider Cast 18x8 27 12.2469948
Mille Miglia Spider II Cast 15x7 23 10.4326252
Mille Miglia Spider II Cast 16x7 22.5 10.205829
Mille Miglia Spider II Cast 17x7 24.5 11.1130138
Mille Miglia Uno Cast 18x8 28.4 12.88202416
Millenium Kurbkrusher Cast 18x8 34 15.4221416
Miller Motorworks RS-R Cast 18x8 28 12.7005872
MiM ""ScoobySport"" Cast 17x7 21 9.5254404
MiM Venezia Cast 16x7.5 23.6 10.70478064
MiM Vento Cast 15x7 19 8.6182556
Mini R105 Cast 17x7 23.3 10.56870292
Mini R105 Cast 18x7 23.3 10.56870292
Mini R107 GP Cast 18x7 19.8 8.98112952
Mini R12 Steel 15x5 14.8 6.71316752
Mini R81 Imola (7-hole) Cast 15x5.5 12.1 5.48846804
Mini R82 Silverstone (8-spoke) Cast 15x5.5 15.2 6.89460448
Mini R83 Daytona (5-star) Cast 16x6.5 20.1 9.11720724
Mini R84 X-Lite Monza (V-spoke) Cast 16x6.5 17.6 7.98322624
Mini R85 S-Lite (LeMans) Cast 17x7 25.1 11.38516924
Mini R86 (star spoke) Cast 15x5.5 15 6.803886
Mini R87 (double spoke) Cast 16x5.5 16.5 7.4842746
Mini R88 Cast 16x5.5 19.6 8.89041104
Mini R90 Cast/Spun 17x7 24.1 10.93157684
Mini R91 Bullet Cast 17x7 20.6 9.34400344
Mini R92 Fin (7-spoke) Cast 16x6.5 19 8.6182556
Mini R93 Rocket Cast 15x5.5 14.8 6.71316752
Mini R94 Bridge-spoke Cast 16x6.5 20.9 9.48008116
Mini R95 JCW Cast 18x7 23.5 10.6594214
Mini R96 (7-spoke) Cast 15x5.5 13.8 6.25957512
Mini R97 Flame Cast 17x7 22 9.9790328
Mini R98 Cast/Spun 17x7 22.3 10.11511052
Mini R99 Cast 17x7 21.9 9.93367356
Mini Spare Steel 15x3.5 12.7 5.76062348
Mini Steel Steel 15x5.5 14.7 6.66780828
Minilite Competition Cast 13x7 13 5.8967012
Minilite Magnesium Forged Mg 14x6 10 4.535924
Minilite Magnesium Forged Mg 15x7 10.5 4.7627202
Minilite Sport Cast 14x6 14 6.3502936
Minilite Sport Cast 15x6.5 16 7.2574784
Miro Type 111 Cast 19x8.5 24 10.8862176
Miro Type 111 Cast 19x9.5 25 11.33981
Mitsubishi 3000GT VR-4 95 Cast 18x8.5 25 11.33981
Mitsubishi Galant 91 Cast 15x6 17 7.7110708
Mitsubishi Galant 92 Cast 15x6 16 7.2574784
Mitsubishi Galant 94-96 (5-spoke) Cast 15x6 15 6.803886
Mitsubishi Galant 96-97 (4-spoke) Cast 15x6 14.5 6.5770898
Mitsubishi GSX 1997 Cast 17x6.5 25 11.33981
Mitsubishi Lancer EVO2 Cast 15x6.5 13.4 6.07813816
Mitsubishi Lancer EVO6 Cast 17x7.5 21 9.5254404
Mitsubishi Lancer EVO6 TME Cast 17x7.5 23.8 10.79549912
Mitsubishi Lancer EVO7 Cast 17x7.5 22.3 10.11511052
Mitsubishi Lancer EVO8 Cast 17x8 20.5 9.2986442
Mitsubishi Lancer EVO8/9 MR (BBS) Forged 17x7.5 17.8 8.07394472
Mitsubishi Lancer EVO9 (Enkei) Cast 17x7.5 20.2 9.16256648
Mitsubishi Lancer Evo X (BBS) Forged 18x8.5 19.8 8.98112952
MK Sport Racer X Cast 17x7.5 26 11.7934024
MK Sport Seducer Cast 19x9.5 34 15.4221416
MK Sport Sleeper Cast 17x7.5 25 11.33981
MK-Motorsport MK2 Forged/Spun 18x8.5 24.3 11.02229532
MKW MK-5 Cast 17x7.5 27.5 12.473791
MKW MK-9 Cast 18x8 24.8 11.24909152
Moda MD1 Cast 18x8 25 11.33981
Moda MD1 Cast 19x8.5 26.5 12.0201986
Moda MD2 Cast 18x8 28.5 12.9273834
Moda MD2 Cast 19x8.5 32.5 14.741753
Moda MD3 Cast 19x8.5 33.5 15.1953454
Moda MD5 Cast 18x8 24.5 11.1130138
Moda MD5 Cast 19x8.5 27.5 12.473791
Moda MD5 Cast 19x9.5 30 13.607772
Moda R1 Cast 17x8 24 10.8862176
Moda R10 Cast 19x8 36.6 16.60148184
Moda R2 Cast 15x7 19.5 8.8450518
Moda R2 Cast 16x7 21.5 9.7522366
Moda R3 Cast 17x7 24.6 11.15837304
Moda R3 Cast 18x8 27 12.2469948
Moda R4 Cast 18x8 27 12.2469948
Moda R6 Cast 18x8 28.6 12.97274264
Modex Ks-Ce Forged 15x6.5 9.2 4.17305008
Modex Ks-Ce Forged 17x7 13 5.8967012
Modulo Euro Performance R5 Cast 17x7 21 9.5254404
Modulo Euro Performance R5 Cast 17x8.5 22.3 10.11511052
MOMO Arrow Cast 15x7 20 9.071848
MOMO Arrow Cast 16x7 23 10.4326252
MOMO Arrow Cast 17x8 26 11.7934024
MOMO GT2 Cast 17x8 26 11.7934024
MOMO Racer Cast 17x8 27.3 12.38307252
MOMO Racer Cast 18x8.5 35.5 16.1025302
MOMO Sport Cast 16x7 23 10.4326252
MOMO Sport Cast 17x8 26 11.7934024
MOMO Superlight Forged 17x7 17 7.7110708
Mondera Spyder Cast 18x7.5 26.4 11.97483936
Monocoque RT Cast 17x10 20 9.071848
Monster Sport Type-R Forged 15x6.5 8.6 3.90089464
Monster Sport Type-R Forged 16x7 12.9 5.85134196
Motec Pantera Cast 18x8.5 24.8 11.24909152
Motec Pantera Cast 18x9.5 26 11.7934024
Motec Pantera Cast 19x8.5 26.7 12.11091708
Motec Pantera Cast 19x9.5 27.2 12.33771328
Motegi Racing DP1 Cast 17x7 26.5 12.0201986
Motegi Racing DP1 Cast 18x8 28 12.7005872
Motegi Racing DP1 Cast 20x7.5 31 14.0613644
Motegi Racing DP10 Cast 17x7 18.5 8.3914594
Motegi Racing DP10 Cast 18x8 23.5 10.6594214
Motegi Racing DP10 Cast 20x7.5 27 12.2469948
Motegi Racing DP12 Cast 17x7 21 9.5254404
Motegi Racing DP12 Cast 18x7.5 22.5 10.205829
Motegi Racing DP12 Cast 20x7.5 30 13.607772
Motegi Racing DP20 Cast 17x7 20.7 9.38936268
Motegi Racing DP20 Cast 18x7.5 24.3 11.02229532
Motegi Racing DP20 Cast 20x7.5 27.3 12.38307252
Motegi Racing DP5 Cast 17x7 19 8.6182556
Motegi Racing DP5 Cast 18x7.5 22.5 10.205829
Motegi Racing DP6 Cast 17x7 21 9.5254404
Motegi Racing DP6 Cast 18x7.5 22.5 10.205829
Motegi Racing DP6 Cast 18x8 22.5 10.205829
Motegi Racing DP6 Cast 20x7.5 25 11.33981
Motegi Racing DPK Cast 17x7 23 10.4326252
Motegi Racing DPK Cast 18x8 25 11.33981
Motegi Racing DPK Cast 19x8 26.5 12.0201986
Motegi Racing DV5 Cast 17x7 21.2 9.61615888
Motegi Racing DV5 Cast 18x8 24.5 11.1130138
Motegi Racing DV5 Cast 19x8 25 11.33981
Motegi Racing FF15 Cast 16x7 16 7.2574784
Motegi Racing FF15 Cast 17x7 19 8.6182556
Motegi Racing FF15 Cast 18x7 22.5 10.205829
Motegi Racing FF5 Cast 17x7 21 9.5254404
Motegi Racing FF5 Cast 18x7.5 23.5 10.6594214
Motegi Racing FF5 Cast 18x8 24 10.8862176
Motegi Racing FF5 Cast 19x8 26 11.7934024
Motegi Racing FF7 Cast 16x7 19 8.6182556
Motegi Racing FF7 Cast 17x7 21.5 9.7522366
Motegi Racing FF7 Cast 18x7.5 24.5 11.1130138
Motegi Racing FF7 Cast 19x7.5 25.5 11.5666062
Motegi Racing LC12 Cast 17x8 16.5 7.4842746
Motegi Racing LC12 Cast 18x7.5 20 9.071848
Motegi Racing LC5 Cast 15x7 12.5 5.669905
Motegi Racing LC5 Cast 17x7 15.5 7.0306822
Motegi Racing LC5 Cast 17x8 16.5 7.4842746
Motegi Racing LC5 Cast 18x7.5 20 9.071848
Motegi Racing MR12 Cast 15x7 17.5 7.937867
Motegi Racing MR12 Cast 16x7 19 8.6182556
Motegi Racing MR12 Cast 17x7.5 22.5 10.205829
Motegi Racing MR12 Cast 18x7 27.5 12.473791
Motegi Racing MR15 Cast 16x7 19.5 8.8450518
Motegi Racing MR15 Cast 17x7 23 10.4326252
Motegi Racing MR15 Cast 18x7 26.5 12.0201986
Motegi Racing MR4 Cast 17x7 25.5 11.5666062
Motegi Racing MR4 Cast 18x8 28.5 12.9273834
Motegi Racing MR5 Cast 16x7 19 8.6182556
Motegi Racing MR5 Cast 17x7 24.5 11.1130138
Motegi Racing MR5 Cast 18x7 29 13.1541796
Motegi Racing MR7 Cast 14x6 15.8 7.16675992
Motegi Racing MR7 Cast 15x6.5 16.5 7.4842746
Motegi Racing MR7 Cast 16x7 20 9.071848
Motegi Racing MR7 Cast 17x7 24.5 11.1130138
Motegi Racing MR7 Cast 18x7 27.5 12.473791
Motegi Racing MR7 Cast 18x7.5 28.5 12.9273834
Motegi Racing MR8 Cast 16x7 16.5 7.4842746
Motegi Racing MR8 Cast 17x7 22.5 10.205829
Motegi Racing MR8 Cast 18x7 26.5 12.0201986
Motegi Racing RT5 Cast 14x6 12 5.4431088
Motegi Racing RT5 Cast 15x6.5 14 6.3502936
Motegi Racing RT5 Cast 16x7 16 7.2574784
Motegi Racing RT5 Cast 17x7 19 8.6182556
Motegi Racing RT5 Cast 18x7.5 22.5 10.205829
Motegi Racing SP10 Cast 15x7 14.5 6.5770898
Motegi Racing SP10 Cast 17x7 16.8 7.62035232
Motegi Racing SP10 Cast 18x8 18.6 8.43681864
Motegi Racing SP5 Cast 17x7 19.5 8.8450518
Motegi Racing SP5 Cast 18x7.5 23.4 10.61406216
Motegi Racing SP5 Cast 19x8.5 27.6 12.51915024
Motegi Racing SP5 Cast 19x9.5 28.1 12.74594644
Motegi Racing SP7 Cast 17x7 20.3 9.20792572
Motegi Racing SP7 Cast 18x8 22.9 10.38726596
Motegi Racing SP7 Cast 19x8.5 28.4 12.88202416
Motegi Racing SP7 Cast 19x9.5 29.3 13.29025732
Motegi Racing SX5 Cast 15x6.5 16.5 7.4842746
Motegi Racing SX5 Cast 16x7 17.2 7.80178928
Motegi Racing SX5 Cast 17x7 18.9 8.57289636
Motegi Racing SX5 Cast 18x7.5 20.5 9.2986442
Motegi Racing SX7 Cast 15x6.5 16.8 7.62035232
Motegi Racing SX7 Cast 16x7 18.8 8.52753712
Motegi Racing SX7 Cast 17x7 20.5 9.2986442
Motegi Racing SX7 Cast 18x7.5 23 10.4326252
Motegi Racing Touge Cast 17x9 24 10.8862176
Motegi Racing Touge Cast 18x10 28 12.7005872
Motegi Racing Touge Cast 18x7.5 24.5 11.1130138
Motegi Racing Touge Cast 18x9 26 11.7934024
Motegi Racing Touge Cast 19x10 26.3 11.92948012
Motegi Racing Touge Cast 19x8 24.6 11.15837304
Motegi Racing Touge Cast 19x9 25.2 11.43052848
Motegi Racing Trak Lite Forged 15x6.5 10.2 4.62664248
Motegi Racing Trak Lite Forged 15x7 10.8 4.89879792
Motegi Racing Trak Lite Forged 16x6.5 12.1 5.48846804
Motegi Racing Trak Lite Forged 16x7 12.5 5.669905
Motegi Racing Trak Lite Forged 17x7 14.5 6.5770898
Motegi Racing Trak Lite Forged 17x8 15 6.803886
Motegi Racing Trak Lite Forged 19x7.5 19.4 8.79969256
Motegi Racing Trak Lite 2 Forged 15x7 10.3 4.67200172
Motegi Racing Trak Lite 2 Forged 17x8 14.6 6.62244904
Motegi Racing US7 Cast 17x7 27.4 12.42843176
Motegi Racing US7 Cast 18x7.5 29.8 13.51705352
Motegi Racing US7 Cast 20x7.5 34.5 15.6489378
Motoform Sekta Cast 17x7 30 13.607772
Motoform Talon Cast 17x7 30 13.607772
MRR GT1 Cast 19x8.5 24.5 11.1130138
MRR GT1 Cast 19x9.5 27.7 12.56450948
MRT Steel 13x7 17 7.7110708
MRT Steel 15x7 23 10.4326252
MRT Steel 15x8 24 10.8862176
MRT Billet/Carbon Fiber 15x10 10 4.535924
MRT Steel 15x10 26 11.7934024
MSD Millenium Cast 16x7 20.3 9.20792572
MSR 190 Cast 17x7 18.2 8.25538168
MSR 197 Cast 20x7.5 38.3 17.37258892
MSW Type 11 Cast 15x7 18 8.1646632
MSW Type 11 Cast 17x7 21 9.5254404
MSW Type 11 Cast 17x8 23 10.4326252
MSW Type 11 Cast 18x8 25 11.33981
MSW Type 12 Cast 17x8 24 10.8862176
MSW Type 12 Cast 18x8 26.8 12.15627632
MSW Type 12 Cast 19x8 28.5 12.9273834
MSW Type 14 Cast 15x6.5 17.5 7.937867
MSW Type 14 Cast 17x7 21 9.5254404
MSW Type 14 Cast 17x8 22 9.9790328
MSW Type 14 Cast 18x8 24.5 11.1130138
MSW Type 15 Cast 15x6.5 17.5 7.937867
MSW Type 15 Cast 17x8 23.5 10.6594214
MSW Type 15 Cast 18x8 27 12.2469948
MSW Type 16 Cast 18x8 26 11.7934024
MSW Type 45 Cast 15x7 20 9.071848
MSW Type 55 Cast 15x7 22 9.9790328
Mugen GP Forged 17x7 15.2 6.89460448
Mugen GP Forged 17x7.5 15.8 7.16675992
Mugen GP Forged 17x8.5 16.5 7.4842746
Mugen GP Forged 18x7.5 17 7.7110708
Mugen M12 (made by OZ Racing) Cast 17x7 20 9.071848
Mugen M7 Forged/Spun (Brittle) 15x6 13 5.8967012
Mugen MF10 Forged 16x7 11 4.9895164
Mugen MF10 Forged 17x7.5 14 6.3502936
Mugen MF10 Forged 17x8.5 16 7.2574784
Mugen MF10L Forged 15x6.5 10.5 4.7627202
Mugen MF10L Forged 15x7 11 4.9895164
Mugen MF8 Forged 16x7 12 5.4431088
Mugen MR5 Forged/Spun 15x6 15 6.803886
Mugen MZ3x Cast 17x7 17.5 7.937867
Mugen NR Cast 15x6.5 16.8 7.62035232
Mugen RG Cast (soft) 15x6.5 10.5 4.7627202
Mugen RG Cast 16x7 13 5.8967012
Mugen RNR Cast (soft) 15x6.5 10.5 4.7627202
MVR Magnum Cast 19x8.5 24 10.8862176
Myrtle Shoot Cast 17x8 33 14.9685492
Nakayama RS 6 Speed Cast 17x7 19 8.6182556
Nakayama RS Mach 7 Cast 17x7 19.6 8.89041104
Nakayama RS Phantom GT-R Cast 17x7 19.3 8.75433332
Nakayama RS TS6 Cast 17x7 17.6 7.98322624
NAR Type II Cast 14x6.5 10.4 4.71736096
NEEZ BM7S Cast 17x7.5 17.2 7.80178928
NEEZ Euro Cross Cast 16x7.5 15 6.803886
Niche Bella Cast 17x7 25.5 11.5666062
Niche Bella Cast/Spun 19x8 30 13.607772
Niche E-tune Cast 17x8 25 11.33981
Niche Mecha Cast 18x7 25 11.33981
Niche Pultec Cast 18x7 25.5 11.5666062
Niche Pultec Cast 20x8.5 33.8 15.33142312
Niche Spitfire Cast 20x8.5 39.5 17.9168998
Niche Throttle Cast 17x7.5 24.8 11.24909152
Niche Venice Cast 19x10 32.6 14.78711224
Niche Venice Cast 19x8.5 32.2 14.60567528
Nippon Racing Advantispeed Cast 17x7 24 10.8862176
Nippon Racing Evolution Cast 17x7 21 9.5254404
Nippon Racing F2 Cast 15x6.5 12 5.4431088
Nippon Racing Formula 1 Cast 17x7 20.8 9.43472192
Nippon Racing Hyperspeed Cast 17x7 22.3 10.11511052
Nippon Racing Indy Cup Cast 17x7 22.3 10.11511052
Nippon Racing Intertouring Cup Cast 17x7 21 9.5254404
Nippon Racing Sassy Cast 17x7 22 9.9790328
Nippon Racing Scorpion Cast 17x7 21.2 9.61615888
Nippon Racing Taiko Cast 17x7 22.4 10.16046976
Nippon Racing Type C Cast 15x6.5 13 5.8967012
Nippon Racing Version 2 Cast 17x7 21.8 9.88831432
Nippon Racing Version 5 Cast 17x7 22.8 10.34190672
Nippon Racing Version 5 Cast 18x8 26.5 12.0201986
Nippon Racing Wishbone Cast 17x7 23 10.4326252
Nippon Racing Zen Cast 15x6.5 13.4 6.07813816
Nismo LM GT Magnesium Forged Mg 18x10 17.1 7.75643004
Nismo LM GT4 Forged 18x8.5 18.1 8.21002244
Nismo LM GT4 Forged 18x9.5 19 8.6182556
Nismo LM GT4 Forged 19x8.5 20.4 9.25328496
Nismo LM GT4 Forged 19x9.5 20.7 9.38936268
Nissan 200SX 84 Cast 14x5.5 15 6.803886
Nissan 200SX 84-87 Cast 15x6 19 8.6182556
Nissan 200SX Turbo 85-86 Cast 15x6 19 8.6182556
Nissan 240SX 89-90 Cast 15x6 16 7.2574784
Nissan 240SX 91-94 Cast 15x6 18 8.1646632
Nissan 240SX 95-96 Cast 15x6 15 6.803886
Nissan 240SX 95-98 LE and SE Cast 16x6.5 18.5 8.3914594
Nissan 300ZX 84-85 Cast 15x6.5 19 8.6182556
Nissan 300ZX NA and TT front Cast 16x7.5 19 8.6182556
Nissan Altima 93-97 Cast 15x6 17 7.7110708
Nissan Altima 98-01 Cast 16x6 18 8.1646632
Nissan Maxima 85-86 Cast 15x6 20 9.071848
Nissan Maxima 87-88 Cast 15x6 17 7.7110708
Nissan Maxima 95-99 GLE Cast 15x6.5 16.5 7.4842746
Nissan Maxima 95-99 SE Cast 16x6.5 19.6 8.89041104
Nissan Sentra SE + SE-R 01-02 Cast 16x6 18 8.1646632
Nissan Sentra SE-R Spec V 02 Cast 17x7 24 10.8862176
Nissan Skyline GTR 89-94 Forged 16x8 16 7.2574784
Nissan Stanza 90-92 Cast 14x6 15 6.803886
NZO 050 Cast 16x6.5 12.8 5.80598272
NZO 213 Cast 18x7.5 27 12.2469948
NZO 214 Hyper Cast 18x7.5 28 12.7005872
Oettinger RE Cast 18x8 24.8 11.24909152
Oettinger RZ Cast 18x8 29.6 13.42633504
Omni Concept GT Champion Cast 20x9.5 29.3 13.29025732
OZ 35th Anniverary Cast 15x6.5 19 8.6182556
OZ 35th Anniverary Cast 16x7 22 9.9790328
OZ 35th Anniverary Cast 17x7 24 10.8862176
OZ 35th Anniverary Cast 17x8 27 12.2469948
OZ 35th Anniverary Cast 18x8 29.1 13.19953884
OZ Alleggertia HLT Cast 17x7 14 6.3502936
OZ Antares Cast 18x8 25 11.33981
OZ Botticelli Cast 17x8 21.5 9.7522366
OZ Botticelli Cast 18x8 22.2 10.06975128
OZ Botticelli Cast 18x9 23 10.4326252
OZ Canova Cast 15x7 19.2 8.70897408
OZ Canova Cast 16x7 21.5 9.7522366
OZ Canova Cast 17x7 25.5 11.5666062
OZ Canova Cast 17x8 26 11.7934024
OZ Canova Cast 18x7 27 12.2469948
OZ Canova Cast 18x8 28.4 12.88202416
OZ Canova Cast 19x8 29.5 13.3809758
OZ Canyon II Cast/Spun 18x8 30.9 14.01600516
OZ Carvagio Cast 16x7 23 10.4326252
OZ Carvagio Cast 17x7 25.5 11.5666062
OZ Carvagio Cast 17x8 27 12.2469948
OZ Carvagio Cast 18x8 29.5 13.3809758
OZ Carvagio Cast 19x8 34 15.4221416
OZ Competition Cast 17x8.5 30 13.607772
OZ Crono EVO Cast 17x7 19 8.6182556
OZ Crono EVO Cast 18x8 20 9.071848
OZ Crono HLT Cast 19x8 21 9.5254404
OZ Crono HT Cast 15x7 13.5 6.1234974
OZ Crono HT Cast 16x7 15.7 7.12140068
OZ Crono HT Cast 17x7 18 8.1646632
OZ Crono HT Cast 18x8 18.8 8.52753712
OZ F1 Cup Cast 16x7 22 9.9790328
OZ F1 Cup Cast 17x7 25 11.33981
OZ F1 Cup Cast 18x8 25.3 11.47588772
OZ F1 Plus Cast 17x7.5 26 11.7934024
OZ Forgiata Forged 17x7.5 13.2 5.98741968
OZ Forgiata Forged 18x8.5 16.5 7.4842746
OZ Galileo III Cast/Spun 18x8 28 12.7005872
OZ Galileo III Cast/Spun 18x8.5 30 13.607772
OZ Galileo III Cast/Spun 19x10 30.7 13.92528668
OZ Galileo III Cast/Spun 19x8 28.6 12.97274264
OZ Galileo III Cast/Spun 19x8.5 29.6 13.42633504
OZ Giotti II Cast/Spun 19x10 35.5 16.1025302
OZ Giotti II Cast/Spun 19x8.5 33.2 15.05926768
OZ Hydra Cast 15x7 20.6 9.34400344
OZ Hydra Cast 17x7 23 10.4326252
OZ Hydra Cast 17x8 25 11.33981
OZ Leonardo III Cast/Spun 19x8.5 32.4 14.69639376
OZ Leonardo III Cast/Spun 19x9.5 32 14.5149568
OZ Michelangelo 10 Cast 17x7.5 28 12.7005872
OZ Michelangelo 8 Cast 15x6.5 20.5 9.2986442
OZ Michelangelo 8 Cast 16x7 23.8 10.79549912
OZ Michelangelo 8 Cast 17x7 26 11.7934024
OZ Michelangelo II Cast/Spun 18x8.5 32.5 14.741753
OZ Michelangelo II Cast/Spun 19x9.5 37.2 16.87363728
OZ Mito Modular Cast 17x7 27 12.2469948
OZ Opera EVO Cast 18x8 26 11.7934024
OZ Palladio Cast 17x7.5 22.5 10.205829
OZ Palladio Cast 18x8 25.5 11.5666062
OZ Palladio Cast 19x8 27.5 12.473791
OZ Prodrive P1 Cast 17x7 20.4 9.25328496
OZ Racing F1 Cast 15x7 19.8 8.98112952
OZ Raffaello III Cast/Spun 19x8 26 11.7934024
OZ Raffaello III Cast/Spun 19x9.5 27.2 12.33771328
OZ Record Cast 15x6.5 19.4 8.79969256
OZ Record Cast 16x7 21 9.5254404
OZ Record Cast 17x7 21.2 9.61615888
OZ Record Cast 17x7.5 22.2 10.06975128
OZ Record Cast 18x7 22.5 10.205829
OZ Record Cast 18x7.5 24 10.8862176
OZ Salina Cast 18x8 28 12.7005872
OZ Sardegna Cast 18x8 29 13.1541796
OZ Sardegna Cast 19x8 31 14.0613644
OZ Sardegna Cast 19x9 34 15.4221416
OZ Superleggera Cast 15x7 11.5 5.2163126
OZ Superleggera Cast 16x7 14.6 6.62244904
OZ Superleggera Cast 17x7 15.2 6.89460448
OZ Superleggera Cast 17x8 15.9 7.21211916
OZ Superleggera Cast 18x8 17.6 7.98322624
OZ Superleggera Forged 19x8 21.5 9.7522366
OZ Superleggera III Forged/Spun 18x8 24 10.8862176
OZ Superleggera III Forged/Spun 18x8.5 24.7 11.20373228
OZ Superleggera III Forged/Spun 19x10 26.8 12.15627632
OZ Superleggera III Forged/Spun 19x8 24.7 11.20373228
OZ Superleggera III Forged/Spun 19x8.5 25.3 11.47588772
OZ Superleggera III Forged/Spun 19x9.5 27 12.2469948
OZ Superturismo Evolution Cast 17x7 18 8.1646632
OZ Superturismo GT Cast 15x6.5 18.5 8.3914594
OZ Superturismo GT Cast 16x7 19.6 8.89041104
OZ Superturismo GT Cast 17x7 20.7 9.38936268
OZ Superturismo GT Cast 17x7.5 21.5 9.7522366
OZ Superturismo GT Cast 17x8 23 10.4326252
OZ Superturismo GT Cast 18x8 25.2 11.43052848
OZ Superturismo GT Cast 19x8 26.7 12.11091708
OZ Superturismo WRC Cast 15x6.5 18.8 8.52753712
OZ Superturismo WRC Cast 16x7 21 9.5254404
OZ Superturismo WRC Cast 17x7 21.4 9.70687736
OZ Titan Cast 17x8 23.4 10.61406216
OZ Titan Cast 18x8 25.1 11.38516924
OZ Tribe EVO Cast 17x8 27.5 12.473791
OZ Tribe EVO Cast 18x7 27 12.2469948
OZ Tribe EVO Cast 18x8 29 13.1541796
OZ Ultraleggera Cast 15x7 12.4 5.62454576
OZ Ultraleggera Cast 16x7 14.5 6.5770898
OZ Ultraleggera Cast 17x7 16 7.2574784
OZ Ultraleggera Cast 17x8 17 7.7110708
OZ Ultraleggera Cast 18x7 17.6 7.98322624
OZ Ultraleggera Cast 18x8 18.6 8.43681864
OZ Ultraleggera Cast 18x9 19.2 8.70897408
OZ Ultraleggera Cast 19x8 20.6 9.34400344
OZ Vela Cast/Spun 18x8 24.5 11.1130138
OZ Vela Cast/Spun 18x9 25.3 11.47588772
OZ Volcano Cast 16x7 23 10.4326252
OZ Volcano Cast 18x8 26.3 11.92948012
Palo Uber Signature Forged 17x7 15 6.803886
Palo Uber Signature Forged 18x7.5 16 7.2574784
Palo Uber Web Cast 17x7 20.5 9.2986442
Panasport C8 Cast/Spun 13x9 10.5 4.7627202
Panasport FC Cast 14x6 14 6.3502936
Panasport FC Cast 16x7 17 7.7110708
Panasport FS Cast 13x6 10 4.535924
Panasport FS Cast 15x6 15 6.803886
Panasport FS Lite Cast 13x6 9.5 4.3091278
Panasport FS Lite Cast 13x7 10 4.535924
Panasport Pro Rallye Cast 14x6 14.5 6.5770898
Panasport ULW Cast 13x6 13.5 6.1234974
Panasport ULW Cast 14x6 14.1 6.39565284
Panasport ULW Cast 15x7 16 7.2574784
Panasport ULW Cast 16x7 17 7.7110708
Panther EMR151 Cast 16x7.5 20.8 9.43472192
Panther EMR175 Cast 17x7 24.5 11.1130138
Panther EMR200 Cast 17x7 22.3 10.11511052
Panther EMR219 Cast 18x7.5 21.6 9.79759584
Panther EMR220 Cast 18x7 25 11.33981
Paradyme F206 Cast 17x7.5 23 10.4326252
Paradyme F220 Cast 18x7.5 25.8 11.70268392
Paulsen Racing 13x5.5 17 7.7110708
PCW Panther Cast 17x7.5 23 10.4326252
PCW Panther Cast 18x8 29.3 13.29025732
Performance Industries (race only) 13x7 15 6.803886
Performance Specialties Superlite Cast 13x6 13 5.8967012
Peugeot 205GTI - Speedline Cast 15x6 19.6 8.89041104
Peugeot 205GTI - Speedline SL201 Cast 14x5.5 15.4 6.98532296
PIAA FR-7 Cast/Spun 15x5 10.4 4.71736096
PIAA FR-7 Cast/Spun 15x6.5 12.2 5.53382728
PIAA FR-7 Cast/Spun 16x7 15.6 7.07604144
PIAA FR-7 Cast/Spun 17x7.5 18 8.1646632
PIAA FR-7 Cast/Spun 17x8 18.5 8.3914594
PIAA FR-S Cast 17x7 21 9.5254404
PIAA FR-S Cast 18x7.5 23 10.4326252
PIAA FR-S Cast 18x9.5 29 13.1541796
PIAA Sport Mesh Cast 17x7 21 9.5254404
PIAA Sport Mesh Cast 17x8 23 10.4326252
PIAA Sport Mesh Cast 18x7.5 23.4 10.61406216
PIAA Sport Mesh Cast 18x8.5 26 11.7934024
PIAA Sport Mesh Cast 18x9.5 29 13.1541796
PIAA Super Rozza Cast/Spun 18x7.5 22 9.9790328
PIAA Super Rozza Cast/Spun 18x8 23 10.4326252
PIAA Super Rozza Cast/Spun 19x10 26 11.7934024
PIAA Super Rozza Cast/Spun 19x7.5 23.2 10.52334368
PIAA Super Rozza Cast/Spun 19x8 24 10.8862176
PIAA Super Rozza Cast/Spun 19x8.5 25 11.33981
PIAA Super Rozza Cast/Spun 19x9 25 11.33981
PIAA Super Rozza Cast/Spun 20x10 27.5 12.473791
PIAA Super Rozza Cast/Spun 20x8.5 26 11.7934024
PIAA Super Rozza Cast/Spun 20x9 27 12.2469948
PIAA Super Rozza Monoblock Cast 18x8 23 10.4326252
PIAA Super Rozza Monoblock Cast 19x8 24 10.8862176
Platinum FX-2 Cast 18x7 25 11.33981
Platinum Koge Cast 17x7 24.5 11.1130138
Platinum Krees (Type 143) Cast 20x8.5 35 15.875734
Platinum Stinger (Type 141) Cast 20x8.5 41 18.5972884
Polo Monarch Cast 20x8.5 39 17.6901036
Polo Tornado Cast 17x7.5 33 14.9685492
Polo Warlock Cast 17x7.5 35 15.875734
Porsche 911 Fuchs Forged 16x6 17 7.7110708
Porsche 911 Fuchs Forged 16x7 18 8.1646632
Porsche 911 Fuchs Forged 16x8 19 8.6182556
Porsche 911 Fuchs Forged 16x9 20 9.071848
Porsche 914 6-cylinder 5-bolt Mahle (rare) Forged Mg 15x5.5 10 4.535924
Porsche 928CS Forged 16x8 19 8.6182556
Porsche 944 Turbo S/951S Design 90 ""Clubsport"" Forged 16x7 18.5 8.3914594
Porsche 944 Turbo S/951S Design 90 ""Clubsport"" Forged 16x9 20 9.071848
Porsche 944 Turbo/951 ""Flat Dish"" Forged 16x7 18.5 8.3914594
Porsche 944 Turbo/951 ""Flat Dish"" Forged 16x8 20 9.071848
Porsche 944 Turbo/951 ""Phone Dial"" Cast 16x7 18.5 8.3914594
Porsche 944 Turbo/951 ""Phone Dial"" Cast 16x8 20 9.071848
Porsche 944 Turbo/951 ""Phone Dial"" - Optional Cast Mg 16x8 16.1 7.30283764
Porsche 944 Turbo/951 ""Phone Dial"" - Optional Cast Mg 16x9 16.5 7.4842746
Porsche 944 Turbo/951 Fuchs Forged 16x7 15 6.803886
Porsche 944 Turbo/951 Fuchs Forged 16x8 16 7.2574784
Porsche 944S2 Cast 16x7 18.7 8.48217788
Porsche 944S2 Cast 16x8 22 9.9790328
Porsche 968 Cast 17x7.5 20 9.071848
Porsche 968 Cast 17x9 23 10.4326252
Porsche 993 Cast 17x7.5 18 8.1646632
Porsche 993 Cast 17x9 19.5 8.8450518
Porsche 996 Cast 17x7 19.1 8.66361484
Porsche 996 Cast 17x9 22.3 10.11511052
Porsche 996 Cast 18x10 23.4 10.61406216
Porsche 996 Cast 18x8 20 9.071848
Porsche Boxter Cast 17x7 20.3 9.20792572
Porsche Boxter Cast 17x8.5 22.7 10.29654748
Porsche Carrera S 987/997 Cast 19x8 22.3 10.11511052
Porsche Carrera S 987/997 Cast 19x9.5 24.7 11.20373228
Porsche Cayenne S Cast 20x8.5 31 14.0613644
Porsche Club Sports Cast 16x7 19 8.6182556
Porsche Club Sports Cast 16x9 21.5 9.7522366
Porsche Cup Cast 18x10 29.3 13.29025732
Porsche Cup Cast 18x8 26.2 11.88412088
Power Racing VS-01 Cast 17x7 19.5 8.8450518
Power Racing VS-01 Cast 18x7.5 20.5 9.2986442
Power Racing VS-04 Cast 15x6.5 12.3 5.57918652
Power Racing VS-04 Cast 16x7 14.3 6.48637132
Power Racing VS-04 Cast 17x7 16.5 7.4842746
Power Racing VS-05 Cast 17x7 22.5 10.205829
Primax 618 Tuner Cast 17x7 22.5 10.205829
Primax 684 Cast 15x7 18 8.1646632
ProDrive GC-010 Forged 18x8 19 8.6182556
ProDrive GC-05F Forged 18x8 18.3 8.30074092
ProDrive GC-07C Forged 17x7.5 15.2 6.89460448
ProDrive GC-07C Forged 18x9.5 18.2 8.25538168
ProDrive GC-10E Forged 17x7.5 15.2 6.89460448
ProDrive GT1 Cast 17x8.5 20.4 9.25328496
ProDrive P1 Cast 17x7 22 9.9790328
ProDrive P1 Cast 18x7.5 23.4 10.61406216
ProDrive P7 Cast 17x7 22.4 10.16046976
Progressive Pro 293 Cast 16x7 24 10.8862176
Proline B700 Cast 16x6.5 18.6 8.43681864
Proline B700 Cast 16x7.5 19.8 8.98112952
Proline B700 Cast 17x7.5 21.6 9.79759584
Proline B800 Cast 14x6 13.668644 6.2
Proline B800 Cast 15x6.5 14.991416 6.8
Proline B800 Cast 16x6.5 16.314188 7.4
Proline B800 Cast 16x7 18.077884 8.2
Proline B800 Cast 17x7.5 21.384814 9.7
Proline B900 Cast 15x6.5 16.314188 7.4
Proline B900 Cast 16x7 18.518808 8.4
Proline B900/s Cast 16x7 20.502966 9.3
Proline PB Cast 17x8 24.25082 11
Proline PB Cast 18x8 27.337288 12.4
Proline PCC Cast 14x6 14.109568 6.4
Proline PCC Cast 15x7 18.077884 8.2
Proline PCC Cast 16x7.5 20.723428 9.4
Proline PCC Cast 17x8 24.912206 11.3
Proline PD Cast 16x7.5 19.621118 8.9
Proline PE Cast 17x8 25.35313 11.5
Proline PE Cast 17x9 27.998674 12.7
Proline PE Cast 18x9 29.982832 13.6
Proline PF Cast 14x6 15.652802 7.1
Proline PF Cast 15x7 18.73927 8.5
Proline PF Cast 16x7.5 22.487124 10.2
Proline PG Cast 16x7 20.723428 9.4
Proline PG Cast 17x7.5 23.809896 10.8
Proline PG Cast 18x8 26.675902 12.1
Proline PG Cast 20x9 32.407914 14.7
Proline PI Cast 17x7.5 23.14851 10.5
Proline PI Cast 18x8 25.35313 11.5
Proline PI Cast 19x8.5 29.541908 13.4
Proline PJ Cast 16x7 23.368972 10.6
Proline PJ Cast 17x7 26.675902 12.1
Proline PJ Cast 17x8 27.55775 12.5
Proline PJ Cast 18x8 29.321446 13.3
Proline PJ Cast 18x9.5 32.187452 14.6
Proline PJ Cast 19x8.5 35.053458 15.9
Proline PK Cast 16x7.5 19.84158 9
Proline PK Cast 17x7.5 22.0462 10
Proline PK Cast 18x8 24.25082 11
Proline PK Cast 19x8.5 28.66006 13
Proline PL Cast 15x6.5 17.196036 7.8
Proline PL Cast 16x7.5 20.94389 9.5
Proline PL Cast 17x7 22.0462 10
Proline PL Cast 17x7.5 23.809896 10.8
Proline PL Cast 17x8 24.25082 11
Proline PL Cast 18x8 27.55775 12.5
Proline PM Cast 16x7 20.502966 9.3
Proline PM Cast 17x7.5 25.35313 11.5
Proline PM Cast 18x8 27.55775 12.5
Proline PP Cast 18x8 28.219136 12.8
Proline PP Cast 19x8.5 28.66006 13
Proline PQ Cast 15x6.5 17.857422 8.1
Proline PQ Cast 16x7.5 19.180194 8.7
Proline PR Cast 17x7.5 22.0462 10
Proline PR Cast 18x8 25.132668 11.4
Proline PR Cast 19x8.5 29.321446 13.3
Proline PS Cast 17x7 26.45544 12
Proline PS Cast 18x8 28.66006 13
Proline PS Cast 19x8.5 30.86468 14
Proline PU Cast 15x6.5 15.43234 7
Proline PU Cast 16x7 18.518808 8.4
Proline PU Cast 17x7 20.723428 9.4
Proline PU Cast 17x8 22.928048 10.4
Proline PU Cast 18x8 26.234978 11.9
Proline PV Cast 14x6 13.22772 6
Proline PV Cast 15x6.5 14.33003 6.5
Proline PV Cast 16x6.5 15.211878 6.9
Proline PV Cast 16x7 17.63696 8
Proline PV Cast 17x7 17.196036 7.8
Proline PV Cast 18x7.5 21.605276 9.8
Proline PV/s Cast 17x8 23.14851 10.5
Proline PW Cast 16x7 20.723428 9.4
Proline PY Cast 15x7 19.84158 9
Proline PY Cast 16x7 24.25082 11
Proline PY Cast 17x7 26.45544 12
Proline PY Cast 17x8 27.55775 12.5
Proline PY Cast 18x7.5 29.76237 13.5
Proline PY Cast 18x8.5 30.86468 14
Proline PZ Cast 15x7 17.196036 7.8
Proline PZ Cast 16x7.5 21.384814 9.7
Proline PZ Cast 17x8 25.35313 11.5
PS Engineering Halibrand Replicas Cast 15x7 16 7.2574784
PS Engineering TA II Cast 15x7 16 7.2574784
Quantum Tek S-05 Cast 17x7.5 25.3 11.47588772
Quantum Tek S-05 Cast 18x7.5 29.3 13.29025732
Quantum Tek S-06 Cast 17x7.5 26 11.7934024
Quantum Tek S-07 Cast 18x7.5 28.5 12.9273834
Quantum Tek S-08 Cast 16x7 24 10.8862176
Quantum Tek S-10 Cast 15x7 18.5 8.3914594
Quantum Tek S-10 Cast 18x7.5 24.3 11.02229532
Quantum Tek S-11 Cast 16x7 19.5 8.8450518
Quantum Tek S-13 Cast 18x7.5 27 12.2469948
Quantum Tek S-14 Cast 18x7.5 22 9.9790328
Quantum Tek S-15 Cast 18x7.5 21.4 9.70687736
RAC Monolites RS110 Forged 16x7 11.3 5.12559412
RAC Monolites RS110 Forged 17x8 13.3 6.03277892
Race Inc RPK 133 C-Sport Cast 19x10 26.5 12.0201986
Race Inc RPK 133 C-Sport Cast 19x11.5 27.8 12.60986872
Race Inc RPK 133 C-Sport Cast 19x8.5 23.5 10.6594214
Raceline RL-7 Cast 15x7 19.8 8.98112952
Racing Beat RB-02 (made by Racing Hart) Cast/Spun 15x6.5 16 7.2574784
Racing Dynamics RGQ Cast 19x9.5 29.5 13.3809758
Racing Dynamics RGS Cast 17x8 27 12.2469948
Racing Dynamics RS-2 Cast 19x10 25.5 11.5666062
Racing Dynamics RS-2 Cast 19x8 24 10.8862176
Racing Firrenze RF-Pro Forged 15x6.5 9.8 4.44520552
Racing Gear RG-6 Cast 15x6.5 12 5.4431088
Racing Gear RG-6 Cast 16x7 16 7.2574784
Racing Hart C2 Cast 18x10 24 10.8862176
Racing Hart C2 Cast 18x8.5 21.5 9.7522366
Racing Hart C4 1-piece Cast 18x7.5 24 10.8862176
Racing Hart C5 Cast 18x8.5 28 12.7005872
Racing Hart CP-035R Forged 15x6 7.9 3.58337996
Racing Hart CP-035R Forged 15x6.5 8.6 3.90089464
Racing Hart CP-035R Forged 15x7 9.4 4.26376856
Racing Hart CP-035R Forged 15x7.5 9.7 4.39984628
Racing Hart CP-035R Forged 16x7 10.8 4.89879792
Racing Hart CP-035R Forged 16x7.5 11.2 5.08023488
Racing Hart CP-035R Forged 16x8 11.5 5.2163126
Racing Hart CP-035R Forged 17x7.5 13 5.8967012
Racing Hart CP-035R Forged 17x8 13.6 6.16885664
Racing Hart CP-035R Forged 17x8.5 14.4 6.53173056
Racing Hart CP-035R Forged 17x9 15 6.803886
Racing Hart CP-035R Forged 17x9.5 15.2 6.89460448
Racing Hart CP-035R Forged 18x7.5 19.7 8.93577028
Racing Hart CP-035R Forged 18x8.5 20.2 9.16256648
Racing Hart CP10 Forged 18x8 18 8.1646632
Racing Hart CP8 Forged 17x7 17 7.7110708
Racing Hart CP-F Forged 15x6.5 10.5 4.7627202
Racing Hart CP-S10 Cast 18x8.5 22.1 10.02439204
Racing Hart Evolution Cast 18x7.5 20.8 9.43472192
Racing Hart Evolution S7 EVO Cast 18x7.5 22.2 10.06975128
Racing Hart Evolution Z5000 Cast 19x7.5 23.3 10.56870292
Racing Hart Hyper Tuner Cast 16x7 17 7.7110708
Racing Hart M5 Cast 19x10 28.5 12.9273834
Racing Hart M6 Cast 18x7.5 26.3 11.92948012
Racing Hart Project 521 Cast/Spun 18x9 19.9 9.02648876
Racing Hart S7 Cast 17x7 19 8.6182556
Racing Hart Tracer Cast 17x10 18 8.1646632
Racing Hart Tuner Cast 15x6.5 15 6.803886
Racing Hart TypeC Cast 17x9.5 21 9.5254404
Racing Sparco Cromodora Cast 16x7 20.5 9.2986442
Racing Sparco D-Spec Stage I Cast 17x7 21 9.5254404
Racing Sparco LE Forged 16x7 11.7 5.30703108
Racing Sparco LE Forged 17x8 14.6 6.62244904
Racing Sparco NS-II Python Cast 17x7 22 9.9790328
Racing Sparco NT Cast 18x8 26 11.7934024
Racing Sparco NT-R Cast 17x7 15.4 6.98532296
Racing Sparco NT-R Cast 17x8 16.7 7.57499308
Racing Sparco NT-R Cast 17x9 17.2 7.80178928
Racing Sparco Viper R (Japan Only) Forged/Spun 15x6.5 9 4.0823316
Racing Sparco Viper R (Japan Only) Forged/Spun 16x7 11.2 5.08023488
Racing Sparco Viper R (Japan Only) Forged/Spun 17x7 13.7 6.21421588
Racing Sparco Viper R (Japan Only) Forged/Spun 18x8.5 16.3 7.39355612
Rage 10 Cast 15x6.5 16 7.2574784
Rage Breaker Cast 17x7 19 8.6182556
Rage Enduro Cast 17x7 21 9.5254404
Rage Motif Cast 17x7 19.8 8.98112952
Rage Split Cast 17x7 21.8 9.88831432
Rage Vigor Cast 16x7 17.8 8.07394472
Rage Vulcan Cast 18x8 26.5 12.0201986
Raptor Racing GX-T Cast 17x7 24 10.8862176
Raptor Racing MZ-1 Cast 17x7 25.6 11.61196544
Rays Master Pieces DIA 106 Cast/Spun 19x8 31 14.0613644
Rays Master Pieces DIA 106 Cast/Spun 19x9.5 31.5 14.2881606
Raze R24 Cast 17x7 20 9.071848
Raze R74 Cast 17x7 19 8.6182556
RD Sport C4 Cast 19x8.5 24.8 11.24909152
RD Sport RS-4 Cast 19x9.5 27.5 12.473791
RD Sport S4 Cast 19x10 27.3 12.38307252
Real Racing Cast 13x7 10.4 4.71736096
Real Racing Cast 15x7 12.7 5.76062348
Real Racing R-5 Cast 17x7 18 8.1646632
Renault Alpine GTA Cast 15x6 14 6.3502936
Renault Alpine GTA Cast 15x8.5 17 7.7110708
Renntech RS118 Forged 19x9 23 10.4326252
Revolution ""ScoobySport"" Cast 17x7 18.7 8.48217788
Revolution Classic 4-Spoke Race Cast 13x5.5 8.8 3.99161312
Revolution Classic 4-Spoke Race Cast 13x6 11 4.9895164
Revolution Classic 4-Spoke Race Cast 13x7 10.2 4.62664248
Revolution Classic 5-Spoke Race Cast 15x7 16.8 7.62035232
Revolution Classic 5-Spoke Race Cast 15x7 18.1 8.21002244
Revolution Classic 5-Spoke Race Cast 15x8 16 7.2574784
Revolution RFX Race Cast 13x6 11.5 5.2163126
Revolution RFX Race Cast 14x6 11.8 5.35239032
Revolution RFX Race Cast 14x7 12.5 5.669905
Revolution RFX Race Cast 15x7 15.3 6.93996372
Revolution RFX Race Cast 16x7 17.8 8.07394472
Revolution RFX Rally Cast 15x6 18.3 8.30074092
Revolution RFX Rally Cast 15x7 18.8 8.52753712
Revolution RFX Road Cast 16x7 20.3 9.20792572
Revolution RZX Race Cast 17x7 18.3 8.30074092
Revolution RZX Rally Cast 17x7 22.5 10.205829
Revolution RZX Road Cast 17x7.5 22.5 10.205829
Rial Bari Cast 17x8 23 10.4326252
Rial Campo Cast 15x6.5 17 7.7110708
Rial Como Cast 15x7 18.4 8.34610016
Rial Como Cast 16x7 20.2 9.16256648
Rial Como Cast 17x7.5 22.8 10.34190672
Rial Como Cast 18x8 26 11.7934024
Rial DF Cast 17x8 24.5 11.1130138
Rial Flair Cast 16x6 20 9.071848
Rial Monza Cast 17x7.5 22.3 10.11511052
Rial MS Cast 15x7 17.2 7.80178928
Rial Nogaro Cast 17x8 21.5 9.7522366
Rial Nogaro Cast 18x8 23.5 10.6594214
Rial Nogaro Cast 19x8 25.4 11.52124696
Rial Porto Cast 16x7 20.5 9.2986442
Rial Porto Cast 17x7.5 22.5 10.205829
Rial Porto Cast 18x8 26.6 12.06555784
Rial Ravenna Cast 16x7.5 22 9.9790328
Rial Ravenna Cast 17x8 25 11.33981
Rial Viper D70 Cast 15x7 17 7.7110708
Rial Viper D70 Cast 17x7.5 26.5 12.0201986
Riverside Trafficstar DTM Cast 19x9 27.8 12.60986872
Riverside Trafficstar DTS Cast 19x10 28.4 12.88202416
Ro_Ja Formula 5 Forged 17x7 14.5 6.5770898
Ro_Ja Formula 5 Forged 18x7 18 8.1646632
Ro_Ja Formula 5 Forged 18x8 19 8.6182556
Ro_Ja Formula 5 Forged 18x9 20 9.071848
Ro_Ja Formula 5 Forged 19x8 22 9.9790328
Ro_Ja Formula 5 Forged 19x9 24 10.8862176
Ro_Ja GT-M Cast 18x8 27 12.2469948
Ro_Ja Kruzz Cast 19x8 26.2 11.88412088
Ro_Ja Neo5 Cast 19x8 26.2 11.88412088
Ro_Ja R2-5 Cast 18x10 23.4 10.61406216
Ro_Ja R2-5 Cast 18x7.5 22.8 10.34190672
Ro_Ja R2-5 Cast 18x8 23.1 10.47798444
Ro_Ja R2-5 Cast 19x10.5 28 12.7005872
Ro_Ja R2-5 Cast 19x8.5 26.7 12.11091708
Ro_Ja R2-5 Cast 19x9.5 27.1 12.29235404
Ro_Ja R2-7 Cast 18x10 24.9 11.29445076
Ro_Ja R2-7 Cast 18x7.5 23.2 10.52334368
Ro_Ja R2-7 Cast 18x8 23.8 10.79549912
Ro_Ja R2-7 Cast 18x8.5 24.2 10.97693608
Ro_Ja R2-7 Cast 18x9 24.3 11.02229532
Ro_Ja R2-7 Cast 19x10 28.5 12.9273834
Ro_Ja R2-7 Cast 19x8.5 27.1 12.29235404
Ro_Ja R2-7 Cast 19x9 27.8 12.60986872
ROH Adrenaline Cast 17x7 23.1 10.47798444
ROH Adrenaline Cast 17x8 24.2 10.97693608
ROH Adrenaline Cast 18x7 25.6 11.61196544
ROH Astron Cast 17x7.5 23.3 10.56870292
ROH Azzurro Cast 18x8 28.5 12.9273834
ROH Blade Cast 17x7 25 11.33981
ROH Illusion Cast 16x7 25 11.33981
ROH Reflex Cast 16x7 15.5 7.0306822
ROH Reflex Cast 17x7.5 23.5 10.6594214
ROH Snyper Cast 15x7 15 6.803886
ROH Snyper Cast 16x8 19 8.6182556
ROH Snyper Cast 17x9 26 11.7934024
ROH ZS Cast 17x8.5 23 10.4326252
ROH ZS Cast 17x9.5 28 12.7005872
Ronal ACT Cast 17x9.5 22 9.9790328
Ronal Bear Cast 14x6 18.3 8.30074092
Ronal LS Cast 15x7.5 16.7 7.57499308
Ronal LV (Spider) Cast 15x7 15.9 7.21211916
Ronal LV (Spider) Cast 16x7.5 18.2 8.25538168
Ronal LV (Spider) Cast 17x8 21.4 9.70687736
Ronal LV (Spider) Cast 18x8.5 24.3 11.02229532
Ronal LW Cast 14x6 17.3 7.84714852
Ronal LW Cast 15x7.5 19 8.6182556
Ronal LZ (Eleganz) Cast 18x8.5 30.3 13.74384972
Ronal R-10 (Turbo) Cast 15x7 18 8.1646632
Ronal R-1001 Cast 17x8 22.5 10.205829
Ronal R-23 Cast 14x6 14.8 6.71316752
Ronal R-23 Cast 15x7 17.3 7.84714852
Ronal R-25 Cast 14x6 14.8 6.71316752
Ronal R-25 Cast 15x7 17.3 7.84714852
Ronal R-25 Cast 16x7.5 18.5 8.3914594
Ronal R-25 Cast 17x8 23.5 10.6594214
Ronal R-26 Cast 14x6 16.4 7.43891536
Ronal R-26 Cast 15x7 17.3 7.84714852
Ronal R-26 Cast 16x7.5 20.3 9.20792572
Ronal R-28 (Joker) Cast 14x6 16.4 7.43891536
Ronal R-28 (Joker) Cast 15x7 18.9 8.57289636
Ronal R-28 (Joker) Cast 16x7.5 24.1 10.93157684
Ronal R-28 (Joker) Cast 17x8.5 28.2 12.79130568
Ronal R-31 Cast 16x7 21.5 9.7522366
Ronal R-34 Cast 16x7.5 20.9 9.48008116
Ronal R-7 (Bulldog) Cast 17x7 25 11.33981
Ronal R-7 (Bulldog) Cast 18x8 27.8 12.60986872
Ronal RT (Twin) Cast 17x7.5 24.5 11.1130138
Ronal SL Cast 17x7.5 21.1 9.57079964
Ronal T-34 Cast 16x7.5 21 9.5254404
RonJon Devotion Forged 19x8.5 24 10.8862176
Rota Action Cast 17x7.5 17 7.7110708
Rota Attack Cast 15x6.5 13 5.8967012
Rota Attack Cast 17x7 16.5 7.4842746
Rota Auto X Cast 15x6.5 13 5.8967012
Rota Aztec Cast 15x6.5 16.4 7.43891536
Rota Aztec Cast 16x7 19 8.6182556
Rota Battle Cast 15x6.5 14 6.3502936
Rota Battle Cast 17x7.5 19 8.6182556
Rota Battle Cast 18x7.5 22 9.9790328
Rota Boost Cast 16x7 15.9 7.21211916
Rota Boost Cast 17x8 20 9.071848
Rota Boost Cast 18x9 23.5 10.6594214
Rota Circuit 10 Cast 15x6.5 13 5.8967012
Rota Circuit 10 Cast 16x7 17 7.7110708
Rota Circuit 10 Cast 17x7.5 20 9.071848
Rota Circuit 8 Cast 15x6.5 12 5.4431088
Rota Circuit 8 Cast 16x7 16 7.2574784
Rota Competition Cast 15x6.5 16.8 7.62035232
Rota Competition Cast 16x7 19.6 8.89041104
Rota D2 Cast 17x7.5 22.2 10.06975128
Rota Downshift Cast 17x7.5 19 8.6182556
Rota Flight Cast 15x6.5 13 5.8967012
Rota Formel Cast 16x7 17.7 8.02858548
Rota G-Force Cast 18x8 20 9.071848
Rota Grid Racing Cast 15x6.5 13 5.8967012
Rota Grid Racing Cast 16x7 15 6.803886
Rota Grid Racing Cast 17x7.5 18.5 8.3914594
Rota Group A Cast 17x7.5 19 8.6182556
Rota Group A Cast 18x7.5 21 9.5254404
Rota Group N Cast 15x6.5 12.5 5.669905
Rota GT-3 Cast 15x7 13.5 6.1234974
Rota GT-3 Cast 16x7 16.5 7.4842746
Rota J.SPL Cast 15x6.5 12.4 5.62454576
Rota J.SPL Cast 16x7 14 6.3502936
Rota J-MAG Cast 15x7 13 5.8967012
Rota Machspeed Cast 17x7.5 23 10.4326252
Rota Manta Cast 15x6.5 16.5 7.4842746
Rota Manta Cast 16x7 17.6 7.98322624
Rota MSR Cast 15x6.5 16.9 7.66571156
Rota MSR Cast 16x7 17.2 7.80178928
Rota N1R Cast 16x7 17.7 8.02858548
Rota P45F Cast 18x8.5 21.7 9.84295508
Rota P45M Cast 17x9 21 9.5254404
Rota RB Cast 15x7 14.4 6.53173056
Rota Retro Cast 15x6.5 14 6.3502936
Rota SDR Cast 17x7.5 16.5 7.4842746
Rota SDX Cast 17x7.5 16.5 7.4842746
Rota Slipstream Cast 15x6.5 11.9 5.39774956
Rota Slipstream Cast 15x7 12.9 5.85134196
Rota Slipstream Cast 15x7.5 13.7 6.21421588
Rota Slipstream Cast 15x8 14.7 6.66780828
Rota Slipstream Cast 16x7 13.9 6.30493436
Rota Slipstream Cast 17x7.5 19 8.6182556
Rota Slipstream Cast 17x8.5 21.1 9.57079964
Rota Speed 5 Cast 15x7 12.7 5.76062348
Rota Stage 5 Cast 15x6.5 17.6 7.98322624
Rota Stage 5 Cast 16x7 20.1 9.11720724
Rota Subzero Cast 15x6.5 12.9 5.85134196
Rota Subzero Cast 16x7 14.5 6.5770898
Rota Subzero Cast 17x7 16.5 7.4842746
Rota Subzero Cast 17x7.5 16.9 7.66571156
Rota Subzero Cast 18x7.5 19 8.6182556
Rota Tarmac Cast 17x7 19 8.6182556
Rota Tarmac 3 Cast 18x8 20.1 9.11720724
Rota Torque Cast 15x6.5 13 5.8967012
Rota Torque Cast 17x7 18 8.1646632
Rota Torque Cast 17x7.5 18.8 8.52753712
Rota Torque Cast 17x8 19 8.6182556
Rota Torque Cast 18x8 20 9.071848
Rota Track R Cast 16x7 16 7.2574784
Rota Tuner Cast 16x7 18 8.1646632
Rota Velo Cast 15x6.5 16.8 7.62035232
Rota Velo Cast 16x7 19.6 8.89041104
Rozest MF-02 Forged 17x7 13.7 6.21421588
RPM R-505 Cast 18x8 28 12.7005872
RPM R-505 Cast 19x9.5 30 13.607772
RS Limited Ricochet Cast 17x7 19.4 8.79969256
RS Limited S-Type Cast 18x7.5 28 12.7005872
RS Watanabe Forged Mg 19x8 16.5 7.4842746
RS Watanabe Cyclone Forged Mg 15x6.5 10.1 4.58128324
RS Watanabe Cyclone Forged Mg 15x7 10.4 4.71736096
RS Watanabe Cyclone Forged Mg 16x7 11.5 5.2163126
RS Watanabe Cyclone Forged Mg 16x8 12.3 5.57918652
RS Watanabe Cyclone Forged Mg 18x8 14.6 6.62244904
RS Watanabe Cyclone Forged Mg 18x9 16.1 7.30283764
RS Watanabe EightSpoke A Cast Mg 10x6 5.1 2.31332124
RS Watanabe EightSpoke A Cast 10x6 7.3 3.31122452
RS Watanabe EightSpoke A Cast 12x5.5 8.8 3.99161312
RS Watanabe EightSpoke A Cast Mg 12x6 6.8 3.08442832
RS Watanabe EightSpoke A Cast 12x6 9.7 4.39984628
RS Watanabe EightSpoke A Cast 13x6 11.2 5.08023488
RS Watanabe EightSpoke A Cast 13x6.5 11 4.9895164
RS Watanabe EightSpoke A Cast 13x7 11 4.9895164
RS Watanabe EightSpoke A Cast Mg 14x6 9 4.0823316
RS Watanabe EightSpoke A Cast 14x6 13 5.8967012
RS Watanabe EightSpoke A Cast Mg 14x6.5 9.3 4.21840932
RS Watanabe EightSpoke A Cast 14x6.5 13.2 5.98741968
RS Watanabe EightSpoke A Cast Mg 14x7 9 4.0823316
RS Watanabe EightSpoke A Cast 14x7 12.8 5.80598272
RS Watanabe EightSpoke A Cast Mg 14x7.5 9.9 4.49056476
RS Watanabe EightSpoke A Cast 14x7.5 13.6 6.16885664
RS Watanabe EightSpoke B Cast Mg 13x5 8.8 3.99161312
RS Watanabe EightSpoke B Cast 13x5 9.7 4.39984628
RS Watanabe EightSpoke B Cast Mg 13x5.5 9.3 4.21840932
RS Watanabe EightSpoke B Cast 13x5.5 10.4 4.71736096
RS Watanabe EightSpoke B Cast Mg 13x6 7.1 3.22050604
RS Watanabe EightSpoke B Cast 13x6 10.1 4.58128324
RS Watanabe EightSpoke B Cast Mg 13x6.5 7.7 3.49266148
RS Watanabe EightSpoke B Cast 13x6.5 11 4.9895164
RS Watanabe EightSpoke B Cast 13x7 11.2 5.08023488
RS Watanabe EightSpoke B Cast 13x7.5 10.7 4.85343868
RS Watanabe EightSpoke B Cast Mg 14x5.5 8.2 3.71945768
RS Watanabe EightSpoke B Cast 14x5.5 11.7 5.30703108
RS Watanabe EightSpoke B Cast Mg 14x6 8.4 3.81017616
RS Watanabe EightSpoke B Cast 14x6 12.1 5.48846804
RS Watanabe EightSpoke B Cast Mg 14x6.5 8.4 3.81017616
RS Watanabe EightSpoke B Cast 14x6.5 12.1 5.48846804
RS Watanabe EightSpoke B Cast Mg 14x7 8.6 3.90089464
RS Watanabe EightSpoke B Cast 14x7 12.3 5.57918652
RS Watanabe EightSpoke B Cast Mg 14x7.5 9.5 4.3091278
RS Watanabe EightSpoke B Cast 14x7.5 12.5 5.669905
RS Watanabe EightSpoke CVF Cast 13x5 9.7 4.39984628
RS Watanabe EightSpoke CVF Cast 13x5.5 9.9 4.49056476
RS Watanabe EightSpoke CVF Cast 13x6 11.2 5.08023488
RS Watanabe EightSpoke CVFP Cast 13x5 10.1 4.58128324
RS Watanabe EightSpoke CVFP Cast 13x5.5 10.4 4.71736096
RS Watanabe EightSpoke CVP Cast 13x5 10.4 4.71736096
RS Watanabe EightSpoke F8 Cast 12x5 9 4.0823316
RS Watanabe EightSpoke F8 Cast Mg 14x6 7.9 3.58337996
RS Watanabe EightSpoke F8 Cast 14x6 11.2 5.08023488
RS Watanabe EightSpoke F8 Cast Mg 14x6.5 8.4 3.81017616
RS Watanabe EightSpoke F8 Cast 14x6.5 12.1 5.48846804
RS Watanabe EightSpoke F8 Cast Mg 14x7 9.9 4.49056476
RS Watanabe EightSpoke F8 Cast 14x7 14.1 6.39565284
RS Watanabe EightSpoke F8 Cast Mg 15x6 10.6 4.80807944
RS Watanabe EightSpoke F8 Cast Mg 15x6.5 9.5 4.3091278
RS Watanabe EightSpoke F8 Cast Mg 15x7 10.1 4.58128324
RS Watanabe EightSpoke F8 Cast Mg 15x7.5 11 4.9895164
RS Watanabe EightSpoke F8 Cast Mg 16x8 13 5.8967012
RS Watanabe EightSpoke F8F Cast 12x4.5 9 4.0823316
RS Watanabe EightSpoke F8F Cast 13x4.5 10.4 4.71736096
RS Watanabe EightSpoke F8F Cast 14x5.5 14.1 6.39565284
RS Watanabe EightSpoke F8F Cast Mg 14x6 9.9 4.49056476
RS Watanabe EightSpoke F8F Cast 14x6.5 12.5 5.669905
RS Watanabe EightSpoke F8F Cast Mg 15x6 10.1 4.58128324
RS Watanabe EightSpoke F8F Cast 15x6 15 6.803886
RS Watanabe EightSpoke F8F Cast Mg 15x6.5 10.4 4.71736096
RS Watanabe EightSpoke F8F Cast 15x6.5 13.7 6.21421588
RS Watanabe EightSpoke F8F Cast Mg 15x7 11.2 5.08023488
RS Watanabe EightSpoke F8F Cast 15x7 14.6 6.62244904
RS Watanabe EightSpoke F8F Cast 15x7.5 15.9 7.21211916
RS Watanabe EightSpoke F8F Cast 15x8 16.1 7.30283764
RS Watanabe EightSpoke F8F Cast 15x8.5 20 9.071848
RS Watanabe EightSpoke F8F Cast 16x7 16.1 7.30283764
RS Watanabe EightSpoke F8F Cast 16x7.5 17.2 7.80178928
RS Watanabe EightSpoke F8F Cast 16x8 18.1 8.21002244
RS Watanabe EightSpoke F8F Cast 16x9 20.5 9.2986442
RS Watanabe EightSpoke F8FR (Rally) Cast 15x6.5 17.3 7.84714852
RS Watanabe EightSpoke F8FS Cast 14x6 13 5.8967012
RS Watanabe EightSpoke F8FS Cast 14x6.5 13.7 6.21421588
RS Watanabe EightSpoke F8FS Cast Mg 15x6 9.9 4.49056476
RS Watanabe EightSpoke F8FS Cast 15x6 14.6 6.62244904
RS Watanabe EightSpoke F8FS Cast Mg 15x6.5 10.6 4.80807944
RS Watanabe EightSpoke F8FS Cast 15x6.5 15.2 6.89460448
RS Watanabe EightSpoke F8FS Cast Mg 15x7 11.7 5.30703108
RS Watanabe EightSpoke F8FS Cast 15x7 16.5 7.4842746
RS Watanabe EightSpoke F8FS Cast 16x6.5 17.2 7.80178928
RS Watanabe EightSpoke F8FS Cast 16x7 18.1 8.21002244
RS Watanabe EightSpoke F8FS Cast 16x7.5 18.5 8.3914594
RS Watanabe EightSpoke F8FS Cast 16x8 19.2 8.70897408
RS Watanabe EightSpoke F8FS Cast 16x8.5 19.8 8.98112952
RS Watanabe EightSpoke F8FT Cast 14x6 12.6 5.71526424
RS Watanabe EightSpoke F8FT Cast 14x6.5 13.2 5.98741968
RS Watanabe EightSpoke F8FT Cast 16x6.5 16.3 7.39355612
RS Watanabe EightSpoke F8FT Cast 16x7 17.2 7.80178928
RS Watanabe EightSpoke F8FT Cast 16x7.5 17.6 7.98322624
RS Watanabe EightSpoke F8FT Cast 16x8 18.3 8.30074092
RS Watanabe EightSpoke F8-RST Cast Mg 15x6.5 9.9 4.49056476
RS Watanabe EightSpoke F8-RST Cast 15x6.5 14.1 6.39565284
RS Watanabe EightSpoke F8S Cast Mg 14x6 9 4.0823316
RS Watanabe EightSpoke F8S Cast Mg 14x6.5 9.5 4.3091278
RS Watanabe EightSpoke F8S Cast 16x7 16.5 7.4842746
RS Watanabe EightSpoke F8S Cast 16x7.5 17.6 7.98322624
RS Watanabe EightSpoke F8S Cast Mg 16x8 13.2 5.98741968
RS Watanabe EightSpoke F8S Cast 16x8 18.5 8.3914594
RS Watanabe EightSpoke F8S Cast 16x9 20.9 9.48008116
RS Watanabe EightSpoke F8T Cast Mg 14x6 8.8 3.99161312
RS Watanabe EightSpoke F8T Cast Mg 14x6.5 9.3 4.21840932
RS Watanabe EightSpoke F8T Cast 16x7 15.7 7.12140068
RS Watanabe EightSpoke F8T Cast 16x7.5 16.8 7.62035232
RS Watanabe EightSpoke F8T Cast Mg 16x8 12.6 5.71526424
RS Watanabe EightSpoke F8T Cast 16x8 17.6 7.98322624
RS Watanabe EightSpoke F8T Cast 16x8.5 20.8 9.43472192
RS Watanabe EightSpoke F8T Cast 16x9 20.3 9.20792572
RS Watanabe EightSpoke R Type Cast 13x10 16.2 7.34819688
RS Watanabe EightSpoke R Type Cast 13x8 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x8.5 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x9 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x9.5 15.2 6.89460448
RS Watanabe EightSpoke R Type Cast Mg 14x10 11 4.9895164
RS Watanabe EightSpoke R Type Cast 14x10 15.9 7.21211916
RS Watanabe EightSpoke R Type Cast Mg 14x10.5 11.2 5.08023488
RS Watanabe EightSpoke R Type Cast 14x10.5 16.1 7.30283764
RS Watanabe EightSpoke R Type Cast Mg 14x11 11.5 5.2163126
RS Watanabe EightSpoke R Type Cast 14x11 16.3 7.39355612
RS Watanabe EightSpoke R Type Cast Mg 14x11.5 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 14x11.5 16.5 7.4842746
RS Watanabe EightSpoke R Type Cast Mg 14x12 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 14x12 16.8 7.62035232
RS Watanabe EightSpoke R Type Cast Mg 14x8 10.6 4.80807944
RS Watanabe EightSpoke R Type Cast 14x8 15 6.803886
RS Watanabe EightSpoke R Type Cast Mg 14x8.5 10.6 4.80807944
RS Watanabe EightSpoke R Type Cast 14x8.5 15.2 6.89460448
RS Watanabe EightSpoke R Type Cast Mg 14x9 10.8 4.89879792
RS Watanabe EightSpoke R Type Cast 14x9 15.4 6.98532296
RS Watanabe EightSpoke R Type Cast Mg 14x9.5 11 4.9895164
RS Watanabe EightSpoke R Type Cast 14x9.5 15.7 7.12140068
RS Watanabe EightSpoke R Type Cast Mg 15x10 12.1 5.48846804
RS Watanabe EightSpoke R Type Cast 15x10 17.2 7.80178928
RS Watanabe EightSpoke R Type Cast Mg 15x10.5 12.3 5.57918652
RS Watanabe EightSpoke R Type Cast 15x10.5 17.6 7.98322624
RS Watanabe EightSpoke R Type Cast Mg 15x11 12.6 5.71526424
RS Watanabe EightSpoke R Type Cast 15x11 18.1 8.21002244
RS Watanabe EightSpoke R Type Cast Mg 15x11.5 13 5.8967012
RS Watanabe EightSpoke R Type Cast 15x11.5 18.5 8.3914594
RS Watanabe EightSpoke R Type Cast Mg 15x12 13.2 5.98741968
RS Watanabe EightSpoke R Type Cast 15x12 19 8.6182556
RS Watanabe EightSpoke R Type Cast 15x8 15.4 6.98532296
RS Watanabe EightSpoke R Type Cast Mg 15x8.5 11 4.9895164
RS Watanabe EightSpoke R Type Cast 15x8.5 15.9 7.21211916
RS Watanabe EightSpoke R Type Cast Mg 15x9 11.5 5.2163126
RS Watanabe EightSpoke R Type Cast 15x9 16.3 7.39355612
RS Watanabe EightSpoke R Type Cast Mg 15x9.5 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 15x9.5 16.8 7.62035232
RS Watanabe EightSpoke R Type Cast 16x8 16.5 7.4842746
RS Watanabe EightSpoke R Type Cast 16x8.5 17.2 7.80178928
RS Watanabe EightSpoke R Type Cast 16x9 17.9 8.11930396
RS Watanabe EightSpoke R Type Cast 16x9.5 18.5 8.3914594
RS Watanabe Forged Eight Forged 15x6.5 11.5 5.2163126
RS Watanabe Forged Eight Forged 15x7 12.1 5.48846804
RS Watanabe SMW Cast Mg 14x5 8.6 3.90089464
RS Watanabe SMW Cast Mg 14x5.5 9 4.0823316
RS Watanabe SMW Cast Mg 14x6 8.6 3.90089464
Ruf Cast 17x10 27.7 12.56450948
Ruf Cast 17x9 24.6 11.15837304
Ruf Carrera 4S (flat-faced) Cast 18x10 29.1 13.19953884
Ruf Carrera 4S (flat-faced) Cast 18x8.5 26.5 12.0201986
Ruff Racing R278 Cast 19x8.5 28 12.7005872
Ruff Racing R278 Cast 19x9.5 31 14.0613644
Ruff Racing R281 Cast 19x8.5 30 13.607772
Ruff Racing R281 Cast 19x9.5 34 15.4221416
Saturn ""Sawtooth"" 94-95 Cast 15x6 13.6 6.16885664
Schmidt TH-Line 2 Cast 16x8 20.2 9.16256648
Shaper Sunlight Cast 16x7.5 17.2 7.80178928
Shaper Twilight Cast 16x7.5 18.3 8.30074092
Shaper Twilight Cast 17x7.5 21.8 9.88831432
Shuk BS1 Cast 17x7.5 20.3 9.20792572
Shuk BS1 Cast 18x7.5 21.6 9.79759584
Shuk BS1 Cast 18x8.5 23 10.4326252
Shuk W21 Cast 17x7 19 8.6182556
Shuk W21 Cast 18x7.5 20.7 9.38936268
Shuk W21 Cast 18x8 21 9.5254404
Shuk W22 Cast 17x7 18.5 8.3914594
Shuk WR1 Cast 17x7 18.5 8.3914594
Simmons F-Series Cast 17x10 23.8 10.79549912
Simmons OM-Series Cast 18x9 26.5 12.0201986
SJ Racing Cross Forged 16x7 14.4 6.53173056
SJ Racing Cross Forged 17x8 18 8.1646632
SJ Racing Leggero Forged 15x7 11.3 5.12559412
SJ Racing Leggero Forged 16x7 12.9 5.85134196
SJ Racing Leggero Forged 16x8 14.7 6.66780828
SJ Racing Leggero Forged 17x8 17.1 7.75643004
SMC Type H Cast 17x7.5 28.6 12.97274264
Smith's Wheels Highlander Cast 18x9 28 12.7005872
Smith's Wheels Infinity Cast 17x7 23 10.4326252
Smith's Wheels Twister Cast 18x8 29.5 13.3809758
Speed Star D5R Cast 18x7.5 22.9 10.38726596
Speed Star D5R Cast 18x8 23.4 10.61406216
Speed Star D5R Cast 19x8 25.1 11.38516924
Speed Star SP1 Cast 19x7.5 22.9 10.38726596
Speed Star Zxpeed Cast 18x8 27 12.2469948
Speedline 2020 Cast Mg 15x7 16.3 7.39355612
Speedline 2020 Cast Mg 17x7.5 20.1 9.11720724
Speedline 2021 HTC Cast Mg 17x7.5 17.6 7.98322624
Speedline 2113 Cast 17x7 23.5 10.6594214
Speedline 2116 Cast 16x7 20.5 9.2986442
Speedline 2116 Cast 17x7 23.5 10.6594214
Speedline 2118 Racing 2000 Cast 15x6 18.3 8.30074092
Speedline 2118 Racing 2000 Cast 15x7 21.2 9.61615888
Speedline 2120 Turini Cast 15x6.5 16.8 7.62035232
Speedline 2120 Turini Cast 16x7 19.7 8.93577028
Speedline Competition Cast 18x8.5 24 10.8862176
Speedline Prodrive 7 Cast 17x7 22.5 10.205829
Speedline Race Cast 17x10 19 8.6182556
Speedline Routa/GT1 Lite Cast 18x7.5 18.5 8.3914594
Speedline Street Cast 17x10 25 11.33981
SpeedLite Racing Formula Cast 17x7 21.5 9.7522366
Speedmaster SM-046 Cast 15x6.5 11.4 5.17095336
Speedmaster SM-058 Cast 15x7 16 7.2574784
Speedmaster TR-05 Cast 17x7 17.6 7.98322624
Speedy Wheels Atix-5 Cast 17x7 18 8.1646632
Speedy Wheels Baltic Cast 17x7.5 22.3 10.11511052
Speedy Wheels G-Force Cast 20x8.5 35.3 16.01181172
Speedy Wheels Longchamp Cast 18x7.5 27.4 12.42843176
Speedy Wheels Nexxus Cast 18x7.5 25.3 11.47588772
Speedy Wheels Octopus Cast 17x7 18.8 8.52753712
Speedy Wheels Race Mode Cast 15x6.5 13.2 5.98741968
Speedy Wheels Race Mode Cast 16x7 16.1 7.30283764
Speedy Wheels Race Mode Cast 17x7 17.6 7.98322624
Speedy Wheels Sports-R Cast 15x6.5 13.9 6.30493436
Speedy Wheels Toskana Cast 17x7 24 10.8862176
Spoon Sports Forged 16x7 11.9 5.39774956
Spoon Sports Forged 16x8 12.9 5.85134196
Spoon Sports SW388 Forged 15x6.5 8.6 3.90089464
Sport Edition A7 Cast 15x6.5 17.5 7.937867
Sport Edition A7 Cast 17x7.5 24.4 11.06765456
Sport Edition A7 Cast 18x8 25.8 11.70268392
Sport Edition CD Cast 15x6.5 16 7.2574784
Sport Edition CD Cast 16x7.5 19 8.6182556
Sport Edition CD Cast 17x7.5 20.5 9.2986442
Sport Edition CD Cast 18x8 22 9.9790328
Sport Edition D3 Cast 15x6.5 15.5 7.0306822
Sport Edition D3 Cast 16x7 17 7.7110708
Sport Edition D3 Cast 17x7 20 9.071848
Sport Edition D4 Cast 16x7 16 7.2574784
Sport Edition D4 Cast 17x7 18 8.1646632
Sport Edition D5 Cast 16x7 17.6 7.98322624
Sport Edition D5 Cast 17x7 18.5 8.3914594
Sport Edition Daisy Cast 16x6.5 19.6 8.89041104
Sport Edition E1 Cast 16x7 19.5 8.8450518
Sport Edition E1 Cast 17x7 21.5 9.7522366
Sport Edition E1 Cast 18x8 23 10.4326252
Sport Edition E2 Cast 16x7 18.2 8.25538168
Sport Edition E2 Cast 17x7 21 9.5254404
Sport Edition E3 Cast 16x7 18.4 8.34610016
Sport Edition E3 Cast 17x7 20.8 9.43472192
Sport Edition Fox 10 Cast 16x7 17.5 7.937867
Sport Edition Fox 10 Cast 17x8 20.8 9.43472192
Sport Edition Fox 10 Cast 18x8 23 10.4326252
Sport Edition Fox 2 Cast 15x6.5 16 7.2574784
Sport Edition Fox 2 Cast 16x7 20.8 9.43472192
Sport Edition Fox 2 Cast 17x7 23 10.4326252
Sport Edition Fox 2 Cast 17x7.5 24 10.8862176
Sport Edition Fox 2 Cast 18x7.5 25 11.33981
Sport Edition Fox 3 Cast 15x6.5 19 8.6182556
Sport Edition Fox 3 Cast 16x6.5 20.3 9.20792572
Sport Edition Fox 3 Cast 17x7 23 10.4326252
Sport Edition Fox 5 Cast 15x6.5 18 8.1646632
Sport Edition Fox 5 Cast 16x7 21 9.5254404
Sport Edition Fox 5 Cast 18x8 23 10.4326252
Sport Edition Fox 6 Cast 16x7 18.8 8.52753712
Sport Edition Fox 6 Cast 17x7 21.5 9.7522366
Sport Edition Fox 6 Cast 17x7.5 22 9.9790328
Sport Edition Fox 7 Cast 16x7 19.5 8.8450518
Sport Edition Fox 7 Cast 17x7 21.5 9.7522366
Sport Edition Fox 7 Cast 17x7.5 22 9.9790328
Sport Edition KM11 Cast 17x8 23 10.4326252
Sport Edition KM11 Cast 18x8 24 10.8862176
Sport Edition KV5 Cast 17x8 22 9.9790328
Sport Edition KV5 Cast 18x8 23 10.4326252
Sport Edition KV5 Cast 19x8.5 27 12.2469948
Sport Edition KV5 Cast 19x9.5 27.5 12.473791
Sport Edition ST3 Cast 17x8 24.5 11.1130138
Sport Edition ST3 Cast 18x8 26.5 12.0201986
Sport Edition ST3 Cast 19x8.5 28.5 12.9273834
Sport Edition ST3 Cast 19x9.5 31 14.0613644
Sport Edition ST4 Cast 18x8 26.5 12.0201986
Sport Edition ST4 Cast 19x8.5 28 12.7005872
Sport Edition ST4 Cast 19x9.5 30.6 13.87992744
Sport Edition ST5 Cast 19x8.5 31.5 14.2881606
Sport Edition ST5 Cast 19x9.5 30 13.607772
Sport Edition Tekno Cast 17x7 23 10.4326252
Sport Edition Tekno Cast 18x8 25 11.33981
Sport Edition Tekno Cast 19x8 31.4 14.24280136
Sport Edition TK5 Cast 15x6.5 17 7.7110708
Sport Edition TK5 Cast 16x7 19 8.6182556
Sport Edition TK5 Cast 17x7 22 9.9790328
Sport Edition Valore Cast 15x6.5 18.5 8.3914594
Sport Edition Valore Cast 16x7 20 9.071848
Sport Tuning Blade Cast 17x7 21.5 9.7522366
Sport Tuning Blade Cast 18x7.5 24 10.8862176
Sport Tuning Flight Cast 17x8 20 9.071848
Sport Tuning Flight Cast 18x8 22 9.9790328
Sport Tuning Flight Cast 19x8 24.5 11.1130138
Sport Tuning Glide Cast 17x7 20.5 9.2986442
Sport Tuning Glide Cast 18x7.5 23.5 10.6594214
Sport Tuning Glide Cast 18x8 24.5 11.1130138
Sport Tuning Gunner Cast 17x7 19.5 8.8450518
Sport Tuning Gunner Cast 18x8 24 10.8862176
Sport Tuning Jet Cast 17x7 22 9.9790328
Sport Tuning Jet Cast 17x7.5 21.5 9.7522366
Sport Tuning Jet Cast 18x8 24 10.8862176
Sport Tuning Propeller Cast 18x8 26.5 12.0201986
Sport Tuning Propeller Cast 19x8 28.5 12.9273834
Sport Tuning Turbine Cast 15x6.5 16 7.2574784
Sport Tuning Turbine Cast 16x7 17.5 7.937867
Sport Tuning Turbine Cast 17x7 19 8.6182556
Sport Tuning Turbine Cast 18x7.5 21.5 9.7522366
Sportiva Liberty Cast 19x8 31 14.0613644
Sportiva Modena Cast 18x8.5 26 11.7934024
Sportmax 002 Cast 15x7 15 6.803886
Sportmax 513 Cast 15x7 16.1 7.30283764
Sportmax 513 Cast 15x8 17.3 7.84714852
SSR Agle Strusse Forged/Spun 19x12 32 14.5149568
SSR Comp-H Forged 19x8 20.3 9.20792572
SSR De Colte Forged 17x9 19.8 8.98112952
SSR GP-Theta Forged 16x8 19 8.6182556
SSR GT1 Forged 16x7 15 6.803886
SSR GT1 Forged 17x7 16.5 7.4842746
SSR GT1 Forged 17x7.5 17.5 7.937867
SSR GT1 Forged 17x8 17.8 8.07394472
SSR GT1 Forged 17x9 18.3 8.30074092
SSR GT1 Forged 18x7.5 17.8 8.07394472
SSR GT1 Forged 18x8 19 8.6182556
SSR GT1 Forged 18x9 19.7 8.93577028
SSR GT10 Forged 18x8 23.4 10.61406216
SSR GT10 Forged 18x8.5 24.3 11.02229532
SSR GT10 Forged 19x8.5 27 12.2469948
SSR GT2 Forged 17x7.5 14.6 6.62244904
SSR GT2 Forged 17x8 15.2 6.89460448
SSR GT2 Forged 18x7.5 15.9 7.21211916
SSR GT3 Forged/Spun 18x7.5 24 10.8862176
SSR GT3 Forged/Spun 18x8 24.6 11.15837304
SSR GT3 Forged/Spun 19x7.5 25.5 11.5666062
SSR GT3 Forged/Spun 19x8.5 26.5 12.0201986
SSR GT7 Forged 17x7.5 16.6 7.52963384
SSR GT7 Forged 17x8 17.6 7.98322624
SSR GT7 Forged 17x8.5 18.5 8.3914594
SSR GT7-H Forged 18x8 19.4 8.79969256
SSR GT7-H Forged 19x7.5 19.9 9.02648876
SSR Integral Forged 16x7 15.5 7.0306822
SSR Integral Forged 16x8 16.9 7.66571156
SSR Integral Forged 17x7 17 7.7110708
SSR Integral Forged 17x8 18 8.1646632
SSR Integral Forged 17x9 18.8 8.52753712
SSR Integral Forged 18x8 20 9.071848
SSR Integral Forged 18x9 20 9.071848
SSR MK-III Forged/Spun 15x7 12.2 5.53382728
SSR Professor SP1 Forged/Spun 18x8 21.6 9.79759584
SSR Professor SP1 Forged/Spun 19x7.5 22.9 10.38726596
SSR Professor SP1 Forged/Spun 19x8 23.8 10.79549912
SSR RF Firrenze Forged/Spun 16x8 18.5 8.3914594
SSR S1 Forged 17x7 16.8 7.62035232
SSR Schumacher Forged/Spun 15x7 12.5 5.669905
SSR Schumacher Forged/Spun 16x7 15 6.803886
SSR Type-C (called Competitions in the US) Forged 15x6 8 3.6287392
SSR Type-C (called Competitions in the US) Forged 15x6.5 8.6 3.90089464
SSR Type-C (called Competitions in the US) Forged 15x7 9.2 4.17305008
SSR Type-C (called Competitions in the US) Forged 15x7.5 9.6 4.35448704
SSR Type-C (called Competitions in the US) Forged 16x7 11 4.9895164
SSR Type-C (called Competitions in the US) Forged 16x8 12.1 5.48846804
SSR Type-C (called Competitions in the US) Forged 17x7.5 13 5.8967012
SSR Type-C (called Competitions in the US) Forged 17x8 14.3 6.48637132
SSR Type-C (called Competitions in the US) Forged 17x8.5 15 6.803886
SSR Type-C (called Competitions in the US) Forged 17x9 15.2 6.89460448
SSR Type-C (called Competitions in the US) Forged 17x9.5 15.4 6.98532296
SSR Type-C (called Competitions in the US) Forged 18x7.5 15.5 7.0306822
SSR Type-C (called Competitions in the US) Forged 18x8 16.3 7.39355612
SSR Type-C (called Competitions in the US) Forged 18x8.5 16.8 7.62035232
SSR Type-C (called Competitions in the US) Forged 18x9 17 7.7110708
SSR Type-C (called Competitions in the US) Forged 18x9.5 17.7 8.02858548
SSR Type-C H Forged 19x8 20.3 9.20792572
SSR Type-C RS Forged 17x10 17.2 7.80178928
SSR Type-C RS Forged 17x10.5 17.6 7.98322624
SSR Type-C RS Forged 17x7.5 14.6 6.62244904
SSR Type-C RS Forged 17x8 15.5 7.0306822
SSR Type-C RS Forged 17x8.5 16.2 7.34819688
SSR Type-C RS Forged 17x9 16.4 7.43891536
SSR Type-C RS Forged 17x9.5 16.8 7.62035232
SSR Type-C RS Forged 18x10.5 19.9 9.02648876
SSR Type-C RS Forged 18x7.5 17.6 7.98322624
SSR Type-C RS Forged 18x8 18 8.1646632
SSR Type-C RS Forged 18x8.5 19 8.6182556
SSR Type-C RS Forged 18x9 19.6 8.89041104
SSR Type-C RS Forged 18x9.5 18.8 8.52753712
SSR Type-C RS Forged 19x10.5 22.3 10.11511052
SSR Type-C RS Forged 19x8 20 9.071848
SSR Type-C RS Forged 19x8.5 20.8 9.43472192
SSR Type-C RS Forged 19x9.5 21.5 9.7522366
SSR Type-F Forged 17x10 17.7 8.02858548
SSR Type-F Forged 17x8 16.3 7.39355612
SSR Type-F Forged 17x8.5 16.6 7.52963384
SSR Type-F Forged 17x9 16.8 7.62035232
SSR Type-F Forged 17x9.5 16.9 7.66571156
SSR Type-F Forged 18x10.5 20 9.071848
SSR Type-F Forged 18x11 20.3 9.20792572
SSR Type-F Forged 18x7.5 16.9 7.66571156
SSR Type-F Forged 18x8 17.1 7.75643004
SSR Type-F Forged 18x8.5 17.8 8.07394472
SSR Type-F Forged 18x9 18.2 8.25538168
SSR Type-F Forged 18x9.5 18.8 8.52753712
SSR Type-M Forged 15x6.5 11 4.9895164
SSR Type-R Forged 16x7 11.5 5.2163126
SSR Type-V Forged 16x7 13 5.8967012
SSR Type-X Forged 15x6.5 10.5 4.7627202
SSR Vienna Forged/Spun 18x8.5 22.3 10.11511052
SSW S001 Blaze Cast 17x7.5 22 9.9790328
SSW S001 Blaze Cast 18x8 24.9 11.29445076
SSW S002 Inspire Cast 14x6 15.9 7.21211916
SSW S002 Inspire Cast 15x6.5 17 7.7110708
SSW S003 Inferno Cast 17x7.5 20.3 9.20792572
SSW S004 Raze Cast 17x7.5 20.9 9.48008116
SSW S004 Raze Cast 18x8 22 9.9790328
SSW S005 Flash Cast 17x7.5 22.5 10.205829
SSW S005 Flash Cast 18x8 23.8 10.79549912
SSW S006 Illusion Cast 18x8 27.8 12.60986872
SSW S007 Eternity Cast 15x6.5 15.4 6.98532296
SSW S007 Eternity Cast 16x7 16.3 7.39355612
SSW S007 Eternity Cast 17x7 18.1 8.21002244
SSW S008 Menace Cast 15x6.5 16.5 7.4842746
SSW S008 Menace Cast 16x7 19.4 8.79969256
SSW S008 Menace Cast 17x7 20.9 9.48008116
SSW S009 Fanatic Cast 18x8 24.3 11.02229532
SSW S010 Haste Cast 15x6.5 15.4 6.98532296
SSW S010 Haste Cast 16x7 18.5 8.3914594
SSW S010 Haste Cast 17x7 19 8.6182556
SSW S011 Cosmo Cast 15x6.5 16.3 7.39355612
SSW S011 Cosmo Cast 16x7 19.4 8.79969256
SSW S011 Cosmo Cast 17x7 20.9 9.48008116
SSW S012 Eclipse Cast 19x8 24.7 11.20373228
SSW S012 Eclipse Cast 20x7.5 27.3 12.38307252
SSW S013 Trex Cast 15x6.5 16.8 7.62035232
SSW S013 Trex Cast 16x7 18.7 8.48217788
SSW S013 Trex Cast 17x7 19.8 8.98112952
SSW S013 Trex Cast 18x8 22 9.9790328
SSW S014 Cyclone Cast 15x8 19.4 8.79969256
SSW S014 Cyclone Cast 16x8 20.3 9.20792572
SSW S015 Triton Cast 15x8 19 8.6182556
SSW S015 Triton Cast 16x8 19.8 8.98112952
SSW S016 Torque Cast 13x5.5 16.3 7.39355612
SSW S016 Torque Cast 14x6 16.5 7.4842746
SSW S016 Torque Cast 15x6.5 17 7.7110708
SSW S017 Zenith Cast 17x7 20.3 9.20792572
SSW S018 Infinitum Cast 20x9 30 13.607772
SSW S019 Multispoke Cast 18x8 27 12.2469948
SSW S019 Multispoke Cast 19x8.5 29 13.1541796
SSW S020 Quest Cast 13x5.5 15.2 6.89460448
SSW S020 Quest Cast 14x6 15.7 7.12140068
SSW S020 Quest Cast 15x6.5 16.1 7.30283764
SSW S021 Frost Cast 14x6 13.7 6.21421588
SSW S022 Cynik Cast 17x7 19 8.6182556
SSW S023 Rage Cast 14x6 13 5.8967012
SSW S025 Vigor Cast 18x7.5 22.7 10.29654748
Starcorp Racing Lite 5 Cast 15x6.5 11 4.9895164
Starcorp Racing Lite 5 Cast 16x7 13.2 5.98741968
Starcorp Racing Lite 5 Cast 17x7 15.4 6.98532296
Starcorp Racing Techno Cast 16x7 20.3 9.20792572
Starform Basel Cast 17x7 21.6 9.79759584
Starform Basel Cast 17x8 24.3 11.02229532
Starform Real Racing Model II Forged 17x7.5 13.4 6.07813816
Starform Real Racing Model II Forged 17x8.5 14.1 6.39565284
Starform Real Racing Model II Forged 17x9.5 15 6.803886
Starform Real Racing R2 Forged 15x6.5 9.7 4.39984628
Starform Real Racing R2 Forged 15x7 9.9 4.49056476
Starform Real Racing R2 Forged 17x7.5 14.1 6.39565284
Starform Real Racing R2 Forged 17x8.5 14.8 6.71316752
Starform Real Racing R2 Forged 17x9.5 15.7 7.12140068
Stark MS Forged 14x5 7.3 3.31122452
Stark MS Forged 15x6 9.5 4.3091278
Stark MS Forged 15x6.5 10.1 4.58128324
Stark MS Forged 17x7.5 14.6 6.62244904
Stern Aguzze-S07 Cast 15x7 13.4 6.07813816
Stern Aguzze-S07 Cast 16x7 14.8 6.71316752
Stern Aguzze-S07 Cast 16x8 16.1 7.30283764
Stern Aguzze-S07R Forged 17x7 14.3 6.48637132
Stern Aguzze-S07R Forged 17x7.5 14 6.3502936
Stern Aguzze-S07R Forged 17x8 14 6.3502936
Stern Aguzze-S07R Forged 17x9 15.3 6.93996372
Stern Aguzze-S07R Forged 18x7.5 16.5 7.4842746
Stern Aguzze-S07R Forged 18x8.5 16.5 7.4842746
Stern Aguzze-S07R Forged 18x9.5 16.8 7.62035232
Stern Axia Cast 19x9.5 31 14.0613644
Stern Intertouring Cast 17x8 23.5 10.6594214
Stern Leacher Cast 17x7 23.5 10.6594214
Stern Mach III Cast 15x7 13.5 6.1234974
Stern Mach III Cast 16x7 14.5 6.5770898
Stern Mach III Forged 17x7.5 14 6.3502936
Stern Sports Line LIIva Forged/Spun 17x7 21.5 9.7522366
Stern ST-1 Face III Beast Cast/Spun 18x8.5 26.9 12.20163556
Stern ST-2 Face II Touring Cast/Spun 18x8.5 28.1 12.74594644
Sti RS-Zero Forged 17x7.5 15.7 7.12140068
Stilauto 5 Cast 19x10 29 13.1541796
Stilauto Racing C Cast 17x7.5 24 10.8862176
Stillen GTV Cast 17x9 22.5 10.205829
Stillen GTV Cast 18x8 21.6 9.79759584
STR RS16 Cast 17x7 20.8 9.43472192
STR RS17 Cast 17x7 19.5 8.8450518
Subaru Impreza MY00/01 Cast 16x7 16.5 7.4842746
Subaru Impreza MY00/01 WRX STi Forged 17x7.5 19.8 8.98112952
Subaru Impreza MY02 WRX Cast 16x6.5 16.5 7.4842746
Subaru Impreza MY02 WRX (BBS) Forged 17x7 16 7.2574784
Subaru Impreza MY05 STi (JDM) Forged 17x7.5 18.6 8.43681864
Subaru Impreza MY06 WRX Cast 17x7 21 9.5254404
Subaru Impreza MY07 WRX STi Forged 17x8 18 8.1646632
Subaru Impreza MY08 WRX STi Cast 18x8.5 27.5 12.473791
Subaru Impreza MY08 WRX STi BBS Forged 18x8.5 18.5 8.3914594
Subaru Impreza MY98 Cast 16x7 17 7.7110708
Subaru Impreza MY99 Cast 16x7 17 7.7110708
Subaru Legacy Stamped Steel 15x6 19.5 8.8450518
Subaru Legacy (Enkei) Cast 15x6 16 7.2574784
Subaru Legacy GT-B (Japan) Forged 17x7 17.8 8.07394472
Subaru Legacy Outback (Topy) Cast 15x6 18 8.1646632
Subaru Legacy Spec B 06 Cast 18x7 18 8.1646632
Subary Impreza MY05 STi (BBS) Forged 17x8 19.2 8.70897408
Superlight Billet Billet/Spun 13x10 10.4 4.71736096
Superlight Billet Billet/Spun 13x10.5 10.6 4.80807944
Superlight Billet Billet/Spun 13x11 10.9 4.94415716
Superlight Billet Billet/Spun 13x11.5 11.2 5.08023488
Superlight Billet Billet/Spun 13x5 7.7 3.49266148
Superlight Billet Billet/Spun 13x5.5 8 3.6287392
Superlight Billet Billet/Spun 13x6 8.2 3.71945768
Superlight Billet Billet/Spun 13x6.5 8.5 3.8555354
Superlight Billet Billet/Spun 13x7 8.8 3.99161312
Superlight Billet Billet/Spun 13x7.5 9 4.0823316
Superlight Billet Billet/Spun 13x8 9.3 4.21840932
Superlight Billet Billet/Spun 13x8.5 9.6 4.35448704
Superlight Billet Billet/Spun 13x9 9.8 4.44520552
Superlight Billet Billet/Spun 13x9.5 10.1 4.58128324
Superlight Billet Billet/Spun 14x10 10.9 4.94415716
Superlight Billet Billet/Spun 14x10.5 11.2 5.08023488
Superlight Billet Billet/Spun 14x6 8.8 3.99161312
Superlight Billet Billet/Spun 14x6.5 9.1 4.12769084
Superlight Billet Billet/Spun 14x7 9.3 4.21840932
Superlight Billet Billet/Spun 14x7.5 9.6 4.35448704
Superlight Billet Billet/Spun 14x8 9.9 4.49056476
Superlight Billet Billet/Spun 14x8.5 10.1 4.58128324
Superlight Billet Billet/Spun 14x9 10.4 4.71736096
Superlight Billet Billet/Spun 14x9.5 10.7 4.85343868
Superlight Billet Billet/Spun 15x10 15.8 7.16675992
Superlight Billet Billet/Spun 15x10.5 16.1 7.30283764
Superlight Billet Billet/Spun 15x11 16.4 7.43891536
Superlight Billet Billet/Spun 15x6.5 13.2 5.98741968
Superlight Billet Billet/Spun 15x7 13.8 6.25957512
Superlight Billet Billet/Spun 15x7.5 14.1 6.39565284
Superlight Billet Billet/Spun 15x8 14.4 6.53173056
Superlight Billet Billet/Spun 15x8.5 14.8 6.71316752
Superlight Billet Billet/Spun 15x9 15.1 6.84924524
Superlight Billet Billet/Spun 15x9.5 15.4 6.98532296
Superlight Classic Cast 10x5 8.8 3.99161312
Superlight Classic Cast 12x5 9.6 4.35448704
Superlight Classic Cast 13x5.5 11.7 5.30703108
Superlight Classic Cast 13x6 12.3 5.57918652
Superlight Classic Cast 13x7 13.2 5.98741968
Superlight Classic Cast 13x8 13.4 6.07813816
Superlight Classic Cast 14x6 13.8 6.25957512
Superlight Classic Cast 15x6 18.8 8.52753712
Superlight Classic Cast 15x7 18.9 8.57289636
Superlight Classic Cast 15x8 20.5 9.2986442
Superlight ML Cast 13x5.5 12.8 5.80598272
Superlight ML Cast 13x7 13.2 5.98741968
Superlight ML Cast 13x8 13.9 6.30493436
Superlight ML Cast 14x6 15 6.803886
Superlight Sports Cast 10x4.5 7.9 3.58337996
Superlight Sports Cast 12x5 9 4.0823316
Superlight Sports Cast 13x6 10 4.535924
Superlight Sports Cast 13x7 11 4.9895164
Superlight Sports Cast 13x8 13 5.8967012
Superlight Sports Cast 14x6 14.3 6.48637132
Superlight Sports Cast 15x6 17.6 7.98322624
Superlight Sports Cast 15x7 19.6 8.89041104
Superlight Sports Cast 15x8 19.9 9.02648876
Superlight Sports Cast 16x7 22 9.9790328
Superlight Ultralight Cast/Spun 12x5 7.8 3.53802072
Superlight Ultralight Cast/Spun 12x5.5 8.3 3.76481692
Superlight Ultralight Cast/Spun 12x6 8.5 3.8555354
Superlight Ultralight Cast/Spun 13x10 11.6 5.26167184
Superlight Ultralight Cast/Spun 13x10.5 11.8 5.35239032
Superlight Ultralight Cast/Spun 13x11 12 5.4431088
Superlight Ultralight Cast/Spun 13x11.5 12.2 5.53382728
Superlight Ultralight Cast/Spun 13x5 8.7 3.94625388
Superlight Ultralight Cast/Spun 13x5.5 9 4.0823316
Superlight Ultralight Cast/Spun 13x6 9.3 4.21840932
Superlight Ultralight Cast/Spun 13x6.5 9.8 4.44520552
Superlight Ultralight Cast/Spun 13x7 9.9 4.49056476
Superlight Ultralight Cast/Spun 13x7.5 10.2 4.62664248
Superlight Ultralight Cast/Spun 13x8 10.5 4.7627202
Superlight Ultralight Cast/Spun 13x8.5 10.7 4.85343868
Superlight Ultralight Cast/Spun 13x9 11 4.9895164
Superlight Ultralight Cast/Spun 13x9.5 11.4 5.17095336
Superlight Ultralight Cast/Spun 14x10 14.7 6.66780828
Superlight Ultralight Cast/Spun 14x10.5 14.9 6.75852676
Superlight Ultralight Cast/Spun 14x6 11 4.9895164
Superlight Ultralight Cast/Spun 14x6.5 11.6 5.26167184
Superlight Ultralight Cast/Spun 14x7 12.2 5.53382728
Superlight Ultralight Cast/Spun 14x7.5 12.7 5.76062348
Superlight Ultralight Cast/Spun 14x8 13.1 5.94206044
Superlight Ultralight Cast/Spun 14x8.5 13.5 6.1234974
Superlight Ultralight Cast/Spun 14x9 13.9 6.30493436
Superlight Ultralight Cast/Spun 14x9.5 14.3 6.48637132
Superlight Ultralight Cast/Spun 15x10 17.1 7.75643004
Superlight Ultralight Cast/Spun 15x10.5 17.2 7.80178928
Superlight Ultralight Cast/Spun 15x6.5 15.2 6.89460448
Superlight Ultralight Cast/Spun 15x7 15.4 6.98532296
Superlight Ultralight Cast/Spun 15x7.5 15.9 7.21211916
Superlight Ultralight Cast/Spun 15x8 16.2 7.34819688
Superlight Ultralight Cast/Spun 15x8.5 16.4 7.43891536
Superlight Ultralight Cast/Spun 15x9 16.8 7.62035232
Superlight Ultralight Cast/Spun 16x10 19.4 8.79969256
Superlight Ultralight Cast/Spun 16x10.5 19.7 8.93577028
Superlight Ultralight Cast/Spun 16x11 20.2 9.16256648
Superlight Ultralight Cast/Spun 16x11.5 20.5 9.2986442
Superlight Ultralight Cast/Spun 16x12 20.9 9.48008116
Superlight Ultralight Cast/Spun 16x12.5 21.3 9.66151812
Superlight Ultralight Cast/Spun 16x6.5 17.4 7.89250776
Superlight Ultralight Cast/Spun 16x7 17.6 7.98322624
Superlight Ultralight Cast/Spun 16x7.5 18 8.1646632
Superlight Ultralight Cast/Spun 16x8 18.2 8.25538168
Superlight Ultralight Cast/Spun 16x8.5 18.4 8.34610016
Superlight Ultralight Cast/Spun 16x9 18.7 8.48217788
Superlight Ultralight Cast/Spun 16x9.5 19.1 8.66361484
Superlite Japan 2-Piece (very rare) Cast/Spun 15x6 16 7.2574784
Taylor 13x5.5 7 3.1751468
Team Dynamics Diablo Cast 17x7.5 20.9 9.48008116
Team Dynamics Diablo Cast 18x7.5 25.1 11.38516924
Team Dynamics DTM Cast 15x7 14 6.3502936
Team Dynamics DTM Cast 16x7.5 17.6 7.98322624
Team Dynamics Monza Cast 17x7 22.5 10.205829
Team Dynamics Motorsport Cast 16x7 19.8 8.98112952
Team Dynamics Motorsport Cast 17x7 23 10.4326252
Team Dynamics Motorsport Cast 18x8 24 10.8862176
Team Dynamics Phantom Cast 17x7 21.8 9.88831432
Team Dynamics Pro BTCC Cast 17x9 19.8 8.98112952
Team Dynamics Pro Comp 1 Cast 17x7 19.2 8.70897408
Team Dynamics Pro Comp 1 Cast 18x8 21.2 9.61615888
Team Dynamics Pro ETC Cast 17x9 19.8 8.98112952
Team Dynamics Pro Mag Cast Mg 17x11 19.8 8.98112952
Team Dynamics Pro Race 1 Cast 15x7 13.4 6.07813816
Team Dynamics Pro Race 1 Cast 16x7 16.5 7.4842746
Team Dynamics Pro Race 1 Cast 17x7 16.8 7.62035232
Team Dynamics Pro Race 1 Cast 17x7.5 18.3 8.30074092
Team Dynamics Pro Race 1 Cast 17x8 19.9 9.02648876
Team Dynamics Pro Race 1.2 Cast 14x7 12 5.4431088
Team Dynamics Pro Race 1.2 Cast 17x7.5 19.8 8.98112952
Team Dynamics Pro Race 2 Cast 15x7 14.1 6.39565284
Team Dynamics Pro Race 2 Cast 16x7 15.4 6.98532296
Team Dynamics Pro Race 2 Cast 17x7 16.5 7.4842746
Team Dynamics Pro Race 2 Cast 18x7.5 18.1 8.21002244
Team Dynamics Pro Rally Cast 15x6 17.2 7.80178928
Team Dynamics Pro Rally Cast 15x7 17.6 7.98322624
Team Dynamics Qualifier Cast 15x7 15 6.803886
Team Dynamics Qualifier Cast 18x8 21 9.5254404
Team Dynamics Raider Cast 17x7 24 10.8862176
Team Dynamics Rim 2000 Cast 17x7.5 21.5 9.7522366
Team Dynamics Sebring DTM Cast 17x7.5 22.5 10.205829
Team Dynamics Super Touring Cast 17x7.5 22 9.9790328
Team Dynamics Tornado Cast 17x7 19.8 8.98112952
Team Dynamics Visage Forged 18x8 17.9 8.11930396
Team Loco 142 Cast 16x7 22 9.9790328
Team Loco Kai Cast 17x7 23 10.4326252
Team Loco Shako Tan Cast 17x7 23 10.4326252
Team Toyota Europe GT-1 Cast 18x8 24 10.8862176
Tecnocast Corsia Forged 17x7 14.8 6.71316752
Tecnomagnesio Cast Mg 15x6.5 10.9 4.94415716
Tecnomagnesio MT 5B2 Cast Mg 16x7 15.4 6.98532296
Tecnomagnesio MT 5B2 Cast Mg 17x10 18 8.1646632
Tecnomagnesio MT 5B2 Cast Mg 17x8 16.3 7.39355612
Tecnomagnesio MT 5B2 Cast Mg 17x8.5 17.6 7.98322624
Tecnomagnesio MT 5B2 Cast Mg 18x10 20.5 9.2986442
Tecnomagnesio MT 6B3 Cast Mg 17x7 19 8.6182556
Tecnomagnesio MT 6B3 Cast Mg 17x8 19.4 8.79969256
Tecnomagnesio MT 6B3 Cast Mg 17x9 20.5 9.2986442
Tecnomagnesio MT 6B3 Cast Mg 18x10 22.7 10.29654748
Tecnomagnesio Sport Cast 15x6.5 17.6 7.98322624
Tecnomagnesio Sport Cast 16x7 19.6 8.89041104
Tecnomagnesio Sport Cast 17x7 24.8 11.24909152
Tenzo-R 2-Type Cast 17x7 20.8 9.43472192
Tenzo-R Apex-5 Cast 17x7 20.3 9.20792572
Tenzo-R Apex-5 Cast 18x7.5 23.9 10.84085836
Tenzo-R AV7 Cast 17x7 20 9.071848
Tenzo-R DC5 Cast 17x7 17.5 7.937867
Tenzo-R DC5 Cast 18x8 21.7 9.84295508
Tenzo-R DC5 Cast 19x10 26.4 11.97483936
Tenzo-R DC5 Cast 19x8.5 23.5 10.6594214
Tenzo-R DC5 v2 Cast 17x7 17.5 7.937867
Tenzo-R DC5 v2 Cast 18x8 21.7 9.84295508
Tenzo-R DC5 v2 Cast 19x10 26.4 11.97483936
Tenzo-R DC5 v2 Cast 19x8.5 23.5 10.6594214
Tenzo-R DC6 Cast 16x7 16.3 7.39355612
Tenzo-R DC6 Cast 17x7 17.8 8.07394472
Tenzo-R DC6 Cast 18x8 22.5 10.205829
Tenzo-R DC6 Cast 18x9.5 24.6 11.15837304
Tenzo-R DC6 v2 Cast 16x7 16.3 7.39355612
Tenzo-R DC6 v2 Cast 17x7 17.8 8.07394472
Tenzo-R DC6 v2 Cast 18x8 22.5 10.205829
Tenzo-R DC6 v2 Cast 18x9.5 24.6 11.15837304
Tenzo-R DriveX-7 Cast 17x7 18.7 8.48217788
Tenzo-R DriveX-7 Cast 18x7.5 21.1 9.57079964
Tenzo-R Formula-10 Cast 17x7 17.4 7.89250776
Tenzo-R Formula-10 Cast 18x7.5 21.5 9.7522366
Tenzo-R GF7 Cast 17x7 19.1 8.66361484
Tenzo-R GF7 Cast 18x7.5 22.3 10.11511052
Tenzo-R GF7 Cast 19x10 28.4 12.88202416
Tenzo-R GF7 Cast 19x8 25.4 11.52124696
Tenzo-R GT5 Cast 18x8 22.2 10.06975128
Tenzo-R GT5 Cast 19x8.5 26.9 12.20163556
Tenzo-R GT5 Cast 20x8.5 28.1 12.74594644
Tenzo-R GT6 Cast 17x7 19.4 8.79969256
Tenzo-R GT6 Cast 18x7.5 23.5 10.6594214
Tenzo-R GT6 Cast 19x10.5 32.1 14.56031604
Tenzo-R GT6 Cast 19x8.5 25.4 11.52124696
Tenzo-R Mach-10 Cast 17x7 19.2 8.70897408
Tenzo-R Mach-10 Cast 18x7.5 22.1 10.02439204
Tenzo-R Mean-6 Cast 17x7 21.7 9.84295508
Tenzo-R Mean-6 Cast 18x7.5 23.2 10.52334368
Tenzo-R Overdose Cast 17x7 22.6 10.25118824
Tenzo-R Overdose Cast 18x7.5 24.3 11.02229532
Tenzo-R Passion-5 Cast 17x7 17.9 8.11930396
Tenzo-R Passion-5 Cast 18x7.5 21 9.5254404
Tenzo-R Poke-10 Cast 17x7 20.9 9.48008116
Tenzo-R Poke-10 Cast 18x7.5 23 10.4326252
Tenzo-R Psycho Cast 17x7 19.5 8.8450518
Tenzo-R Psycho Cast 18x7.5 22.4 10.16046976
Tenzo-R Psycho Cast 19x8 23.5 10.6594214
Tenzo-R RS-5 Cast 17x7 20.3 9.20792572
Tenzo-R RS-5 Cast 18x7.5 22 9.9790328
Tenzo-R Shu-10 Cast 17x7 20.5 9.2986442
Tenzo-R Shu-10 Cast 18x7.5 23 10.4326252
Tenzo-R Shu-4 Cast 15x6.5 16.6 7.52963384
Tenzo-R Shu-4 Cast 17x7 21.2 9.61615888
Tenzo-R Shu-4 Cast 18x7.5 22.9 10.38726596
Tenzo-R Sinko Cast 15x6.5 12.3 5.57918652
Tenzo-R Sinko Cast 17x7 18.7 8.48217788
Tenzo-R Sinko Cast 18x7.5 21.7 9.84295508
Tenzo-R Sinko-R Cast 17x7 19.2 8.70897408
Tenzo-R Sinko-R Cast 18x7.5 21.3 9.66151812
Tenzo-R Tenzo-C Type Cast 17x7 21.8 9.88831432
Tenzo-R Type 2 Cast 17x7 21.6 9.79759584
Tenzo-R ZT-6 Cast 17x7 23.1 10.47798444
Tenzo-R ZT-6 Cast 18x7.5 25.5 11.5666062
TGF MX Cast 17x7 18.3 8.30074092
TIS 07 Cast 20x7.5 33 14.9685492
TMW GTV Cast 17x7 19.5 8.8450518
TMW RX Cast 17x7 20.3 9.20792572
TMW RX Cast 18x7.5 24 10.8862176
Tom Motorsports TCR Cast 17x7 24 10.8862176
TommyKaira ProR Forged 17x7 15.9 7.21211916
TOM's New Action Cast/Spun 14x6 11.1 5.03487564
TOM's New Action Cast/Spun 15x6.5 12.2 5.53382728
TOM's New Sports II Forged 18x7.5 15 6.803886
TOM's S2 Cast 18x8.5 23.8 10.79549912
TOM's S4 Spiker Cast 15x6.5 15.5 7.0306822
TOORA Monotoora (Erebuni) Cast 15x7 22 9.9790328
Toybox48 Hethel Forged 16x7 12.1 5.48846804
Toybox48 Hethel Forged 17x8 13.7 6.21421588
Toyota Altezza (Lexus IS300) Z-Edition Cast 17x7 22 9.9790328
Toyota Camry Steel 14x5.5 18.6 8.43681864
Toyota Celica GTS/Supra P 82-85 Cast 14x7 15 6.803886
Toyota Celica/Supra 82-84 Cast 14x5.5 14.5 6.5770898
Toyota Corolla 86-87 Cast 14x5.5 14.5 6.5770898
Toyota Corolla 93-97 Cast 14x5.5 19 8.6182556
Toyota Matrix Steel 15x6 18.1 8.21002244
Toyota MR2 Cast 15x6 14.5 6.5770898
Toyota MR2 Cast 15x6.5 15 6.803886
Toyota MR-S (front) Cast 15x6 14.6 6.62244904
Toyota Prius 01-03 Cast 14x5.5 13 5.8967012
Toyota Supra 86.5-89 Cast 16x7 23 10.4326252
Toyota Supra L 85 Cast 15x6 15 6.803886
Toyota Supra mk IV Cast 16x8 17.4 7.89250776
Toyota Supra mk IV Cast 16x9 20 9.071848
Toyota Tacoma 4x4 Xtra Cab - 99 Cast 15x7 21 9.5254404
Toyota Van Cast 14x5.5 17 7.7110708
Toyota Yaris Cast 15x6 16 7.2574784
TRD Sports SC430 Cast 18x8 28 12.7005872
TRD Sports T3 Forged 15x6.5 11.4 5.17095336
TRD Sports T3 Forged 16x7 14.9 6.75852676
TRD Sports T3 Forged 16x8 15.7 7.12140068
TRD Sports T3 Forged 17x7.5 18.5 8.3914594
TRD Sports T3 Forged 17x8 18.7 8.48217788
TRD Sports T3 Forged 17x8.5 19 8.6182556
TRM (Tire Rack Motorsports) BR5 Cast 17x7 21 9.5254404
TRM (Tire Rack Motorsports) F1 Forged 16x6.5 10.8 4.89879792
TRM (Tire Rack Motorsports) F1 Forged 17x7.5 12.3 5.57918652
TRM (Tire Rack Motorsports) MT1 Cast 17x8 17 7.7110708
TRM (Tire Rack Motorsports) MT1 Cast 17x8.5 17.5 7.937867
TRM (Tire Rack Motorsports) MT1 Cast 18x8 19 8.6182556
TRM (Tire Rack Motorsports) MT1 Cast 18x9.5 19.2 8.70897408
TRM (Tire Rack Motorsports) R2 Cast 16x6.5 20.3 9.20792572
TRM (Tire Rack Motorsports) R2 Cast 18x7 24.7 11.20373228
TRM (Tire Rack Motorsports) R5 Cast 18x7.5 24.7 11.20373228
TRM (Tire Rack Motorsports) RB5 Cast 15x6.5 17 7.7110708
TRM (Tire Rack Motorsports) RB5 Cast 16x6.5 18.8 8.52753712
TRM (Tire Rack Motorsports) Sniper Cast 18x9 27 12.2469948
TRM (Tire Rack Motorsports) Typhoon Cast 17x7 23 10.4326252
TRM (Tire Rack Motorsports) Typhoon Cast 18x9 26.5 12.0201986
TSW Alpine Cast 14x6 15.5 7.0306822
TSW Alpine Cast 15x6.5 19.4 8.79969256
TSW Avus R Cast 15x7 19.4 8.79969256
TSW Avus R Cast 16x7.5 21.7 9.84295508
TSW Big Deep Cast 17x7 23.3 10.56870292
TSW Blade Cast 16x7.5 21 9.5254404
TSW Bremma Cast 19x9.5 32 14.5149568
TSW Edge Cast 17x7 21.8 9.88831432
TSW Eurace Cast 17x7 24.3 11.02229532
TSW Evo Cast 15x7 17 7.7110708
TSW Evo Cast 16x7 20.4 9.25328496
TSW Fly Cast 15x7 18.5 8.3914594
TSW Fly Cast 16x7 20.7 9.38936268
TSW Fly Cast 17x7 22.8 10.34190672
TSW Fury Cast 15x6.5 16.5 7.4842746
TSW Hockenheim Cast 15x7 18.8 8.52753712
TSW Hockenheim Cast 17x8 23.8 10.79549912
TSW Hockenheim Cast 18x8 25.5 11.5666062
TSW Quad Cast 14x6 12.5 5.669905
TSW Quad Cast 15x6.5 15 6.803886
TSW Revo Cast 16x7 20.4 9.25328496
TSW Revo Cast 17x7 24.8 11.24909152
TSW SGV Cast 16x7 22 9.9790328
TSW SGV Cast 18x8 30.5 13.8345682
TSW Spirit Cast 18x8 27.5 12.473791
TSW Trophy Cast 15x7 19 8.6182556
TSW Turn 7 Cast 17x7 22 9.9790328
TSW Volcano Cast 18x8 21 9.5254404
TSW VX1 Cast 16x7 22.5 10.205829
TSW VX1 Cast 17x7 24 10.8862176
TSW VX1 Cast 18x8 27 12.2469948
TSW Zenon Cast 17x7 24 10.8862176
Ultra Wheels Cast 17x7.5 24.8 11.24909152
Ultra Wheels Cast 20x8.5 44.5 20.1848618
Ultra Wheels Koge Cast 17x7 25 11.33981
Veilside Andrew Racing eF Forged/Spun 18x10 27 12.2469948
Veilside Andrew Racing Pasha D Cast 17x7 22 9.9790328
Velocity Motoring VB3 (CSL replica) Cast 18x8.5 24 10.8862176
Velocity Motoring VB3 (CSL replica) Cast 18x9.5 24.4 11.06765456
Velocity Motoring VB3 (CSL replica) Cast 19x8.5 24.8 11.24909152
Velocity Motoring VB3 (CSL replica) Cast 19x9.5 25.3 11.47588772
Velox Drift Spec Cast 18x8.5 26 11.7934024
Velox Drift Spec Cast 18x9.5 28 12.7005872
Velox Hyperion Cast 20x8.5 29.4 13.33561656
Velox PG-5s Forged 17x7 12.5 5.669905
Velox PG-5s Forged 18x7.5 16.5 7.4842746
Velox PG-Rev10 Forged 17x7 11.5 5.2163126
Velox PG-Rev5 Forged 17x7 12.1 5.48846804
Velox VX-5 Cast 19x8 27 12.2469948
Velox VX-6 Cast 17x7 23 10.4326252
Velox VX-6 Cast 18x7.5 25.5 11.5666062
Velox VX-6r Cast 17x7 14.5 6.5770898
Velox VX-6r Cast 18x7.5 18 8.1646632
Velox VX-8 Cast 17x7.5 23 10.4326252
Velox VX-8 Cast 18x7.5 25.5 11.5666062
Velox VX-8r Cast 16x7 21 9.5254404
Velox VX-K Cast 17x7.5 23 10.4326252
Velox VX-K Cast 18x7.5 25.5 11.5666062
Velox VX-Nova Cast 17x7.5 23 10.4326252
Velox VX-Nova Cast 18x8.5 25.5 11.5666062
Velox VX-Scythe Cast 17x7.5 23 10.4326252
Velox VX-Scythe Cast 17x8.5 25.5 11.5666062
Velox Zeta 5 Cast 17x7.5 23 10.4326252
Velox Zeta 5 Cast 18x7.5 25.5 11.5666062
Velox Zeta K Cast 17x7.5 23 10.4326252
Velox Zeta K Cast 18x7.5 25.5 11.5666062
Vision 814 Cast 16x7 22 9.9790328
Vision 818 Cast 14x6 15 6.803886
Vision 818 Cast 16x7 21.3 9.66151812
Vision 96 Cast 16x7.5 22.8 10.34190672
Volk CE28N Forged 14x5.5 6.5 2.9483506
Volk CE28N Forged 15x5.5 7.7 3.49266148
Volk CE28N Forged 15x6.5 8.1 3.67409844
Volk CE28N Forged 15x7 9.1 4.12769084
Volk CE28N Forged 16x7 11.9 5.39774956
Volk CE28N Forged 16x8 12.9 5.85134196
Volk CE28N Forged 17x7.5 13.8 6.25957512
Volk CE28N Forged 17x9 14.8 6.71316752
Volk CE28N Forged 18x8 14.7 6.66780828
Volk CE28N Forged 18x8.5 16 7.2574784
Volk CE28N Forged 18x9.5 17 7.7110708
Volk CE28N Forged 19x8.5 19.4 8.79969256
Volk CE28N Time Attack Forged 17x8 15 6.803886
Volk CE28N Time Attack Forged 17x9 16.4 7.43891536
Volk Challenge Cast 17x8 19.5 8.8450518
Volk Daytona Speed Cast 17x8 24 10.8862176
Volk GTA Forged/Spun 17x9 21 9.5254404
Volk GTN Forged/Spun 18x7.5 18.5 8.3914594
Volk GTN Forged/Spun 18x8.5 19 8.6182556
Volk GTP Forged/Spun 17x9 19.5 8.8450518
Volk LE28N Forged 18x8.5 17 7.7110708
Volk LE37T Forged 18x7.5 17.3 7.84714852
Volk Progressiv ME Face-1 Forged 19x8.5 21.4 9.70687736
Volk Progressiv ME Face-1 Forged 19x9.5 22.3 10.11511052
Volk Progressiv Spoke Forged 18x7.5 20.9 9.48008116
Volk RE30 Forged 18x7.5 15.8 7.16675992
Volk RE30 Forged 18x8 16.2 7.34819688
Volk RE30 Forged 18x8.5 17 7.7110708
Volk SE37K Forged 17x7.5 14.3 6.48637132
Volk SE37K Forged 18x9.5 16.8 7.62035232
Volk Sebring ITC Cast 18x7.5 21.5 9.7522366
Volk SS Cast 18x7.5 25 11.33981
Volk TE37 Forged 13x5 7.4 3.35658376
Volk TE37 Forged 13x5.5 7.7 3.49266148
Volk TE37 Forged 13x6 7.5 3.401943
Volk TE37 Forged 13x8 8.3 3.76481692
Volk TE37 Forged 14x5 8.4 3.81017616
Volk TE37 Forged 14x5.5 8.5 3.8555354
Volk TE37 Forged 14x6 8.7 3.94625388
Volk TE37 Forged 14x6.5 8.9 4.03697236
Volk TE37 Forged 14x7 9.3 4.21840932
Volk TE37 Forged 15x5.5 7.9 3.58337996
Volk TE37 Forged 15x6 8.2 3.71945768
Volk TE37 Forged 15x6.5 8.8 3.99161312
Volk TE37 Forged 15x7 9.2 4.17305008
Volk TE37 Forged 15x7.5 10.6 4.80807944
Volk TE37 Forged 15x8 11.5 5.2163126
Volk TE37 Forged 16x7 11.2 5.08023488
Volk TE37 Forged 16x7.5 11.3 5.12559412
Volk TE37 Forged 16x8 13.3 6.03277892
Volk TE37 Forged 16x8.5 13.7 6.21421588
Volk TE37 Forged 17x7.5 15 6.803886
Volk TE37 Forged 17x8 16.3 7.39355612
Volk TE37 Forged 17x8.5 15.9 7.21211916
Volk TE37 Forged 17x9 17 7.7110708
Volk TE37 Forged 17x9.5 17.2 7.80178928
Volk TE37 Forged 18x10 19 8.6182556
Volk TE37 Forged 18x10.5 19.4 8.79969256
Volk TE37 Forged 18x7.5 17 7.7110708
Volk TE37 Forged 18x8 18.1 8.21002244
Volk TE37 Forged 18x8.5 17.2 7.80178928
Volk TE37 Forged 18x9 17.7 8.02858548
Volk TE37 Forged 18x9.5 18.3 8.30074092
Volk TE37 Forged 19x8 20 9.071848
Volk TE37 Forged 19x8.5 20.2 9.16256648
Volk TE37 Forged 19x9.5 20.9 9.48008116
Volk TE37 Gravel Forged 14x6 9.9 4.49056476
Volk TE37 Gravel Forged 15x6.5 11 4.9895164
Volk TE37 Gravel Forged 15x7 11.2 5.08023488
Volk TE37 Gravel Forged 16x6.5 13.1 5.94206044
Volk TE37 Mag Forged Mg 18x10 17.7 8.02858548
Volk TE37 Mag Forged Mg 18x8.5 16.1 7.30283764
Volk TE37 Mag Forged Mg 18x9.5 17.2 7.80178928
Volk TE37 Time Attack Forged 18x7.5 17 7.7110708
Volk TE37X Forged 16x5.5 13.8 6.25957512
Volk TE37X Forged 16x6.5 14.8 6.71316752
Volk TE37X Forged 16x7 14.6 6.62244904
Volk TE37X Forged 16x8 15.2 6.89460448
Volk Versus Tourismo Spada Cast 18x7.5 25.5 11.5666062
Volkswagen Avus (Snowflake) Cast 15x6.5 16.5 7.4842746
Volkswagen Bettle Cast 15x6 27 12.2469948
Volkswagen Bettle 06-07 Cast 16x6.5 19 8.6182556
Volkswagen Bettle Sport & Cabriolet Cast 17x7 24 10.8862176
Volkswagen Bravo Cast 17x7.5 22.5 10.205829
Volkswagen Cabriolet Cast 14x6 15.5 7.0306822
Volkswagen Corrado G60 Cast 15x6.5 19 8.6182556
Volkswagen Corrado SLC BBS Cast 15x6.5 18.5 8.3914594
Volkswagen EOS Cast 18x8 28 12.7005872
Volkswagen Golf (BBS RM 2-piece) Cast/Cast (very soft) 15x6.5 15 6.803886
Volkswagen Golf 03-05 Cast 15x6 20 9.071848
Volkswagen Jetta GLI Cast 17x7.5 20 9.071848
Volkswagen Golf GLS 03-06 Cast 15x6 17.5 7.937867
Volkswagen Golf GTI (BBS RS 3-piece) Forged/Cast 15x7 13.2 5.98741968
Volkswagen Golf GTI (Denver) Cast 17x7 28 12.7005872
Volkswagen Golf GTI (Huffeisen) Cast 18x7.5 29 13.1541796
Volkswagen Golf VR6 03-06 Cast 17x7.5 25 11.33981
Volkswagen Jetta 90-92 Cast 14x6 15.4 6.98532296
Volkswagen Golf GTI (Indianapolis) Cast 17x7 27 12.2469948
Volkswagen Jetta 99-04 Cast 15x6 16.5 7.4842746
Volkswagen Jetta 05-07 Cast 16x6.5 22 9.9790328
Volkswagen Jetta 06-07 Cast 17x7 22.5 10.205829
Volkswagen Passat 01-05 Cast 15x7 20 9.071848
Volkswagen Passat 98-02 Cast 16x7 18.5 8.3914594
Volkswagen Passat 98-02 (Montreal) Cast 16x6.5 17.5 7.937867
Volkswagen Passat 98-02 (Tango) Cast 16x6.5 22 9.9790328
Volkswagen Passat 01-06 Cast 16x7 22 9.9790328
Volkswagen Passat 06 Sport Cast 18x8 28 12.7005872
Volkswagen Passat 06 Sport (Euro) Cast 18x8 29 13.1541796
Volkswagen Passat 01-05 W8 Cast 17x7.5 25 11.33981
Volkwagen Phaeton Cast 18x8.5 27 12.2469948
Volkwagen Phaeton W12 Cast 18x8.5 28 12.7005872
Volkwagen Phaeton Cast 19x9 33 14.9685492
Volkwagen Phaeton Cast 19x8.5 31 14.0613644
Volkswagen R32 Cast 18x7.5 28 12.7005872
Volkswagen Siata Cast 17x7 21 9.5254404
Voxx Argus Cast 17x7 22.5 10.205829
Voxx Forza Cast 18x9 30.4 13.78920896
Voxx JB Cast 18x8 24.3 11.02229532
Voxx Matrix Cast 17x7 21 9.5254404
Voxx Scorze Cast 18x9 27.9 12.65522796
Voxx Saga Cast 17x7 20.9 9.48008116
Voxx Saga Cast 17x8 22.9 10.38726596
Voxx Saga Cast 18x8 25.6 11.61196544
Voxx Saga Cast 19x8 27.8 12.60986872
Voxx Scorze Cast 17x7 21.9 9.93367356
Voxx Scorze Cast 17x8 24 10.8862176
Voxx Scorze Cast 18x8 26.3 11.92948012
Voxx Scorze Cast 20x8 34 15.4221416
Voxx Scorze Cast 20x9 31.6 14.33351984
Voxx MG Cast 15x7 17.9 8.11930396
Voxx MG Cast 16x7 18.7 8.48217788
Voxx MG Cast 17x7 22.1 10.02439204
Voxx Toscana Cast 16x7 19.5 8.8450518
Voxx Toscana Cast 17x7 21.2 9.61615888
Voxx Ancona Cast 17x8 24 10.8862176
Voxx Ancona Cast 17x9 27 12.2469948
Voxx Ancona Cast 18x8 27 12.2469948
Voxx Ancona Cast 18x9 30 13.607772
Voxx Ancona Cast 20x8.5 36 16.3293264
Voxx Ancona Cast 20x9.5 38 17.2365112
Voxx Misano Cast 17x8 22 9.9790328
Voxx Misano Cast 17x9 25 11.33981
Voxx Misano Cast 18x8 27 12.2469948
Voxx Misano Cast 18x9 30 13.607772
Voxx Misano Cast 20x8.5 33 14.9685492
Voxx Misano Cast 20x9.5 35 15.875734
Voxx Monza Cast 15x7 18.7 8.48217788
Voxx Monza Cast 16x7 20.2 9.16256648
Voxx Monza Cast 17x7 21.2 9.61615888
VSMPO Alfa Cast 17x7.5 15.2 6.89460448
VSMPO Pallada R Cast 15x6.5 13.5 6.1234974
VSMPO Solaris Cast 15x6 11.5 5.2163126
VSMPO Vega R Cast 15x6.5 14.4 6.53173056
Wed's Celeb V2 Cast 16x7 19 8.6182556
Wed's RE-005 Cast 18x8 22 9.9790328
Wed's RE-005 Cast 19x8 24 10.8862176
Wed's RS-5 (Original design) Cast/Spun 15x6.5 13.5 6.1234974
Wed's RS-5 Super Street Cast 14x5 8.9 4.03697236
Wed's RS-5 Super Street Cast 15x5 9.2 4.17305008
Wed's RS-5 Super Street Cast 16x7 13.5 6.1234974
Wed's RS-5 Super Street Cast 17x7.5 15.6 7.07604144
Wed's SA-70 Cast 17x7.5 16.7 7.57499308
Wed's SA-70 Cast 17x9 17.8 8.07394472
Wed's SA-70 Cast 18x9 18.4 8.34610016
Wed's SA-90 Cast 15x7 17.4 7.89250776
Wed's SA-90 Cast 16x7 18.4 8.34610016
Wed's SA-90 Cast 17x7.5 20 9.071848
Wed's SA-90 Cast 17x8 20.8 9.43472192
Wed's TC-005 Forged 14x6 8.8 3.99161312
Wed's TC-005 Forged 15x6.5 10.2 4.62664248
Wed's TC-005 Forged 15x7 10.7 4.85343868
Wed's TC-005 Forged 15x7.5 11 4.9895164
Wed's TC-005 Forged 16x7 12.7 5.76062348
Wed's TC-005 Forged 16x7.5 13.2 5.98741968
Wed's TC-005 Forged 16x8 13.9 6.30493436
Wed's TC-005 Forged 17x7 13.8 6.25957512
Wed's TC-005 Forged 17x7.5 14.2 6.44101208
Wed's TC-005 Forged 17x8 14.9 6.75852676
Wed's TC-005 Forged 17x8.5 15.3 6.93996372
Wed's TC-005 Forged 17x9 15.8 7.16675992
Wed's TC-005 Forged 17x9.5 16.3 7.39355612
Wed's TC-005 Forged 18x10 18.9 8.57289636
Wed's TC-005 Forged 18x7.5 16.8 7.62035232
Wed's TC-005 Forged 18x8 17.7 8.02858548
Wed's TC-005 Forged 18x8.5 17.9 8.11930396
Wed's TC-005 Forged 18x9 18.6 8.43681864
Wed's TC-105N Forged 15x6.5 10.6 4.80807944
Wed's TC-105N Forged 15x7 11.2 5.08023488
Wed's TC-105N Forged 16x7 12.2 5.53382728
Wed's TC-105N Forged 17x8 14.9 6.75852676
Wed's TC-105N Forged 17x8.5 15.4 6.98532296
Wed's TC-105N Forged 17x9 15.8 7.16675992
Wed's TC-105N Forged 17x9.5 16.3 7.39355612
Wed's TC-105N Forged 18x10.5 18.4 8.34610016
Wed's TC-105N Forged 18x8 16.1 7.30283764
Wed's TC-105N Forged 18x8.5 17 7.7110708
Wed's TC-105N Forged 18x9.5 17.6 7.98322624
Weld (racing only) Cast 13x8 9.5 4.3091278
Weld (racing only) Cast 13x9 10 4.535924
Weld EVO Forged 16x8 16.2 7.34819688
Weld EVO Espada SL Forged 20x8.5 28.6 12.97274264
Weld EVO R-71 Forged 18x8 23 10.4326252
Weld EVO R-76 Forged 17x8 20 9.071848
Weld EVO SL-5 Forged 17x7 20 9.071848
Weld Magnum Import Drag Forged 13x8 8.6 3.90089464
Weld Type 76 Forged 15x7 15 6.803886
Western Turbine Cast 13x6 10 4.535924
Wolfrace ML Cast 15x7 17 7.7110708
Work CR-02 Cast 17x7 17.4 7.89250776
Work CR-03 Cast 18x8 20.9 9.48008116
Work Emotion Forged 17x7.5 15.3 6.93996372
Work Emotion Forged 17x8.5 16.2 7.34819688
Work Emotion Forged 18x7.5 16.7 7.57499308
Work Emotion Forged 18x8.5 17.4 7.89250776
Work Emotion CR Kai Cast 15x7 15 6.803886
Work Emotion CR Kai Cast 16x7 17 7.7110708
Work Emotion CR Kai Cast 17x7 19 8.6182556
Work Emotion CR Kai Cast 17x8 20 9.071848
Work Emotion CR Kai Cast 17x9 19 8.6182556
Work Emotion CR Kai Cast 18x7.5 21.4 9.70687736
Work Emotion CR Kai Cast 18x8.5 20.7 9.38936268
Work Equip 01 Cast 14x7 14.1 6.39565284
Work Equip 03 Cast 14x7 13.2 5.98741968
Work Ewing RS Beta 3-Piece Cast 15x6.5 15 6.803886
Work Meister S1 Cast/Spun 19x8.5 24 10.8862176
Work Meister S2R Forged/Spun 17x7 19.2 8.70897408
Work Meister S2R Forged/Spun 17x7.5 19 8.6182556
Work Meister S2R Forged/Spun 17x9 20.5 9.2986442
Work Meister S2R Forged/Spun 18x9 22.3 10.11511052
Work Rezax II Mag Forged Mg 18x8.5 19 8.6182556
Work Rezax III Mag Forged Mg 18x8 17.4 7.89250776
Work VS-XX Cast/Spun 15x6.5 15 6.803886
Work VS-XX Cast/Spun 15x7 15.5 7.0306822
Work VS-XX Cast/Spun 17x7 20 9.071848
Work VS-XX Cast/Spun 18x10 26 11.7934024
Work VS-XX Cast/Spun 18x8 24 10.8862176
Xenex Muse Cast 19x8 26.3 11.92948012
Zauber Genesis D-Six Cast 18x7.5 29.7 13.47169428
Zauber Genesis D-Six Cast 18x8 31.2 14.15208288
Zauber Glanzen Cast/Spun 17x7 24.1 10.93157684
Zauber Glanzen EV 3-Piece Cast/Spun 17x7.5 25.2 11.43052848
Zen Racing Matrix Cast 18x7.5 24 10.8862176
Zen Racing Race Cast 18x7.5 25.3 11.47588772
Zenetti Cast 18x8.5 24 10.8862176
Zenetti Cast 20x8.5 39.8 18.05297752
Zenetti Blade Cast 22x10 50 22.67962
Zinik Z15 Verona Cast 18x7.5 23.5 10.6594214
Zinik Z16 Duet Cast 18x8 28.5 12.9273834
Zinik Z17 Caroza Cast 18x7.5 26 11.7934024
Zinik Z18 Minardi Cast 18x7.5 23.5 10.6594214
Zinik Z20 Violi Cast 18x7.5 27.8 12.60986872
Zinik Z24 Risso Cast 17x7.5 23.5 10.6594214
Zinik Z24 Risso Cast 18x7.5 27 12.2469948
Zinik Z24 Risso Cast 19x8 30 13.607772
Zinik Z25 Luni Cast 18x7.5 27 12.2469948
Zinik Z27 Sofin Cast 18x7.5 27 12.2469948
Zinik Z5 Ikeda Cast 17x7.5 26 11.7934024
Zinik Z5 Ikeda Cast 18x7.5 28.5 12.9273834
Zinik Z7 Adrian Cast 17x7.5 21.8 9.88831432
Zinik Z7 Adrian Cast 18x7.5 26 11.7934024
Zinik Z9 Sabini Cast 18x7.5 27.1 12.29235404
Z-Speed Cast 15x6.5 12.3 5.57918652
LAST UPDATE: 6/29/10 total weights = 4495
You may send any additions/corrections to info@wheelweights.net
Please click on a Google ad or two to help me pay for part of my web hosting fees. Thanks.
Just came across this. Some good info
Name Manufacturing Method Size Weight (lbs.) Weight (kgs.)
562 Fuel Cast 17x7 26.5 12.0201986
562 Kabuki Cast 17x7 27 12.2469948
57Motorsport G07WT Cast 17x7 18 8.1646632
5Zigen 5ZR Copse Cast/Spun 16x7 15.7 7.12140068
5Zigen 5ZR Copse Cast/Spun 17x7 23 10.4326252
5Zigen 5ZR Copse Cast/Spun 17x7.5 23.5 10.6594214
5Zigen 5ZR Copse Cast/Spun 18x10 26 11.7934024
5Zigen Beckets FN-01R Forged 15x7 10.6 4.80807944
5Zigen Beckets FN-01R Forged 16x7 11.7 5.30703108
5Zigen Beckets FN-01R Forged 17x7.5 13.9 6.30493436
5Zigen Beckets FN-01R Forged 17x8 14.7 6.66780828
5Zigen Beckets FN-01R Forged 17x8.5 15.4 6.98532296
5Zigen Beckets FN-01R Forged 17x9 15.6 7.07604144
5Zigen Beckets FN-01R Forged 17x9.5 15.8 7.16675992
5Zigen Copse Cast 15x7 11 4.9895164
5Zigen DIV.3 Cast 15x6.5 12.6 5.71526424
5Zigen Fighter Cast 17x7 17 7.7110708
5Zigen Fireball Cast 17x7 18 8.1646632
5Zigen Fireball Typhoon Cast 17x7.5 21.5 9.7522366
5Zigen Fireball Typhoon Cast 17x8 22 9.9790328
5Zigen Fireball Typhoon Cast 17x9 22.5 10.205829
5Zigen FN01R-C Cast 15x7 14 6.3502936
5Zigen FN01R-C Cast 16x7 15 6.803886
5Zigen FN01R-C Cast 17x10 21.5 9.7522366
5Zigen FN01R-C Cast 17x7 16 7.2574784
5Zigen FN01R-C Cast 17x8 17 7.7110708
5Zigen FN01R-C Cast 17x9 19 8.6182556
5Zigen FN01R-C Cast 18x7.5 18.5 8.3914594
5Zigen FN01R-C Cast 18x8.5 21.5 9.7522366
5Zigen FN01R-C Cast 18x9.5 23 10.4326252
5Zigen Heidfeld Cast 17x7 19 8.6182556
5Zigen Heidfeld Cast 18x7.5 20 9.071848
5Zigen Heidfeld 2-Piece Cast/Spun 17x7.5 24.3 11.02229532
5Zigen Hyper 5ZR Cast 18x7.5 25 11.33981
5Zigen Imperio M05 Cast 17x7 19 8.6182556
5Zigen Imperio M05 Cast 18x7.5 20.5 9.2986442
5Zigen Imperio S08 Cast 16x7 19.8 8.98112952
5Zigen Imperio S08 Cast 17x7 20.5 9.2986442
5Zigen N1R-SP08 Cast 15x6.5 14.1 6.39565284
5Zigen N1R-SP08 Cast 17x7 17.5 7.937867
5Zigen ProRacer GN+ Cast 17x7.5 20 9.071848
5Zigen ProRacer GN+ Cast 17x8.5 20.5 9.2986442
5Zigen ProRacer GN+ Cast 17x9.5 21 9.5254404
5Zigen ProRacer GN+ Cast 18x7.5 21.5 9.7522366
5Zigen ProRacer GN+ Cast 18x8.5 22 9.9790328
5Zigen ProRacer GN+ Cast 18x9.5 22.5 10.205829
5Zigen RSX-6 Cast 17x7 17.7 8.02858548
5Zigen Sports Engine SC3000 Cast 19x8.5 27 12.2469948
5Zigen Sports Engine SC3000 Cast 19x9.5 28 12.7005872
5Zigen Super Six Cast 17x7 19 8.6182556
5Zigen Super Six Cast 18x7.5 19.8 8.98112952
5Zigen Typhoon Cast 17x7.5 21.5 9.7522366
5Zigen Typhoon Cast 17x8 22 9.9790328
5Zigen Typhoon Cast 17x9 22.5 10.205829
6061 A5 Forged 17x7 14.5 6.5770898
6061 A5 Forged 19x7.5 18.5 8.3914594
6061 A5LW Forged 17x7 13.5 6.1234974
6061 A5LW Forged 19x7.5 15 6.803886
6061 AM Forged 19x7.5 16.5 7.4842746
949Racing 6UL Cast 15x7.5 12 5.4431088
949Racing 6UL Cast 15x8 12.8 5.80598272
949Racing 6UL Cast 15x9 13.4 6.07813816
AB-Eintz Type 06 Cast 20x8.5 29 13.1541796
AB-Eintz Type 07 Cast 18x8.5 27.8 12.60986872
AB-Eintz Type 13 Cast 19x9.5 31.3 14.19744212
ABT Sportsline A-10 Cast 18x8 24 10.8862176
ABT Sportsline A-16 Cast 17x8 24.8 11.24909152
ABT Sportsline A-23 Cast 17x7.5 22.5 10.205829
ABT Sportsline New Classic Cast 18x8 26 11.7934024
ABT Sportsline V1 Cast 17x7.5 21.3 9.66151812
AC Schnitzer (front) Forged 20x10 22 9.9790328
AC Schnitzer (rear) Forged 20x10 23.8 10.79549912
AC Schnitzer Type II Forged 17x8.5 21.5 9.7522366
Ace A109 (Formula) Cast 17x7 25 11.33981
Ace A130 (Spyder) Cast 18x10 25 11.33981
Ace A130 (Spyder) Cast 18x8.5 23 10.4326252
Ace A131 (Lola) Cast 17x7 23.5 10.6594214
Ace A132 (Klassik) Cast 19x8.5 28.5 12.9273834
Ace A134 (Turbo) Cast 17x7 20.5 9.2986442
Ace A137 (Flame) Cast 18x8.5 31.5 14.2881606
Ace A151 (Spade) Cast 18x7.5 23 10.4326252
Ace A157 (Monaco) Cast 19x8 27.3 12.38307252
Ace A164 (Desire) Cast 18x8.5 26.5 12.0201986
Ace A184 (Zeus) Cast 18x7.5 25 11.33981
Ace A184 (Zeus) Cast 18x8.5 30 13.607772
Ace A204 (Impact) Cast 17x7 19 8.6182556
Ace A204 (Impact) Cast 19x8 24 10.8862176
Ace A205 (Manta) Cast 18x7.5 23 10.4326252
Ace A205 (Manta) Cast 19x8 26.6 12.06555784
Ace A205 (Manta) Cast 19x8.5 27 12.2469948
Ace C001 (T1) Cast 22x9.5 39 17.6901036
Ace C053 (Trend) Cast 19x8.5 28 12.7005872
Ace C103 (Allure) Cast 18x8 25.5 11.5666062
Ace C808 (Spark) Cast 18x8 26.5 12.0201986
Ace C808 (Spark) Cast 20x8.5 36.5 16.5561226
Ace C808B (Mack) Cast 22x9.5 46.5 21.0920466
Ace C813 (Le Mans) Cast 22x9.5 37 16.7829188
Ace C814 (Slick) Cast 19x11 30 13.607772
Ace D632 (Matrix) Cast 19x8.5 27 12.2469948
Ace D636 (Radium) Cast 18x8 22.5 10.205829
Ace D636 (Radium) Cast 19x8 27 12.2469948
Acura Integra GS 92 Cast 14x5.5 15.5 7.0306822
Acura Integra GS-R 94-95 Cast 15x6 16 7.2574784
Acura Integra GS-R 96 Cast 15x6 15.5 7.0306822
Acura Integra GS-R 97 (00+ LS) Cast 15x6 15 6.803886
Acura Integra GS-R 98-01 Cast 15x6 16.3 7.39355612
Acura Integra Type-R (Euro 5-bolt) Cast 15x6 13 5.8967012
Acura Integra Type-R (JDM 4-bolt) Cast 15x6 12.3 5.57918652
Acura Integra Type-R (JDM 4-bolt) Cast 16x7 17 7.7110708
Acura Integra Type-R (US 5-bolt) Cast 15x6 15.6 7.07604144
Acura NSX Forged 15x6.5 15.2 6.89460448
Acura NSX Forged 16x7 16.8 7.62035232
Acura NSX Forged 16x8 18.9 8.57289636
Acura NSX Forged 17x8.5 20.9 9.48008116
Acura RSX 02-04 Cast 16x6.5 16 7.2574784
Acura RSX 05-06 Cast 17x7 20.7 9.38936268
Acura TSX 04-05 Cast 17x7 21 9.5254404
Adler Racing AR05A Cast 16x7 15.7 7.12140068
Adler Racing AR08 Cast 16x7 15.7 7.12140068
ADR 39 (Intercrew) Cast 17x7 20.3 9.20792572
ADR 42 (M-Classic) Cast 20x8.5 29.8 13.51705352
ADR 43 (X-Factor) Cast 19x8 27.8 12.60986872
ADR Battle Axe Cast 17x7 22.5 10.205829
ADR Cobra Cast 17x9 26 11.7934024
ADR DTM Cast 16x7 19 8.6182556
ADR Hypertek Cast 17x7 19 8.6182556
ADR J-Sprint Cast 17x7 18.8 8.52753712
ADR Kasai Cast 18x8 22.8 10.34190672
ADR Lightning Cast 17x7 25.5 11.5666062
ADR M-Sport Cast 17x7 22.1 10.02439204
ADR M-Sport Cast 18x7.5 23 10.4326252
ADR M-Sport Cast 18x8.5 25 11.33981
ADR M-Sport Cast 18x9.5 26.7 12.11091708
ADR Reaction Cast 16x7 19.9 9.02648876
ADR Reaction Cast 18x7.5 24.3 11.02229532
ADR Revolution Cast 17x7 20.5 9.2986442
ADR RS Limited 17 Shinwa Cast 17x7 20.1 9.11720724
ADR RS Limited Concept Pro Cast 15x6.5 13 5.8967012
ADR RS Limited Concept Pro Cast 16x7 16.5 7.4842746
ADR RS Limited Concept Pro Cast 17x7 18 8.1646632
ADR RS Limited Mase Cast 17x7 17.5 7.937867
ADR RS Limited Mase Cast 18x7.5 19.5 8.8450518
ADR RS Limited Ricochet Cast 17x7 19.4 8.79969256
ADR RS Limited Shinwa Cast 16x7 15 6.803886
ADR RS2000 Cast 17x7 21 9.5254404
ADR RS2000 Cast 18x8 23 10.4326252
ADR Version II Cast 18x8 28.6 12.97274264
Advan Kreuzer Series X Cast 18x8 16.5 7.4842746
Advan Model 5 Cast 18x8 19.8 8.98112952
Advan Model 7 Cast 15x5.5 12.3 5.57918652
Advan Model 7 Cast 19x9 27 12.2469948
Advan Model T6 Cast 18x8 20 9.071848
Advan Racing Oni Cast 15x7 14.5 6.5770898
Advan Racing RA3-DT Cast 17x9.5 18.5 8.3914594
Advan Racing RA3-DT Cast 18x10 20.5 9.2986442
Advan Racing RC II Cast 18x7.5 17 7.7110708
Advan Racing RC Rally Cast 17x7 18.5 8.3914594
Advan Racing RG Cast 14x6 8.9 4.03697236
Advan Racing RG Cast 14x6.5 9.9 4.49056476
Advan Racing RG Cast 15x6.5 10.5 4.7627202
Advan Racing RG Cast 15x7 11.4 5.17095336
Advan Racing RG Cast 15x7.5 12.1 5.48846804
Advan Racing RG Cast 15x8 12.6 5.71526424
Advan Racing RG Cast 16x7 12.7 5.76062348
Advan Racing RG Cast 16x7.5 13.4 6.07813816
Advan Racing RG Cast 16x8 13.8 6.25957512
Advan Racing RG Cast 17x7.5 15.2 6.89460448
Advan Racing RG Cast 17x8.5 16.5 7.4842746
Advan Racing RG Cast 17x9.5 17.9 8.11930396
Advan Racing RG Cast 18x9 19 8.6182556
Advan Racing RG II Cast 16x7 12.9 5.85134196
Advan Racing RG II Cast 17x9 16.7 7.57499308
Advan Racing RG II Cast 18x7.5 17 7.7110708
Advan Racing RG II Cast 18x8 17.4 7.89250776
Advan Racing RG II Cast 18x9 17.9 8.11930396
Advan Racing RS Cast 17x8.5 16.5 7.4842746
Advan Racing RS Cast 17x9 17.5 7.937867
Advan Racing RS Cast 18x9 17.7 8.02858548
Advan Racing RZ Cast 18x8 16.5 7.4842746
Advan Racing T6 Cast 17x8 17 7.7110708
Advan Racing T6 Cast 18x8 17.4 7.89250776
Advan Racing T7 Cast 18x8 17.4 7.89250776
Advan Racing TC Cast 18x7.5 19.8 8.98112952
Advan Racing TC II Cast 18x7.5 17 7.7110708
Advan Racing TC II Cast 18x9.5 17.5 7.937867
Advan Siena Generation II Cast 18x10 25 11.33981
Advan Super Advan Generation II Cast 18x7.5 17.6 7.98322624
Advan Super Advan Generation II Cast 18x8.5 18 8.1646632
Advan Super Advan Racing SA3R Cast 17x8 23.5 10.6594214
Advan Super Advan Racing SA3R Cast 18x9.5 25.5 11.5666062
Advanti Racing 976 Cast 17x7 21.8 9.88831432
Advanti Racing Battle Z Cast 17x7 22 9.9790328
Advanti Racing Jazz Cast 16x7 18.5 8.3914594
Advanti Racing Lightening Cast 17x7 23.5 10.6594214
Advanti Racing Tuner 6 Cast 17x7 18 8.1646632
Aerospeed RS-11 Cast 17x7 21.4 9.70687736
Aerospeed RS-12 Cast 17x7 23.5 10.6594214
Aerospeed RS-14 Cast 17x7 20.5 9.2986442
Aerospeed RS-6 Cast 17x7 23 10.4326252
AEZ Bimo Cast 18x8.5 26.8 12.15627632
AEZ Paron Cast 18x8.5 27.4 12.42843176
AEZ Radon Cast 16x7.5 19 8.6182556
AEZ Simas X Cast 18x8.5 30.5 13.8345682
AFX Ambush 750 Cast 20x8.5 33 14.9685492
AFX Wedge Cast 17x7.5 27.5 12.473791
AG Forged SMK Monoblock AG1-SMK13 Forged 17x9 13.2 5.98741968
AG Forged SMK Monoblock AG3-SMK26 Forged 17x7.5 9.5 4.3091278
AG Forged SMK Monoblock D104 Forged 17x8 16.3 7.39355612
AG Forged SMK Monoblock D104 Forged 18x8 19.2 8.70897408
AG Forged SMK Monoblock D13 Forged 17x8 17.8 8.07394472
AG Forged SMK Monoblock D57 Forged 16x7 12.5 5.669905
AG Forged SMK Monoblock D57 Forged 17x7.5 17.6 7.98322624
AG Forged SMK Monoblock D57 Forged 18x8 16.5 7.4842746
AG Forged SMK Monoblock D74 Forged 18x8 19.7 8.93577028
AG Forged SMK Monoblock D99 Forged 18x8 18.8 8.52753712
AG Forged SMK Monoblock DG Forged 15x6.5 16.6 7.52963384
AK Tires Monza Cast 15x6.5 13 5.8967012
AK Tires Monza Cast 16x6.5 14.5 6.5770898
Akuza 209 Siege Cast 17x7.5 21 9.5254404
Akuza 209 Siege Cast 18x8.5 25.6 11.61196544
Akuza Z18 Sublime Cast 19x8.5 31.8 14.42423832
Alba 530 Cast 18x7.5 27.3 12.38307252
Alba 540 (Lexo) Cast 18x7.5 27.6 12.51915024
Alba 707 (Bertha) Cast 18x7.5 33 14.9685492
Alba 804 (Delta) Cast 18x8.5 33.3 15.10462692
Alba 907(Blaze) Cast 20x8.5 31.5 14.2881606
Alba Helix Cast 17x7.5 26.5 12.0201986
Alba R-510 Cast 17x7.5 22 9.9790328
Alba Wolverine Cast 17x7.5 27 12.2469948
Alessio Arizona Cast 16x7.5 20.8 9.43472192
Alfa Romeo Cast Mg 13x5.5 9 4.0823316
Alfa Romeo 156 Cast 16x6.5 21.7 9.84295508
Alfa Romeo GTV Cast 17x7.5 25.3 11.47588772
ALT 148 Cast 15x6.5 16.5 7.4842746
ALT AT-186 Cast 17x7 24 10.8862176
ALT AT-210 Cast 16x7 15.5 7.0306822
ALT AT-213 Cast 17x7 19 8.6182556
ALT AT-226 (Ciber) Cast 18x7.5 21.6 9.79759584
ALT AT-228 (Fusion) Cast 18x8 25.8 11.70268392
ALT Seven Cast 17x7 23 10.4326252
ALT Slash Cast 17x7 22.3 10.11511052
ALT X-phile Cast 17x7 20.8 9.43472192
Altstadt IV Cast 18x8.5 24.5 11.1130138
Altstadt Mesh Cast 18x8 27.5 12.473791
Aluett Type 10 Cast 15x6 15.9 7.21211916
Aluett Type 03 Cast 15x6 18.9 8.57289636
AME Circlar RS Cast/Spun 17x7 18.1 8.21002244
AME Circlar RS Cast/Spun 17x8 19.1 8.66361484
AME Circlar RS Cast/Spun 17x9 19.9 9.02648876
AME Circlar RS Cast/Spun 18x10 22 9.9790328
AME Circlar RS Cast/Spun 18x7.5 19.6 8.89041104
AME Circlar RS Cast/Spun 18x8 20.1 9.11720724
AME Circlar RS Cast/Spun 18x8.5 20.7 9.38936268
AME Circlar RS Cast/Spun 18x9 21.1 9.57079964
AME Circlar RS Cast/Spun 18x9.5 21.5 9.7522366
AME Circlar Spec M Cast/Spun 19x10 24.8 11.24909152
AME Circlar Spec M Cast/Spun 19x8.5 22.5 10.205829
AME Circlar Spec M Cast/Spun 19x9 23.3 10.56870292
AME Circlar Spec M Cast/Spun 19x9.5 24 10.8862176
AME Tracer Spec M Cast 19x10 24 10.8862176
AME Tracer Spec M Cast 19x8 21.9 9.93367356
AME Tracer Spec M Cast 19x8.5 22.2 10.06975128
AME Tracer Spec M Cast 19x9 23.3 10.56870292
AME Tracer Spec M Cast 19x9.5 23.1 10.47798444
AME Tracer TSSC Cast 15x7 10.2 4.62664248
AME Tracer TSSC Cast 16x7 14.7 6.66780828
AME Tracer TSSC Cast 16x8 14.9 6.75852676
AME Tracer TSSC Cast 17x7 15 6.803886
AME Tracer TSSC Cast 17x8 15.7 7.12140068
AME Tracer TSSC Cast 17x9 15.5 7.0306822
AME Tracer TSSC Cast 18x7.5 17.5 7.937867
AME Tracer TSSC Cast 18x8.5 18.3 8.30074092
AME Tracer TSSC Cast 18x9.5 18.2 8.25538168
American Eagle 077 Cast 17x8 22 9.9790328
American Eagle 112 Cast 20x8.5 34.7 15.73965628
American Eagle 133 Cast 20x8.5 38 17.2365112
American Eagle 135 Cast 17x7.5 20 9.071848
American Eagle 168 (Cobra) Cast 17x9 24 10.8862176
American Racing AR-210 (Zurg) Cast 16x7 19.5 8.8450518
American Racing AR-222 (Pinzetti) Cast 16x7 20 9.071848
American Racing AR-222 (Pinzetti) Cast 17x7 22.5 10.205829
American Racing AR-245 (Twisted Tuner) Cast 16x7 21.5 9.7522366
American Racing AR-245 (Twisted Tuner) Cast 18x7 24 10.8862176
American Racing AR-50 Cast 16x7 17.5 7.937867
American Racing AR-55 (Spyder) Cast 14x6 15 6.803886
American Racing AR-55 (Spyder) Cast 15x7 15.9 7.21211916
American Racing AR-55 (Spyder) Cast 16x7 17 7.7110708
American Racing AR-95 (Estrella) Cast 14x6 13.5 6.1234974
American Racing AR-95 (Estrella) Cast 15x7 18 8.1646632
American Racing AR-95 (Estrella) Cast 16x7 20 9.071848
American Racing Libre Cast 13x5.5 12.8 5.80598272
American Racing Libre Cast 14x5.5 13.5 6.1234974
American Racing Muscle Razor Cast 16x7.5 20 9.071848
American Racing Muscle Razor Cast 17x7.5 22 9.9790328
AMG 170 Cast/Spun 17x7.5 25.6 11.61196544
AMG 170 Cast/Spun 18x7.5 27.3 12.38307252
AMG 171 Cast 17x7.5 25.1 11.38516924
AMG 171 Cast 18x7.5 26.9 12.20163556
AMG 203 Cast/Spun 18x7.5 32.6 14.78711224
AMG Monoblock Cast 17x7.5 27.5 12.473791
AMG Monoblock Cast 17x8.5 28 12.7005872
Anterra Type 145 Cast 17x7 25 11.33981
Anterra Type 161 Cast 17x7 29 13.1541796
Anterra Type 163 Cast 18x8 33 14.9685492
Anterra Type 165 Cast 18x7.5 24.2 10.97693608
Anterra Type 183 Cast 18x8 30.8 13.97064592
Anterra Type 309 Cast 18x8 27.4 12.42843176
Anzio Ultra Cast 18x8 26.5 12.0201986
Arbet III Cast 17x7 25 11.33981
Arbet V Cast 15x7 21 9.5254404
Arceo Eurostar Cast 18x7.5 23.8 10.79549912
Arceo Megastar Cast 19x8 29.8 13.51705352
Arelli Bling-Bling (Type 101) Cast 20x8.5 34 15.4221416
Arelli Czar Cast 18x7.5 27.5 12.473791
Arelli DeLemma Cast 20x8.5 38.8 17.59938512
Arelli Hang Tyme Cast 20x10 56 25.4011744
Arelli Hang Tyme Cast 22x10 65 29.483506
Arelli Kaz'mir Cast 18x8.5 30 13.607772
Arelli Pulse Cast 17x7 24 10.8862176
Arelli Q Cast 17x7 26 11.7934024
Arelli Sensei Cast 20x8.5 33.8 15.33142312
Arelli Tranz Cast 18x8.5 26.5 12.0201986
Arelli Type 170 Cast 17x7.5 26 11.7934024
Arospeed RS11 Cast 17x7 18.5 8.3914594
Arospeed RS17 Cast 17x7 20.2 9.16256648
Arospeed RS23 Cast 17x7 18 8.1646632
Arospeed RS-GT Cast 18x7.5 22.8 10.34190672
ASA AR1 Cast 15x6.5 15.9 7.21211916
ASA AR1 Cast 16x7 18.1 8.21002244
ASA AR1 Cast 17x7 20.5 9.2986442
ASA AR1 Cast 17x8 21.2 9.61615888
ASA AR1 Cast 18x7.5 22 9.9790328
ASA AR1 Cast 18x8.5 23.5 10.6594214
ASA AR1 Cast 19x8.5 27.8 12.60986872
ASA AR2 Cast 17x7 21 9.5254404
ASA AR2 Cast 18x7.5 22.2 10.06975128
ASA AR2 Cast 18x8 23 10.4326252
ASA AR7 Cast 19x8 27 12.2469948
ASA AR9 Cast 18x8 23.5 10.6594214
ASA AR9 Cast 19x8.5 26.5 12.0201986
ASA EM9 Cast 15x7 19 8.6182556
ASA EM9 Cast 16x7 19.5 8.8450518
ASA EM9 Cast 17x7 21 9.5254404
ASA FR1 Forged 17x7 16.5 7.4842746
ASA FR1 Forged 17x8 18 8.1646632
ASA JH2 Cast 18x7.5 24.3 11.02229532
ASA JH3 Cast 16x7 19.8 8.98112952
ASA JH3 Cast 17x7.5 23.8 10.79549912
ASA JH3 Cast 18x8 25.5 11.5666062
ASA JH6 Cast 16x7 18 8.1646632
ASA JH6 Cast 17x7 19 8.6182556
ASA JH8 Cast 17x7.5 20.2 9.16256648
ASA JH8 Cast 18x7.5 21.8 9.88831432
ASA JH8 Cast 18x8.5 22.8 10.34190672
ASA JH8 Cast 19x8.5 25 11.33981
ASA JH9 Cast 18x8 28.5 12.9273834
ASA JH9 Cast 19x8 30.5 13.8345682
ASA JS1 Cast 15x7 17 7.7110708
ASA JS1 Cast 16x7 18 8.1646632
ASA JS1 Cast 17x7 20.5 9.2986442
ASA JS5 Cast 15x7 18 8.1646632
ASA JS5 Cast 16x7.5 20 9.071848
ASA JS5 Cast 17x7 21.5 9.7522366
ASA JS5 Cast 18x7.5 23 10.4326252
ASA JS5 Cast 18x8 23 10.4326252
ASA JS6 Cast 15x7 19.5 8.8450518
ASA JS6 Cast 16x7 20.5 9.2986442
ASA JS6 Cast 17x7 22.5 10.205829
ASA KA3 Cast 17x7.5 23.4 10.61406216
ASA LS5 Cast 16x7 17 7.7110708
ASA LS5 Cast 17x7 17.4 7.89250776
ASA LW5 Cast 15x7 14.5 6.5770898
ASA LW5 Cast 16x7.5 16 7.2574784
ASA LW5 Cast 17x7.5 17.2 7.80178928
ASA ST2 Cast 18x8 26.5 12.0201986
ASA ST3 Cast 18x8 25.6 11.61196544
ASA ST4 Cast 17x8 25.6 11.61196544
ASA ST4 Cast 18x8 24.7 11.20373228
ASA ST4 Cast 19x8.5 26.9 12.20163556
ASA ZR2 Cast/Spun 18x8 27 12.2469948
ASA ZR2 Cast/Spun 19x8.5 28.8 13.06346112
AT Italia 10 Razze Cast 16x7.5 20.5 9.2986442
AT Italia 10 Razze Cast 17x7.5 22 9.9790328
AT Italia 9 Razze Cast 18x8 28.5 12.9273834
AT Italia 9 Razze Cast 19x8.5 30.2 13.69849048
AT Italia Alp Cast 16x7.5 23.5 10.6594214
AT Italia Alp Cast 17x7.5 25.8 11.70268392
AT Italia Alp Cast 18x8 27 12.2469948
AT Italia Flash Cast 17x8 25.4 11.52124696
AT Italia Flash Cast 18x8 27 12.2469948
AT Italia Inox Cast 17x7.5 26 11.7934024
AT Italia Nido Cast 18x8 26 11.7934024
AT Italia Nido Cast 18x8.5 27 12.2469948
AT Italia Nido Cast 19x8.5 29 13.1541796
AT Italia Propeller Cast 18x8 27 12.2469948
AT Italia Propeller Cast 18x8.5 28.5 12.9273834
AT Italia Riva Cast/Spun 16x7.5 23.5 10.6594214
AT Italia Riva Cast/Spun 17x8 26 11.7934024
AT Italia Riva Cast/Spun 18x8 27 12.2469948
AT Italia S5 Cast 17x7.5 26 11.7934024
AT Italia S5 Cast 18x8 27 12.2469948
AT Italia Spider Cast/Spun 17x7.5 22.4 10.16046976
AT Italia Spider Cast/Spun 18x8 25.8 11.70268392
AT Italia Spider Cast/Spun 18x8.5 26.2 11.88412088
AT Italia Spider Cast/Spun 19x8.5 28 12.7005872
ATA H10 Cast 17x7.5 28.5 12.9273834
ATA H20 Cast 17x7.5 25 11.33981
ATA H20 Cast 18x8.5 28.8 13.06346112
ATA H30 Cast 18x7.5 28.4 12.88202416
A-Tech Finalspeed Cast 15x7 13 5.8967012
A-Tech Finalspeed Cast 17x7 17 7.7110708
ATP 5 Razze Cast 16x7 23.3 10.56870292
ATP Flashsports Cast 18x8 26 11.7934024
ATP PT5 Cast 17x7.5 28.3 12.83666492
ATP Spa Cast 17x7 24.5 11.1130138
ATP Spa Cast 17x8.5 25.8 11.70268392
ATS 2000 DTM Cast 17x7.5 20.8 9.43472192
ATS Cetus Cast 18x8 26.5 12.0201986
ATS Cup Cast 15x7 17 7.7110708
ATS DTC Comp Lite Cast 15x8 13.8 6.25957512
ATS DTC Comp Lite Cast 17x7.5 15.5 7.0306822
ATS DTC Motorsport Cast 15x7 12.3 5.57918652
ATS DTC Motorsport Cast 15x8 13.2 5.98741968
ATS DTC Motorsport Cast 17x7.5 18.9 8.57289636
ATS DTC Motorsport Cast 17x9 19.4 8.79969256
ATS DTC Motorsport Cast 18x8.5 19.8 8.98112952
ATS DTC Superlight Cast 17x7.5 16.3 7.39355612
ATS DTM Comp Cast 17x7 20.8 9.43472192
ATS DTM Comp Cast 17x7.5 21.8 9.88831432
ATS DTM Comp Cast 17x9 24.9 11.29445076
ATS DTM Comp Cast 18x7 23.3 10.56870292
ATS DTM Comp Cast 18x8 22.4 10.16046976
ATS DTM Comp Racing Cast 17x7.5 19.4 8.79969256
ATS DTM Comp Racing Cast 17x9 20.2 9.16256648
ATS DTM Comp Racing Cast 18x7 19.1 8.66361484
ATS DTM Comp Racing Cast 18x8 19.8 8.98112952
ATS Epsilon Cast 17x8 21.4 9.70687736
ATS Planet Cast 16x7 18.8 8.52753712
ATS Planet Cast 18x8 25 11.33981
Audi A3 97 Cast 15x6 13.3 6.03277892
Audi A3 97 Cast 15x7 15.5 7.0306822
Audi A4 5-spoke Cast 16x7 20 9.071848
Audi A4 7-spoke Cast 16x7 20.6 9.34400344
Audi A8 Forged 17x8 21 9.5254404
Audi A8 9-spoke Cast 20x8.5 28.6 12.97274264
Audi RS4 mk1 9-spoke Cast 18x8 19.5 8.8450518
Audi RS4 Cast 19x9 33 14.9685492
Audi R8 (Front) Cast 19x8.5 30 13.607772
Audi S4 92-94 Forged 16x8 18 8.1646632
Audi S4 Avus Cast 17x7.5 28 12.7005872
Audi S8 Avus Cast 18x8 27.2 12.33771328
Audi TT Cast 16x7 18.5 8.3914594
Audi TT Forged 17x7.5 21.5 9.7522366
Audi TT Cast 17x7.5 29 13.1541796
Autobahn International C2 Cup Cast 17x7.5 21.5 9.7522366
Autobahn International Twisted Spoke Cast 18x9.5 31.5 14.2881606
Axis Crux Cast 17x7 19.8 8.98112952
Axis Crux Cast 18x7.5 21.6 9.79759584
Axis Crux Cast 19x8 25 11.33981
Axis Decade Cast 18x8 22.5 10.205829
Axis GT-R Cast 20x10.5 31.5 14.2881606
Axis GT-R Cast 20x9 27 12.2469948
Axis Hiro Cast 18x8.5 22.4 10.16046976
Axis Hiro Cast 19x10.5 26.9 12.20163556
Axis Hiro Cast 19x8.5 26.8 12.15627632
Axis Hiro Cast 19x9.5 27 12.2469948
Axis Kent Cast 22x10 42 19.0508808
Axis Mach V Cast 16x7 20 9.071848
Axis Mach V Cast 18x7.5 26 11.7934024
Axis Mag-Lite Cast 15x7 12.6 5.71526424
Axis Mag-Lite Cast 17x7 15.6 7.07604144
Axis Mesh Cast 16x7 20 9.071848
Axis Mesh Cast 17x7 22.5 10.205829
Axis Milano Plus Cast 19x8.5 25 11.33981
Axis Milano Plus Cast 19x9.5 26 11.7934024
Axis Milano Plus Cast 20x8.5 28 12.7005872
Axis Milano Plus Cast 20x9.5 28.5 12.9273834
Axis MOD Cast 18x7.5 20.8 9.43472192
Axis MOD Cast 19x8 25.5 11.5666062
Axis MOD Cast 20x10 28.1 12.74594644
Axis MOD Cast 20x9 26.1 11.83876164
Axis Mulliner Cast 22x10.5 39.4 17.87154056
Axis Mulliner Cast 22x9 35.8 16.23860792
Axis Ne-O Cast 17x7 20.8 9.43472192
Axis Ne-O Cast 19x8 26.3 11.92948012
Axis Orden Cast 20x10 29.7 13.47169428
Axis Orden Cast 20x8.5 29.5 13.3809758
Axis Orden Cast 22x10.5 38.6 17.50866664
Axis Orden Cast 22x9 38 17.2365112
Axis Penta Cast 19x8.5 24.8 11.24909152
Axis Penta Cast 19x9.5 25.4 11.52124696
Axis Phin Cast 19x8.5 23 10.4326252
Axis Phin Cast 19x9.5 25 11.33981
Axis Regulator Cast 15x7.5 17.3 7.84714852
Axis Regulator Cast 16x9 19.6 8.89041104
Axis Regulator Cast 17x10 23.2 10.52334368
Axis Reverb Cast 17x7.5 18 8.1646632
Axis Reverb Cast 18x10.5 22 9.9790328
Axis Reverb Cast 18x7.5 19 8.6182556
Axis Reverb Cast 18x8.5 20 9.071848
Axis Reverb Cast 18x9.5 22.6 10.25118824
Axis Reverb Cast 20x7.5 21.5 9.7522366
Axis Seven Cast 19x8 24.3 11.02229532
Axis Speed Six Cast 19x8 26 11.7934024
Axis Starz Cast 17x7 21.8 9.88831432
Axis TC Evo Cast 18x7.5 23 10.4326252
Axis TC Evo Cast 19x8 24.6 11.15837304
Axis Titan Cast 20x9 34.5 15.6489378
Axis Titan Cast 22x9 41 18.5972884
Axis Touring Cup Cast 16x7 20 9.071848
Axis Touring Cup Cast 18x7 23 10.4326252
Axis VIP Cast 20x8.5 28.2 12.79130568
Axis VIP Cast 20x9.5 28.5 12.9273834
Axis Warlock Cast 17x10 26.1 11.83876164
Axis Warlock Cast 20x10 38.5 17.4633074
Axis WSM2 Cast 17x7 20.2 9.16256648
Azev Type H Cast 18x8 27.5 12.473791
Azev Type LS Cast 18x8.5 27.6 12.51915024
Azev Type M Cast 18x8.5 32.4 14.69639376
Azul Speed 5 Cast 17x7 17 7.7110708
Azul Speedmesh Cast 18x8 23.5 10.6594214
Azul Sprint 5 Cast 17x7 17 7.7110708
Azzur Matrix Cast 20x8.5 33 14.9685492
BBS CH Cast 17x7.5 20.2 9.16256648
BBS CH Cast 17x8.5 22 9.9790328
BBS CH Cast 18x8 24 10.8862176
BBS CH Cast 18x8.5 24.5 11.1130138
BBS CH Cast 19x10 28.2 12.79130568
BBS CH Cast 19x8.5 26 11.7934024
BBS CK Cast 18x8 23.5 10.6594214
BBS CV Cast 17x7.5 22.5 10.205829
BBS CV Cast 18x7.5 26 11.7934024
BBS DTM Forged 17x7.5 17.9 8.11930396
BBS DTM Forged 17x8 18.3 8.30074092
BBS DTM Forged 17x9 19.6 8.89041104
BBS DTM Forged 18x10.5 23.8 10.79549912
BBS DTM Forged 18x7.5 19.8 8.98112952
BBS DTM Forged 18x8.5 21.4 9.70687736
BBS DTM Forged 18x9.5 21.8 9.88831432
BBS DTM Forged 19x10.5 25.8 11.70268392
BBS DTM Forged 19x9.5 24.7 11.20373228
BBS Elise (sector 111) Forged 16x7 13.5 6.1234974
BBS Elise (sector 111) Forged 17x8 17.8 8.07394472
BBS GTII Forged/Spun 18x10 21.2 9.61615888
BBS GTII Forged/Spun 18x11 22.9 10.38726596
BBS GTII Forged/Spun 18x8 20.3 9.20792572
BBS GTII Forged/Spun 18x8.5 20.7 9.38936268
BBS GTII Forged/Spun 18x9 21 9.5254404
BBS GTII Forged/Spun 18x9.5 21.8 9.88831432
BBS LM Forged/Spun 17x7 19.1 8.66361484
BBS LM Forged/Spun 17x7.5 19.9 9.02648876
BBS LM Forged/Spun 17x8 20.2 9.16256648
BBS LM Forged/Spun 17x9 20.5 9.2986442
BBS LM Forged/Spun 18x10 21.1 9.57079964
BBS LM Forged/Spun 18x10.5 22.7 10.29654748
BBS LM Forged/Spun 18x11 26.9 12.20163556
BBS LM Forged/Spun 18x13 29.4 13.33561656
BBS LM Forged/Spun 18x7.5 20.5 9.2986442
BBS LM Forged/Spun 18x8 21.1 9.57079964
BBS LM Forged/Spun 18x8.5 21.6 9.79759584
BBS LM Forged/Spun 18x9 22.4 10.16046976
BBS LM Forged/Spun 18x9.5 23.3 10.56870292
BBS LM Forged/Spun 19x10 25.1 11.38516924
BBS LM Forged/Spun 19x8.5 24 10.8862176
BBS LM Forged/Spun 19x9 24.2 10.97693608
BBS LM Forged/Spun 19x9.5 24.6 11.15837304
BBS LM Forged/Spun 20x10 26.2 11.88412088
BBS LM Forged/Spun 20x8.5 25.7 11.65732468
BBS LM Forged/Spun 20x9.5 26.6 12.06555784
BBS Primadonna Forged/Spun 17x8 20 9.071848
BBS Primadonna Forged/Spun 18x10 22.7 10.29654748
BBS Primadonna Forged/Spun 18x8 22.4 10.16046976
BBS Primadonna Forged/Spun 18x9 22.9 10.38726596
BBS Primadonna Forged/Spun 19x8.5 23.3 10.56870292
BBS Primadonna Forged/Spun 19x9.5 24 10.8862176
BBS RC Cast (soft) 16x7 15 6.803886
BBS RC Cast (soft) 16x7.5 16 7.2574784
BBS RC Cast (soft) 17x7 16 7.2574784
BBS RC Cast (soft) 17x8 16.4 7.43891536
BBS RC Cast (soft) 17x9 18.4 8.34610016
BBS RC Cast (soft) 18x10 19.5 8.8450518
BBS RC Cast (soft) 18x8 19.5 8.8450518
BBS RC Cast (soft) 18x8.5 18.7 8.48217788
BBS RCJ Forged 18x8 17.9 8.11930396
BBS RCJ Forged 18x9 18.7 8.48217788
BBS RD Cast 17x7 20.6 9.34400344
BBS RE Forged 18x10 21.8 9.88831432
BBS RE Forged 18x7.5 18.7 8.48217788
BBS RE Forged 18x8 20.2 9.16256648
BBS RE Forged 18x8.5 20.5 9.2986442
BBS RE Forged 18x9 20.9 9.48008116
BBS RE Forged 18x9.5 21.3 9.66151812
BBS RE Forged 20x10.5 24.9 11.29445076
BBS RE Forged 20x8.5 23.1 10.47798444
BBS RE Forged 20x9.5 23.3 10.56870292
BBS RE-Mg Forged Mg 18x10 16.5 7.4842746
BBS RE-Mg Forged Mg 18x11 18.5 8.3914594
BBS RE-Mg Forged Mg 18x8.5 15.4 6.98532296
BBS RE-Mg Forged Mg 18x9.5 16.7 7.57499308
BBS RG F1-Racing (Japan Only) Forged 15x6.5 9.9 4.49056476
BBS RG F1-Racing (Japan Only) Forged 15x7 10.2 4.62664248
BBS RG F1-Racing (Japan Only) Forged 16x7 12.6 5.71526424
BBS RG II Forged 18x8 20.2 9.16256648
BBS RG II Forged 18x9 21.3 9.66151812
BBS RG II / Open Forged 15x6.5 11.4 5.17095336
BBS RG II / Open Forged 16x7 12.8 5.80598272
BBS RG-F Forged 15x5.5 9 4.0823316
BBS RG-F Forged 15x6 9.2 4.17305008
BBS RG-F Forged 15x6.5 9.9 4.49056476
BBS RG-F Forged 15x7 10.2 4.62664248
BBS RG-F Forged 16x7 12.8 5.80598272
BBS RG-R Forged 17x7 16.5 7.4842746
BBS RG-R Forged 17x7.5 17 7.7110708
BBS RG-R Forged 17x8 16.9 7.66571156
BBS RG-R Forged 17x8.5 17.8 8.07394472
BBS RG-R Forged 17x9 17.2 7.80178928
BBS RG-R Forged 17x9.5 17.8 8.07394472
BBS RG-R Forged 18x10 19.8 8.98112952
BBS RG-R Forged 18x7.5 17.8 8.07394472
BBS RG-R Forged 18x8 18 8.1646632
BBS RG-R Forged 18x8.5 18.3 8.30074092
BBS RG-R Forged 18x9 18.9 8.57289636
BBS RG-R Forged 18x9.5 19.4 8.79969256
BBS RG-R Forged 19x10 21.8 9.88831432
BBS RG-R Forged 19x8.5 20.5 9.2986442
BBS RG-R Forged 19x9 20.7 9.38936268
BBS RG-R Forged 19x9.5 20.9 9.48008116
BBS RK Cast 15x7 14.2 6.44101208
BBS RK Cast 16x7 15.3 6.93996372
BBS RK Cast 16x8 15.9 7.21211916
BBS RK Cast 17x7 16.2 7.34819688
BBS RK Cast 17x8 16.5 7.4842746
BBS RK Cast 18x7.5 18.2 8.25538168
BBS RK II Cast 17x7.5 20.7 9.38936268
BBS RK II Cast 17x8 21.5 9.7522366
BBS RK II Cast 17x9 22.1 10.02439204
BBS RK II Cast 18x10 24.6 11.15837304
BBS RK II Cast 18x8.5 23 10.4326252
BBS RM II Cast/Spun 17x8 24 10.8862176
BBS RR Forged/Spun 17x7.5 18.7 8.48217788
BBS RR Forged/Spun 17x8 20.2 9.16256648
BBS RR Forged/Spun 17x9 20.7 9.38936268
BBS RR Forged/Spun 18x10 24.9 11.29445076
BBS RR Forged/Spun 18x7.5 21.3 9.66151812
BBS RR Forged/Spun 18x8 22.1 10.02439204
BBS RR Forged/Spun 18x8.5 23.1 10.47798444
BBS RR Forged/Spun 18x9.5 23.3 10.56870292
BBS RS Forged/Spun 16x7 16 7.2574784
BBS RS II Forged/Cast 17x8 23 10.4326252
BBS RS II Forged/Cast 18x10 25.4 11.52124696
BBS RS II Forged/Cast 18x8.5 24 10.8862176
BBS RS II Forged/Cast 20x10 28.3 12.83666492
BBS RS II Forged/Cast 20x9 27.4 12.42843176
BBS RS-GT Forged 17x7 17.5 7.937867
BBS RS-GT Forged 17x7.5 18.3 8.30074092
BBS RS-GT Forged 17x8 18.7 8.48217788
BBS RS-GT Forged 17x8.5 18.9 8.57289636
BBS RS-GT Forged 17x9 19.8 8.98112952
BBS RS-GT Forged 18x10 22 9.9790328
BBS RS-GT Forged 18x11 24.4 11.06765456
BBS RS-GT Forged 18x8 19.9 9.02648876
BBS RS-GT Forged 18x8.5 20 9.071848
BBS RS-GT Forged 18x9 20.2 9.16256648
BBS RS-GT Forged 18x9.5 21.1 9.57079964
BBS RS-GT Forged 19x10 22.9 10.38726596
BBS RS-GT Forged 19x8.5 21.8 9.88831432
BBS RS-GT Forged 19x9 22.4 10.16046976
BBS RS-GT Forged 19x9.5 22 9.9790328
BBS RS-GT Forged 20x8.5 22.7 10.29654748
BBS RS-GT Forged 20x9.5 22.9 10.38726596
BBS RT II Delta Cast/Spun 17x9.5 29.2 13.24489808
BBS RT II Delta Cast/Spun 18x10 33.4 15.14998616
BBS RV Cast 14x6 12.7 5.76062348
BBS RV Cast 15x7 15.5 7.0306822
BBS RV Cast 16x7 16 7.2574784
BBS RV Cast 16x8 18.2 8.25538168
BBS RV Cast 17x7.5 18.4 8.34610016
BBS RV Cast 17x8 21.1 9.57079964
BBS RV-F Forged 17x7 14.7 6.66780828
BBS RV-F Forged 17x7.5 15.4 6.98532296
BBS RW Cast 15x7 18 8.1646632
BBS RW II Cast/Spun 17x7.5 22.6 10.25118824
BBS RW II Cast/Spun 17x8 23.9 10.84085836
BBS RW II Cast/Spun 18x10 26.3 11.92948012
BBS RW II Cast/Spun 18x8.5 25.3 11.47588772
BBS RX Cast 14x6 12.5 5.669905
BBS RX Cast 15x7 14.7 6.66780828
BBS RX Cast 16x7 20.1 9.11720724
BBS RX Cast 16x8 22 9.9790328
BBS RX Cast 17x7.5 20.9 9.48008116
BBS RX Cast 17x8 23.3 10.56870292
BBS RX Cast 18x8 23.5 10.6594214
BBS RX Cast 18x8.5 25.1 11.38516924
BBS RX II Cast/Spun 14x5.5 13.3 6.03277892
BBS RX II Cast/Spun 14x6 13.9 6.30493436
BBS RX II Cast/Spun 17x7.5 21.2 9.61615888
BBS RX II Cast/Spun 17x8 23.6 10.70478064
BBS RX II Cast/Spun 18x8.5 26.3 11.92948012
BBS RZ Cast 17x7 21.8 9.88831432
BBS Super-RS Forged/Spun 17x8 20 9.071848
BBS Super-RS Forged/Spun 18x10 22.7 10.29654748
BBS Super-RS Forged/Spun 18x8 22.4 10.16046976
BBS Super-RS Forged/Spun 18x9 22.6 10.25118824
BBS Super-RS Forged/Spun 19x8.5 23.3 10.56870292
BBS Super-RS Forged/Spun 19x9.5 24 10.8862176
BBS SX Cast 18x8 25 11.33981
BBS VZ Cast 16x7.5 17 7.7110708
BBS VZ Cast 17x7.5 22 9.9790328
BBS VZ Cast 17x8 23 10.4326252
BBS VZ Cast 18x8 25 11.33981
Beyern Type 5 Cast 18x8.5 23.8 10.79549912
Billet Specialties E1 Cast 17x7 23.3 10.56870292
Billet Specialties SLX 21 Cast 18x7 22.4 10.16046976
Billet Specialties SLX 30 Cast 18x7 26.2 11.88412088
Black Racing Phantom Cast 15x6.5 14.3 6.48637132
Black Racing Pro N1 Cast 17x7.5 20 9.071848
Black Racing Pro N1 Cast 17x8 20.5 9.2986442
Black Racing Pro N1 Cast 17x9 21.2 9.61615888
Blitz Technospeed Z1 Forged/Spun 18x10 25.8 11.70268392
Blitz Technospeed Z1 Forged/Spun 19x10 28.5 12.9273834
Blitz Technospeed Z1 Forged/Spun 19x9 25.8 11.70268392
Blitz Technospeed Z2 Forged/Spun 18x9 24 10.8862176
Blitz Type 01 Forged/Spun 17x8 20.3 9.20792572
Blitz Type 01 Forged/Spun 17x9 20.5 9.2986442
Blitz Type 01R Forged 16x7 16.8 7.62035232
Blitz Type 02 Forged/Spun 15x7 13 5.8967012
Blitz Type 03 Forged/Spun 18x8 22.5 10.205829
Blitz Type 03 Forged/Spun 18x9 26.8 12.15627632
BMW 3 Series Steel 15x6.5 18 8.1646632
BMW 320i Cast 13x6 10.8 4.89879792
BMW 328is Cast 16x7 19 8.6182556
BMW E30 M3 Cast 15x7 16 7.2574784
BMW E30 M3 (BBS RS003) Cast/Spun 16x7 16 7.2574784
BMW E34 M5 ""Throwing Stars"" Forged 17x8 19.5 8.8450518
BMW E36 M3 Contour Cast 17x7.5 22.3 10.11511052
BMW E36 M3 Contour Cast 17x8.5 23.4 10.61406216
BMW E36 M3 Doublespoke I (Motorsport) Cast 17x7.5 21.3 9.66151812
BMW E36 M3 Doublespoke I (Motorsport) Cast 17x8.5 22.3 10.11511052
BMW E36 M3 Doublespoke II Cast 17x7.5 20.7 9.38936268
BMW E36 M3 Doublespoke II Cast 17x8.5 21.9 9.93367356
BMW E36 M3 Forged Forged 17x7.5 19.7 8.93577028
BMW E36 M3 Forged Forged 17x8.5 20.9 9.48008116
BMW E36 M3 LTW Forged 17x7.5 19.5 8.8450518
BMW E36 M3 LTW Forged 17x8.5 20.7 9.38936268
BMW E39 M5 Forged 18x8 23.6 10.70478064
BMW E39 M5 Forged 18x9.5 25.6 11.61196544
BMW E46 CSL Cast 19x8.5 27.8 12.60986872
BMW E46 CSL Cast 19x9.5 30.5 13.8345682
BMW E46 M135 Cast 18x8 28.5 12.9273834
BMW E46 M135 Cast 18x8.5 29 13.1541796
BMW E46 M3 Compeition Cast 19x8 24 10.8862176
BMW E46 M3 Compeition Cast 19x9.5 25.5 11.5666062
BMW E46 MZ4 224M Cast 18x8 28 12.7005872
BMW E46 MZ4 224M Cast 18x9 30 13.607772
BMW E46 Style 44 Cast 17x8 23.1 10.47798444
BMW E46 Style 45 Cast 16x7 20.1 9.11720724
BMW E46 Style 68 Cast 17x7.5 21 9.5254404
BMW E46 Style 71 Forged/Spun 18x8 21 9.5254404
BMW E46 Style 71 Forged/Spun 18x8.5 22 9.9790328
BMW E90 Style 162 Cast 18x8 30 13.607772
BMW E90 Style 162 Cast 18x8.5 32.2 14.60567528
BMW Parallels Forged 18x8 23 10.4326252
Bogart 13x5.5 15.3 6.93996372
Borbet Type B Cast 15x6.5 16.5 7.4842746
Borbet Type B Cast 15x7 17.5 7.937867
Borbet Type B Cast 16x7.5 19 8.6182556
Borbet Type C Cast 15x7 16.5 7.4842746
Borbet Type C Cast 17x7.5 24 10.8862176
Borbet Type C2T Cast 17x7.5 28 12.7005872
Borbet Type C2T Cast 17x9 30 13.607772
Borbet Type C2T (Porsche OE) Cast 17x7.5 22 9.9790328
Borbet Type C2T (Porsche OE) Cast 17x9 23.5 10.6594214
Borbet Type CA Cast 15x6.5 19 8.6182556
Borbet Type CA Cast 16x7 21.6 9.79759584
Borbet Type CA Cast 18x7.5 27.3 12.38307252
Borbet Type E Cast 15x7 17.5 7.937867
Borbet Type E Cast 17x7 21 9.5254404
Borbet Type E Cast 17x8 23.6 10.70478064
Borbet Type F Cast 16x7 19 8.6182556
Borbet Type FS Cast 17x7 20.1 9.11720724
Borbet Type FS Cast 17x8 21 9.5254404
Borbet Type FS Cast 18x7.5 23 10.4326252
Borbet Type FS Cast 18x8.5 24.7 11.20373228
Borbet Type H Cast 15x7 18.5 8.3914594
Borbet Type LS Cast 15x6.5 18.5 8.3914594
Borbet Type LS Cast 16x7 22 9.9790328
Borbet Type LS Cast 17x7 22.5 10.205829
Borbet Type LS Cast 18x8 26.5 12.0201986
Borbet Type LV4 Cast 17x7 20.5 9.2986442
Borbet Type LV4 Cast 18x7 21.5 9.7522366
Borbet Type LV5 Cast 17x7 22.5 10.205829
Borbet Type M Cast 16x7 23 10.4326252
Borbet Type M Cast 17x8 27.5 12.473791
Borbet Type R Cast 17x8 20.5 9.2986442
Borbet Type R Cast 18x8 23 10.4326252
Borbet Type S Cast 15x7 15.5 7.0306822
Borbet Type S Cast 17x7 21 9.5254404
Borbet Type S Cast 18x8 22.5 10.205829
Borbet Type T Cast 14x6 14.2 6.44101208
Borbet Type T Cast 15x7 17.5 7.937867
Borbet Type T Cast 16x7.5 21 9.5254404
Borbet Type T Cast 17x7 22.5 10.205829
Borbet Type TD Cast 18x8 25 11.33981
Borbet Type TS Cast 18x8.5 26.9 12.20163556
Borbet Type VS Cast 18x8 24 10.8862176
Borbet Type XL Cast 17x7.5 22 9.9790328
Borbet Type XL Cast 18x8 23.5 10.6594214
Boss 307 Cast 20x8.5 33.8 15.33142312
Brabus Mono III Cast 17x8 29 13.1541796
Branzach BZ-11 Cast 18x8 28 12.7005872
Branzach BZ-12 (Zeo) Cast 18x7.5 24.2 10.97693608
Breyton Inspiration Cast 17x7 23.5 10.6594214
Breyton Magic Cast 18x7 26 11.7934024
Breyton Magic Cast 18x8.5 28 12.7005872
Breyton Softline Cast 17x8 24 10.8862176
Bridgestone Super R.A.P. Cast 14x6 10 4.535924
BRIG Magline 10 Forged 17x7 15.3 6.93996372
BRIG Magline 5 Forged 15x6.5 9.9 4.49056476
BRIG Magline 5 Forged 17x7 14.6 6.62244904
BRIG Magline 8 Forged 15x6.5 10.6 4.80807944
BRIG Magline 8 Forged 17x7 14.5 6.5770898
BRIG Proline 7 Cast 15x6.5 17.4 7.89250776
Brock B13 Cast 17x7.5 20.3 9.20792572
BSA 248 Cast 18x7.5 23.2 10.52334368
BSA 259 Cast 18x7.5 24.4 11.06765456
BSA 333 Cast 17x7 19.5 8.8450518
BSA 341 Cast 17x7 19.5 8.8450518
BSA Octopus Cast 16x7 19.5 8.8450518
Buddy Club P1 Racing II Cast/Spun 19x10 24.3 11.02229532
Buddy Club P1 Racing II Cast/Spun 19x9 22 9.9790328
Buddy Club P1 Racing QF Forged 15x7 10.1 4.58128324
Buddy Club P1 Racing QF Forged 16x7 11.1 5.03487564
Buddy Club P1 Racing QF Forged 17x7.5 12.9 5.85134196
Buddy Club P1 Racing QF Forged 17x8 13.6 6.16885664
Buddy Club P1 Racing QF Forged 17x9 14.5 6.5770898
Buddy Club P1 Racing QF Forged 17x9.5 15.1 6.84924524
Buddy Club P1 Racing QF Forged 18x10 16.1 7.30283764
Buddy Club P1 Racing QF Forged 18x9 14.8 6.71316752
Buddy Club P1 Racing SF Cast 15x6.5 13.7 6.21421588
Buddy Club P1 Racing SF Cast 17x7 17.4 7.89250776
Budnik Gasses Forged 17x8 20 9.071848
Budnik Grid Forged 17x7 21.5 9.7522366
Budnik GT-5 Lite Forged 18x7 23 10.4326252
Budnik Pentacle FL Forged 17x8 25.2 11.43052848
Budnik Prism Forged 18x8 21 9.5254404
CAM 1 (Challenge) Cast 16x7 18 8.1646632
CAM 1 (Challenge) Cast 17x7 21 9.5254404
CAM 2 (Trophy) Cast 16x7 16.5 7.4842746
Carlsson Design 1/16 Ultra Light Forged 19x8.5 21.2 9.61615888
Carlsson Design 1/5 Cast 18x8.5 29.3 13.29025732
Carlsson Design 1/6 EVO Cast 19x8.5 33.3 15.10462692
Carlsson Design 2/5 Cast 18x8.5 33 14.9685492
Carusi Type 62 Cast 17x7 28 12.7005872
CCW (not hub or lug-centric) Forged/Spun 17x10 18.6 8.43681864
CCW (not hub or lug-centric) Forged/Spun 17x9.5 18 8.1646632
CCW (not hub or lug-centric) Forged/Spun 18x10 22 9.9790328
CEC Techart Daytona Cast 18x11 27.8 12.60986872
CEC Type 139 Cast 17x7 25 11.33981
CEC Type 149 Cast 18x8 25 11.33981
CEC Type 169 Cast 18x8.5 33 14.9685492
CEC Type 185 (Antera) Cast 17x7.5 27 12.2469948
CEC Type 971 (Valbrem) Cast 16x7 23 10.4326252
CEC Type 992 Cast 17x7.5 21 9.5254404
CEC Type H (Azev) Cast 17x7.5 26 11.7934024
Centerline Convo-Pro Forged 15x15 14.5 6.5770898
Centerline Impulse Forged 17x7 11.8 5.35239032
Centerline Neutron Forged 15x7 14 6.3502936
Centerline Neutron Forged 17x7 17.5 7.937867
Centerline RPM Forged 17x7 13.5 6.1234974
Centerline RPM Forged 18x8.5 15 6.803886
Centerline RPM Forged 19x7.5 15.6 7.07604144
Centerline Thruster 806 Cast 17x9.5 22 9.9790328
Champion Motorsport RS98 Forged 19x10 19.4 8.79969256
Champion Motorsport RS98 Forged 19x11.5 20.5 9.2986442
Champion Motorsport RS98 Forged 19x8.5 18.1 8.21002244
Champion Motorsport stellaCORSE Forged 16x7 13.9 6.30493436
Champion Motorsport stellaCORSE Forged 17x8 16 7.2574784
Chaparral S 15 Cast 15x7 15.3 6.93996372
Chevrolet Corvette Z06 01 Forged 17x9.5 19.6 8.89041104
Chevrolet Corvette Z06 01 Forged 18x10.5 21.4 9.70687736
Chevrolet Corvette Z06 01 - CCW skeletal mod Forged 17x9.5 17.8 8.07394472
Chevrolet Corvette Z06 01 - CCW skeletal mod Forged 18x10.5 19.8 8.98112952
Chevrolet Corvette Z06 02 Cast/Spun 17x9.5 19.2 8.70897408
Chevrolet Corvette Z06 02 Cast/Spun 18x10.5 21 9.5254404
Chevrolet Sprint / Geo Metro / Suzuki Steel 12x4 10 4.535924
Circlar GTA Cast 18x8.5 21.6 9.79759584
Circle Racing Series 01 Steel 13x5.5 15 6.803886
Circle Racing Series 01 Steel 13x7 16.5 7.4842746
Circle Racing Series 01 Steel 15x10 31.5 14.2881606
Circle Racing Series 01 Steel 15x7 24.5 11.1130138
Circle Racing Series 01 Steel 15x8 26 11.7934024
Circle Racing Series 02 Steel 13x5.5 15 6.803886
Circle Racing Series 02 Steel 13x7 16.5 7.4842746
Circle Racing Series 02 Steel 15x10 31.5 14.2881606
Circle Racing Series 02 Steel 15x7 24.5 11.1130138
Circle Racing Series 02 Steel 15x8 26 11.7934024
Circle Racing Series 11 Spun 13x10 15.5 7.0306822
Circle Racing Series 11 Spun 13x6 12.5 5.669905
Circle Racing Series 11 Spun 13x7 13 5.8967012
Circle Racing Series 11 Spun 13x8 14 6.3502936
Circle Racing Series 12 Spun 13x10 15.5 7.0306822
Circle Racing Series 12 Spun 13x6 12.5 5.669905
Circle Racing Series 12 Spun 13x7 13 5.8967012
Circle Racing Series 12 Spun 13x8 14 6.3502936
Circle Racing Series 13 Spun 13x10 15.5 7.0306822
Circle Racing Series 13 Spun 13x6 12.5 5.669905
Circle Racing Series 13 Spun 13x7 13 5.8967012
Circle Racing Series 13 Spun 13x8 14 6.3502936
Circle Racing Series 22 Steel 15x10 25.5 11.5666062
Circle Racing Series 22 Steel 15x8 24.5 11.1130138
Circle Racing Series 23 Steel 15x10 25.5 11.5666062
Circle Racing Series 23 Steel 15x8 24.5 11.1130138
Circle Racing Series 25 Steel 15x10 21.5 9.7522366
Circle Racing Series 25 Steel 15x7 18.5 8.3914594
Circle Racing Series 25 Steel 15x8 19.5 8.8450518
Circle Racing Series 26 Steel 15x10 21.5 9.7522366
Circle Racing Series 26 Steel 15x7 18.5 8.3914594
Circle Racing Series 26 Steel 15x8 19.5 8.8450518
Circle Racing Series 27 Steel 15x10 21.5 9.7522366
Circle Racing Series 27 Steel 15x7 18.5 8.3914594
Circle Racing Series 27 Steel 15x8 19.5 8.8450518
Circle Racing Series 28 Steel 15x10 21.5 9.7522366
Circle Racing Series 28 Steel 15x7 18.5 8.3914594
Circle Racing Series 28 Steel 15x8 19.5 8.8450518
Circle Racing Series 29 Steel 15x10 21.5 9.7522366
Circle Racing Series 29 Steel 15x7 18.5 8.3914594
Circle Racing Series 29 Steel 15x8 19.5 8.8450518
Circle Racing Series 30 Steel 15x10 21.5 9.7522366
Circle Racing Series 30 Steel 15x7 18.5 8.3914594
Circle Racing Series 30 Steel 15x8 19.5 8.8450518
Circle Racing Series 31 Spun 13x6 12 5.4431088
Circle Racing Series 31 Spun 13x7 13 5.8967012
Circle Racing Series 31 Spun 13x8 14.5 6.5770898
Circle Racing Series 32 Spun 13x6 12 5.4431088
Circle Racing Series 32 Spun 13x7 13 5.8967012
Circle Racing Series 32 Spun 13x8 14.5 6.5770898
Circle Racing Series 33 Spun 13x6 12 5.4431088
Circle Racing Series 33 Spun 13x7 13 5.8967012
Circle Racing Series 33 Spun 13x8 14.5 6.5770898
Circle Racing Series 34 Spun 13x6 12 5.4431088
Circle Racing Series 34 Spun 13x7 13 5.8967012
Circle Racing Series 34 Spun 13x8 14.5 6.5770898
Circle Racing Series 35 Steel 15x10 22 9.9790328
Circle Racing Series 35 Steel 15x7 18.5 8.3914594
Circle Racing Series 35 Steel 15x8 19.5 8.8450518
Circle Racing Series 36 Steel 15x10 22 9.9790328
Circle Racing Series 36 Steel 15x7 18.5 8.3914594
Circle Racing Series 36 Steel 15x8 19.5 8.8450518
Circle Racing Series 37 Steel 15x10 22 9.9790328
Circle Racing Series 37 Steel 15x7 18.5 8.3914594
Circle Racing Series 37 Steel 15x8 19.5 8.8450518
Circle Racing Series 38 Steel 15x10 21.5 9.7522366
Circle Racing Series 38 Steel 15x7 18.5 8.3914594
Circle Racing Series 38 Steel 15x8 19.5 8.8450518
Circle Racing Series 39 Steel 15x10 21.5 9.7522366
Circle Racing Series 39 Steel 15x7 18.5 8.3914594
Circle Racing Series 39 Steel 15x8 19.5 8.8450518
Circle Racing Series 40 Steel 15x10 21.5 9.7522366
Circle Racing Series 40 Steel 15x7 18.5 8.3914594
Circle Racing Series 40 Steel 15x8 19.5 8.8450518
Circle Racing Series 41 Spun 15x10 21.5 9.7522366
Circle Racing Series 41 Spun 15x8 17.1 7.75643004
Circle Racing Series 42 Spun 15x10 21.5 9.7522366
Circle Racing Series 42 Spun 15x8 17.1 7.75643004
Circle Racing Series 43 Spun 15x10 19 8.6182556
Circle Racing Series 43 Spun 15x8 17.1 7.75643004
Circle Racing Series 44 Spun 15x10 19 8.6182556
Circle Racing Series 44 Spun 15x8 17.1 7.75643004
Circle Racing Series 51 Spun 15x10 17.7 8.02858548
Circle Racing Series 51 Spun 15x8 13.8 6.25957512
Circle Racing Series 52 Spun 15x10 17.7 8.02858548
Circle Racing Series 52 Spun 15x8 13.8 6.25957512
Circle Racing Series 53 Spun 15x10 17.7 8.02858548
Circle Racing Series 54 Spun 15x10 17.7 8.02858548
Circle Racing Series 55 Spun 15x10 17.7 8.02858548
Circle Racing Series 55 Spun 15x8 13.8 6.25957512
Circle Racing Series 56 Spun 15x10 17.7 8.02858548
Circle Racing Series 56 Spun 15x8 13.8 6.25957512
Circle Racing Series 57 Spun 15x10 17.7 8.02858548
Circle Racing Series 57 Spun 15x8 13.8 6.25957512
Circle Racing Series 61 Steel 15x9.5 27 12.2469948
Circle Racing Series 82 Spun 13x5.5 7.7 3.49266148
Circle Racing Series 82 Spun 13x6 8 3.6287392
Circle Racing Series 82 Spun 13x7 8.7 3.94625388
Circle Racing Series 82 Spun 13x8 9.7 4.39984628
Circle Racing Series 82 Spun 14x7 11.5 5.2163126
Circle Racing Series 82 Spun 15x10 15.3 6.93996372
Circle Racing Series 82 Spun 15x7 12.2 5.53382728
Circle Racing Series 82 Spun 15x8 13.7 6.21421588
Circle Racing Series 82 Spun 16x7 13.2 5.98741968
Circle Racing Series 82 Spun 16x8 14.4 6.53173056
Circle Racing Series 82 Spun 16x9.5 15.8 7.16675992
Circle Racing Series 84 Spun 13x5.5 8.2 3.71945768
Circle Racing Series 84 Spun 13x6 8.8 3.99161312
Circle Racing Series 84 Spun 13x8 9.2 4.17305008
Cirlce Racing Series 21 Steel 15x10 25.5 11.5666062
Cirlce Racing Series 21 Steel 15x8 24.5 11.1130138
Club Linea Special Cast 18x8 25 11.33981
Cobb Tuning CT-One Cast 17x7.5 22 9.9790328
Compomotive ML Cast 13x10 15.4 6.98532296
Compomotive ML Cast 13x5.5 13.2 5.98741968
Compomotive ML Cast 13x6 13.6 6.16885664
Compomotive ML Cast 13x7 14.3 6.48637132
Compomotive ML Cast 13x8 14.5 6.5770898
Compomotive ML Cast 13x9 14.7 6.66780828
Compomotive ML Cast 14x6 13.6 6.16885664
Compomotive ML Cast 15x5.5 16.5 7.4842746
Compomotive ML Cast 15x6 18 8.1646632
Compomotive ML Cast 15x7 20.9 9.48008116
Compomotive ML Cast 15x8 22 9.9790328
Compomotive MO Cast 14x5.5 15 6.803886
Compomotive MO Cast 14x6 15 6.803886
Compomotive MO Cast 15x6 17.2 7.80178928
Compomotive MO Cast 15x7 18.7 8.48217788
Compomotive MO Cast 15x8 18.9 8.57289636
Compomotive MO Cast 16x5.5 16.5 7.4842746
Compomotive MO Cast 16x6 16.9 7.66571156
Compomotive MO Cast 16x6.5 17.4 7.89250776
Compomotive MO Cast 16x7 19.6 8.89041104
Compomotive MO Cast 16x7.5 21.8 9.88831432
Compomotive MO Cast 16x8 20.9 9.48008116
Compomotive MO Cast 17x7 21.3 9.66151812
Compomotive MO Cast 17x7.5 22.4 10.16046976
Compomotive MO Cast 17x8 24 10.8862176
Compomotive MO Cast 18x8 26.4 11.97483936
Compomotive PS Cast 17x10 20.5 9.2986442
Compomotive TH Cast 13x5 11.2 5.08023488
Compomotive TH Cast 13x5.5 11.4 5.17095336
Compomotive TH Cast 14x5 12.8 5.80598272
Compomotive TH Cast 14x5.5 15 6.803886
Compomotive TH Cast 14x6 15.6 7.07604144
Compomotive TH Cast 15x5 16.1 7.30283764
Compomotive TH Cast 15x5.5 16.3 7.39355612
Compomotive TH Cast 15x6 16.6 7.52963384
Compomotive TH Cast 15x6.5 17.8 8.07394472
Compomotive TH Cast 15x7 18.3 8.30074092
Compomotive TH Cast 15x7.5 19.1 8.66361484
Compomotive TH Cast 15x8 20 9.071848
Compomotive TH Cast 16x5.5 20 9.071848
Compomotive TH Cast 16x6 20.5 9.2986442
Compomotive TH Cast 16x7 20.9 9.48008116
Compomotive TH Cast 16x7.5 20.5 9.2986442
Compomotive TH Cast 16x8 20.9 9.48008116
Compomotive TH2 Cast 15x5.5 18.1 8.21002244
Compomotive TH2 Cast 15x6 16.9 7.66571156
Compomotive TH2 Cast 15x6.5 17.9 8.11930396
Compomotive TH2 Cast 15x7 18.1 8.21002244
Compomotive TH2 Cast 16x6.5 18.1 8.21002244
Compomotive TH2 Cast 17x7.5 21.2 9.61615888
Compomotive TH2 Cast 18x8 24.1 10.93157684
Concept Neeper Dagg Cast 20x8.5 33 14.9685492
Concept Neeper Fly Cast 20x8.5 32 14.5149568
Concept Neeper Haaz Cast 18x8.5 30.3 13.74384972
Concept Neeper N170 Cast 20x8.5 30.3 13.74384972
Concept Neeper Sideburn Cast 18x7 35.6 16.14788944
Concord Racing Cast 15x7 24 10.8862176
Cray Scorpion Cast 19x10.5 32.8 14.87783072
Cromodora Ego Cast 16x7 22 9.9790328
Cromodora Mg Cast Mg 13x5.5 8.8 3.99161312
Dale Earnhardt Jr Knuckle Cast 17x7.5 20 9.071848
Datsun 200SX 80-83 (16-spoke) Cast 14x5.5 15 6.803886
Datsun 200SX 80-83 (32-spoke) Cast 14x5.5 16 7.2574784
Datsun 200SX 80-83 (disk) Cast 14x5.5 14 6.3502936
Datsun 280Z 79-80 Cast 14x6 18 8.1646632
Datsun 280ZX 81-83 Cast 14x6 13 5.8967012
Datsun 280ZX Turbo 81 Cast 15x6 17 7.7110708
Datsun 280ZX Turbo 82-83 Cast 15x6 14 6.3502936
Datsun 810/Maxima 81-84 Cast 14x5.5 15 6.803886
DAZZ Camus Cast 19x9.5 27.3 12.38307252
DAZZ Matrix Cast 19x9.5 28 12.7005872
Decorsa Arch Cast 19x8.5 27.5 12.473791
Decorsa DC5 Cast 18x7.5 31 14.0613644
Decorsa DC6 Cast 22x9.5 37 16.7829188
Decorsa Flex Cast 22x9.5 42.5 19.277677
Decorsa Fusion Cast 18x8 25.5 11.5666062
Decorsa Magnum Cast 18x7.5 22.5 10.205829
Decorsa Maze Cast 19x8 26 11.7934024
Decorsa Phantom Cast 20x8.5 32.5 14.741753
Decorsa Polaris 5 Cast 18x8.5 23 10.4326252
Decorsa Polaris 6 Cast 22x9.5 33 14.9685492
Decorsa Stellar Cast 20x8.5 30.5 13.8345682
Desmond Rega Master EVO Forged 15x6.5 8.6 3.90089464
Desmond Rega Master EVO Forged 16x7 11.9 5.39774956
Desmond Rega Master EVO Forged 16x8 12.9 5.85134196
Desmond Rega Master EVO Forged 17x7 15 6.803886
Detata DT-105 Cast 17x8 26 11.7934024
Detata DT-109 Cast 17x7.5 28.3 12.83666492
Detata DT-111 Cast 17x7.5 24 10.8862176
Diamond Racing Spun Steel 13x6 11 4.9895164
Diamond Racing Spun Steel 13x8 13.6 6.16885664
Diamond Racing Spun Steel 15x7 18.8 8.52753712
Dinan BMW (Fiske) Forged/Spun 18x9 18 8.1646632
Dinan BMW D750 Forged 19x10 20 9.071848
Dinan BMW D750 Forged 19x9 20 9.071848
Dodge Challenger 78-83 Cast 14x5.5 15 6.803886
Dodge Colt 88-90 Cast 14x5.5 13 5.8967012
Dodge Conquest 84-85 (large vents) Cast 15x6.5 14 6.3502936
Dodge Conquest 84-86 Cast 14x6 15 6.803886
Dodge Conquest 84-87 (all others) Cast 15x6.5 16 7.2574784
Dodge Neon ACR 02 Cast 15x6 16.5 7.4842746
Dodge Viper - 01 Cast 18x10 28.4 12.88202416
Dodge Viper - 01 Cast 18x13 32.3 14.65103452
Dotz Brands Hatch Cast 15x6.5 21.8 9.88831432
Dotz Daytona Cast 15x6.5 19.2 8.70897408
Dotz Daytona Cast 17x7.5 20.8 9.43472192
DPE GT7 Forged 18x8 19 8.6182556
DPE R05 Variant S Forged 19x8 24 10.8862176
Drag Wheels DR16 Cast 16x7 16.5 7.4842746
Drag Wheels DR20 Cast 15x7 15.2 6.89460448
Drag Wheels DR21 Cast 15x7 12.9 5.85134196
Drag Wheels DR23 Cast 15x6.5 16.5 7.4842746
Drag Wheels DR9 Cast 15x7 12.3 5.57918652
Drive Mach 5 Cast 20x8.5 34.3 15.55821932
Drive Zila Cast 20x8.5 42.5 19.277677
Dronell CA-05 Cast 20x8.5 30.6 13.87992744
Dronell D-06 Cast 19x8 27.8 12.60986872
Dronell M-10 Forged 19x8.5 18.5 8.3914594
Dronell TS-05 Cast 17x7 18 8.1646632
Dronell TS-06 Cast 17x7 20.8 9.43472192
Dronell Type II Cast 19x7.5 28.8 13.06346112
DTM FS-01 Cast 15x6.5 14.8 6.71316752
DTM FS-02 Cast 15x6.5 14.7 6.66780828
DTM FS-02 Cast 17x7 21 9.5254404
Ducatro Daytona Cast/Spun 15x6.5 14.8 6.71316752
Duralight Cast 17x10 18 8.1646632
Dymag Motorsport Cast Mg 15x6 10.8 4.89879792
Dymag Motorsport Cast Mg 16x7 13 5.8967012
Dymag Motorsport Forged Mg/Carbon Fiber 17x8 12.9 5.85134196
Dymag Motorsport Forged Mg/Carbon Fiber 18x10.5 15.9 7.21211916
Dymag Motorsport Forged Mg/Carbon Fiber 18x9 14 6.3502936
Dymag Motorsport Forged Mg/Carbon Fiber 20x12 18.2 8.25538168
Dymag Motorsport (Mosler MT900) Forged Mg/Carbon Fiber 19x10 14 6.3502936
Dymag Motorsport (Mosler MT900) Forged Mg/Carbon Fiber 20x12.5 17.5 7.937867
Elite 726 Rockport Cast 16x7 20 9.071848
Elite Barb Cast 18x7 28.4 12.88202416
Elite Indis Cast 20x8.5 36.5 16.5561226
EMO 502 (Ozone) Cast 15x7 22 9.9790328
EMO 702 (Obelix) Cast 15x7 20.6 9.34400344
EMPI 5-spoke Cast 15x5.5 20 9.071848
Enkei 5+ Cast 17x7 19 8.6182556
Enkei Aegis Cast 17x7 20.7 9.38936268
Enkei Aegis Cast 17x8 21.9 9.93367356
Enkei Aegis Cast 17x9 22.1 10.02439204
Enkei Aegis Cast 18x10 24.3 11.02229532
Enkei Aegis Cast 18x8 23.1 10.47798444
Enkei Aegis Cast 18x8.5 23.3 10.56870292
Enkei Aegis Cast 18x9.5 23.7 10.75013988
Enkei Aegis Cast 19x8.5 24.8 11.24909152
Enkei Aegis Cast 19x9.5 24.9 11.29445076
Enkei Aka Cast 17x7.5 28.2 12.79130568
Enkei Aka Cast 18x7.5 30 13.607772
Enkei Aka Cast 20x8.5 37.4 16.96435576
Enkei Arashi Cast 17x7 19 8.6182556
Enkei C.R.A.N.K. Cast 17x7.5 27.1 12.29235404
Enkei CDR9 Cast 15x6.5 16.7 7.57499308
Enkei CDR9 Cast 16x7 18.9 8.57289636
Enkei CDR9 Cast 17x7 21.6 9.79759584
Enkei CDR9 Cast 18x7 23.1 10.47798444
Enkei CTM-3 Cast 15x10 28.3 12.83666492
Enkei CTM-3 Cast 15x8 24.6 11.15837304
Enkei CTM-3 Cast 16x8 27.1 12.29235404
Enkei CTM-4 Cast 16x8 28.4 12.88202416
Enkei CTM-5 Cast 15x10 25 11.33981
Enkei CTM-5 Cast 15x8 24 10.8862176
Enkei CTM-5 Cast 16x8 24.5 11.1130138
Enkei DM-5 Cast 16x7 17.4 7.89250776
Enkei Duji Cast 17x7 23 10.4326252
Enkei EM5 Cast 17x7 21.5 9.7522366
Enkei EM5 Cast 18x7.5 23.5 10.6594214
Enkei ERO-1 Cast 15x7 17.2 7.80178928
Enkei ERO-1 Cast 16x7 18 8.1646632
Enkei ES6 Cast 16x7 19.5 8.8450518
Enkei ES6 Cast 17x7 21 9.5254404
Enkei ES6 Cast 18x7.5 23 10.4326252
Enkei ES-Gravel Cast 14x6 12.9 5.85134196
Enkei ES-Tarmac Cast 14x6 8.7 3.94625388
Enkei ES-Tarmac Cast 14x6.5 8.9 4.03697236
Enkei ES-Tarmac Cast 15x6.5 10.7 4.85343868
Enkei ES-Tarmac Cast 15x7 11 4.9895164
Enkei ES-Tarmac Cast 15x7.5 11.6 5.26167184
Enkei ES-Tarmac Cast 16x7 13.7 6.21421588
Enkei ES-Tarmac Cast 16x7.5 14.3 6.48637132
Enkei ES-Tarmac Cast 17x7.5 14.8 6.71316752
Enkei Etoria Cast 15x6 17 7.7110708
Enkei EUM5 Cast 15x6.5 16 7.2574784
Enkei EUM5 Cast 16x7 18 8.1646632
Enkei EVO 5 Cast 17x7 18.5 8.3914594
Enkei EVO 5 Cast 18x7.5 20.5 9.2986442
Enkei EVO 6 Cast 17x7 18.5 8.3914594
Enkei EVO 6 Cast 18x7.5 20.5 9.2986442
Enkei Exocent Cast 19x9.5 31 14.0613644
Enkei Fubuki Cast 17x7 23.2 10.52334368
Enkei Gattling Cast 18x10 27 12.2469948
Enkei GTC01 Cast 17x7 17.5 7.937867
Enkei GTC01 Cast 17x8 18 8.1646632
Enkei GTC01 Cast 18x8 20 9.071848
Enkei GTC01 Cast 18x8.5 21 9.5254404
Enkei GTV Cast 18x8 24.3 11.02229532
Enkei Inazuma Cast 17x7 21.7 9.84295508
Enkei J10 Cast 17x7 21 9.5254404
Enkei JS M Cast 15x6.5 12.1 5.48846804
Enkei JS M Cast 17x7.5 15.4 6.98532296
Enkei J-Speed III Cast/Spun 14x5 11 4.9895164
Enkei J-Speed III Cast/Spun 14x6 11.2 5.08023488
Enkei J-Speed III Cast/Spun 14x6.5 11.5 5.2163126
Enkei J-Speed III Cast/Spun 14x7 11.7 5.30703108
Enkei J-Speed III Cast/Spun 15x6 12.6 5.71526424
Enkei J-Speed III Cast/Spun 15x6.5 12.8 5.80598272
Enkei J-Speed III Cast/Spun 15x7 13.2 5.98741968
Enkei J-Speed III Cast/Spun 15x7.5 13.4 6.07813816
Enkei J-Speed III Cast/Spun 16x7 15 6.803886
Enkei J-Speed III Cast/Spun 16x7.5 15.4 6.98532296
Enkei J-Speed III Cast/Spun 16x8 16.1 7.30283764
Enkei Kriminal Cast 23x10 60 27.215544
Enkei LF-10 Cast 18x7.5 26 11.7934024
Enkei Liberty Cast 17x9 32.8 14.87783072
Enkei Liberty Cast 18x9 33.6 15.24070464
Enkei LS-5 Cast 18x7.5 25 11.33981
Enkei NP03 Cast 16x7 17.6 7.98322624
Enkei NP03 Cast 18x7 19.3 8.75433332
Enkei NT03 M Cast 17x7.5 17.4 7.89250776
Enkei NT03 M Cast 17x8 18.9 8.57289636
Enkei NT03 M Cast 17x9.5 20.1 9.11720724
Enkei NT03 M Cast 18x10 20.5 9.2986442
Enkei NT03 M Cast 18x10.5 21 9.5254404
Enkei NT03 M Cast 18x7.5 18.5 8.3914594
Enkei NT03 M Cast 18x8 19.4 8.79969256
Enkei NT03 M Cast 18x8.5 19.6 8.89041104
Enkei NT03 M Cast 18x9.5 19.9 9.02648876
Enkei OR52 Cast 16x7 16 7.2574784
Enkei OR52 Cast 17x7 18 8.1646632
Enkei OR52 Cast 18x7.5 20.5 9.2986442
Enkei OR52 Cast 18x8.5 21 9.5254404
Enkei Phalenx Cast 17x7 21.9 9.93367356
Enkei Phalenx Cast 17x8 23 10.4326252
Enkei Phalenx Cast 17x9 23.3 10.56870292
Enkei Phalenx Cast 18x10 26.2 11.88412088
Enkei Phalenx Cast 18x7 23.1 10.47798444
Enkei Phalenx Cast 18x8 23.8 10.79549912
Enkei Phalenx Cast 18x9 24.2 10.97693608
Enkei Phalenx Cast 19x10 29.6 13.42633504
Enkei Phalenx Cast 19x8.5 28.5 12.9273834
Enkei RC5 Cast 17x7 18 8.1646632
Enkei RC5 Cast 18x9 19.5 8.8450518
Enkei RCT-1 Cast 15x7 14.5 6.5770898
Enkei RCT-1 Cast 16x7 16.7 7.57499308
Enkei RCT-1 Cast 17x7 17.8 8.07394472
Enkei RCT-4 Cast 18x9 19.6 8.89041104
Enkei RF1 Cast 16x7 16.5 7.4842746
Enkei RF-1 Cast 15x7 15.9 7.21211916
Enkei RF-1 Cast 16x7 16.5 7.4842746
Enkei RF-1 Cast 17x7 18.1 8.21002244
Enkei RMR Cast 17x7.5 20 9.071848
Enkei RP-F1 Cast 19x8.5 19.9 9.02648876
Enkei RP-F1 Cast 15x7 9.8 4.44520552
Enkei RP-F1 Cast 16x7 13.5 6.1234974
Enkei RP-F1 Cast 16x8 14.9 6.75852676
Enkei RP-F1 Cast 17x10 17 7.7110708
Enkei RP-F1 Cast 17x7 15 6.803886
Enkei RP-F1 Cast 17x7.5 15.3 6.93996372
Enkei RP-F1 Cast 17x8 15.6 7.07604144
Enkei RP-F1 Cast 17x8.5 15.8 7.16675992
Enkei RP-F1 Cast 17x9 16 7.2574784
Enkei RP-F1 Cast 17x9.5 16.5 7.4842746
Enkei RP-F1 Cast 18x7.5 17 7.7110708
Enkei RP-F1 Cast 18x8 17.8 8.07394472
Enkei RP-F1 Cast 18x8.5 18.3 8.30074092
Enkei RP-F1 Cast 18x9.5 17.2 7.80178928
Enkei RP-F1 Cast 19x10 20.7 9.38936268
Enkei RP-F1 Cast 19x8 18.7 8.48217788
Enkei RP-F1 Cast 19x9.5 19.6 8.89041104
Enkei RP-F1 RC Cast/Spun 18x10 23.6 10.70478064
Enkei RP-F1 RC Cast/Spun 18x8.5 22 9.9790328
Enkei RP-F1 RC Cast/Spun 18x9 22.9 10.38726596
Enkei RP-F1 RC Cast/Spun 18x9.5 22.7 10.29654748
Enkei RP-F1 RC Cast/Spun 19x10 25.4 11.52124696
Enkei RP-F1 RC Cast/Spun 19x9 24.7 11.20373228
Enkei RPM-2 Cast 17x7 16.9 7.66571156
Enkei RPM-2 Cast 17x8 17.4 7.89250776
Enkei RPM-2 Cast 17x9 18.7 8.48217788
Enkei RPM-2 Cast 18x7.5 18.9 8.57289636
Enkei RPM-2 Cast 18x8 19.4 8.79969256
Enkei RPM-2 Cast 18x9 21.1 9.57079964
Enkei RPO-1 Cast 15x7 14.3 6.48637132
Enkei RPO-1 Cast 16x6.5 14.5 6.5770898
Enkei RPO-1 Cast 16x7 15.8 7.16675992
Enkei RPO-1 Cast 17x7 17.6 7.98322624
Enkei RPO-1 Cast 17x7.5 18 8.1646632
Enkei RPO-1 Cast 17x8 18.2 8.25538168
Enkei RPO-1 Cast 17x9 20 9.071848
Enkei RPO-1 Cast 18x8.5 20.7 9.38936268
Enkei RPO-1 Cast 18x9 21.3 9.66151812
Enkei RPO-1 Cast 18x9.5 23.4 10.61406216
Enkei RPO-2 Cast 15x5 14.1 6.39565284
Enkei RPO-2 Cast 15x7 15.2 6.89460448
Enkei RPO-2 Cast 16x7 17 7.7110708
Enkei RPO-2 Cast 16x8 17.5 7.937867
Enkei RPO-2 Cast 17x7 18.5 8.3914594
Enkei RPO-2 Cast 17x7.5 19.1 8.66361484
Enkei RPO-2 Cast 17x8 19.8 8.98112952
Enkei RPO-2 Cast 17x9 20.3 9.20792572
Enkei RPO-2 Cast 18x7.5 20.8 9.43472192
Enkei RPO-2 Cast 18x8 21.3 9.66151812
Enkei RPO-2 Cast 18x9 21.9 9.93367356
Enkei RPO-2J Cast 15x7 13 5.8967012
Enkei RPO-3 Cast 17x10 21.4 9.70687736
Enkei RPO-3 Cast 17x7 16.8 7.62035232
Enkei RPO-3 Cast 17x8 17.5 7.937867
Enkei RPO-3 Cast 17x8.5 19.1 8.66361484
Enkei RPO-3 Cast 17x9.5 19.6 8.89041104
Enkei RPO-3 Cast 18x10 21.5 9.7522366
Enkei RPO-3 Cast 18x7.5 19.2 8.70897408
Enkei RPO-3 Cast 18x8 20.2 9.16256648
Enkei RPO-3 Cast 18x8.5 20.9 9.48008116
Enkei RPO-3 Cast 18x9 21 9.5254404
Enkei RPO-3 Cast 18x9.5 21.3 9.66151812
Enkei RPO-3 Cast 19x10 23.1 10.47798444
Enkei RPO-3 Cast 19x8 20.5 9.2986442
Enkei RPO-3 Cast 19x8.5 20.6 9.34400344
Enkei RPO-3 Cast 19x9 21.8 9.88831432
Enkei RPO-3 Cast 19x9.5 22.2 10.06975128
Enkei RPO-3 RC Cast 18x8.5 21.5 9.7522366
Enkei RPO-5 Cast 17x7 20 9.071848
Enkei RPO-5 Cast 17x8 21 9.5254404
Enkei RPO-5 Cast 18x7 21.8 9.88831432
Enkei RPO-5 Cast 18x8 22.1 10.02439204
Enkei RPO-7 Cast 18x7 20 9.071848
Enkei RPO-7 Cast 19x7.5 21 9.5254404
Enkei RPOM Cast 17x7 19.5 8.8450518
Enkei RPOM Cast 18x7 21 9.5254404
Enkei RS Evolution Cast 16x7 17 7.7110708
Enkei RS Evolution Cast 17x7 19.4 8.79969256
Enkei RS+M Cast 15x5 11.7 5.30703108
Enkei RS+M Cast 15x6.5 14 6.3502936
Enkei RS+M Cast 15x7 14.8 6.71316752
Enkei RS+M Cast 16x7 14.8 6.71316752
Enkei RS+M Cast 17x7 15.6 7.07604144
Enkei RS+M Cast 17x8 16.1 7.30283764
Enkei RS+M Cast 18x7.5 17.5 7.937867
Enkei RS+M Cast 18x8.5 19.3 8.75433332
Enkei RS-05 Cast 17x7 17.5 7.937867
Enkei RS-05 Cast 18x7.5 18.5 8.3914594
Enkei RS-05 Cast 18x8.5 19.5 8.8450518
Enkei RS-5 Cast 15x6.5 15.4 6.98532296
Enkei RS-5 Cast 16x7 17.6 7.98322624
Enkei RS-5 Cast 17x7 19.8 8.98112952
Enkei RS-5 Cast 18x7 21.6 9.79759584
Enkei RS-6 Cast 15x6.5 17.5 7.937867
Enkei RS-6 Cast 16x7 19.6 8.89041104
Enkei RS-6 Cast 17x7 20.2 9.16256648
Enkei RS-6 Cast 18x7 23.3 10.56870292
Enkei RS-7 Cast 17x7 17.9 8.11930396
Enkei RS-E Cast 16x7 18.1 8.21002244
Enkei RS-E Cast 17x7 19.4 8.79969256
Enkei RS-E Cast 17x8 20 9.071848
Enkei RSF-2 Cast 15x6.5 16.3 7.39355612
Enkei RSF-2 Cast 16x7 18.1 8.21002244
Enkei RSF-2 Cast 17x7 19.8 8.98112952
Enkei RSF-2 Cast 18x7 21.8 9.88831432
Enkei RSV Cast 17x7 17.5 7.937867
Enkei RSV Cast 18x7.5 20 9.071848
Enkei RT6 Cast 17x8 24.6 11.15837304
Enkei RT6 Cast 18x8.5 26.1 11.83876164
Enkei RTO-1 Cast 16x7 16 7.2574784
Enkei RTS Cast 16x8 22.1 10.02439204
Enkei RTS Cast 17x8 23.9 10.84085836
Enkei RZ-5 Cast 15x6.5 16.5 7.4842746
Enkei RZ-5 Cast 16x7 20.5 9.2986442
Enkei RZ-5 Cast 17x7 22.5 10.205829
Enkei RZ-5 Cast 18x7.5 24.5 11.1130138
Enkei RZ-5 Cast 18x8.5 25.5 11.5666062
Enkei RZ-5 Cast 18x9.5 26 11.7934024
Enkei SC-03 Cast 16x7 19 8.6182556
Enkei SC-03 Cast 17x7 20.5 9.2986442
Enkei SC-05 Cast 17x7 20.5 9.2986442
Enkei SC-05 Cast 17x8 21.5 9.7522366
Enkei SC-05 Cast 18x7.5 23.5 10.6594214
Enkei SC-05 Cast 18x8 24.5 11.1130138
Enkei Shogun Cast 17x7 24.9 11.29445076
Enkei Shutoko Cast 17x7 23.7 10.75013988
Enkei Silverstar Cast 17x9 29.7 13.47169428
Enkei Silverstar Cast 18x9 30.6 13.87992744
Enkei SS6A Cast 15x6.5 15.8 7.16675992
Enkei Suzuka Cast 17x7 21.5 9.7522366
Enkei Tarmac Cast 18x8 27 12.2469948
Enkei Tarmac Cast 18x9.5 28 12.7005872
Enkei Tarmac Cast 19x8.5 29.5 13.3809758
Enkei Tarmac Cast 19x9.5 30 13.607772
Enkei Tatonka Cast 17x8 28.5 12.9273834
Enkei Tatonka Cast 18x9 30.3 13.74384972
Enkei TBS1 Cast 16x7 18.3 8.30074092
Enkei TBS1 Cast 17x7 20 9.071848
Enkei TBS11 Cast 16x7 18.3 8.30074092
Enkei TBS11 Cast 17x7 20 9.071848
Enkei Tuscarora Cast 16x8 26.7 12.11091708
Enkei Tuscarora Cast 17x8 28.4 12.88202416
Enkei Tuscarora Cast 18x9 32.5 14.741753
Enkei V-1 Cast 17x8 23.8 10.79549912
Enkei V-1 Cast 17x8.5 23.9 10.84085836
Enkei V-1 Cast 17x9 24.2 10.97693608
Enkei V-1 Cast 17x9.5 25 11.33981
Enkei V-1 Cast 18x10 27.4 12.42843176
Enkei V-1 Cast 18x8 26 11.7934024
Enkei V-1 Cast 18x8.5 26.6 12.06555784
Enkei V-1 Cast 18x9 26.7 12.11091708
Enkei V-1 Cast 18x9.5 27 12.2469948
Enkei Valor Cast 17x9 30 13.607772
Enkei Valor Cast 18x9 30.3 13.74384972
Enkei Valor Cast 20x9 33.8 15.33142312
Enkei Victory Cast 17x9 30 13.607772
Enkei Victory Cast 18x9 31.2 14.15208288
Enkei Victory Cast 20x9 33.9 15.37678236
Enkei WDM Cast 16x7 20 9.071848
Enkei WDM Cast 17x7 23.5 10.6594214
Enkei WDM Cast 18x7.5 26 11.7934024
Enkei Zenkei Cast 17x7 26 11.7934024
Enkei Zoku Cast 17x7 19.8 8.98112952
Enkei ZR1 Cast 17x7.5 18 8.1646632
Enkei ZR1 Cast 18x8 20.5 9.2986442
Enkei ZR2 Cast 17x7 19 8.6182556
Enkei ZR2 Cast 18x7.5 21.5 9.7522366
Enkei ZXC Cast 17x8.5 21.4 9.70687736
Enkei ZXC Cast 18x9 23.8 10.79549912
Enzo Cup Cast 17x8 28.8 13.06346112
Enzo M Cast 16x7.5 23.5 10.6594214
Enzo V Cast 16x7 22 9.9790328
Epic Laguna Cast 16x7.5 24.5 11.1130138
Epic Series 73 (Aero) Cast 17x7 26 11.7934024
Esses SpeedMaster SM-058 Cast 15x7 15.4 6.98532296
Falken Atlantic City Cast 20x8.5 33.2 15.05926768
Falken Atlantic City Cast 22x9 35.6 16.14788944
Falken Atlantic City Cast 23x10 40 18.143696
Falken Circuit Spec Cast 17x7 22.5 10.205829
Falken Circuit Spec Cast 18x7 26.5 12.0201986
Falken Circuit Spec Cast 19x7.5 26 11.7934024
Falken Circuit Spec Cast 19x8 27.5 12.473791
Falken Explicit Cast 17x7.5 17 7.7110708
Falken Explicit Cast 18x7.5 19 8.6182556
Falken Explicit Cast 20x8.5 31 14.0613644
Falken Hanabi Cast 15x7 11.5 5.2163126
Falken Hanabi Cast 17x7.5 17 7.7110708
Falken Hanabi Cast 18x7.5 19 8.6182556
Falken Hanabi Cast 18x8.5 20 9.071848
Falken Koblenz Cast 18x8 25.1 11.38516924
Falken Koblenz Cast 18x9 26.6 12.06555784
Falken Koblenz Cast 19x10.5 32.5 14.741753
Falken Koblenz Cast 19x8.5 25.8 11.70268392
Falken Koblenz Cast 19x9.5 31.7 14.37887908
Falken Koblenz Cast 20x8.5 33.3 15.10462692
Falken Roid Cast 20x8.5 31.3 14.19744212
Falken Roid Cast 22x9.5 34.5 15.6489378
Falken Roid Cast 23x10 37.5 17.009715
Falken Spine Cast 20x8.5 28.8 13.06346112
Falken Spine Cast 22x9.5 36 16.3293264
Falken Spine Cast 23x10 37.7 17.10043348
Falken Torque 5 Cast 17x7 24 10.8862176
Falken Torque 5 Cast 18x7 25 11.33981
Falken Torque 5 Cast 18x8 26.8 12.15627632
Falken Torque 5 Cast 19x7.5 26.5 12.0201986
Falken Torque 5 Cast 19x8 28.5 12.9273834
Fast Wheels 13x5.5 14 6.3502936
Fast Wheels Techno Cast 17x7 18.5 8.3914594
Fikse ARO Forged/Spun 17x10 18.9 8.57289636
Fikse FM-10 Forged/Spun 17x10 18.5 8.3914594
Fikse FM-10 Forged/Spun 18x8 20.8 9.43472192
Fikse FM-10 Forged/Spun 18x9.5 20.9 9.48008116
Fikse FM-5 Forged/Spun 17x10 18.5 8.3914594
Fikse FM-5 Forged/Spun 17x8 16 7.2574784
Fikse FM-5 Forged/Spun 17x8.5 17.5 7.937867
Fikse FM-5 Forged/Spun 18x8.5 18 8.1646632
Fikse Mach 5 Forged/Spun 17x10 18.5 8.3914594
Final Speed Forged Forged 17x7.5 13 5.8967012
Fittipaldi 500 SS Cast 17x7 23.3 10.56870292
Fittipaldi 916 SP Cast 18x8 23.3 10.56870292
Fittipaldi Argus Cast 20x8.5 31 14.0613644
Fittipaldi AV3 Cast 17x8 27 12.2469948
Fittipaldi Avus Cast 17x8 27 12.2469948
Fittipaldi Fin Cast 18x8.5 29.4 13.33561656
Fittipaldi Flame Cast 17x7 20 9.071848
Fittipaldi Polaris Cast 17x8 28.5 12.9273834
Fittipaldi Tubolare Cast 18x8 33 14.9685492
Fittipaldi Vela Cast 18x8 23.3 10.56870292
Flik Apex Cast 15x6.5 11.9 5.39774956
Flik Apex Cast 16x7 15 6.803886
Flik Apex2 Cast 16x7 14.8 6.71316752
Flik Artic Cast 17x7 18 8.1646632
Flik Artic Cast 18x8.5 23 10.4326252
Flik Blast Cast 15x6.5 11.9 5.39774956
Flik Bullet Cast 15x6.5 12.5 5.669905
Flik Bullet Cast 17x7 17 7.7110708
Flik Ftd Cast 16x7 16 7.2574784
Flik Ftd Cast 17x7 17 7.7110708
Flik Ftd Cast 17x8.5 18.5 8.3914594
Flik Fuel Cast 15x6.5 12 5.4431088
Flik Fuel Cast 17x7 17 7.7110708
Flik Hornet Cast 16x7 16.5 7.4842746
Flik Hornet Cast 17x7 17 7.7110708
Flik Hornet Cast 17x8 18 8.1646632
Flik Hornet Cast 18x8 20 9.071848
Flik Justice Cast 17x8 22 9.9790328
Flik Justice Cast 18x8 25 11.33981
Flik Lex Cast 17x7 18 8.1646632
Flik Lex Cast 17x8 19 8.6182556
Flik Lex Cast 18x8 22 9.9790328
Flik Titan Cast 17x7 18 8.1646632
Flik Wasp Cast 17x7 19 8.6182556
Flik Wasp Cast 18x7.5 22 9.9790328
Focal F1 (Type 173) Cast 18x7 25.6 11.61196544
Focal F10 Cast 18x7 26.3 11.92948012
Focal F5 (Type 165) Cast 17x7 23.5 10.6594214
Focal F5 (Type 165) Cast 18x7 25.8 11.70268392
Focal F7 (Type 168) Cast 18x7 24.3 11.02229532
Focal G7 Cast 18x7 27.3 12.38307252
Focal R3 Cast 18x7 26.3 11.92948012
Focal SD5 Cast 18x7 26 11.7934024
Fondmetal Tech 4 Cast 18x8 27.8 12.60986872
Fondmetal Type 5700 Cast 15x7 16.8 7.62035232
Fondmetal Type 6500 Cast 17x7 24 10.8862176
Fondmetal Type 6700 Cast 16x7 22.2 10.06975128
Fondmetal Type 6800 Cast 16x7 22.6 10.25118824
Fondmetal Type 9a Cast 17x7 24.6 11.15837304
Ford Cobra 03-04 Cast 17x9 25 11.33981
Ford Focus ZTS and Wagon Cast 15x6 15.2 6.89460448
Ford Focus ZX3 Cast 16x6 19.1 8.66361484
Ford Mustang - Roush (made by Prime) Cast 17x8 26.5 12.0201986
Ford Taurus SHO Cast 16x6.5 18.8 8.52753712
Forgeline LS Forged/Spun 17x8 19.5 8.8450518
Forgeline LS Forged/Spun 17x9.5 18.5 8.3914594
Forgeline RS Forged/Spun (brittle) 16x8 17.2 7.80178928
Forgeline RS Forged/Spun (brittle) 17x9.5 18.5 8.3914594
Forgeline RS Forged/Spun (brittle) 18x9.5 22.5 10.205829
Forge-Tec FT15 Forged 20x8.5 24 10.8862176
Formula F1 (TE-37 copy) Cast 15x6.5 13.5 6.1234974
Formula F1 (TE-37 copy) Cast 16x7 15.5 7.0306822
Formula F1 (TE-37 copy) Cast 17x7 18.5 8.3914594
Formula F1 (TE-37 copy) Cast 18x7 19.5 8.8450518
G.MAX M078 Cast 18x7.5 21 9.5254404
G.MAX M078 Cast 18x8.5 22 9.9790328
GAB Sports Cast 16x7 15 6.803886
GAB Sports Cast 16x8 16.3 7.39355612
G-games 77w Cast 17x7 18 8.1646632
G-games Sidewinder 1-piece Cast 18x7.5 21 9.5254404
Gianelle 5 (Twin) Cast 18x7.5 24.2 10.97693608
Gianelle 6 (Oval) Cast 18x8.5 27.2 12.33771328
Giovanna Akita Cast 18x7.5 20 9.071848
Giovanna Anzio Cast 18x7.5 22.8 10.34190672
Giovanna Anzio Cast 22x9.5 37 16.7829188
Giovanna Barletta Cast 20x8.5 46 20.8652504
Giovanna Berlin Cast 20x10 42 19.0508808
Giovanna Boizano Cast 20x8.5 37 16.7829188
Giovanna Chiba Cast 18x7.5 24.5 11.1130138
Giovanna Kobe Cast 18x7.5 24.3 11.02229532
Giovanna Kuji Cast 18x7.5 26.3 11.92948012
Giovanna Kyoto Cast 18x7.5 25 11.33981
Giovanna Mito Cast 18x7.5 22.6 10.25118824
Giovanna Nagano Cast 18x7.5 23 10.4326252
Giovanna Rio Cast 18x8.5 29.5 13.3809758
Giovanna Suzu Cast 15x6.5 12.5 5.669905
GMC Syclone/Typhoon (Front) Cast/Spun 16x8 21.2 9.61615888
GMC Syclone/Typhoon (Rear) Cast/Spun 16x8 21.8 9.88831432
Gram Lights 57C Cast 15x7 13.5 6.1234974
Gram Lights 57C Cast 16x7 15.4 6.98532296
Gram Lights 57C Cast 17x7.5 18 8.1646632
Gram Lights 57F Forged 17x7.5 15 6.803886
Gram Lights 57F Forged 18x8.5 20 9.071848
Gram Lights 57Maximum Cast 15x6.5 13 5.8967012
Gram Lights 57Maximum Cast 16x7 15 6.803886
Gram Lights 57Maximum Cast 17x7 17.5 7.937867
Gram Lights 57Maximum Cast 18x7.5 20.3 9.20792572
Gram Lights 57Optomize Cast 16x6.5 15.5 7.0306822
Gram Lights 57Optomize Cast 17x7.5 17.5 7.937867
Gram Lights 57Optomize Cast 18x7.5 19.3 8.75433332
Gram Lights 57Pro Cast 15x7.5 16.8 7.62035232
Gram Lights 57Pro Cast 17x7 19.5 8.8450518
Gram Lights 57S Cast 16x7 16 7.2574784
Gram Lights 57S Cast 17x7.5 17.5 7.937867
Gram Lights 57S Cast 18x7.5 19.5 8.8450518
Gram Lights 57S Cast 18x8.5 20 9.071848
Gram Lights T57-RC Cast 17x7 18.5 8.3914594
Gram Lights T57-RC Cast 17x8 20 9.071848
Gram Lights T57-RC Cast 18x7.5 20 9.071848
Hamann Magnesium Forged 19x8.5 18 8.1646632
Hart Sport Diablo Cast 17x10 21 9.5254404
Hart Sport Mirage Cast 17x10 21 9.5254404
Hart Sport Odyssey Cast 17x10 21 9.5254404
Hartge Classic Cast 19x8 24 10.8862176
Hartge Classic Cast 19x9 26 11.7934024
Hartge Classic Cast 19x9.5 30 13.607772
Hartge Design-E Forged/Spun 17x7.5 18.8 8.52753712
Hartge Design-E Forged/Spun 17x8.5 19.8 8.98112952
Hartge Nova 3 Cast 18x8.5 25 11.33981
Hartge Nova 5 Cast 19x9.5 31 14.0613644
Hayashi Street Fin Cast 14x8 9.4 4.26376856
Hayashi Street Wheel Type STF Cast 15x6.5 13.2 5.98741968
Hayashi Street Wheel Type STF Cast 15x7 13.9 6.30493436
Hickock Sprint Forged 18x11 18 8.1646632
Hickock Sprint Forged 18x9.5 17 7.7110708
Hokuto Racing Miyabi Cast 17x7 21.5 9.7522366
Honda Accord Steel 15x6.5 17.7 8.02858548
Honda Accord Type R (Euro) Cast 17x7 21.8 9.88831432
Honda Civic Steel 15x6 20.2 9.16256648
Honda Civic 88-91 Steel 13x5 16 7.2574784
Honda Civic EX 06-07 Cast 16x6.5 19.5 8.8450518
Honda Civic EX/Si 92+ Cast 14x5 18 8.1646632
Honda Civic HX 96-97 Cast 14x5.5 11.75 5.3297107
Honda Civic Si 02-04 Cast 15x6 22.2 10.06975128
Honda Civic Si 05+ HFP Cast 17x7 20 9.071848
Honda Civic Si 99-00 Cast 15x6 18 8.1646632
Honda Civic Type R 02 Cast 17x7 20.2 9.16256648
Honda Civic Vi-RS 99-00 Cast 15x6.5 16.8 7.62035232
Honda Civic VX Cast 13x5 9.7 4.39984628
Honda CRX Si 86-87 Cast 14x5 15.4 6.98532296
Honda CRX Si 90 Cast 14x5 16 7.2574784
Honda Del Sol 97 ""Fat 5"" Cast 14x5.5 15 6.803886
Honda Prelude 97-99 Cast 16x6.5 19 8.6182556
Honda Prelude 97-99 SH Cast 16x6.5 19.7 8.93577028
Honda Prelude VTEC 93 Cast 15x6.5 22.5 10.205829
Honda Prelude VTEC/Si 95-96 Cast 15x6.5 17 7.7110708
Honda S2000 Cast 16x6.5 17.5 7.937867
Honda S2000 Cast 16x7.5 18.6 8.43681864
Honda S2000 04+ Cast 17x7 17.6 7.98322624
Honda S2000 04+ Cast 17x8.5 20.5 9.2986442
Honda S2000 JDM (BBS) Forged 16x6.5 13.3 6.03277892
Honda S2000 JDM (BBS) Forged 16x7.5 14.3 6.48637132
HP Racing Avalanche Cast 17x7.5 23 10.4326252
HP Racing Flight Cast 18x8 22 9.9790328
HP Racing Fusion Cast 17x7 21.2 9.61615888
HP Racing Hurricane Cast 17x7 18.5 8.3914594
HP Racing Lightning Cast 17x7 19.8 8.98112952
HP Racing Shadow Cast 18x8 25 11.33981
HP Racing Vortex Cast 18x7.5 25.8 11.70268392
HRE 445 Forged/Spun 18x10 20.4 9.25328496
HRE 447 Forged/Spun 18x10 25.3 11.47588772
HRE 504 Forged/Spun 17x11 19.5 8.8450518
HRE 504 Forged/Spun 17x9.5 18 8.1646632
HRE 504 Forged/Spun 18x7.5 16.5 7.4842746
HRE 535 Forged/Spun 17x10 22 9.9790328
HRE 540 Forged/Spun 17x10 24 10.8862176
HRE 540 Forged/Spun 17x8.5 23 10.4326252
HRE 540 Forged/Spun 18x10 26 11.7934024
HRE 545 Forged/Spun 17x10 25 11.33981
HRE 545 Forged/Spun 18x10 27 12.2469948
HRE 546 Forged/Spun 18x8.5 20 9.071848
HRE 546 Forged/Spun 20x9 27 12.2469948
HRE 547 Forged/Spun 17x10 23 10.4326252
HRE 547 Forged/Spun 18x10 23 10.4326252
HRE 835 Forged/Spun 17x10 18 8.1646632
HRE C21 Forged 19x8.5 18.8 8.52753712
HRE C21 Forged 19x9.5 19.8 8.98112952
IFG A5 Forged 17x8 18.5 8.3914594
IFG A5 Forged 17x9 20 9.071848
iForged Aero Forged 19x10 25 11.33981
iForged Aero Forged 19x10.5 26 11.7934024
iForged Aero Forged 19x11 27 12.2469948
iForged Aero Forged 19x7.5 22 9.9790328
iForged Aero Forged 19x8 22 9.9790328
iForged Aero Forged 19x8.5 23 10.4326252
iForged Aero Forged 19x9 24 10.8862176
iForged Aero Forged 19x9.5 24 10.8862176
iForged Aero Forged 20x10 27 12.2469948
iForged Aero Forged 20x8 25 11.33981
iForged Aero Forged 20x8.5 25 11.33981
iForged Aero Forged 20x9 26 11.7934024
iForged Aero Forged 22x10 35 15.875734
iForged Aero Forged 22x9.5 30 13.607772
iForged Evolution Forged 19x10 25 11.33981
iForged Evolution Forged 19x10.5 26 11.7934024
iForged Evolution Forged 19x11 27 12.2469948
iForged Evolution Forged 19x7.5 22 9.9790328
iForged Evolution Forged 19x8 22 9.9790328
iForged Evolution Forged 19x8.5 23 10.4326252
iForged Evolution Forged 19x9 24 10.8862176
iForged Evolution Forged 19x9.5 24 10.8862176
iForged Evolution Forged 20x10 27 12.2469948
iForged Evolution Forged 20x8 25 11.33981
iForged Evolution Forged 20x8.5 25 11.33981
iForged Evolution Forged 20x9 26 11.7934024
iForged Evolution Forged 22x10 35 15.875734
iForged Evolution Forged 22x9.5 30 13.607772
iForged Flux Forged 19x10 25 11.33981
iForged Flux Forged 19x10.5 26 11.7934024
iForged Flux Forged 19x11 27 12.2469948
iForged Flux Forged 19x7.5 22 9.9790328
iForged Flux Forged 19x8 22 9.9790328
iForged Flux Forged 19x8.5 23 10.4326252
iForged Flux Forged 19x9 24 10.8862176
iForged Flux Forged 19x9.5 24 10.8862176
iForged Flux Forged 20x10 27 12.2469948
iForged Flux Forged 20x8 25 11.33981
iForged Flux Forged 20x8.5 25 11.33981
iForged Flux Forged 20x9 26 11.7934024
iForged Flux Forged 22x10 35 15.875734
iForged Flux Forged 22x9.5 30 13.607772
iForged Marquis Forged 19x10 25 11.33981
iForged Marquis Forged 19x10.5 26 11.7934024
iForged Marquis Forged 19x11 27 12.2469948
iForged Marquis Forged 19x7.5 22 9.9790328
iForged Marquis Forged 19x8 22 9.9790328
iForged Marquis Forged 19x8.5 23 10.4326252
iForged Marquis Forged 19x9 24 10.8862176
iForged Marquis Forged 19x9.5 24 10.8862176
iForged Marquis Forged 20x10 27 12.2469948
iForged Marquis Forged 20x8 25 11.33981
iForged Marquis Forged 20x8.5 25 11.33981
iForged Marquis Forged 20x9 26 11.7934024
iForged Marquis Forged 22x10 35 15.875734
iForged Marquis Forged 22x9.5 30 13.607772
iForged Retro Forged 19x10 25 11.33981
iForged Retro Forged 19x10.5 26 11.7934024
iForged Retro Forged 19x11 27 12.2469948
iForged Retro Forged 19x7.5 22 9.9790328
iForged Retro Forged 19x8 22 9.9790328
iForged Retro Forged 19x8.5 23 10.4326252
iForged Retro Forged 19x9 24 10.8862176
iForged Retro Forged 19x9.5 24 10.8862176
iForged Retro Forged 20x10 27 12.2469948
iForged Retro Forged 20x8 25 11.33981
iForged Retro Forged 20x8.5 25 11.33981
iForged Retro Forged 20x9 26 11.7934024
iForged Retro Forged 22x10 35 15.875734
iForged Retro Forged 22x9.5 30 13.607772
iForged Rev Forged 19x10 25 11.33981
iForged Rev Forged 19x10.5 26 11.7934024
iForged Rev Forged 19x11 27 12.2469948
iForged Rev Forged 19x7.5 22 9.9790328
iForged Rev Forged 19x8 22 9.9790328
iForged Rev Forged 19x8.5 23 10.4326252
iForged Rev Forged 19x9 24 10.8862176
iForged Rev Forged 19x9.5 24 10.8862176
iForged Rev Forged 20x10 27 12.2469948
iForged Rev Forged 20x8 25 11.33981
iForged Rev Forged 20x8.5 25 11.33981
iForged Rev Forged 20x9 26 11.7934024
iForged Rev Forged 22x10 35 15.875734
iForged Rev Forged 22x9.5 30 13.607772
iForged Seneka Forged 19x10 25 11.33981
iForged Seneka Forged 19x10.5 26 11.7934024
iForged Seneka Forged 19x11 27 12.2469948
iForged Seneka Forged 19x7.5 22 9.9790328
iForged Seneka Forged 19x8 22 9.9790328
iForged Seneka Forged 19x8.5 23 10.4326252
iForged Seneka Forged 19x9 24 10.8862176
iForged Seneka Forged 19x9.5 24 10.8862176
iForged Seneka Forged 20x10 27 12.2469948
iForged Seneka Forged 20x8 25 11.33981
iForged Seneka Forged 20x8.5 25 11.33981
iForged Seneka Forged 20x9 26 11.7934024
iForged Seneka Forged 22x10 35 15.875734
iForged Seneka Forged 22x9.5 30 13.607772
iForged Sprint Forged 19x10 25 11.33981
iForged Sprint Forged 19x10.5 26 11.7934024
iForged Sprint Forged 19x11 27 12.2469948
iForged Sprint Forged 19x7.5 22 9.9790328
iForged Sprint Forged 19x8 22 9.9790328
iForged Sprint Forged 19x8.5 23 10.4326252
iForged Sprint Forged 19x9 24 10.8862176
iForged Sprint Forged 19x9.5 24 10.8862176
iForged Sprint Forged 20x10 27 12.2469948
iForged Sprint Forged 20x8 25 11.33981
iForged Sprint Forged 20x8.5 25 11.33981
iForged Sprint Forged 20x9 26 11.7934024
iForged Sprint Forged 22x10 35 15.875734
iForged Sprint Forged 22x9.5 30 13.607772
iForged Swift Forged 19x10 25 11.33981
iForged Swift Forged 19x10.5 26 11.7934024
iForged Swift Forged 19x11 27 12.2469948
iForged Swift Forged 19x7.5 22 9.9790328
iForged Swift Forged 19x8 22 9.9790328
iForged Swift Forged 19x8.5 23 10.4326252
iForged Swift Forged 19x9 24 10.8862176
iForged Swift Forged 19x9.5 24 10.8862176
iForged Swift Forged 20x10 27 12.2469948
iForged Swift Forged 20x8 25 11.33981
iForged Swift Forged 20x8.5 25 11.33981
iForged Swift Forged 20x9 26 11.7934024
iForged Swift Forged 22x10 35 15.875734
iForged Swift Forged 22x9.5 30 13.607772
iForged Technik Forged 19x10 25 11.33981
iForged Technik Forged 19x10.5 26 11.7934024
iForged Technik Forged 19x11 27 12.2469948
iForged Technik Forged 19x7.5 22 9.9790328
iForged Technik Forged 19x8 22 9.9790328
iForged Technik Forged 19x8.5 23 10.4326252
iForged Technik Forged 19x9 24 10.8862176
iForged Technik Forged 19x9.5 24 10.8862176
iForged Technik Forged 20x10 27 12.2469948
iForged Technik Forged 20x8 25 11.33981
iForged Technik Forged 20x8.5 25 11.33981
iForged Technik Forged 20x9 26 11.7934024
iForged Technik Forged 22x10 35 15.875734
iForged Technik Forged 22x9.5 30 13.607772
Import Development Forged 19x10 21 9.5254404
Import Development Forged 19x8 19.5 8.8450518
Import Development Forged 19x8.5 20 9.071848
Impul NS-01R Forged 17x7.5 14.5 6.5770898
Infinity G20 91-97 Cast 14x6 15 6.803886
Infinity M30 90-92 Cast 15x6.5 17 7.7110708
InterMilano RG6 Cast 15x6.5 12 5.4431088
InterMilano RG6 Cast 16x7 16.5 7.4842746
Isuzu Impulse Stylus/Geo Storm 90-93 Stamped Steel 14x5.5 16 7.2574784
Isuzu Impulse Stylus/Geo Storm 90-93 Cast 14x5.5 14 6.3502936
Isuzu Impulse Stylus/Geo Storm 90-93 Cast 15x6 17.4 7.89250776
Jax Light Cast 15x6.5 12.9 5.85134196
Joustmeister Forged 17x7 13 5.8967012
J's Racing PR 6 Forged Mg 17x7.5 13.2 5.98741968
J's Racing PR 6 Forged Mg 17x8.5 13.6 6.16885664
KAD F1 Forged Mg 6x10 4.7 2.13188428
KAD F1 Forged Mg 7x10 5.5 2.4947582
Katana Belajeo Cast 18x7.5 26 11.7934024
Katana Berlini Cast 18x8 26.7 12.11091708
Katana Concept Six Cast 18x7.5 24 10.8862176
Katana Ducati Cast 18x7.5 25 11.33981
Kazera KZ-A Cast 17x7.5 20 9.071848
Kazera KZ-A Cast 18x7.5 22 9.9790328
Kazera KZ-A Cast 18x8.5 23.8 10.79549912
Kazera KZ-A Dual Cast 18x7.5 21.2 9.61615888
Kazera KZ-B Cast 17x7.5 22 9.9790328
Kazera KZ-B Cast 18x7.5 22.5 10.205829
Kazera KZ-C Cast 17x7.5 27.2 12.33771328
Kazera KZ-C Cast 18x7.5 28.2 12.79130568
Kazera KZ-C Cast 19x7.5 30 13.607772
Kazera KZ-F Cast 18x8 24.5 11.1130138
Kazera KZ-L Cast 17x7.5 20.5 9.2986442
Kazera KZ-L Cast 18x8 21 9.5254404
Kazera KZ-R Cast 16x7 17.6 7.98322624
Kazera KZ-R Cast 17x7 18.6 8.43681864
Kazera KZ-R Cast 18x7 19.4 8.79969256
Kazera KZ-S Cast 16x7 18 8.1646632
Kazera KZ-S Cast 17x7 19.4 8.79969256
Kazera KZ-S Cast 18x7 20.5 9.2986442
Kazera KZ-S Cast 19x7.5 24.5 11.1130138
Kazera KZ-T Cast 17x7.5 20.1 9.11720724
Kazera KZ-T Cast 18x7.5 21.2 9.61615888
Kazera KZ-U Cast 16x7 18.5 8.3914594
Kazera KZ-U Cast 17x7 19 8.6182556
Kazera KZ-U Cast 18x7 19.5 8.8450518
Kazera KZ-V Cast 16x7 16.5 7.4842746
Kazera KZ-V Cast 17x7 17.5 7.937867
Kazera KZ-V Cast 18x7 18.8 8.52753712
Kei Racing Flight Cast 15x6.5 16 7.2574784
Kei Racing RSGT Cast 17x7 18.7 8.48217788
Kei Racing Velocity Cast 15x6.5 17.4 7.89250776
Keizer (racing only) Cast 13x8 7.8 3.53802072
Kid's Racing Cast 14x6 9.7 4.39984628
Kid's Racing Cast 15x6.5 10.6 4.80807944
Kinesis K20 Forged/Spun 17x10 20 9.071848
Kinesis K20 Forged/Spun 17x9 19.5 8.8450518
Kinesis K28 Forged/Spun 18x8.5 21.5 9.7522366
Kinesis K28 Forged/Spun 18x9.5 22.5 10.205829
Kinesis K5 Forged/Spun 17x10 18 8.1646632
Kinesis K5 Forged/Spun 17x8.5 17 7.7110708
Kinesis K58 Forged/Spun 18x10 24 10.8862176
Kinesis K58 Forged/Spun 18x8 23 10.4326252
Kinesis K58 Forged/Spun 18x9 23.5 10.6594214
Kinesis Supercup Forged/Spun 17x10 22 9.9790328
KMC Alf Cast 17x7 26 11.7934024
KMC Gear Cast 17x7 24.5 11.1130138
KMC Street Rebel Spyder Cast 17x7 21 9.5254404
KMC Suicide 320 Cast 18x7 20.6 9.34400344
KMC Tarantula Cast 17x7 23.5 10.6594214
KMC Wizdom Cast 18x7 24 10.8862176
KMS Superlight Forged 15x7 10.1 4.58128324
KMS Superlight Forged 16x8 11.9 5.39774956
Kodiak Racing Forged/Spun 16x7 14.5 6.5770898
Kodiak Racing Forged/Spun 17x8 15.4 6.98532296
Konig Absolute Cast 17x7 21.2 9.61615888
Konig Absolute Cast 18x7.5 22.8 10.34190672
Konig Antarres Cast 13x6 15.5 7.0306822
Konig Antarres Cast 16x7.5 21 9.5254404
Konig Appeal Cast 17x7 18.2 8.25538168
Konig Appeal Cast 17x8 20.4 9.25328496
Konig Appeal Cast 17x9.5 22.2 10.06975128
Konig Appeal Cast 18x8 22.2 10.06975128
Konig Appeal Cast 19x8.5 23.8 10.79549912
Konig Appeal Cast 20x8.5 26.3 11.92948012
Konig Arrive Cast 20x8.5 36.3 16.46540412
Konig Blatant Cast 18x8 22.6 10.25118824
Konig Britelite Cast 15x6.5 12 5.4431088
Konig Britelite Cast 15x7 12.5 5.669905
Konig Britelite Cast 16x7 15 6.803886
Konig Burner Cast 15x7 16 7.2574784
Konig Burner Cast 16x7 17.2 7.80178928
Konig Caffeine Cast 15x6.5 16.5 7.4842746
Konig Caffeine Cast 16x7 19 8.6182556
Konig Caffeine Cast 17x7 19.9 9.02648876
Konig Caffeine Cast 17x8 20.1 9.11720724
Konig Caffeine Cast 18x7.5 21.9 9.93367356
Konig Coastal Cast 20x8.5 35.2 15.96645248
Konig Coastal Cast 20x9.5 37.4 16.96435576
Konig Coastal Cast 22x9.5 38.72 17.56309773
Konig Cobra Cast 15x6.5 16 7.2574784
Konig Cobra Cast 16x7 19.5 8.8450518
Konig Cobra Cast 17x7.5 22 9.9790328
Konig Competition Cast 16x7 18.4 8.34610016
Konig Diva Cast 13x5.5 12.5 5.669905
Konig Diva Cast 14x6 13.2 5.98741968
Konig Diva Cast 15x6.5 15.8 7.16675992
Konig Diva Cast 17x7.5 19.5 8.8450518
Konig Diva Cast 18x7.5 22 9.9790328
Konig Drift Cast 17x7 20.2 9.16256648
Konig Drift Cast 18x8 22 9.9790328
Konig DTM Cast 17x7.5 21 9.5254404
Konig Elan Cast 16x7 18 8.1646632
Konig Elan Cast 17x7 20 9.071848
Konig Elan Cast 18x8 21 9.5254404
Konig Featherlite Cast 15x6.5 12.3 5.57918652
Konig Featherlite Cast 16x7 15 6.803886
Konig Featherlite Cast 17x7 17.2 7.80178928
Konig Five-O Cast 16x8 19.2 8.70897408
Konig Five-O Cast 17x8 20.1 9.11720724
Konig Flatline Cast 15x6.5 17.9 8.11930396
Konig Flatline Cast 16x7 19.8 8.98112952
Konig Flatline Cast 17x7 21.1 9.57079964
Konig Flatline Cast 18x7.5 22.6 10.25118824
Konig Flight Cast 15x6.5 17.4 7.89250776
Konig Flight Cast 16x7 18.4 8.34610016
Konig Flight Cast 17x8 20.1 9.11720724
Konig Flight Cast 17x9.5 27.3 12.38307252
Konig Flight Cast 18x7.5 23.5 10.6594214
Konig Flight Cast 18x8 24.9 11.29445076
Konig Freefall Cast 16x7 18.3 8.30074092
Konig Freefall Cast 17x7 20.9 9.48008116
Konig Freefall Cast 18x7.5 22.2 10.06975128
Konig Glide Cast 17x7 22.6 10.25118824
Konig Greenlight Cast 15x6.5 15.4 6.98532296
Konig GT-R Cast 15x6.5 16 7.2574784
Konig GT-R Cast 16x7 17.5 7.937867
Konig GT-R Cast 17x7 19.5 8.8450518
Konig Helium Cast 15x6.5 11.5 5.2163126
Konig Helium Cast 16x7 16.4 7.43891536
Konig Holes Cast 15x6.5 13.8 6.25957512
Konig Holes Cast 16x7 16.1 7.30283764
Konig Holes Cast 17x7 17.8 8.07394472
Konig Holes Cast 18x7.5 21.3 9.66151812
Konig Holes Cast 19x7.5 21.8 9.88831432
Konig Holes Cast 19x8 21.4 9.70687736
Konig Hurry Cast 15x6.5 13.6 6.16885664
Konig Imagine Cast 17x7 22.4 10.16046976
Konig Imagine Cast 18x7.5 25.3 11.47588772
Konig Imagine Cast 18x8.5 28.4 12.88202416
Konig Imagine Cast 19x8 27.5 12.473791
Konig Impact Cast 17x7.5 21 9.5254404
Konig Kilo Cast 15x6.5 11.5 5.2163126
Konig Kolors Cast 15x7 15 6.803886
Konig Kolors Cast 17x7 17.4 7.89250776
Konig LiveWire Cast 17x7 24.9 11.29445076
Konig LiveWire Cast 18x7.5 26.2 11.88412088
Konig Minuz Cast 15x6.5 11.8 5.35239032
Konig Monsoon Cast 15x6.5 16.4 7.43891536
Konig Monsoon Cast 16x7 19.5 8.8450518
Konig Monsoon Cast 17x7 21 9.5254404
Konig Monsoon Cast 17x8 22.6 10.25118824
Konig Monsoon Cast 17x9.5 24 10.8862176
Konig Monsoon Cast 18x7.5 26 11.7934024
Konig MP3 Cast 17x7.5 23.4 10.61406216
Konig MP3 Cast 18x7.5 24.9 11.29445076
Konig Network Cast 15x7 13.4 6.07813816
Konig Next Cast 15x7 14 6.3502936
Konig Next Cast 17x7 18.7 8.48217788
Konig Next Cast 18x7.5 20.7 9.38936268
Konig Next Cast 19x8 23.3 10.56870292
Konig Next Cast 19x9 25.1 11.38516924
Konig Nrn Cast 16x8 18.4 8.34610016
Konig Nrn Cast 17x8 21 9.5254404
Konig Octane Cast 16x7 19.1 8.66361484
Konig OpenRoad Cast 20x8.5 35.2 15.96645248
Konig OpenRoad Cast 20x9.5 35.2 15.96645248
Konig OpenRoad Cast 22x9.5 37 16.7829188
Konig Prophet Cast 17x7.5 22.5 10.205829
Konig Prophet Cast 18x7.5 22.7 10.29654748
Konig Prophet Cast 18x8 24.3 11.02229532
Konig Prophet Cast 19x8 24.5 11.1130138
Konig Prowler Cast 16x7 24 10.8862176
Konig Rated-R Cast 14x6 14.5 6.5770898
Konig Rated-R Cast 15x6.5 16.5 7.4842746
Konig Rated-R Cast 16x7 17.5 7.937867
Konig Rated-R Cast 17x7 19.2 8.70897408
Konig Rated-R Cast 18x7.5 21.5 9.7522366
Konig Rewind Cast 15x7 14.6 6.62244904
Konig Rhythym Cast 17x7 20.9 9.48008116
Konig Rhythym Cast 18x7.5 22.5 10.205829
Konig Rush Cast 14x6 13.5 6.1234974
Konig Rush Cast 15x6.5 17.7 8.02858548
Konig Rush Cast 16x7 19 8.6182556
Konig Rush Cast 17x7.5 22.8 10.34190672
Konig Rush Cast 18x7.5 24.9 11.29445076
Konig Rush Cast 19x8 26.5 12.0201986
Konig Septor Cast 17x7 21.2 9.61615888
Konig Spec Cast 17x7 21.2 9.61615888
Konig SubZero Cast 15x6.5 12.9 5.85134196
Konig SubZero Cast 17x7.5 16.9 7.66571156
Konig Tantrum Cast 15x6.5 16.5 7.4842746
Konig Tantrum Cast 16x7 17.9 8.11930396
Konig Tantrum Cast 17x7 19.2 8.70897408
Konig Tantrum Cast 17x8 22.9 10.38726596
Konig Tantrum Cast 17x9 23 10.4326252
Konig Tantrum Cast 18x7.5 23.2 10.52334368
Konig Tantrum Cast 18x8 24.9 11.29445076
Konig Tantrum Cast 18x9 25.3 11.47588772
Konig Tantrum Cast 19x8 27 12.2469948
Konig Tantrum 2 Cast/Spun 18x10 23.4 10.61406216
Konig Temperr Cast 17x7.5 20.7 9.38936268
Konig Temperr Cast 18x7.5 22.9 10.38726596
Konig Tequila Cast 17x7 19 8.6182556
Konig Theory Cast 17x7 19.3 8.75433332
Konig Theory Cast 18x7.5 20.3 9.20792572
Konig Theory Cast 18x8 22.4 10.16046976
Konig Theory Cast 19x8 24.5 11.1130138
Konig Toxxin Cast 17x7.5 18.6 8.43681864
Konig Toxxin Cast 18x7.5 19.8 8.98112952
Konig Traffik Cast 18x7.5 20.5 9.2986442
Konig Tremor Cast 17x8.5 23.2 10.52334368
Konig Tremor Cast 20x8.5 28.2 12.79130568
Konig Trouble Cast 15x6.5 16.5 7.4842746
Konig Trouble Cast 16x7 18.7 8.48217788
Konig Trouble Cast 17x7 19.8 8.98112952
Konig Trouble Cast 18x7.5 23.1 10.47798444
Konig Trouble Cast 18x8 24.2 10.97693608
Konig Trouble Cast 19x8 26.4 11.97483936
Konig Trouble Cast 19x9 28.6 12.97274264
Konig Tuner Cast 15x6.5 17 7.7110708
Konig Tuner Cast 16x7 17.5 7.937867
Konig Tuner Cast 17x7 18 8.1646632
Konig Tuner2 Cast 17x7.5 21.6 9.79759584
Konig Tuner2 Cast 18x7.5 27 12.2469948
Konig Tuner2 Cast 19x7.5 26.4 11.97483936
Konig Tuner2 Cast 20x7.5 27.1 12.29235404
Konig Unknöwn Cast 17x7 19.6 8.89041104
Konig Unknöwn Cast 17x8 19.6 8.89041104
Konig Unknöwn Cast 18x7.5 23.1 10.47798444
Konig Unknöwn Cast 18x8 24.4 11.06765456
Konig Unknöwn Cast 19x8 24.9 11.29445076
Konig Unknöwn Cast 19x9.5 25 11.33981
Konig Unknöwn Cast 20x8 25.3 11.47588772
Konig Verdict Cast 15x6.5 19.6 8.89041104
Konig Verdict Cast 16x7 20.7 9.38936268
Konig Verdict Cast 17x7 22.4 10.16046976
Konig Verdict Cast 17x8 23.1 10.47798444
Konig Verdict Cast 18x7.5 27.3 12.38307252
Konig Verdict Cast 18x8 27.5 12.473791
Konig Verdict Cast 19x8 27.5 12.473791
Konig Villian Cast 15x6.5 14.5 6.5770898
Konig Villian Cast 17x8 19.8 8.98112952
Konig Villian Cast 17x9 22.3 10.11511052
Konig Villian Cast 18x8 23.8 10.79549912
Konig Villian Cast 18x9 26.5 12.0201986
Konig Volume Cast 18x7.5 26 11.7934024
Konig V-Racing Cast 16x7 18 8.1646632
Konig Whatever Cast 18x8.5 33.4 15.14998616
Konig Ziege Cast 15x6.5 17.2 7.80178928
Konig Ziege Cast 16x7 18.7 8.48217788
Konig Ziege Cast 17x7 20.2 9.16256648
Konig Ziege Cast 18x7.5 22.9 10.38726596
Kosei Double Racer Cast 17x7 17.7 8.02858548
Kosei GK 11 Cast 15x6.5 14 6.3502936
Kosei JGT Cast 18x7.5 24 10.8862176
Kosei K1 Racing Cast 15x7 13.5 6.1234974
Kosei K1 Racing Cast 15x8 14.5 6.5770898
Kosei K1 Racing Cast 16x7.5 15.5 7.0306822
Kosei K1 Racing Cast 16x8.5 16.2 7.34819688
Kosei K1 Racing Cast 17x7.5 16.7 7.57499308
Kosei K1 Racing Cast 17x8.5 16.7 7.57499308
Kosei K1 TS Cast 14x6 9.8 4.44520552
Kosei K1 TS Cast 15x7 12.6 5.71526424
Kosei K1 TS Cast 17x7 13.9 6.30493436
Kosei K1 TS Cast 17x8 15.4 6.98532296
Kosei K1 TS Cast 18x7.5 16 7.2574784
Kosei K1 TS Cast 18x8 16.8 7.62035232
Kosei K3 Cast 15x6.5 15.3 6.93996372
Kosei K3 Cast 17x7 17.2 7.80178928
Kosei K3 Cast 18x7.5 18.5 8.3914594
Kosei K3 Cast 18x8.5 20 9.071848
Kosei K3 Cast 19x8.5 21.2 9.61615888
Kosei Racer Cast 17x7 17.6 7.98322624
Kosei ROM Cast 18x7 24.5 11.1130138
Kosei RT MAXi Cast 15x7 16.8 7.62035232
Kosei RT MAXi Cast 17x7.5 19 8.6182556
Kosei RT Penta Cast 15x7 13.8 6.25957512
Kosei RT Penta Cast 18x7.5 18.5 8.3914594
Kosei RT Sport Cast 15x6.5 14.6 6.62244904
Kosei RT Sport Cast 17x7 20 9.071848
Kosei RT Sport Cast 17x8 21 9.5254404
Kosei RT Sport Cast 18x8 21.5 9.7522366
Kosei S5R Cast 16x8 23 10.4326252
Kosei S5R Cast 17x7 22 9.9790328
Kosei Seneka Cast 15x6.5 15 6.803886
Kosei Seneka Cast 16x7 19 8.6182556
Kosei Seneka Cast 17x7 21.5 9.7522366
Kosei Seneka RG Cast 18x8 25.3 11.47588772
Kosei Sniper Cast 16x7 18.9 8.57289636
Kosei Sniper Cast 17x8 23.5 10.6594214
Kosei Sniper Cast 18x9 25 11.33981
Kosoku Sports Turismo Cast 17x7 27 12.2469948
Kronix Bio Hazard Cast 17x7.5 25.8 11.70268392
Kronix Insignia 770 Cast 17x7.5 26.2 11.88412088
Kuhl Wheel 4-Spoke Steel 14x5.5 14.1 6.39565284
Kuhl Wheel 5-Spoke Steel 16x7 22.5 10.205829
Kuhl Wheel 6-Spoke Steel 17x7 27.3 12.38307252
Kyoho Tracer Cast 15x7 9.9 4.49056476
Kyoho Tracer Cast 16x7 14.7 6.66780828
Kyoho Tracer Cast 16x8 14.9 6.75852676
Kyoho Tracer Cast 17x7 15.2 6.89460448
Kyoho Tracer Cast 17x8 15.6 7.07604144
Kyoho Tracer Cast 17x9 17.6 7.98322624
Kyoho Tracer Cast 18x7.5 17.6 7.98322624
Kyoho Tracer Cast 18x8.5 18 8.1646632
Kyoho Tracer Cast 18x9.5 18.2 8.25538168
Lada Cast Mg 14x6 10.4 4.71736096
Lenso GT-05 Cast 19x8.5 26 11.7934024
Lenso GTR Cast 16x7 15.9 7.21211916
Lenso VPD Cast 13x7.5 10 4.535924
Lenso VPD Cast 15x6.5 13.1 5.94206044
Lenso VPD Cast 16x7 15 6.803886
Lenso VPD Cast 17x7 17 7.7110708
Lexani Amethist Cast 17x7.5 29 13.1541796
Lexani Iris 2009 Cast 18x8 27.5 12.473791
Lexani Krystal Cast 18x8 34 15.4221416
Lexani Solar Cast 17x7.5 28 12.7005872
Lexani Synergy Cast 18x8 30.8 13.97064592
Lexus ES300 97 Cast 15x6 18 8.1646632
Lexus IS300 Cast 17x7 21 9.5254404
Lexus IS300 (Chrome version) Cast 17x7 22 9.9790328
Lezaro Stiletto Cast 17x7.5 25.4 11.52124696
LimiX Linea BE5-RSK Forged 18x7.5 16.8 7.62035232
Lite Speed Billet/ Spun 17x10 18 8.1646632
LLTek Competition Cast 18x8 24 10.8862176
Lotus Elise 111 Cast 15x5.5 16.7 7.57499308
Lotus Elise 111 Cast 16x7 19 8.6182556
Lotus Elise 111S Cast 15x5.5 15.3 6.93996372
Lotus Elise 111S Cast 16x7.5 20.7 9.38936268
Lotus Elise 160Sport Cast 15x6 18.3 8.30074092
Lotus Elise 160Sport Cast 16x8 22 9.9790328
Lotus Elise LSS Forged 16x6.5 13.2 5.98741968
Lotus Elise LSS Forged 17x7.5 15.1 6.84924524
Lotus Elise US Cast 16x5.5 15.2 6.89460448
Lotus Elise US Cast 17x7.5 21 9.5254404
Lotus Exige 111R Cast 16x6.5 17.6 7.98322624
Lotus Exige 111R Cast 17x7.5 20.7 9.38936268
Lowenhart BR-S Cast 20x9 29.3 13.29025732
Lowenhart BS-5 Cast 18x8.5 29 13.1541796
Lowenhart BS-D Cast 20x10 42 19.0508808
Lowenhart LD-1 Cast 20x10 32.3 14.65103452
Lowenhart LG-M Cast 18x8.5 26 11.7934024
Lowenhart LH-5 Cast 18x8 28 12.7005872
Mackin Gewalt Cast 17x10 23 10.4326252
Mackin Gewalt Cast 17x7 22 9.9790328
Madhi Caesar Cast 19x9 27.4 12.42843176
Manaray SP Cast 17x10 24 10.8862176
Manaray SP Cast 17x8.5 22 9.9790328
Mandrus Regenmeister Cast 17x8 23 10.4326252
MAS Axel Cast 18x8 25 11.33981
MAS Bi Turbo Look Cast 18x8 31 14.0613644
MAS Madel Cast 17x8 29 13.1541796
MAS Majestic Cast 18x8 26.5 12.0201986
MAS MGR Cast 16x7.5 22.5 10.205829
MAS MGR Cast 18x7.5 26 11.7934024
MAS MGR Cast 18x8 26.5 12.0201986
MAS Roger Cast 17x7 22 9.9790328
MAS Roger Cast 18x8 29.5 13.3809758
MAS Sagitta Cast 18x8 24.3 11.02229532
Maxxim Approach Cast 18x7.5 24.2 10.97693608
Maxxim Def-Con 6 Cast 17x7 20 9.071848
Mazda 323 7-spoke Cast 15x5.5 15.3 6.93996372
Mazda 626 83-87 Cast 15x6 16 7.2574784
Mazda 929 93-95 Cast 15x6 12 5.4431088
Mazda Miata 01 Cast 16x6.5 15.5 7.0306822
Mazda Miata 02 SE Cast 16x6.5 19 8.6182556
Mazda Miata 06 Cast 17x7 17 7.7110708
Mazda Miata 90-93 Cast 14x5.5 12.5 5.669905
Mazda Miata 90-97 Steel Stamped Steel 14x5.5 18 8.1646632
Mazda Miata 92C/93LE (BBS) Forged 14x6 10.5 4.7627202
Mazda Miata 94 M-Edition Cast 14x6 10.3 4.67200172
Mazda Miata 94-97 (hollow spokes) Cast 14x6 11.8 5.35239032
Mazda Miata 94-97 (semi-hollow spokes) Cast 14x6 10.9 4.94415716
Mazda Miata 95 M-Edition (BBS) Forged 15x6 11.6 5.26167184
Mazda Miata 96 M-Edition (Enkei) Cast 15x6 14.7 6.66780828
Mazda Miata 97 M-Edition Cast 15x6 14.5 6.5770898
Mazda Miata 99-00 Cast 14x6 12.5 5.669905
Mazda Miata 99-00 Cast 15x6 13.4 6.07813816
Mazda Miata Spare Tire & Wheel (includes tire weight) Stamped Steel 14x4 21.6 9.79759584
Mazda Miata UK Cast 15x6 15 6.803886
Mazda Millenia Cast 15x6 11.5 5.2163126
Mazda Protégé 5 ES Cast 16x6.5 16 7.2574784
Mazda RX7 84-85 Cast 14x5.5 13 5.8967012
Mazda RX7 86-88 Cast 14x5.5 13.5 6.1234974
Mazda RX7 88 10AE Cast 16x7 21.1 9.57079964
Mazda RX7 FD3S Cast 16x8 15.4 6.98532296
Mazda RX7 FD3S - PFD Cast (Brittle) 16x8 13.8 6.25957512
Mazda RX7 TII 89-91 Cast 16x7 17.2 7.80178928
Mazda RX8 06-09 Cast 18x8 22 9.9790328
Mazda Sports Forged 16x7 13.1 5.94206044
Mazdaspeed 6 06 Cast 18x7 23.5 10.6594214
Mazdaspeed MS-01 Forged Mg 18x8 16.2 7.34819688
Mazdaspeed MS-01 Forged Mg 18x8.5 16.6 7.52963384
Mazdaspeed MS-01S Forged 18x8 17.7 8.02858548
Mazdaspeed MS-03 Cast 15x6.5 16.5 7.4842746
Mazdaspeed Z01 Forged 18x7.5 17 7.7110708
MB Motoring 005 Cast 14x6 14 6.3502936
MB Motoring 005 Cast 15x6.5 16.5 7.4842746
MB Motoring 005 Cast 16x7 20.5 9.2986442
MB Motoring 005 Cast 17x7 20.5 9.2986442
MB Motoring 070 Cast 15x10 18 8.1646632
MB Motoring 070 Cast 15x8 16 7.2574784
MB Motoring 070 Cast 16.5x9.8 21 9.5254404
MB Motoring 070 Cast 16x10 20.5 9.2986442
MB Motoring 070 Cast 16x8 16.5 7.4842746
MB Motoring 177 Cast 15x7 21.5 9.7522366
MB Motoring 177 Cast 16x7 23.5 10.6594214
MB Motoring 177 Cast 17x7 26 11.7934024
MB Motoring 747 Cast 13x5 12.5 5.669905
MB Motoring 747 Cast 14x6 15 6.803886
MB Motoring 747 Cast 15x6.5 16.5 7.4842746
MB Motoring 747 Cast 16x7 18.5 8.3914594
MB Motoring 747 Cast 17x7 22.5 10.205829
MB Motoring ABYSS Cast 17x7 24.5 11.1130138
MB Motoring ABYSS Cast 18x7.5 29 13.1541796
MB Motoring ABYSS Cast 18x8 29 13.1541796
MB Motoring ABYSS Cast 18x9 30.5 13.8345682
MB Motoring AMMO Cast 17x7 27 12.2469948
MB Motoring AMMO Cast 18x7.5 30 13.607772
MB Motoring AMMO Cast 20x8.5 38 17.2365112
MB Motoring BLAST Cast 17x7.5 20 9.071848
MB Motoring BLAST Cast 18x7.5 20.5 9.2986442
MB Motoring BLI Cast 15x7 22 9.9790328
MB Motoring BLI Cast 15x8 22.5 10.205829
MB Motoring BLI Cast 16x8 26 11.7934024
MB Motoring BLI Cast 17x8 28 12.7005872
MB Motoring BLI Cast 18x10 39.5 17.9168998
MB Motoring BLI Cast 18x8.5 31.5 14.2881606
MB Motoring BOOST Cast 15x6.5 16 7.2574784
MB Motoring BOOST Cast 16x7 19.5 8.8450518
MB Motoring BOOST Cast 17x7 20.5 9.2986442
MB Motoring BOOST Cast 18x7.5 22 9.9790328
MB Motoring BRU Cast 20x8.5 35 15.875734
MB Motoring BRU Cast 22x9.5 41 18.5972884
MB Motoring BRU Cast 24x10 49 22.2260276
MB Motoring BRUZER Cast 20x8.5 35 15.875734
MB Motoring BRUZER Cast 22x9.5 41 18.5972884
MB Motoring BRUZER Cast 24x10 49 22.2260276
MB Motoring CAN Cast 20x8.5 33.5 15.1953454
MB Motoring CAN Cast 22x9.5 45.5 20.6384542
MB Motoring CAN Cast 24x10 50 22.67962
MB Motoring CATALYST 1 Cast 18x8 33.5 15.1953454
MB Motoring CATALYST 1 Cast 20x8.5 39.5 17.9168998
MB Motoring CATALYST 2 Cast 18x8.5 36.5 16.5561226
MB Motoring CATALYST 2 Cast 20x9 42.5 19.277677
MB Motoring CATALYST 2 Cast 22x9.5 51 23.1332124
MB Motoring CLA Cast 16x7 20 9.071848
MB Motoring CLA Cast 17x7 21 9.5254404
MB Motoring CLA Cast 18x7.5 24.5 11.1130138
MB Motoring Competition Cast 15x7 13.5 6.1234974
MB Motoring Competition Cast 17x7 17 7.7110708
MB Motoring DEE Cast 20x9 38 17.2365112
MB Motoring DEE Cast 22x9.5 44.5 20.1848618
MB Motoring EX5 Cast 18x9 28.5 12.9273834
MB Motoring EX5 Cast 20x9 32 14.5149568
MB Motoring EX5 Cast 22x9.5 38 17.2365112
MB Motoring EX6 Cast 18x9 28.5 12.9273834
MB Motoring EX6 Cast 20x9 32 14.5149568
MB Motoring EX6 Cast 22x9 35 15.875734
MB Motoring EXE Cast 17x7 23 10.4326252
MB Motoring EXE Cast 18x7.5 25 11.33981
MB Motoring EXE II Cast 18x7.5 25 11.33981
MB Motoring EXE II Cast 18x8 25 11.33981
MB Motoring EXE II Cast 18x9 25 11.33981
MB Motoring GEAR Cast 17x7 24.5 11.1130138
MB Motoring GEAR Cast 18x8 28 12.7005872
MB Motoring GU5 Cast 16x8 23 10.4326252
MB Motoring GU5 Cast 17x10 28 12.7005872
MB Motoring GU5 Cast 17x8 27 12.2469948
MB Motoring GU5 Cast 18x10 30 13.607772
MB Motoring GU5 Cast 18x8.5 29.5 13.3809758
MB Motoring GU5 Cast 20x10 32 14.5149568
MB Motoring GU5 Cast 20x8.5 32 14.5149568
MB Motoring GU6 Cast 16x8 23 10.4326252
MB Motoring GU6 Cast 17x10 28 12.7005872
MB Motoring GU6 Cast 17x8 23.5 10.6594214
MB Motoring GU6 Cast 18x10 30 13.607772
MB Motoring GU6 Cast 18x8.5 29.5 13.3809758
MB Motoring GU6 Cast 20x10 32.5 14.741753
MB Motoring GU6 Cast 20x8.5 32 14.5149568
MB Motoring GU8 Cast 16x8 24.5 11.1130138
MB Motoring GU8 Cast 17x8 28.5 12.9273834
MB Motoring GU8 Cast 18x10 32 14.5149568
MB Motoring GU8 Cast 20x10 34 15.4221416
MB Motoring GU8 Cast 20x8.5 33.5 15.1953454
MB Motoring GUNNER 5 Cast 16x8 23 10.4326252
MB Motoring GUNNER 5 Cast 17x10 28 12.7005872
MB Motoring GUNNER 5 Cast 17x8 27 12.2469948
MB Motoring GUNNER 5 Cast 18x10 30 13.607772
MB Motoring GUNNER 5 Cast 18x8.5 29.5 13.3809758
MB Motoring GUNNER 5 Cast 20x10 32 14.5149568
MB Motoring GUNNER 5 Cast 20x8.5 32 14.5149568
MB Motoring GUNNER 6 Cast 16x8 23 10.4326252
MB Motoring GUNNER 6 Cast 17x10 28 12.7005872
MB Motoring GUNNER 6 Cast 17x8 23.5 10.6594214
MB Motoring GUNNER 6 Cast 18x10 30 13.607772
MB Motoring GUNNER 6 Cast 18x8.5 29.5 13.3809758
MB Motoring GUNNER 6 Cast 20x10 32.5 14.741753
MB Motoring GUNNER 6 Cast 20x8.5 32 14.5149568
MB Motoring GUNNER 8 Cast 16x8 24.5 11.1130138
MB Motoring GUNNER 8 Cast 17x8 28.5 12.9273834
MB Motoring GUNNER 8 Cast 18x10 32 14.5149568
MB Motoring GUNNER 8 Cast 20x10 34 15.4221416
MB Motoring GUNNER 8 Cast 20x8.5 33.5 15.1953454
MB Motoring JUM Cast 20x8.5 36 16.3293264
MB Motoring JUM Cast 22x9.5 46.5 21.0920466
MB Motoring KAN Cast 16x8 25 11.33981
MB Motoring KAN Cast 17x8 27 12.2469948
MB Motoring KAN Cast 18x8.5 36 16.3293264
MB Motoring KAN Cast 20x8.5 42.5 19.277677
MB Motoring KAN Cast 22x9.5 47.5 21.545639
MB Motoring LINK Cast 17x7.5 27.5 12.473791
MB Motoring LINK Cast 18x7.5 27.5 12.473791
MB Motoring LINK Cast 20x8.5 35 15.875734
MB Motoring OVE Cast 15x7 17.5 7.937867
MB Motoring OVE Cast 15x8 21.5 9.7522366
MB Motoring OVE Cast 16x10 30 13.607772
MB Motoring OVE Cast 16x8 21 9.5254404
MB Motoring OVE Cast 17x10 25.5 11.5666062
MB Motoring OVE Cast 17x8.5 23 10.4326252
MB Motoring PRD Cast 15x8 24 10.8862176
MB Motoring PRD Cast 16x8 28 12.7005872
MB Motoring PRD Cast 17x8 30.5 13.8345682
MB Motoring PRD Cast 18x10 34 15.4221416
MB Motoring PRD Cast 18x8.5 34 15.4221416
MB Motoring PRD Cast 20x10 41 18.5972884
MB Motoring PRD Cast 20x8.5 38.5 17.4633074
MB Motoring PRE Cast 17x8.5 26.5 12.0201986
MB Motoring PRE Cast 18x9 28.5 12.9273834
MB Motoring PRE Cast 20x10 38 17.2365112
MB Motoring PRE Cast 20x8.5 30 13.607772
MB Motoring PRO Cast 18x9 33 14.9685492
MB Motoring PRO Cast 20x9 37.5 17.009715
MB Motoring RAZ Cast 16x8 26.5 12.0201986
MB Motoring RAZ Cast 17x10 31 14.0613644
MB Motoring RAZ Cast 18x10 34.5 15.6489378
MB Motoring RAZ Cast 18x8.5 32.5 14.741753
MB Motoring RAZ Cast 20x10 40 18.143696
MB Motoring RAZ Cast 22x11 48 21.7724352
MB Motoring REV Cast 15x7 19 8.6182556
MB Motoring REV Cast 15x7 20 9.071848
MB Motoring REV Cast 16x7 22 9.9790328
MB Motoring REV Cast 16x7 23 10.4326252
MB Motoring REV Cast 17x7 22.5 10.205829
MB Motoring REV Cast 17x7 23.5 10.6594214
MB Motoring REV Cast 18x7 23.5 10.6594214
MB Motoring REV Cast 18x8 25.5 11.5666062
MB Motoring REV Cast 18x8 27.5 12.473791
MB Motoring ROC Cast 16x10 25.5 11.5666062
MB Motoring ROC Cast 16x8 22.5 10.205829
MB Motoring ROC Cast 17x10 32 14.5149568
MB Motoring ROC Cast 17x8 24.5 11.1130138
MB Motoring ROC Cast 18x10 32.5 14.741753
MB Motoring ROC Cast 20x10 39 17.6901036
MB Motoring SEN Cast 20x8.5 34.5 15.6489378
MB Motoring SEN Cast 22x9 42.5 19.277677
MB Motoring SHA Cast 20x9 40 18.143696
MB Motoring SHAKER Cast 20x9 40 18.143696
MB Motoring SHIFTER Cast 17x7.5 24 10.8862176
MB Motoring SHIFTER Cast 18x7.5 24.5 11.1130138
MB Motoring SMO Cast 18x9 27.5 12.473791
MB Motoring SMO Cast 20x10 33 14.9685492
MB Motoring SPARK Cast 15x6.5 15.5 7.0306822
MB Motoring SPARK Cast 16x7 18 8.1646632
MB Motoring SPARK Cast 17x7 19.5 8.8450518
MB Motoring VA1 Cast 18x8.5 29 13.1541796
MB Motoring VA1 Cast 20x8.5 32 14.5149568
MB Motoring VA2 Cast 18x8.5 34.5 15.6489378
MB Motoring VA2 Cast 20x8.5 37 16.7829188
MB Motoring VIN Cast 17x8 20.5 9.2986442
MB Motoring VISION Cast 15x6.5 17.5 7.937867
MB Motoring VISION Cast 16x7 20 9.071848
MB Motoring VISION Cast 17x7.5 22.5 10.205829
MB Motoring VISION Cast 18x7.5 24.5 11.1130138
MB Motoring VR1 Cast 17x7 22 9.9790328
MB Motoring VR1 Cast 18x7.5 25 11.33981
MB Motoring VR1 Cast 18x8 25.5 11.5666062
MB Motoring VR1 Cast 18x9 26 11.7934024
MB Motoring VR5S Cast 17x7 22 9.9790328
MB Motoring VR5S Cast 18x7.5 24.5 11.1130138
MB Motoring VR5S Cast 18x8 26 11.7934024
MB Motoring WEAPON Cast 17x7 18 8.1646632
MB Motoring WEAPON Cast 17x8 20 9.071848
MB Motoring WEAPON Cast 17x9 21 9.5254404
MB Motoring WEAPON Cast 18x7.5 21 9.5254404
MB Motoring WEAPON Cast 18x8 22 9.9790328
MB Motoring WEAPON Cast 18x9 23.5 10.6594214
MB Motoring YUM Cast 20x8.5 35 15.875734
MB Motoring YUM Cast 22x9 40.5 18.3704922
MB Motoring YUMA Cast 20x8.5 35 15.875734
MB Motoring YUMA Cast 22x9 40.5 18.3704922
Mercedes Benz AMG SLK (Front) Forged 17x7.5 22.8 10.34190672
Mercedes Benz AMG SLK (Rear) Forged 17x8.5 23.6 10.70478064
Mercedes Benz C32 (Front) Cast 17x7.5 25.6 11.61196544
Mercedes Benz C32 (Rear) Cast 17x8.5 26 11.7934024
Mercedes Benz C55 (Front) Forged 18x8.5 26.4 11.97483936
Mercedes Benz C55 (Rear) Forged 18x9.5 27.2 12.33771328
Mercedes Benz C7 Sport (W203) Cast 17x7.5 24.6 11.15837304
Mercedes Benz CLK230 98-99 Forged 16x7 12.9 5.85134196
Mercedes Benz E-Class W124 (EVO II) Forged 18x8.5 24.7 11.20373228
Mercedes Benz E-Class W124 (15 Hole) Cast 15x6.5 17.9 8.11930396
Mercedes Benz E-Class W124 (8 Hole) Cast 15x6.5 19.6 8.89041104
Mercedes Benz E-Class W124 (8 Hole) Cast 16x8 23.2 10.52334368
Mercedes Benz CLK320 (6 Spoke) Forged 16x7 14.5 6.5770898
Mercedes Benz SL600 (1997) Forged 18x8.5 25.5 11.5666062
Mercedes Benz SL600 (1997) Forged 18x9.5 26.5 12.0201986
MHT Driv Cast 17x7 27.5 12.473791
MHT Qwan Cast 18x8 27 12.2469948
MHT V-10 Cast/Spun 18x7 25 11.33981
MHT V-10 Cast/Spun 20x8.5 30.5 13.8345682
Mille Miglia A3 Cast 15x7 23 10.4326252
Mille Miglia Action Cast 16x7 23 10.4326252
Mille Miglia Action Cast 18x8 25 11.33981
Mille Miglia Action Sport Cast 18x8 23 10.4326252
Mille Miglia Avia Cast 15x6.5 22 9.9790328
Mille Miglia Avia Cast 16x7 21.5 9.7522366
Mille Miglia Avia Cast 18x7.5 26 11.7934024
Mille Miglia Avia II Cast 18x8 25 11.33981
Mille Miglia C2T Cast 17x7.5 24 10.8862176
Mille Miglia C2T Cast 17x9 26 11.7934024
Mille Miglia Cello Cast 15x7 19 8.6182556
Mille Miglia Cello Cast 16x7 20 9.071848
Mille Miglia Cello Cast 18x8 25 11.33981
Mille Miglia Cup 3S Cast 18x8 27 12.2469948
Mille Miglia Emotion SSL Cast 18x8 27 12.2469948
Mille Miglia Evo Cast 17x7 23.3 10.56870292
Mille Miglia Evo Cast 18x8 27 12.2469948
Mille Miglia EV-R Cast 18x8 29 13.1541796
Mille Miglia F20 Cast 17x7 24.4 11.06765456
Mille Miglia HT3 Cast 15x7 17.5 7.937867
Mille Miglia HT3 Cast 17x7 22 9.9790328
Mille Miglia HT3 Cast 17x8 24 10.8862176
Mille Miglia HT3 Cast 18x7 23.5 10.6594214
Mille Miglia HT3 Cast 18x8 26.5 12.0201986
Mille Miglia Max F Forged 20x8.5 23.8 10.79549912
Mille Miglia Max F Forged 22x10 31.1 14.10672364
Mille Miglia MM 11 Sport Cast 16x7 16.5 7.4842746
Mille Miglia MM 11 Sport Cast 17x8.5 22 9.9790328
Mille Miglia MM 11-2 Cast 17x7 23 10.4326252
Mille Miglia MM 11-2 Cast 18x8 25 11.33981
Mille Miglia MM 11-3 Cast 17x7 22.9 10.38726596
Mille Miglia Sfera Cast 16x7 21.8 9.88831432
Mille Miglia Spider Cast 18x8 27 12.2469948
Mille Miglia Spider II Cast 15x7 23 10.4326252
Mille Miglia Spider II Cast 16x7 22.5 10.205829
Mille Miglia Spider II Cast 17x7 24.5 11.1130138
Mille Miglia Uno Cast 18x8 28.4 12.88202416
Millenium Kurbkrusher Cast 18x8 34 15.4221416
Miller Motorworks RS-R Cast 18x8 28 12.7005872
MiM ""ScoobySport"" Cast 17x7 21 9.5254404
MiM Venezia Cast 16x7.5 23.6 10.70478064
MiM Vento Cast 15x7 19 8.6182556
Mini R105 Cast 17x7 23.3 10.56870292
Mini R105 Cast 18x7 23.3 10.56870292
Mini R107 GP Cast 18x7 19.8 8.98112952
Mini R12 Steel 15x5 14.8 6.71316752
Mini R81 Imola (7-hole) Cast 15x5.5 12.1 5.48846804
Mini R82 Silverstone (8-spoke) Cast 15x5.5 15.2 6.89460448
Mini R83 Daytona (5-star) Cast 16x6.5 20.1 9.11720724
Mini R84 X-Lite Monza (V-spoke) Cast 16x6.5 17.6 7.98322624
Mini R85 S-Lite (LeMans) Cast 17x7 25.1 11.38516924
Mini R86 (star spoke) Cast 15x5.5 15 6.803886
Mini R87 (double spoke) Cast 16x5.5 16.5 7.4842746
Mini R88 Cast 16x5.5 19.6 8.89041104
Mini R90 Cast/Spun 17x7 24.1 10.93157684
Mini R91 Bullet Cast 17x7 20.6 9.34400344
Mini R92 Fin (7-spoke) Cast 16x6.5 19 8.6182556
Mini R93 Rocket Cast 15x5.5 14.8 6.71316752
Mini R94 Bridge-spoke Cast 16x6.5 20.9 9.48008116
Mini R95 JCW Cast 18x7 23.5 10.6594214
Mini R96 (7-spoke) Cast 15x5.5 13.8 6.25957512
Mini R97 Flame Cast 17x7 22 9.9790328
Mini R98 Cast/Spun 17x7 22.3 10.11511052
Mini R99 Cast 17x7 21.9 9.93367356
Mini Spare Steel 15x3.5 12.7 5.76062348
Mini Steel Steel 15x5.5 14.7 6.66780828
Minilite Competition Cast 13x7 13 5.8967012
Minilite Magnesium Forged Mg 14x6 10 4.535924
Minilite Magnesium Forged Mg 15x7 10.5 4.7627202
Minilite Sport Cast 14x6 14 6.3502936
Minilite Sport Cast 15x6.5 16 7.2574784
Miro Type 111 Cast 19x8.5 24 10.8862176
Miro Type 111 Cast 19x9.5 25 11.33981
Mitsubishi 3000GT VR-4 95 Cast 18x8.5 25 11.33981
Mitsubishi Galant 91 Cast 15x6 17 7.7110708
Mitsubishi Galant 92 Cast 15x6 16 7.2574784
Mitsubishi Galant 94-96 (5-spoke) Cast 15x6 15 6.803886
Mitsubishi Galant 96-97 (4-spoke) Cast 15x6 14.5 6.5770898
Mitsubishi GSX 1997 Cast 17x6.5 25 11.33981
Mitsubishi Lancer EVO2 Cast 15x6.5 13.4 6.07813816
Mitsubishi Lancer EVO6 Cast 17x7.5 21 9.5254404
Mitsubishi Lancer EVO6 TME Cast 17x7.5 23.8 10.79549912
Mitsubishi Lancer EVO7 Cast 17x7.5 22.3 10.11511052
Mitsubishi Lancer EVO8 Cast 17x8 20.5 9.2986442
Mitsubishi Lancer EVO8/9 MR (BBS) Forged 17x7.5 17.8 8.07394472
Mitsubishi Lancer EVO9 (Enkei) Cast 17x7.5 20.2 9.16256648
Mitsubishi Lancer Evo X (BBS) Forged 18x8.5 19.8 8.98112952
MK Sport Racer X Cast 17x7.5 26 11.7934024
MK Sport Seducer Cast 19x9.5 34 15.4221416
MK Sport Sleeper Cast 17x7.5 25 11.33981
MK-Motorsport MK2 Forged/Spun 18x8.5 24.3 11.02229532
MKW MK-5 Cast 17x7.5 27.5 12.473791
MKW MK-9 Cast 18x8 24.8 11.24909152
Moda MD1 Cast 18x8 25 11.33981
Moda MD1 Cast 19x8.5 26.5 12.0201986
Moda MD2 Cast 18x8 28.5 12.9273834
Moda MD2 Cast 19x8.5 32.5 14.741753
Moda MD3 Cast 19x8.5 33.5 15.1953454
Moda MD5 Cast 18x8 24.5 11.1130138
Moda MD5 Cast 19x8.5 27.5 12.473791
Moda MD5 Cast 19x9.5 30 13.607772
Moda R1 Cast 17x8 24 10.8862176
Moda R10 Cast 19x8 36.6 16.60148184
Moda R2 Cast 15x7 19.5 8.8450518
Moda R2 Cast 16x7 21.5 9.7522366
Moda R3 Cast 17x7 24.6 11.15837304
Moda R3 Cast 18x8 27 12.2469948
Moda R4 Cast 18x8 27 12.2469948
Moda R6 Cast 18x8 28.6 12.97274264
Modex Ks-Ce Forged 15x6.5 9.2 4.17305008
Modex Ks-Ce Forged 17x7 13 5.8967012
Modulo Euro Performance R5 Cast 17x7 21 9.5254404
Modulo Euro Performance R5 Cast 17x8.5 22.3 10.11511052
MOMO Arrow Cast 15x7 20 9.071848
MOMO Arrow Cast 16x7 23 10.4326252
MOMO Arrow Cast 17x8 26 11.7934024
MOMO GT2 Cast 17x8 26 11.7934024
MOMO Racer Cast 17x8 27.3 12.38307252
MOMO Racer Cast 18x8.5 35.5 16.1025302
MOMO Sport Cast 16x7 23 10.4326252
MOMO Sport Cast 17x8 26 11.7934024
MOMO Superlight Forged 17x7 17 7.7110708
Mondera Spyder Cast 18x7.5 26.4 11.97483936
Monocoque RT Cast 17x10 20 9.071848
Monster Sport Type-R Forged 15x6.5 8.6 3.90089464
Monster Sport Type-R Forged 16x7 12.9 5.85134196
Motec Pantera Cast 18x8.5 24.8 11.24909152
Motec Pantera Cast 18x9.5 26 11.7934024
Motec Pantera Cast 19x8.5 26.7 12.11091708
Motec Pantera Cast 19x9.5 27.2 12.33771328
Motegi Racing DP1 Cast 17x7 26.5 12.0201986
Motegi Racing DP1 Cast 18x8 28 12.7005872
Motegi Racing DP1 Cast 20x7.5 31 14.0613644
Motegi Racing DP10 Cast 17x7 18.5 8.3914594
Motegi Racing DP10 Cast 18x8 23.5 10.6594214
Motegi Racing DP10 Cast 20x7.5 27 12.2469948
Motegi Racing DP12 Cast 17x7 21 9.5254404
Motegi Racing DP12 Cast 18x7.5 22.5 10.205829
Motegi Racing DP12 Cast 20x7.5 30 13.607772
Motegi Racing DP20 Cast 17x7 20.7 9.38936268
Motegi Racing DP20 Cast 18x7.5 24.3 11.02229532
Motegi Racing DP20 Cast 20x7.5 27.3 12.38307252
Motegi Racing DP5 Cast 17x7 19 8.6182556
Motegi Racing DP5 Cast 18x7.5 22.5 10.205829
Motegi Racing DP6 Cast 17x7 21 9.5254404
Motegi Racing DP6 Cast 18x7.5 22.5 10.205829
Motegi Racing DP6 Cast 18x8 22.5 10.205829
Motegi Racing DP6 Cast 20x7.5 25 11.33981
Motegi Racing DPK Cast 17x7 23 10.4326252
Motegi Racing DPK Cast 18x8 25 11.33981
Motegi Racing DPK Cast 19x8 26.5 12.0201986
Motegi Racing DV5 Cast 17x7 21.2 9.61615888
Motegi Racing DV5 Cast 18x8 24.5 11.1130138
Motegi Racing DV5 Cast 19x8 25 11.33981
Motegi Racing FF15 Cast 16x7 16 7.2574784
Motegi Racing FF15 Cast 17x7 19 8.6182556
Motegi Racing FF15 Cast 18x7 22.5 10.205829
Motegi Racing FF5 Cast 17x7 21 9.5254404
Motegi Racing FF5 Cast 18x7.5 23.5 10.6594214
Motegi Racing FF5 Cast 18x8 24 10.8862176
Motegi Racing FF5 Cast 19x8 26 11.7934024
Motegi Racing FF7 Cast 16x7 19 8.6182556
Motegi Racing FF7 Cast 17x7 21.5 9.7522366
Motegi Racing FF7 Cast 18x7.5 24.5 11.1130138
Motegi Racing FF7 Cast 19x7.5 25.5 11.5666062
Motegi Racing LC12 Cast 17x8 16.5 7.4842746
Motegi Racing LC12 Cast 18x7.5 20 9.071848
Motegi Racing LC5 Cast 15x7 12.5 5.669905
Motegi Racing LC5 Cast 17x7 15.5 7.0306822
Motegi Racing LC5 Cast 17x8 16.5 7.4842746
Motegi Racing LC5 Cast 18x7.5 20 9.071848
Motegi Racing MR12 Cast 15x7 17.5 7.937867
Motegi Racing MR12 Cast 16x7 19 8.6182556
Motegi Racing MR12 Cast 17x7.5 22.5 10.205829
Motegi Racing MR12 Cast 18x7 27.5 12.473791
Motegi Racing MR15 Cast 16x7 19.5 8.8450518
Motegi Racing MR15 Cast 17x7 23 10.4326252
Motegi Racing MR15 Cast 18x7 26.5 12.0201986
Motegi Racing MR4 Cast 17x7 25.5 11.5666062
Motegi Racing MR4 Cast 18x8 28.5 12.9273834
Motegi Racing MR5 Cast 16x7 19 8.6182556
Motegi Racing MR5 Cast 17x7 24.5 11.1130138
Motegi Racing MR5 Cast 18x7 29 13.1541796
Motegi Racing MR7 Cast 14x6 15.8 7.16675992
Motegi Racing MR7 Cast 15x6.5 16.5 7.4842746
Motegi Racing MR7 Cast 16x7 20 9.071848
Motegi Racing MR7 Cast 17x7 24.5 11.1130138
Motegi Racing MR7 Cast 18x7 27.5 12.473791
Motegi Racing MR7 Cast 18x7.5 28.5 12.9273834
Motegi Racing MR8 Cast 16x7 16.5 7.4842746
Motegi Racing MR8 Cast 17x7 22.5 10.205829
Motegi Racing MR8 Cast 18x7 26.5 12.0201986
Motegi Racing RT5 Cast 14x6 12 5.4431088
Motegi Racing RT5 Cast 15x6.5 14 6.3502936
Motegi Racing RT5 Cast 16x7 16 7.2574784
Motegi Racing RT5 Cast 17x7 19 8.6182556
Motegi Racing RT5 Cast 18x7.5 22.5 10.205829
Motegi Racing SP10 Cast 15x7 14.5 6.5770898
Motegi Racing SP10 Cast 17x7 16.8 7.62035232
Motegi Racing SP10 Cast 18x8 18.6 8.43681864
Motegi Racing SP5 Cast 17x7 19.5 8.8450518
Motegi Racing SP5 Cast 18x7.5 23.4 10.61406216
Motegi Racing SP5 Cast 19x8.5 27.6 12.51915024
Motegi Racing SP5 Cast 19x9.5 28.1 12.74594644
Motegi Racing SP7 Cast 17x7 20.3 9.20792572
Motegi Racing SP7 Cast 18x8 22.9 10.38726596
Motegi Racing SP7 Cast 19x8.5 28.4 12.88202416
Motegi Racing SP7 Cast 19x9.5 29.3 13.29025732
Motegi Racing SX5 Cast 15x6.5 16.5 7.4842746
Motegi Racing SX5 Cast 16x7 17.2 7.80178928
Motegi Racing SX5 Cast 17x7 18.9 8.57289636
Motegi Racing SX5 Cast 18x7.5 20.5 9.2986442
Motegi Racing SX7 Cast 15x6.5 16.8 7.62035232
Motegi Racing SX7 Cast 16x7 18.8 8.52753712
Motegi Racing SX7 Cast 17x7 20.5 9.2986442
Motegi Racing SX7 Cast 18x7.5 23 10.4326252
Motegi Racing Touge Cast 17x9 24 10.8862176
Motegi Racing Touge Cast 18x10 28 12.7005872
Motegi Racing Touge Cast 18x7.5 24.5 11.1130138
Motegi Racing Touge Cast 18x9 26 11.7934024
Motegi Racing Touge Cast 19x10 26.3 11.92948012
Motegi Racing Touge Cast 19x8 24.6 11.15837304
Motegi Racing Touge Cast 19x9 25.2 11.43052848
Motegi Racing Trak Lite Forged 15x6.5 10.2 4.62664248
Motegi Racing Trak Lite Forged 15x7 10.8 4.89879792
Motegi Racing Trak Lite Forged 16x6.5 12.1 5.48846804
Motegi Racing Trak Lite Forged 16x7 12.5 5.669905
Motegi Racing Trak Lite Forged 17x7 14.5 6.5770898
Motegi Racing Trak Lite Forged 17x8 15 6.803886
Motegi Racing Trak Lite Forged 19x7.5 19.4 8.79969256
Motegi Racing Trak Lite 2 Forged 15x7 10.3 4.67200172
Motegi Racing Trak Lite 2 Forged 17x8 14.6 6.62244904
Motegi Racing US7 Cast 17x7 27.4 12.42843176
Motegi Racing US7 Cast 18x7.5 29.8 13.51705352
Motegi Racing US7 Cast 20x7.5 34.5 15.6489378
Motoform Sekta Cast 17x7 30 13.607772
Motoform Talon Cast 17x7 30 13.607772
MRR GT1 Cast 19x8.5 24.5 11.1130138
MRR GT1 Cast 19x9.5 27.7 12.56450948
MRT Steel 13x7 17 7.7110708
MRT Steel 15x7 23 10.4326252
MRT Steel 15x8 24 10.8862176
MRT Billet/Carbon Fiber 15x10 10 4.535924
MRT Steel 15x10 26 11.7934024
MSD Millenium Cast 16x7 20.3 9.20792572
MSR 190 Cast 17x7 18.2 8.25538168
MSR 197 Cast 20x7.5 38.3 17.37258892
MSW Type 11 Cast 15x7 18 8.1646632
MSW Type 11 Cast 17x7 21 9.5254404
MSW Type 11 Cast 17x8 23 10.4326252
MSW Type 11 Cast 18x8 25 11.33981
MSW Type 12 Cast 17x8 24 10.8862176
MSW Type 12 Cast 18x8 26.8 12.15627632
MSW Type 12 Cast 19x8 28.5 12.9273834
MSW Type 14 Cast 15x6.5 17.5 7.937867
MSW Type 14 Cast 17x7 21 9.5254404
MSW Type 14 Cast 17x8 22 9.9790328
MSW Type 14 Cast 18x8 24.5 11.1130138
MSW Type 15 Cast 15x6.5 17.5 7.937867
MSW Type 15 Cast 17x8 23.5 10.6594214
MSW Type 15 Cast 18x8 27 12.2469948
MSW Type 16 Cast 18x8 26 11.7934024
MSW Type 45 Cast 15x7 20 9.071848
MSW Type 55 Cast 15x7 22 9.9790328
Mugen GP Forged 17x7 15.2 6.89460448
Mugen GP Forged 17x7.5 15.8 7.16675992
Mugen GP Forged 17x8.5 16.5 7.4842746
Mugen GP Forged 18x7.5 17 7.7110708
Mugen M12 (made by OZ Racing) Cast 17x7 20 9.071848
Mugen M7 Forged/Spun (Brittle) 15x6 13 5.8967012
Mugen MF10 Forged 16x7 11 4.9895164
Mugen MF10 Forged 17x7.5 14 6.3502936
Mugen MF10 Forged 17x8.5 16 7.2574784
Mugen MF10L Forged 15x6.5 10.5 4.7627202
Mugen MF10L Forged 15x7 11 4.9895164
Mugen MF8 Forged 16x7 12 5.4431088
Mugen MR5 Forged/Spun 15x6 15 6.803886
Mugen MZ3x Cast 17x7 17.5 7.937867
Mugen NR Cast 15x6.5 16.8 7.62035232
Mugen RG Cast (soft) 15x6.5 10.5 4.7627202
Mugen RG Cast 16x7 13 5.8967012
Mugen RNR Cast (soft) 15x6.5 10.5 4.7627202
MVR Magnum Cast 19x8.5 24 10.8862176
Myrtle Shoot Cast 17x8 33 14.9685492
Nakayama RS 6 Speed Cast 17x7 19 8.6182556
Nakayama RS Mach 7 Cast 17x7 19.6 8.89041104
Nakayama RS Phantom GT-R Cast 17x7 19.3 8.75433332
Nakayama RS TS6 Cast 17x7 17.6 7.98322624
NAR Type II Cast 14x6.5 10.4 4.71736096
NEEZ BM7S Cast 17x7.5 17.2 7.80178928
NEEZ Euro Cross Cast 16x7.5 15 6.803886
Niche Bella Cast 17x7 25.5 11.5666062
Niche Bella Cast/Spun 19x8 30 13.607772
Niche E-tune Cast 17x8 25 11.33981
Niche Mecha Cast 18x7 25 11.33981
Niche Pultec Cast 18x7 25.5 11.5666062
Niche Pultec Cast 20x8.5 33.8 15.33142312
Niche Spitfire Cast 20x8.5 39.5 17.9168998
Niche Throttle Cast 17x7.5 24.8 11.24909152
Niche Venice Cast 19x10 32.6 14.78711224
Niche Venice Cast 19x8.5 32.2 14.60567528
Nippon Racing Advantispeed Cast 17x7 24 10.8862176
Nippon Racing Evolution Cast 17x7 21 9.5254404
Nippon Racing F2 Cast 15x6.5 12 5.4431088
Nippon Racing Formula 1 Cast 17x7 20.8 9.43472192
Nippon Racing Hyperspeed Cast 17x7 22.3 10.11511052
Nippon Racing Indy Cup Cast 17x7 22.3 10.11511052
Nippon Racing Intertouring Cup Cast 17x7 21 9.5254404
Nippon Racing Sassy Cast 17x7 22 9.9790328
Nippon Racing Scorpion Cast 17x7 21.2 9.61615888
Nippon Racing Taiko Cast 17x7 22.4 10.16046976
Nippon Racing Type C Cast 15x6.5 13 5.8967012
Nippon Racing Version 2 Cast 17x7 21.8 9.88831432
Nippon Racing Version 5 Cast 17x7 22.8 10.34190672
Nippon Racing Version 5 Cast 18x8 26.5 12.0201986
Nippon Racing Wishbone Cast 17x7 23 10.4326252
Nippon Racing Zen Cast 15x6.5 13.4 6.07813816
Nismo LM GT Magnesium Forged Mg 18x10 17.1 7.75643004
Nismo LM GT4 Forged 18x8.5 18.1 8.21002244
Nismo LM GT4 Forged 18x9.5 19 8.6182556
Nismo LM GT4 Forged 19x8.5 20.4 9.25328496
Nismo LM GT4 Forged 19x9.5 20.7 9.38936268
Nissan 200SX 84 Cast 14x5.5 15 6.803886
Nissan 200SX 84-87 Cast 15x6 19 8.6182556
Nissan 200SX Turbo 85-86 Cast 15x6 19 8.6182556
Nissan 240SX 89-90 Cast 15x6 16 7.2574784
Nissan 240SX 91-94 Cast 15x6 18 8.1646632
Nissan 240SX 95-96 Cast 15x6 15 6.803886
Nissan 240SX 95-98 LE and SE Cast 16x6.5 18.5 8.3914594
Nissan 300ZX 84-85 Cast 15x6.5 19 8.6182556
Nissan 300ZX NA and TT front Cast 16x7.5 19 8.6182556
Nissan Altima 93-97 Cast 15x6 17 7.7110708
Nissan Altima 98-01 Cast 16x6 18 8.1646632
Nissan Maxima 85-86 Cast 15x6 20 9.071848
Nissan Maxima 87-88 Cast 15x6 17 7.7110708
Nissan Maxima 95-99 GLE Cast 15x6.5 16.5 7.4842746
Nissan Maxima 95-99 SE Cast 16x6.5 19.6 8.89041104
Nissan Sentra SE + SE-R 01-02 Cast 16x6 18 8.1646632
Nissan Sentra SE-R Spec V 02 Cast 17x7 24 10.8862176
Nissan Skyline GTR 89-94 Forged 16x8 16 7.2574784
Nissan Stanza 90-92 Cast 14x6 15 6.803886
NZO 050 Cast 16x6.5 12.8 5.80598272
NZO 213 Cast 18x7.5 27 12.2469948
NZO 214 Hyper Cast 18x7.5 28 12.7005872
Oettinger RE Cast 18x8 24.8 11.24909152
Oettinger RZ Cast 18x8 29.6 13.42633504
Omni Concept GT Champion Cast 20x9.5 29.3 13.29025732
OZ 35th Anniverary Cast 15x6.5 19 8.6182556
OZ 35th Anniverary Cast 16x7 22 9.9790328
OZ 35th Anniverary Cast 17x7 24 10.8862176
OZ 35th Anniverary Cast 17x8 27 12.2469948
OZ 35th Anniverary Cast 18x8 29.1 13.19953884
OZ Alleggertia HLT Cast 17x7 14 6.3502936
OZ Antares Cast 18x8 25 11.33981
OZ Botticelli Cast 17x8 21.5 9.7522366
OZ Botticelli Cast 18x8 22.2 10.06975128
OZ Botticelli Cast 18x9 23 10.4326252
OZ Canova Cast 15x7 19.2 8.70897408
OZ Canova Cast 16x7 21.5 9.7522366
OZ Canova Cast 17x7 25.5 11.5666062
OZ Canova Cast 17x8 26 11.7934024
OZ Canova Cast 18x7 27 12.2469948
OZ Canova Cast 18x8 28.4 12.88202416
OZ Canova Cast 19x8 29.5 13.3809758
OZ Canyon II Cast/Spun 18x8 30.9 14.01600516
OZ Carvagio Cast 16x7 23 10.4326252
OZ Carvagio Cast 17x7 25.5 11.5666062
OZ Carvagio Cast 17x8 27 12.2469948
OZ Carvagio Cast 18x8 29.5 13.3809758
OZ Carvagio Cast 19x8 34 15.4221416
OZ Competition Cast 17x8.5 30 13.607772
OZ Crono EVO Cast 17x7 19 8.6182556
OZ Crono EVO Cast 18x8 20 9.071848
OZ Crono HLT Cast 19x8 21 9.5254404
OZ Crono HT Cast 15x7 13.5 6.1234974
OZ Crono HT Cast 16x7 15.7 7.12140068
OZ Crono HT Cast 17x7 18 8.1646632
OZ Crono HT Cast 18x8 18.8 8.52753712
OZ F1 Cup Cast 16x7 22 9.9790328
OZ F1 Cup Cast 17x7 25 11.33981
OZ F1 Cup Cast 18x8 25.3 11.47588772
OZ F1 Plus Cast 17x7.5 26 11.7934024
OZ Forgiata Forged 17x7.5 13.2 5.98741968
OZ Forgiata Forged 18x8.5 16.5 7.4842746
OZ Galileo III Cast/Spun 18x8 28 12.7005872
OZ Galileo III Cast/Spun 18x8.5 30 13.607772
OZ Galileo III Cast/Spun 19x10 30.7 13.92528668
OZ Galileo III Cast/Spun 19x8 28.6 12.97274264
OZ Galileo III Cast/Spun 19x8.5 29.6 13.42633504
OZ Giotti II Cast/Spun 19x10 35.5 16.1025302
OZ Giotti II Cast/Spun 19x8.5 33.2 15.05926768
OZ Hydra Cast 15x7 20.6 9.34400344
OZ Hydra Cast 17x7 23 10.4326252
OZ Hydra Cast 17x8 25 11.33981
OZ Leonardo III Cast/Spun 19x8.5 32.4 14.69639376
OZ Leonardo III Cast/Spun 19x9.5 32 14.5149568
OZ Michelangelo 10 Cast 17x7.5 28 12.7005872
OZ Michelangelo 8 Cast 15x6.5 20.5 9.2986442
OZ Michelangelo 8 Cast 16x7 23.8 10.79549912
OZ Michelangelo 8 Cast 17x7 26 11.7934024
OZ Michelangelo II Cast/Spun 18x8.5 32.5 14.741753
OZ Michelangelo II Cast/Spun 19x9.5 37.2 16.87363728
OZ Mito Modular Cast 17x7 27 12.2469948
OZ Opera EVO Cast 18x8 26 11.7934024
OZ Palladio Cast 17x7.5 22.5 10.205829
OZ Palladio Cast 18x8 25.5 11.5666062
OZ Palladio Cast 19x8 27.5 12.473791
OZ Prodrive P1 Cast 17x7 20.4 9.25328496
OZ Racing F1 Cast 15x7 19.8 8.98112952
OZ Raffaello III Cast/Spun 19x8 26 11.7934024
OZ Raffaello III Cast/Spun 19x9.5 27.2 12.33771328
OZ Record Cast 15x6.5 19.4 8.79969256
OZ Record Cast 16x7 21 9.5254404
OZ Record Cast 17x7 21.2 9.61615888
OZ Record Cast 17x7.5 22.2 10.06975128
OZ Record Cast 18x7 22.5 10.205829
OZ Record Cast 18x7.5 24 10.8862176
OZ Salina Cast 18x8 28 12.7005872
OZ Sardegna Cast 18x8 29 13.1541796
OZ Sardegna Cast 19x8 31 14.0613644
OZ Sardegna Cast 19x9 34 15.4221416
OZ Superleggera Cast 15x7 11.5 5.2163126
OZ Superleggera Cast 16x7 14.6 6.62244904
OZ Superleggera Cast 17x7 15.2 6.89460448
OZ Superleggera Cast 17x8 15.9 7.21211916
OZ Superleggera Cast 18x8 17.6 7.98322624
OZ Superleggera Forged 19x8 21.5 9.7522366
OZ Superleggera III Forged/Spun 18x8 24 10.8862176
OZ Superleggera III Forged/Spun 18x8.5 24.7 11.20373228
OZ Superleggera III Forged/Spun 19x10 26.8 12.15627632
OZ Superleggera III Forged/Spun 19x8 24.7 11.20373228
OZ Superleggera III Forged/Spun 19x8.5 25.3 11.47588772
OZ Superleggera III Forged/Spun 19x9.5 27 12.2469948
OZ Superturismo Evolution Cast 17x7 18 8.1646632
OZ Superturismo GT Cast 15x6.5 18.5 8.3914594
OZ Superturismo GT Cast 16x7 19.6 8.89041104
OZ Superturismo GT Cast 17x7 20.7 9.38936268
OZ Superturismo GT Cast 17x7.5 21.5 9.7522366
OZ Superturismo GT Cast 17x8 23 10.4326252
OZ Superturismo GT Cast 18x8 25.2 11.43052848
OZ Superturismo GT Cast 19x8 26.7 12.11091708
OZ Superturismo WRC Cast 15x6.5 18.8 8.52753712
OZ Superturismo WRC Cast 16x7 21 9.5254404
OZ Superturismo WRC Cast 17x7 21.4 9.70687736
OZ Titan Cast 17x8 23.4 10.61406216
OZ Titan Cast 18x8 25.1 11.38516924
OZ Tribe EVO Cast 17x8 27.5 12.473791
OZ Tribe EVO Cast 18x7 27 12.2469948
OZ Tribe EVO Cast 18x8 29 13.1541796
OZ Ultraleggera Cast 15x7 12.4 5.62454576
OZ Ultraleggera Cast 16x7 14.5 6.5770898
OZ Ultraleggera Cast 17x7 16 7.2574784
OZ Ultraleggera Cast 17x8 17 7.7110708
OZ Ultraleggera Cast 18x7 17.6 7.98322624
OZ Ultraleggera Cast 18x8 18.6 8.43681864
OZ Ultraleggera Cast 18x9 19.2 8.70897408
OZ Ultraleggera Cast 19x8 20.6 9.34400344
OZ Vela Cast/Spun 18x8 24.5 11.1130138
OZ Vela Cast/Spun 18x9 25.3 11.47588772
OZ Volcano Cast 16x7 23 10.4326252
OZ Volcano Cast 18x8 26.3 11.92948012
Palo Uber Signature Forged 17x7 15 6.803886
Palo Uber Signature Forged 18x7.5 16 7.2574784
Palo Uber Web Cast 17x7 20.5 9.2986442
Panasport C8 Cast/Spun 13x9 10.5 4.7627202
Panasport FC Cast 14x6 14 6.3502936
Panasport FC Cast 16x7 17 7.7110708
Panasport FS Cast 13x6 10 4.535924
Panasport FS Cast 15x6 15 6.803886
Panasport FS Lite Cast 13x6 9.5 4.3091278
Panasport FS Lite Cast 13x7 10 4.535924
Panasport Pro Rallye Cast 14x6 14.5 6.5770898
Panasport ULW Cast 13x6 13.5 6.1234974
Panasport ULW Cast 14x6 14.1 6.39565284
Panasport ULW Cast 15x7 16 7.2574784
Panasport ULW Cast 16x7 17 7.7110708
Panther EMR151 Cast 16x7.5 20.8 9.43472192
Panther EMR175 Cast 17x7 24.5 11.1130138
Panther EMR200 Cast 17x7 22.3 10.11511052
Panther EMR219 Cast 18x7.5 21.6 9.79759584
Panther EMR220 Cast 18x7 25 11.33981
Paradyme F206 Cast 17x7.5 23 10.4326252
Paradyme F220 Cast 18x7.5 25.8 11.70268392
Paulsen Racing 13x5.5 17 7.7110708
PCW Panther Cast 17x7.5 23 10.4326252
PCW Panther Cast 18x8 29.3 13.29025732
Performance Industries (race only) 13x7 15 6.803886
Performance Specialties Superlite Cast 13x6 13 5.8967012
Peugeot 205GTI - Speedline Cast 15x6 19.6 8.89041104
Peugeot 205GTI - Speedline SL201 Cast 14x5.5 15.4 6.98532296
PIAA FR-7 Cast/Spun 15x5 10.4 4.71736096
PIAA FR-7 Cast/Spun 15x6.5 12.2 5.53382728
PIAA FR-7 Cast/Spun 16x7 15.6 7.07604144
PIAA FR-7 Cast/Spun 17x7.5 18 8.1646632
PIAA FR-7 Cast/Spun 17x8 18.5 8.3914594
PIAA FR-S Cast 17x7 21 9.5254404
PIAA FR-S Cast 18x7.5 23 10.4326252
PIAA FR-S Cast 18x9.5 29 13.1541796
PIAA Sport Mesh Cast 17x7 21 9.5254404
PIAA Sport Mesh Cast 17x8 23 10.4326252
PIAA Sport Mesh Cast 18x7.5 23.4 10.61406216
PIAA Sport Mesh Cast 18x8.5 26 11.7934024
PIAA Sport Mesh Cast 18x9.5 29 13.1541796
PIAA Super Rozza Cast/Spun 18x7.5 22 9.9790328
PIAA Super Rozza Cast/Spun 18x8 23 10.4326252
PIAA Super Rozza Cast/Spun 19x10 26 11.7934024
PIAA Super Rozza Cast/Spun 19x7.5 23.2 10.52334368
PIAA Super Rozza Cast/Spun 19x8 24 10.8862176
PIAA Super Rozza Cast/Spun 19x8.5 25 11.33981
PIAA Super Rozza Cast/Spun 19x9 25 11.33981
PIAA Super Rozza Cast/Spun 20x10 27.5 12.473791
PIAA Super Rozza Cast/Spun 20x8.5 26 11.7934024
PIAA Super Rozza Cast/Spun 20x9 27 12.2469948
PIAA Super Rozza Monoblock Cast 18x8 23 10.4326252
PIAA Super Rozza Monoblock Cast 19x8 24 10.8862176
Platinum FX-2 Cast 18x7 25 11.33981
Platinum Koge Cast 17x7 24.5 11.1130138
Platinum Krees (Type 143) Cast 20x8.5 35 15.875734
Platinum Stinger (Type 141) Cast 20x8.5 41 18.5972884
Polo Monarch Cast 20x8.5 39 17.6901036
Polo Tornado Cast 17x7.5 33 14.9685492
Polo Warlock Cast 17x7.5 35 15.875734
Porsche 911 Fuchs Forged 16x6 17 7.7110708
Porsche 911 Fuchs Forged 16x7 18 8.1646632
Porsche 911 Fuchs Forged 16x8 19 8.6182556
Porsche 911 Fuchs Forged 16x9 20 9.071848
Porsche 914 6-cylinder 5-bolt Mahle (rare) Forged Mg 15x5.5 10 4.535924
Porsche 928CS Forged 16x8 19 8.6182556
Porsche 944 Turbo S/951S Design 90 ""Clubsport"" Forged 16x7 18.5 8.3914594
Porsche 944 Turbo S/951S Design 90 ""Clubsport"" Forged 16x9 20 9.071848
Porsche 944 Turbo/951 ""Flat Dish"" Forged 16x7 18.5 8.3914594
Porsche 944 Turbo/951 ""Flat Dish"" Forged 16x8 20 9.071848
Porsche 944 Turbo/951 ""Phone Dial"" Cast 16x7 18.5 8.3914594
Porsche 944 Turbo/951 ""Phone Dial"" Cast 16x8 20 9.071848
Porsche 944 Turbo/951 ""Phone Dial"" - Optional Cast Mg 16x8 16.1 7.30283764
Porsche 944 Turbo/951 ""Phone Dial"" - Optional Cast Mg 16x9 16.5 7.4842746
Porsche 944 Turbo/951 Fuchs Forged 16x7 15 6.803886
Porsche 944 Turbo/951 Fuchs Forged 16x8 16 7.2574784
Porsche 944S2 Cast 16x7 18.7 8.48217788
Porsche 944S2 Cast 16x8 22 9.9790328
Porsche 968 Cast 17x7.5 20 9.071848
Porsche 968 Cast 17x9 23 10.4326252
Porsche 993 Cast 17x7.5 18 8.1646632
Porsche 993 Cast 17x9 19.5 8.8450518
Porsche 996 Cast 17x7 19.1 8.66361484
Porsche 996 Cast 17x9 22.3 10.11511052
Porsche 996 Cast 18x10 23.4 10.61406216
Porsche 996 Cast 18x8 20 9.071848
Porsche Boxter Cast 17x7 20.3 9.20792572
Porsche Boxter Cast 17x8.5 22.7 10.29654748
Porsche Carrera S 987/997 Cast 19x8 22.3 10.11511052
Porsche Carrera S 987/997 Cast 19x9.5 24.7 11.20373228
Porsche Cayenne S Cast 20x8.5 31 14.0613644
Porsche Club Sports Cast 16x7 19 8.6182556
Porsche Club Sports Cast 16x9 21.5 9.7522366
Porsche Cup Cast 18x10 29.3 13.29025732
Porsche Cup Cast 18x8 26.2 11.88412088
Power Racing VS-01 Cast 17x7 19.5 8.8450518
Power Racing VS-01 Cast 18x7.5 20.5 9.2986442
Power Racing VS-04 Cast 15x6.5 12.3 5.57918652
Power Racing VS-04 Cast 16x7 14.3 6.48637132
Power Racing VS-04 Cast 17x7 16.5 7.4842746
Power Racing VS-05 Cast 17x7 22.5 10.205829
Primax 618 Tuner Cast 17x7 22.5 10.205829
Primax 684 Cast 15x7 18 8.1646632
ProDrive GC-010 Forged 18x8 19 8.6182556
ProDrive GC-05F Forged 18x8 18.3 8.30074092
ProDrive GC-07C Forged 17x7.5 15.2 6.89460448
ProDrive GC-07C Forged 18x9.5 18.2 8.25538168
ProDrive GC-10E Forged 17x7.5 15.2 6.89460448
ProDrive GT1 Cast 17x8.5 20.4 9.25328496
ProDrive P1 Cast 17x7 22 9.9790328
ProDrive P1 Cast 18x7.5 23.4 10.61406216
ProDrive P7 Cast 17x7 22.4 10.16046976
Progressive Pro 293 Cast 16x7 24 10.8862176
Proline B700 Cast 16x6.5 18.6 8.43681864
Proline B700 Cast 16x7.5 19.8 8.98112952
Proline B700 Cast 17x7.5 21.6 9.79759584
Proline B800 Cast 14x6 13.668644 6.2
Proline B800 Cast 15x6.5 14.991416 6.8
Proline B800 Cast 16x6.5 16.314188 7.4
Proline B800 Cast 16x7 18.077884 8.2
Proline B800 Cast 17x7.5 21.384814 9.7
Proline B900 Cast 15x6.5 16.314188 7.4
Proline B900 Cast 16x7 18.518808 8.4
Proline B900/s Cast 16x7 20.502966 9.3
Proline PB Cast 17x8 24.25082 11
Proline PB Cast 18x8 27.337288 12.4
Proline PCC Cast 14x6 14.109568 6.4
Proline PCC Cast 15x7 18.077884 8.2
Proline PCC Cast 16x7.5 20.723428 9.4
Proline PCC Cast 17x8 24.912206 11.3
Proline PD Cast 16x7.5 19.621118 8.9
Proline PE Cast 17x8 25.35313 11.5
Proline PE Cast 17x9 27.998674 12.7
Proline PE Cast 18x9 29.982832 13.6
Proline PF Cast 14x6 15.652802 7.1
Proline PF Cast 15x7 18.73927 8.5
Proline PF Cast 16x7.5 22.487124 10.2
Proline PG Cast 16x7 20.723428 9.4
Proline PG Cast 17x7.5 23.809896 10.8
Proline PG Cast 18x8 26.675902 12.1
Proline PG Cast 20x9 32.407914 14.7
Proline PI Cast 17x7.5 23.14851 10.5
Proline PI Cast 18x8 25.35313 11.5
Proline PI Cast 19x8.5 29.541908 13.4
Proline PJ Cast 16x7 23.368972 10.6
Proline PJ Cast 17x7 26.675902 12.1
Proline PJ Cast 17x8 27.55775 12.5
Proline PJ Cast 18x8 29.321446 13.3
Proline PJ Cast 18x9.5 32.187452 14.6
Proline PJ Cast 19x8.5 35.053458 15.9
Proline PK Cast 16x7.5 19.84158 9
Proline PK Cast 17x7.5 22.0462 10
Proline PK Cast 18x8 24.25082 11
Proline PK Cast 19x8.5 28.66006 13
Proline PL Cast 15x6.5 17.196036 7.8
Proline PL Cast 16x7.5 20.94389 9.5
Proline PL Cast 17x7 22.0462 10
Proline PL Cast 17x7.5 23.809896 10.8
Proline PL Cast 17x8 24.25082 11
Proline PL Cast 18x8 27.55775 12.5
Proline PM Cast 16x7 20.502966 9.3
Proline PM Cast 17x7.5 25.35313 11.5
Proline PM Cast 18x8 27.55775 12.5
Proline PP Cast 18x8 28.219136 12.8
Proline PP Cast 19x8.5 28.66006 13
Proline PQ Cast 15x6.5 17.857422 8.1
Proline PQ Cast 16x7.5 19.180194 8.7
Proline PR Cast 17x7.5 22.0462 10
Proline PR Cast 18x8 25.132668 11.4
Proline PR Cast 19x8.5 29.321446 13.3
Proline PS Cast 17x7 26.45544 12
Proline PS Cast 18x8 28.66006 13
Proline PS Cast 19x8.5 30.86468 14
Proline PU Cast 15x6.5 15.43234 7
Proline PU Cast 16x7 18.518808 8.4
Proline PU Cast 17x7 20.723428 9.4
Proline PU Cast 17x8 22.928048 10.4
Proline PU Cast 18x8 26.234978 11.9
Proline PV Cast 14x6 13.22772 6
Proline PV Cast 15x6.5 14.33003 6.5
Proline PV Cast 16x6.5 15.211878 6.9
Proline PV Cast 16x7 17.63696 8
Proline PV Cast 17x7 17.196036 7.8
Proline PV Cast 18x7.5 21.605276 9.8
Proline PV/s Cast 17x8 23.14851 10.5
Proline PW Cast 16x7 20.723428 9.4
Proline PY Cast 15x7 19.84158 9
Proline PY Cast 16x7 24.25082 11
Proline PY Cast 17x7 26.45544 12
Proline PY Cast 17x8 27.55775 12.5
Proline PY Cast 18x7.5 29.76237 13.5
Proline PY Cast 18x8.5 30.86468 14
Proline PZ Cast 15x7 17.196036 7.8
Proline PZ Cast 16x7.5 21.384814 9.7
Proline PZ Cast 17x8 25.35313 11.5
PS Engineering Halibrand Replicas Cast 15x7 16 7.2574784
PS Engineering TA II Cast 15x7 16 7.2574784
Quantum Tek S-05 Cast 17x7.5 25.3 11.47588772
Quantum Tek S-05 Cast 18x7.5 29.3 13.29025732
Quantum Tek S-06 Cast 17x7.5 26 11.7934024
Quantum Tek S-07 Cast 18x7.5 28.5 12.9273834
Quantum Tek S-08 Cast 16x7 24 10.8862176
Quantum Tek S-10 Cast 15x7 18.5 8.3914594
Quantum Tek S-10 Cast 18x7.5 24.3 11.02229532
Quantum Tek S-11 Cast 16x7 19.5 8.8450518
Quantum Tek S-13 Cast 18x7.5 27 12.2469948
Quantum Tek S-14 Cast 18x7.5 22 9.9790328
Quantum Tek S-15 Cast 18x7.5 21.4 9.70687736
RAC Monolites RS110 Forged 16x7 11.3 5.12559412
RAC Monolites RS110 Forged 17x8 13.3 6.03277892
Race Inc RPK 133 C-Sport Cast 19x10 26.5 12.0201986
Race Inc RPK 133 C-Sport Cast 19x11.5 27.8 12.60986872
Race Inc RPK 133 C-Sport Cast 19x8.5 23.5 10.6594214
Raceline RL-7 Cast 15x7 19.8 8.98112952
Racing Beat RB-02 (made by Racing Hart) Cast/Spun 15x6.5 16 7.2574784
Racing Dynamics RGQ Cast 19x9.5 29.5 13.3809758
Racing Dynamics RGS Cast 17x8 27 12.2469948
Racing Dynamics RS-2 Cast 19x10 25.5 11.5666062
Racing Dynamics RS-2 Cast 19x8 24 10.8862176
Racing Firrenze RF-Pro Forged 15x6.5 9.8 4.44520552
Racing Gear RG-6 Cast 15x6.5 12 5.4431088
Racing Gear RG-6 Cast 16x7 16 7.2574784
Racing Hart C2 Cast 18x10 24 10.8862176
Racing Hart C2 Cast 18x8.5 21.5 9.7522366
Racing Hart C4 1-piece Cast 18x7.5 24 10.8862176
Racing Hart C5 Cast 18x8.5 28 12.7005872
Racing Hart CP-035R Forged 15x6 7.9 3.58337996
Racing Hart CP-035R Forged 15x6.5 8.6 3.90089464
Racing Hart CP-035R Forged 15x7 9.4 4.26376856
Racing Hart CP-035R Forged 15x7.5 9.7 4.39984628
Racing Hart CP-035R Forged 16x7 10.8 4.89879792
Racing Hart CP-035R Forged 16x7.5 11.2 5.08023488
Racing Hart CP-035R Forged 16x8 11.5 5.2163126
Racing Hart CP-035R Forged 17x7.5 13 5.8967012
Racing Hart CP-035R Forged 17x8 13.6 6.16885664
Racing Hart CP-035R Forged 17x8.5 14.4 6.53173056
Racing Hart CP-035R Forged 17x9 15 6.803886
Racing Hart CP-035R Forged 17x9.5 15.2 6.89460448
Racing Hart CP-035R Forged 18x7.5 19.7 8.93577028
Racing Hart CP-035R Forged 18x8.5 20.2 9.16256648
Racing Hart CP10 Forged 18x8 18 8.1646632
Racing Hart CP8 Forged 17x7 17 7.7110708
Racing Hart CP-F Forged 15x6.5 10.5 4.7627202
Racing Hart CP-S10 Cast 18x8.5 22.1 10.02439204
Racing Hart Evolution Cast 18x7.5 20.8 9.43472192
Racing Hart Evolution S7 EVO Cast 18x7.5 22.2 10.06975128
Racing Hart Evolution Z5000 Cast 19x7.5 23.3 10.56870292
Racing Hart Hyper Tuner Cast 16x7 17 7.7110708
Racing Hart M5 Cast 19x10 28.5 12.9273834
Racing Hart M6 Cast 18x7.5 26.3 11.92948012
Racing Hart Project 521 Cast/Spun 18x9 19.9 9.02648876
Racing Hart S7 Cast 17x7 19 8.6182556
Racing Hart Tracer Cast 17x10 18 8.1646632
Racing Hart Tuner Cast 15x6.5 15 6.803886
Racing Hart TypeC Cast 17x9.5 21 9.5254404
Racing Sparco Cromodora Cast 16x7 20.5 9.2986442
Racing Sparco D-Spec Stage I Cast 17x7 21 9.5254404
Racing Sparco LE Forged 16x7 11.7 5.30703108
Racing Sparco LE Forged 17x8 14.6 6.62244904
Racing Sparco NS-II Python Cast 17x7 22 9.9790328
Racing Sparco NT Cast 18x8 26 11.7934024
Racing Sparco NT-R Cast 17x7 15.4 6.98532296
Racing Sparco NT-R Cast 17x8 16.7 7.57499308
Racing Sparco NT-R Cast 17x9 17.2 7.80178928
Racing Sparco Viper R (Japan Only) Forged/Spun 15x6.5 9 4.0823316
Racing Sparco Viper R (Japan Only) Forged/Spun 16x7 11.2 5.08023488
Racing Sparco Viper R (Japan Only) Forged/Spun 17x7 13.7 6.21421588
Racing Sparco Viper R (Japan Only) Forged/Spun 18x8.5 16.3 7.39355612
Rage 10 Cast 15x6.5 16 7.2574784
Rage Breaker Cast 17x7 19 8.6182556
Rage Enduro Cast 17x7 21 9.5254404
Rage Motif Cast 17x7 19.8 8.98112952
Rage Split Cast 17x7 21.8 9.88831432
Rage Vigor Cast 16x7 17.8 8.07394472
Rage Vulcan Cast 18x8 26.5 12.0201986
Raptor Racing GX-T Cast 17x7 24 10.8862176
Raptor Racing MZ-1 Cast 17x7 25.6 11.61196544
Rays Master Pieces DIA 106 Cast/Spun 19x8 31 14.0613644
Rays Master Pieces DIA 106 Cast/Spun 19x9.5 31.5 14.2881606
Raze R24 Cast 17x7 20 9.071848
Raze R74 Cast 17x7 19 8.6182556
RD Sport C4 Cast 19x8.5 24.8 11.24909152
RD Sport RS-4 Cast 19x9.5 27.5 12.473791
RD Sport S4 Cast 19x10 27.3 12.38307252
Real Racing Cast 13x7 10.4 4.71736096
Real Racing Cast 15x7 12.7 5.76062348
Real Racing R-5 Cast 17x7 18 8.1646632
Renault Alpine GTA Cast 15x6 14 6.3502936
Renault Alpine GTA Cast 15x8.5 17 7.7110708
Renntech RS118 Forged 19x9 23 10.4326252
Revolution ""ScoobySport"" Cast 17x7 18.7 8.48217788
Revolution Classic 4-Spoke Race Cast 13x5.5 8.8 3.99161312
Revolution Classic 4-Spoke Race Cast 13x6 11 4.9895164
Revolution Classic 4-Spoke Race Cast 13x7 10.2 4.62664248
Revolution Classic 5-Spoke Race Cast 15x7 16.8 7.62035232
Revolution Classic 5-Spoke Race Cast 15x7 18.1 8.21002244
Revolution Classic 5-Spoke Race Cast 15x8 16 7.2574784
Revolution RFX Race Cast 13x6 11.5 5.2163126
Revolution RFX Race Cast 14x6 11.8 5.35239032
Revolution RFX Race Cast 14x7 12.5 5.669905
Revolution RFX Race Cast 15x7 15.3 6.93996372
Revolution RFX Race Cast 16x7 17.8 8.07394472
Revolution RFX Rally Cast 15x6 18.3 8.30074092
Revolution RFX Rally Cast 15x7 18.8 8.52753712
Revolution RFX Road Cast 16x7 20.3 9.20792572
Revolution RZX Race Cast 17x7 18.3 8.30074092
Revolution RZX Rally Cast 17x7 22.5 10.205829
Revolution RZX Road Cast 17x7.5 22.5 10.205829
Rial Bari Cast 17x8 23 10.4326252
Rial Campo Cast 15x6.5 17 7.7110708
Rial Como Cast 15x7 18.4 8.34610016
Rial Como Cast 16x7 20.2 9.16256648
Rial Como Cast 17x7.5 22.8 10.34190672
Rial Como Cast 18x8 26 11.7934024
Rial DF Cast 17x8 24.5 11.1130138
Rial Flair Cast 16x6 20 9.071848
Rial Monza Cast 17x7.5 22.3 10.11511052
Rial MS Cast 15x7 17.2 7.80178928
Rial Nogaro Cast 17x8 21.5 9.7522366
Rial Nogaro Cast 18x8 23.5 10.6594214
Rial Nogaro Cast 19x8 25.4 11.52124696
Rial Porto Cast 16x7 20.5 9.2986442
Rial Porto Cast 17x7.5 22.5 10.205829
Rial Porto Cast 18x8 26.6 12.06555784
Rial Ravenna Cast 16x7.5 22 9.9790328
Rial Ravenna Cast 17x8 25 11.33981
Rial Viper D70 Cast 15x7 17 7.7110708
Rial Viper D70 Cast 17x7.5 26.5 12.0201986
Riverside Trafficstar DTM Cast 19x9 27.8 12.60986872
Riverside Trafficstar DTS Cast 19x10 28.4 12.88202416
Ro_Ja Formula 5 Forged 17x7 14.5 6.5770898
Ro_Ja Formula 5 Forged 18x7 18 8.1646632
Ro_Ja Formula 5 Forged 18x8 19 8.6182556
Ro_Ja Formula 5 Forged 18x9 20 9.071848
Ro_Ja Formula 5 Forged 19x8 22 9.9790328
Ro_Ja Formula 5 Forged 19x9 24 10.8862176
Ro_Ja GT-M Cast 18x8 27 12.2469948
Ro_Ja Kruzz Cast 19x8 26.2 11.88412088
Ro_Ja Neo5 Cast 19x8 26.2 11.88412088
Ro_Ja R2-5 Cast 18x10 23.4 10.61406216
Ro_Ja R2-5 Cast 18x7.5 22.8 10.34190672
Ro_Ja R2-5 Cast 18x8 23.1 10.47798444
Ro_Ja R2-5 Cast 19x10.5 28 12.7005872
Ro_Ja R2-5 Cast 19x8.5 26.7 12.11091708
Ro_Ja R2-5 Cast 19x9.5 27.1 12.29235404
Ro_Ja R2-7 Cast 18x10 24.9 11.29445076
Ro_Ja R2-7 Cast 18x7.5 23.2 10.52334368
Ro_Ja R2-7 Cast 18x8 23.8 10.79549912
Ro_Ja R2-7 Cast 18x8.5 24.2 10.97693608
Ro_Ja R2-7 Cast 18x9 24.3 11.02229532
Ro_Ja R2-7 Cast 19x10 28.5 12.9273834
Ro_Ja R2-7 Cast 19x8.5 27.1 12.29235404
Ro_Ja R2-7 Cast 19x9 27.8 12.60986872
ROH Adrenaline Cast 17x7 23.1 10.47798444
ROH Adrenaline Cast 17x8 24.2 10.97693608
ROH Adrenaline Cast 18x7 25.6 11.61196544
ROH Astron Cast 17x7.5 23.3 10.56870292
ROH Azzurro Cast 18x8 28.5 12.9273834
ROH Blade Cast 17x7 25 11.33981
ROH Illusion Cast 16x7 25 11.33981
ROH Reflex Cast 16x7 15.5 7.0306822
ROH Reflex Cast 17x7.5 23.5 10.6594214
ROH Snyper Cast 15x7 15 6.803886
ROH Snyper Cast 16x8 19 8.6182556
ROH Snyper Cast 17x9 26 11.7934024
ROH ZS Cast 17x8.5 23 10.4326252
ROH ZS Cast 17x9.5 28 12.7005872
Ronal ACT Cast 17x9.5 22 9.9790328
Ronal Bear Cast 14x6 18.3 8.30074092
Ronal LS Cast 15x7.5 16.7 7.57499308
Ronal LV (Spider) Cast 15x7 15.9 7.21211916
Ronal LV (Spider) Cast 16x7.5 18.2 8.25538168
Ronal LV (Spider) Cast 17x8 21.4 9.70687736
Ronal LV (Spider) Cast 18x8.5 24.3 11.02229532
Ronal LW Cast 14x6 17.3 7.84714852
Ronal LW Cast 15x7.5 19 8.6182556
Ronal LZ (Eleganz) Cast 18x8.5 30.3 13.74384972
Ronal R-10 (Turbo) Cast 15x7 18 8.1646632
Ronal R-1001 Cast 17x8 22.5 10.205829
Ronal R-23 Cast 14x6 14.8 6.71316752
Ronal R-23 Cast 15x7 17.3 7.84714852
Ronal R-25 Cast 14x6 14.8 6.71316752
Ronal R-25 Cast 15x7 17.3 7.84714852
Ronal R-25 Cast 16x7.5 18.5 8.3914594
Ronal R-25 Cast 17x8 23.5 10.6594214
Ronal R-26 Cast 14x6 16.4 7.43891536
Ronal R-26 Cast 15x7 17.3 7.84714852
Ronal R-26 Cast 16x7.5 20.3 9.20792572
Ronal R-28 (Joker) Cast 14x6 16.4 7.43891536
Ronal R-28 (Joker) Cast 15x7 18.9 8.57289636
Ronal R-28 (Joker) Cast 16x7.5 24.1 10.93157684
Ronal R-28 (Joker) Cast 17x8.5 28.2 12.79130568
Ronal R-31 Cast 16x7 21.5 9.7522366
Ronal R-34 Cast 16x7.5 20.9 9.48008116
Ronal R-7 (Bulldog) Cast 17x7 25 11.33981
Ronal R-7 (Bulldog) Cast 18x8 27.8 12.60986872
Ronal RT (Twin) Cast 17x7.5 24.5 11.1130138
Ronal SL Cast 17x7.5 21.1 9.57079964
Ronal T-34 Cast 16x7.5 21 9.5254404
RonJon Devotion Forged 19x8.5 24 10.8862176
Rota Action Cast 17x7.5 17 7.7110708
Rota Attack Cast 15x6.5 13 5.8967012
Rota Attack Cast 17x7 16.5 7.4842746
Rota Auto X Cast 15x6.5 13 5.8967012
Rota Aztec Cast 15x6.5 16.4 7.43891536
Rota Aztec Cast 16x7 19 8.6182556
Rota Battle Cast 15x6.5 14 6.3502936
Rota Battle Cast 17x7.5 19 8.6182556
Rota Battle Cast 18x7.5 22 9.9790328
Rota Boost Cast 16x7 15.9 7.21211916
Rota Boost Cast 17x8 20 9.071848
Rota Boost Cast 18x9 23.5 10.6594214
Rota Circuit 10 Cast 15x6.5 13 5.8967012
Rota Circuit 10 Cast 16x7 17 7.7110708
Rota Circuit 10 Cast 17x7.5 20 9.071848
Rota Circuit 8 Cast 15x6.5 12 5.4431088
Rota Circuit 8 Cast 16x7 16 7.2574784
Rota Competition Cast 15x6.5 16.8 7.62035232
Rota Competition Cast 16x7 19.6 8.89041104
Rota D2 Cast 17x7.5 22.2 10.06975128
Rota Downshift Cast 17x7.5 19 8.6182556
Rota Flight Cast 15x6.5 13 5.8967012
Rota Formel Cast 16x7 17.7 8.02858548
Rota G-Force Cast 18x8 20 9.071848
Rota Grid Racing Cast 15x6.5 13 5.8967012
Rota Grid Racing Cast 16x7 15 6.803886
Rota Grid Racing Cast 17x7.5 18.5 8.3914594
Rota Group A Cast 17x7.5 19 8.6182556
Rota Group A Cast 18x7.5 21 9.5254404
Rota Group N Cast 15x6.5 12.5 5.669905
Rota GT-3 Cast 15x7 13.5 6.1234974
Rota GT-3 Cast 16x7 16.5 7.4842746
Rota J.SPL Cast 15x6.5 12.4 5.62454576
Rota J.SPL Cast 16x7 14 6.3502936
Rota J-MAG Cast 15x7 13 5.8967012
Rota Machspeed Cast 17x7.5 23 10.4326252
Rota Manta Cast 15x6.5 16.5 7.4842746
Rota Manta Cast 16x7 17.6 7.98322624
Rota MSR Cast 15x6.5 16.9 7.66571156
Rota MSR Cast 16x7 17.2 7.80178928
Rota N1R Cast 16x7 17.7 8.02858548
Rota P45F Cast 18x8.5 21.7 9.84295508
Rota P45M Cast 17x9 21 9.5254404
Rota RB Cast 15x7 14.4 6.53173056
Rota Retro Cast 15x6.5 14 6.3502936
Rota SDR Cast 17x7.5 16.5 7.4842746
Rota SDX Cast 17x7.5 16.5 7.4842746
Rota Slipstream Cast 15x6.5 11.9 5.39774956
Rota Slipstream Cast 15x7 12.9 5.85134196
Rota Slipstream Cast 15x7.5 13.7 6.21421588
Rota Slipstream Cast 15x8 14.7 6.66780828
Rota Slipstream Cast 16x7 13.9 6.30493436
Rota Slipstream Cast 17x7.5 19 8.6182556
Rota Slipstream Cast 17x8.5 21.1 9.57079964
Rota Speed 5 Cast 15x7 12.7 5.76062348
Rota Stage 5 Cast 15x6.5 17.6 7.98322624
Rota Stage 5 Cast 16x7 20.1 9.11720724
Rota Subzero Cast 15x6.5 12.9 5.85134196
Rota Subzero Cast 16x7 14.5 6.5770898
Rota Subzero Cast 17x7 16.5 7.4842746
Rota Subzero Cast 17x7.5 16.9 7.66571156
Rota Subzero Cast 18x7.5 19 8.6182556
Rota Tarmac Cast 17x7 19 8.6182556
Rota Tarmac 3 Cast 18x8 20.1 9.11720724
Rota Torque Cast 15x6.5 13 5.8967012
Rota Torque Cast 17x7 18 8.1646632
Rota Torque Cast 17x7.5 18.8 8.52753712
Rota Torque Cast 17x8 19 8.6182556
Rota Torque Cast 18x8 20 9.071848
Rota Track R Cast 16x7 16 7.2574784
Rota Tuner Cast 16x7 18 8.1646632
Rota Velo Cast 15x6.5 16.8 7.62035232
Rota Velo Cast 16x7 19.6 8.89041104
Rozest MF-02 Forged 17x7 13.7 6.21421588
RPM R-505 Cast 18x8 28 12.7005872
RPM R-505 Cast 19x9.5 30 13.607772
RS Limited Ricochet Cast 17x7 19.4 8.79969256
RS Limited S-Type Cast 18x7.5 28 12.7005872
RS Watanabe Forged Mg 19x8 16.5 7.4842746
RS Watanabe Cyclone Forged Mg 15x6.5 10.1 4.58128324
RS Watanabe Cyclone Forged Mg 15x7 10.4 4.71736096
RS Watanabe Cyclone Forged Mg 16x7 11.5 5.2163126
RS Watanabe Cyclone Forged Mg 16x8 12.3 5.57918652
RS Watanabe Cyclone Forged Mg 18x8 14.6 6.62244904
RS Watanabe Cyclone Forged Mg 18x9 16.1 7.30283764
RS Watanabe EightSpoke A Cast Mg 10x6 5.1 2.31332124
RS Watanabe EightSpoke A Cast 10x6 7.3 3.31122452
RS Watanabe EightSpoke A Cast 12x5.5 8.8 3.99161312
RS Watanabe EightSpoke A Cast Mg 12x6 6.8 3.08442832
RS Watanabe EightSpoke A Cast 12x6 9.7 4.39984628
RS Watanabe EightSpoke A Cast 13x6 11.2 5.08023488
RS Watanabe EightSpoke A Cast 13x6.5 11 4.9895164
RS Watanabe EightSpoke A Cast 13x7 11 4.9895164
RS Watanabe EightSpoke A Cast Mg 14x6 9 4.0823316
RS Watanabe EightSpoke A Cast 14x6 13 5.8967012
RS Watanabe EightSpoke A Cast Mg 14x6.5 9.3 4.21840932
RS Watanabe EightSpoke A Cast 14x6.5 13.2 5.98741968
RS Watanabe EightSpoke A Cast Mg 14x7 9 4.0823316
RS Watanabe EightSpoke A Cast 14x7 12.8 5.80598272
RS Watanabe EightSpoke A Cast Mg 14x7.5 9.9 4.49056476
RS Watanabe EightSpoke A Cast 14x7.5 13.6 6.16885664
RS Watanabe EightSpoke B Cast Mg 13x5 8.8 3.99161312
RS Watanabe EightSpoke B Cast 13x5 9.7 4.39984628
RS Watanabe EightSpoke B Cast Mg 13x5.5 9.3 4.21840932
RS Watanabe EightSpoke B Cast 13x5.5 10.4 4.71736096
RS Watanabe EightSpoke B Cast Mg 13x6 7.1 3.22050604
RS Watanabe EightSpoke B Cast 13x6 10.1 4.58128324
RS Watanabe EightSpoke B Cast Mg 13x6.5 7.7 3.49266148
RS Watanabe EightSpoke B Cast 13x6.5 11 4.9895164
RS Watanabe EightSpoke B Cast 13x7 11.2 5.08023488
RS Watanabe EightSpoke B Cast 13x7.5 10.7 4.85343868
RS Watanabe EightSpoke B Cast Mg 14x5.5 8.2 3.71945768
RS Watanabe EightSpoke B Cast 14x5.5 11.7 5.30703108
RS Watanabe EightSpoke B Cast Mg 14x6 8.4 3.81017616
RS Watanabe EightSpoke B Cast 14x6 12.1 5.48846804
RS Watanabe EightSpoke B Cast Mg 14x6.5 8.4 3.81017616
RS Watanabe EightSpoke B Cast 14x6.5 12.1 5.48846804
RS Watanabe EightSpoke B Cast Mg 14x7 8.6 3.90089464
RS Watanabe EightSpoke B Cast 14x7 12.3 5.57918652
RS Watanabe EightSpoke B Cast Mg 14x7.5 9.5 4.3091278
RS Watanabe EightSpoke B Cast 14x7.5 12.5 5.669905
RS Watanabe EightSpoke CVF Cast 13x5 9.7 4.39984628
RS Watanabe EightSpoke CVF Cast 13x5.5 9.9 4.49056476
RS Watanabe EightSpoke CVF Cast 13x6 11.2 5.08023488
RS Watanabe EightSpoke CVFP Cast 13x5 10.1 4.58128324
RS Watanabe EightSpoke CVFP Cast 13x5.5 10.4 4.71736096
RS Watanabe EightSpoke CVP Cast 13x5 10.4 4.71736096
RS Watanabe EightSpoke F8 Cast 12x5 9 4.0823316
RS Watanabe EightSpoke F8 Cast Mg 14x6 7.9 3.58337996
RS Watanabe EightSpoke F8 Cast 14x6 11.2 5.08023488
RS Watanabe EightSpoke F8 Cast Mg 14x6.5 8.4 3.81017616
RS Watanabe EightSpoke F8 Cast 14x6.5 12.1 5.48846804
RS Watanabe EightSpoke F8 Cast Mg 14x7 9.9 4.49056476
RS Watanabe EightSpoke F8 Cast 14x7 14.1 6.39565284
RS Watanabe EightSpoke F8 Cast Mg 15x6 10.6 4.80807944
RS Watanabe EightSpoke F8 Cast Mg 15x6.5 9.5 4.3091278
RS Watanabe EightSpoke F8 Cast Mg 15x7 10.1 4.58128324
RS Watanabe EightSpoke F8 Cast Mg 15x7.5 11 4.9895164
RS Watanabe EightSpoke F8 Cast Mg 16x8 13 5.8967012
RS Watanabe EightSpoke F8F Cast 12x4.5 9 4.0823316
RS Watanabe EightSpoke F8F Cast 13x4.5 10.4 4.71736096
RS Watanabe EightSpoke F8F Cast 14x5.5 14.1 6.39565284
RS Watanabe EightSpoke F8F Cast Mg 14x6 9.9 4.49056476
RS Watanabe EightSpoke F8F Cast 14x6.5 12.5 5.669905
RS Watanabe EightSpoke F8F Cast Mg 15x6 10.1 4.58128324
RS Watanabe EightSpoke F8F Cast 15x6 15 6.803886
RS Watanabe EightSpoke F8F Cast Mg 15x6.5 10.4 4.71736096
RS Watanabe EightSpoke F8F Cast 15x6.5 13.7 6.21421588
RS Watanabe EightSpoke F8F Cast Mg 15x7 11.2 5.08023488
RS Watanabe EightSpoke F8F Cast 15x7 14.6 6.62244904
RS Watanabe EightSpoke F8F Cast 15x7.5 15.9 7.21211916
RS Watanabe EightSpoke F8F Cast 15x8 16.1 7.30283764
RS Watanabe EightSpoke F8F Cast 15x8.5 20 9.071848
RS Watanabe EightSpoke F8F Cast 16x7 16.1 7.30283764
RS Watanabe EightSpoke F8F Cast 16x7.5 17.2 7.80178928
RS Watanabe EightSpoke F8F Cast 16x8 18.1 8.21002244
RS Watanabe EightSpoke F8F Cast 16x9 20.5 9.2986442
RS Watanabe EightSpoke F8FR (Rally) Cast 15x6.5 17.3 7.84714852
RS Watanabe EightSpoke F8FS Cast 14x6 13 5.8967012
RS Watanabe EightSpoke F8FS Cast 14x6.5 13.7 6.21421588
RS Watanabe EightSpoke F8FS Cast Mg 15x6 9.9 4.49056476
RS Watanabe EightSpoke F8FS Cast 15x6 14.6 6.62244904
RS Watanabe EightSpoke F8FS Cast Mg 15x6.5 10.6 4.80807944
RS Watanabe EightSpoke F8FS Cast 15x6.5 15.2 6.89460448
RS Watanabe EightSpoke F8FS Cast Mg 15x7 11.7 5.30703108
RS Watanabe EightSpoke F8FS Cast 15x7 16.5 7.4842746
RS Watanabe EightSpoke F8FS Cast 16x6.5 17.2 7.80178928
RS Watanabe EightSpoke F8FS Cast 16x7 18.1 8.21002244
RS Watanabe EightSpoke F8FS Cast 16x7.5 18.5 8.3914594
RS Watanabe EightSpoke F8FS Cast 16x8 19.2 8.70897408
RS Watanabe EightSpoke F8FS Cast 16x8.5 19.8 8.98112952
RS Watanabe EightSpoke F8FT Cast 14x6 12.6 5.71526424
RS Watanabe EightSpoke F8FT Cast 14x6.5 13.2 5.98741968
RS Watanabe EightSpoke F8FT Cast 16x6.5 16.3 7.39355612
RS Watanabe EightSpoke F8FT Cast 16x7 17.2 7.80178928
RS Watanabe EightSpoke F8FT Cast 16x7.5 17.6 7.98322624
RS Watanabe EightSpoke F8FT Cast 16x8 18.3 8.30074092
RS Watanabe EightSpoke F8-RST Cast Mg 15x6.5 9.9 4.49056476
RS Watanabe EightSpoke F8-RST Cast 15x6.5 14.1 6.39565284
RS Watanabe EightSpoke F8S Cast Mg 14x6 9 4.0823316
RS Watanabe EightSpoke F8S Cast Mg 14x6.5 9.5 4.3091278
RS Watanabe EightSpoke F8S Cast 16x7 16.5 7.4842746
RS Watanabe EightSpoke F8S Cast 16x7.5 17.6 7.98322624
RS Watanabe EightSpoke F8S Cast Mg 16x8 13.2 5.98741968
RS Watanabe EightSpoke F8S Cast 16x8 18.5 8.3914594
RS Watanabe EightSpoke F8S Cast 16x9 20.9 9.48008116
RS Watanabe EightSpoke F8T Cast Mg 14x6 8.8 3.99161312
RS Watanabe EightSpoke F8T Cast Mg 14x6.5 9.3 4.21840932
RS Watanabe EightSpoke F8T Cast 16x7 15.7 7.12140068
RS Watanabe EightSpoke F8T Cast 16x7.5 16.8 7.62035232
RS Watanabe EightSpoke F8T Cast Mg 16x8 12.6 5.71526424
RS Watanabe EightSpoke F8T Cast 16x8 17.6 7.98322624
RS Watanabe EightSpoke F8T Cast 16x8.5 20.8 9.43472192
RS Watanabe EightSpoke F8T Cast 16x9 20.3 9.20792572
RS Watanabe EightSpoke R Type Cast 13x10 16.2 7.34819688
RS Watanabe EightSpoke R Type Cast 13x8 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x8.5 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x9 14.6 6.62244904
RS Watanabe EightSpoke R Type Cast 13x9.5 15.2 6.89460448
RS Watanabe EightSpoke R Type Cast Mg 14x10 11 4.9895164
RS Watanabe EightSpoke R Type Cast 14x10 15.9 7.21211916
RS Watanabe EightSpoke R Type Cast Mg 14x10.5 11.2 5.08023488
RS Watanabe EightSpoke R Type Cast 14x10.5 16.1 7.30283764
RS Watanabe EightSpoke R Type Cast Mg 14x11 11.5 5.2163126
RS Watanabe EightSpoke R Type Cast 14x11 16.3 7.39355612
RS Watanabe EightSpoke R Type Cast Mg 14x11.5 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 14x11.5 16.5 7.4842746
RS Watanabe EightSpoke R Type Cast Mg 14x12 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 14x12 16.8 7.62035232
RS Watanabe EightSpoke R Type Cast Mg 14x8 10.6 4.80807944
RS Watanabe EightSpoke R Type Cast 14x8 15 6.803886
RS Watanabe EightSpoke R Type Cast Mg 14x8.5 10.6 4.80807944
RS Watanabe EightSpoke R Type Cast 14x8.5 15.2 6.89460448
RS Watanabe EightSpoke R Type Cast Mg 14x9 10.8 4.89879792
RS Watanabe EightSpoke R Type Cast 14x9 15.4 6.98532296
RS Watanabe EightSpoke R Type Cast Mg 14x9.5 11 4.9895164
RS Watanabe EightSpoke R Type Cast 14x9.5 15.7 7.12140068
RS Watanabe EightSpoke R Type Cast Mg 15x10 12.1 5.48846804
RS Watanabe EightSpoke R Type Cast 15x10 17.2 7.80178928
RS Watanabe EightSpoke R Type Cast Mg 15x10.5 12.3 5.57918652
RS Watanabe EightSpoke R Type Cast 15x10.5 17.6 7.98322624
RS Watanabe EightSpoke R Type Cast Mg 15x11 12.6 5.71526424
RS Watanabe EightSpoke R Type Cast 15x11 18.1 8.21002244
RS Watanabe EightSpoke R Type Cast Mg 15x11.5 13 5.8967012
RS Watanabe EightSpoke R Type Cast 15x11.5 18.5 8.3914594
RS Watanabe EightSpoke R Type Cast Mg 15x12 13.2 5.98741968
RS Watanabe EightSpoke R Type Cast 15x12 19 8.6182556
RS Watanabe EightSpoke R Type Cast 15x8 15.4 6.98532296
RS Watanabe EightSpoke R Type Cast Mg 15x8.5 11 4.9895164
RS Watanabe EightSpoke R Type Cast 15x8.5 15.9 7.21211916
RS Watanabe EightSpoke R Type Cast Mg 15x9 11.5 5.2163126
RS Watanabe EightSpoke R Type Cast 15x9 16.3 7.39355612
RS Watanabe EightSpoke R Type Cast Mg 15x9.5 11.7 5.30703108
RS Watanabe EightSpoke R Type Cast 15x9.5 16.8 7.62035232
RS Watanabe EightSpoke R Type Cast 16x8 16.5 7.4842746
RS Watanabe EightSpoke R Type Cast 16x8.5 17.2 7.80178928
RS Watanabe EightSpoke R Type Cast 16x9 17.9 8.11930396
RS Watanabe EightSpoke R Type Cast 16x9.5 18.5 8.3914594
RS Watanabe Forged Eight Forged 15x6.5 11.5 5.2163126
RS Watanabe Forged Eight Forged 15x7 12.1 5.48846804
RS Watanabe SMW Cast Mg 14x5 8.6 3.90089464
RS Watanabe SMW Cast Mg 14x5.5 9 4.0823316
RS Watanabe SMW Cast Mg 14x6 8.6 3.90089464
Ruf Cast 17x10 27.7 12.56450948
Ruf Cast 17x9 24.6 11.15837304
Ruf Carrera 4S (flat-faced) Cast 18x10 29.1 13.19953884
Ruf Carrera 4S (flat-faced) Cast 18x8.5 26.5 12.0201986
Ruff Racing R278 Cast 19x8.5 28 12.7005872
Ruff Racing R278 Cast 19x9.5 31 14.0613644
Ruff Racing R281 Cast 19x8.5 30 13.607772
Ruff Racing R281 Cast 19x9.5 34 15.4221416
Saturn ""Sawtooth"" 94-95 Cast 15x6 13.6 6.16885664
Schmidt TH-Line 2 Cast 16x8 20.2 9.16256648
Shaper Sunlight Cast 16x7.5 17.2 7.80178928
Shaper Twilight Cast 16x7.5 18.3 8.30074092
Shaper Twilight Cast 17x7.5 21.8 9.88831432
Shuk BS1 Cast 17x7.5 20.3 9.20792572
Shuk BS1 Cast 18x7.5 21.6 9.79759584
Shuk BS1 Cast 18x8.5 23 10.4326252
Shuk W21 Cast 17x7 19 8.6182556
Shuk W21 Cast 18x7.5 20.7 9.38936268
Shuk W21 Cast 18x8 21 9.5254404
Shuk W22 Cast 17x7 18.5 8.3914594
Shuk WR1 Cast 17x7 18.5 8.3914594
Simmons F-Series Cast 17x10 23.8 10.79549912
Simmons OM-Series Cast 18x9 26.5 12.0201986
SJ Racing Cross Forged 16x7 14.4 6.53173056
SJ Racing Cross Forged 17x8 18 8.1646632
SJ Racing Leggero Forged 15x7 11.3 5.12559412
SJ Racing Leggero Forged 16x7 12.9 5.85134196
SJ Racing Leggero Forged 16x8 14.7 6.66780828
SJ Racing Leggero Forged 17x8 17.1 7.75643004
SMC Type H Cast 17x7.5 28.6 12.97274264
Smith's Wheels Highlander Cast 18x9 28 12.7005872
Smith's Wheels Infinity Cast 17x7 23 10.4326252
Smith's Wheels Twister Cast 18x8 29.5 13.3809758
Speed Star D5R Cast 18x7.5 22.9 10.38726596
Speed Star D5R Cast 18x8 23.4 10.61406216
Speed Star D5R Cast 19x8 25.1 11.38516924
Speed Star SP1 Cast 19x7.5 22.9 10.38726596
Speed Star Zxpeed Cast 18x8 27 12.2469948
Speedline 2020 Cast Mg 15x7 16.3 7.39355612
Speedline 2020 Cast Mg 17x7.5 20.1 9.11720724
Speedline 2021 HTC Cast Mg 17x7.5 17.6 7.98322624
Speedline 2113 Cast 17x7 23.5 10.6594214
Speedline 2116 Cast 16x7 20.5 9.2986442
Speedline 2116 Cast 17x7 23.5 10.6594214
Speedline 2118 Racing 2000 Cast 15x6 18.3 8.30074092
Speedline 2118 Racing 2000 Cast 15x7 21.2 9.61615888
Speedline 2120 Turini Cast 15x6.5 16.8 7.62035232
Speedline 2120 Turini Cast 16x7 19.7 8.93577028
Speedline Competition Cast 18x8.5 24 10.8862176
Speedline Prodrive 7 Cast 17x7 22.5 10.205829
Speedline Race Cast 17x10 19 8.6182556
Speedline Routa/GT1 Lite Cast 18x7.5 18.5 8.3914594
Speedline Street Cast 17x10 25 11.33981
SpeedLite Racing Formula Cast 17x7 21.5 9.7522366
Speedmaster SM-046 Cast 15x6.5 11.4 5.17095336
Speedmaster SM-058 Cast 15x7 16 7.2574784
Speedmaster TR-05 Cast 17x7 17.6 7.98322624
Speedy Wheels Atix-5 Cast 17x7 18 8.1646632
Speedy Wheels Baltic Cast 17x7.5 22.3 10.11511052
Speedy Wheels G-Force Cast 20x8.5 35.3 16.01181172
Speedy Wheels Longchamp Cast 18x7.5 27.4 12.42843176
Speedy Wheels Nexxus Cast 18x7.5 25.3 11.47588772
Speedy Wheels Octopus Cast 17x7 18.8 8.52753712
Speedy Wheels Race Mode Cast 15x6.5 13.2 5.98741968
Speedy Wheels Race Mode Cast 16x7 16.1 7.30283764
Speedy Wheels Race Mode Cast 17x7 17.6 7.98322624
Speedy Wheels Sports-R Cast 15x6.5 13.9 6.30493436
Speedy Wheels Toskana Cast 17x7 24 10.8862176
Spoon Sports Forged 16x7 11.9 5.39774956
Spoon Sports Forged 16x8 12.9 5.85134196
Spoon Sports SW388 Forged 15x6.5 8.6 3.90089464
Sport Edition A7 Cast 15x6.5 17.5 7.937867
Sport Edition A7 Cast 17x7.5 24.4 11.06765456
Sport Edition A7 Cast 18x8 25.8 11.70268392
Sport Edition CD Cast 15x6.5 16 7.2574784
Sport Edition CD Cast 16x7.5 19 8.6182556
Sport Edition CD Cast 17x7.5 20.5 9.2986442
Sport Edition CD Cast 18x8 22 9.9790328
Sport Edition D3 Cast 15x6.5 15.5 7.0306822
Sport Edition D3 Cast 16x7 17 7.7110708
Sport Edition D3 Cast 17x7 20 9.071848
Sport Edition D4 Cast 16x7 16 7.2574784
Sport Edition D4 Cast 17x7 18 8.1646632
Sport Edition D5 Cast 16x7 17.6 7.98322624
Sport Edition D5 Cast 17x7 18.5 8.3914594
Sport Edition Daisy Cast 16x6.5 19.6 8.89041104
Sport Edition E1 Cast 16x7 19.5 8.8450518
Sport Edition E1 Cast 17x7 21.5 9.7522366
Sport Edition E1 Cast 18x8 23 10.4326252
Sport Edition E2 Cast 16x7 18.2 8.25538168
Sport Edition E2 Cast 17x7 21 9.5254404
Sport Edition E3 Cast 16x7 18.4 8.34610016
Sport Edition E3 Cast 17x7 20.8 9.43472192
Sport Edition Fox 10 Cast 16x7 17.5 7.937867
Sport Edition Fox 10 Cast 17x8 20.8 9.43472192
Sport Edition Fox 10 Cast 18x8 23 10.4326252
Sport Edition Fox 2 Cast 15x6.5 16 7.2574784
Sport Edition Fox 2 Cast 16x7 20.8 9.43472192
Sport Edition Fox 2 Cast 17x7 23 10.4326252
Sport Edition Fox 2 Cast 17x7.5 24 10.8862176
Sport Edition Fox 2 Cast 18x7.5 25 11.33981
Sport Edition Fox 3 Cast 15x6.5 19 8.6182556
Sport Edition Fox 3 Cast 16x6.5 20.3 9.20792572
Sport Edition Fox 3 Cast 17x7 23 10.4326252
Sport Edition Fox 5 Cast 15x6.5 18 8.1646632
Sport Edition Fox 5 Cast 16x7 21 9.5254404
Sport Edition Fox 5 Cast 18x8 23 10.4326252
Sport Edition Fox 6 Cast 16x7 18.8 8.52753712
Sport Edition Fox 6 Cast 17x7 21.5 9.7522366
Sport Edition Fox 6 Cast 17x7.5 22 9.9790328
Sport Edition Fox 7 Cast 16x7 19.5 8.8450518
Sport Edition Fox 7 Cast 17x7 21.5 9.7522366
Sport Edition Fox 7 Cast 17x7.5 22 9.9790328
Sport Edition KM11 Cast 17x8 23 10.4326252
Sport Edition KM11 Cast 18x8 24 10.8862176
Sport Edition KV5 Cast 17x8 22 9.9790328
Sport Edition KV5 Cast 18x8 23 10.4326252
Sport Edition KV5 Cast 19x8.5 27 12.2469948
Sport Edition KV5 Cast 19x9.5 27.5 12.473791
Sport Edition ST3 Cast 17x8 24.5 11.1130138
Sport Edition ST3 Cast 18x8 26.5 12.0201986
Sport Edition ST3 Cast 19x8.5 28.5 12.9273834
Sport Edition ST3 Cast 19x9.5 31 14.0613644
Sport Edition ST4 Cast 18x8 26.5 12.0201986
Sport Edition ST4 Cast 19x8.5 28 12.7005872
Sport Edition ST4 Cast 19x9.5 30.6 13.87992744
Sport Edition ST5 Cast 19x8.5 31.5 14.2881606
Sport Edition ST5 Cast 19x9.5 30 13.607772
Sport Edition Tekno Cast 17x7 23 10.4326252
Sport Edition Tekno Cast 18x8 25 11.33981
Sport Edition Tekno Cast 19x8 31.4 14.24280136
Sport Edition TK5 Cast 15x6.5 17 7.7110708
Sport Edition TK5 Cast 16x7 19 8.6182556
Sport Edition TK5 Cast 17x7 22 9.9790328
Sport Edition Valore Cast 15x6.5 18.5 8.3914594
Sport Edition Valore Cast 16x7 20 9.071848
Sport Tuning Blade Cast 17x7 21.5 9.7522366
Sport Tuning Blade Cast 18x7.5 24 10.8862176
Sport Tuning Flight Cast 17x8 20 9.071848
Sport Tuning Flight Cast 18x8 22 9.9790328
Sport Tuning Flight Cast 19x8 24.5 11.1130138
Sport Tuning Glide Cast 17x7 20.5 9.2986442
Sport Tuning Glide Cast 18x7.5 23.5 10.6594214
Sport Tuning Glide Cast 18x8 24.5 11.1130138
Sport Tuning Gunner Cast 17x7 19.5 8.8450518
Sport Tuning Gunner Cast 18x8 24 10.8862176
Sport Tuning Jet Cast 17x7 22 9.9790328
Sport Tuning Jet Cast 17x7.5 21.5 9.7522366
Sport Tuning Jet Cast 18x8 24 10.8862176
Sport Tuning Propeller Cast 18x8 26.5 12.0201986
Sport Tuning Propeller Cast 19x8 28.5 12.9273834
Sport Tuning Turbine Cast 15x6.5 16 7.2574784
Sport Tuning Turbine Cast 16x7 17.5 7.937867
Sport Tuning Turbine Cast 17x7 19 8.6182556
Sport Tuning Turbine Cast 18x7.5 21.5 9.7522366
Sportiva Liberty Cast 19x8 31 14.0613644
Sportiva Modena Cast 18x8.5 26 11.7934024
Sportmax 002 Cast 15x7 15 6.803886
Sportmax 513 Cast 15x7 16.1 7.30283764
Sportmax 513 Cast 15x8 17.3 7.84714852
SSR Agle Strusse Forged/Spun 19x12 32 14.5149568
SSR Comp-H Forged 19x8 20.3 9.20792572
SSR De Colte Forged 17x9 19.8 8.98112952
SSR GP-Theta Forged 16x8 19 8.6182556
SSR GT1 Forged 16x7 15 6.803886
SSR GT1 Forged 17x7 16.5 7.4842746
SSR GT1 Forged 17x7.5 17.5 7.937867
SSR GT1 Forged 17x8 17.8 8.07394472
SSR GT1 Forged 17x9 18.3 8.30074092
SSR GT1 Forged 18x7.5 17.8 8.07394472
SSR GT1 Forged 18x8 19 8.6182556
SSR GT1 Forged 18x9 19.7 8.93577028
SSR GT10 Forged 18x8 23.4 10.61406216
SSR GT10 Forged 18x8.5 24.3 11.02229532
SSR GT10 Forged 19x8.5 27 12.2469948
SSR GT2 Forged 17x7.5 14.6 6.62244904
SSR GT2 Forged 17x8 15.2 6.89460448
SSR GT2 Forged 18x7.5 15.9 7.21211916
SSR GT3 Forged/Spun 18x7.5 24 10.8862176
SSR GT3 Forged/Spun 18x8 24.6 11.15837304
SSR GT3 Forged/Spun 19x7.5 25.5 11.5666062
SSR GT3 Forged/Spun 19x8.5 26.5 12.0201986
SSR GT7 Forged 17x7.5 16.6 7.52963384
SSR GT7 Forged 17x8 17.6 7.98322624
SSR GT7 Forged 17x8.5 18.5 8.3914594
SSR GT7-H Forged 18x8 19.4 8.79969256
SSR GT7-H Forged 19x7.5 19.9 9.02648876
SSR Integral Forged 16x7 15.5 7.0306822
SSR Integral Forged 16x8 16.9 7.66571156
SSR Integral Forged 17x7 17 7.7110708
SSR Integral Forged 17x8 18 8.1646632
SSR Integral Forged 17x9 18.8 8.52753712
SSR Integral Forged 18x8 20 9.071848
SSR Integral Forged 18x9 20 9.071848
SSR MK-III Forged/Spun 15x7 12.2 5.53382728
SSR Professor SP1 Forged/Spun 18x8 21.6 9.79759584
SSR Professor SP1 Forged/Spun 19x7.5 22.9 10.38726596
SSR Professor SP1 Forged/Spun 19x8 23.8 10.79549912
SSR RF Firrenze Forged/Spun 16x8 18.5 8.3914594
SSR S1 Forged 17x7 16.8 7.62035232
SSR Schumacher Forged/Spun 15x7 12.5 5.669905
SSR Schumacher Forged/Spun 16x7 15 6.803886
SSR Type-C (called Competitions in the US) Forged 15x6 8 3.6287392
SSR Type-C (called Competitions in the US) Forged 15x6.5 8.6 3.90089464
SSR Type-C (called Competitions in the US) Forged 15x7 9.2 4.17305008
SSR Type-C (called Competitions in the US) Forged 15x7.5 9.6 4.35448704
SSR Type-C (called Competitions in the US) Forged 16x7 11 4.9895164
SSR Type-C (called Competitions in the US) Forged 16x8 12.1 5.48846804
SSR Type-C (called Competitions in the US) Forged 17x7.5 13 5.8967012
SSR Type-C (called Competitions in the US) Forged 17x8 14.3 6.48637132
SSR Type-C (called Competitions in the US) Forged 17x8.5 15 6.803886
SSR Type-C (called Competitions in the US) Forged 17x9 15.2 6.89460448
SSR Type-C (called Competitions in the US) Forged 17x9.5 15.4 6.98532296
SSR Type-C (called Competitions in the US) Forged 18x7.5 15.5 7.0306822
SSR Type-C (called Competitions in the US) Forged 18x8 16.3 7.39355612
SSR Type-C (called Competitions in the US) Forged 18x8.5 16.8 7.62035232
SSR Type-C (called Competitions in the US) Forged 18x9 17 7.7110708
SSR Type-C (called Competitions in the US) Forged 18x9.5 17.7 8.02858548
SSR Type-C H Forged 19x8 20.3 9.20792572
SSR Type-C RS Forged 17x10 17.2 7.80178928
SSR Type-C RS Forged 17x10.5 17.6 7.98322624
SSR Type-C RS Forged 17x7.5 14.6 6.62244904
SSR Type-C RS Forged 17x8 15.5 7.0306822
SSR Type-C RS Forged 17x8.5 16.2 7.34819688
SSR Type-C RS Forged 17x9 16.4 7.43891536
SSR Type-C RS Forged 17x9.5 16.8 7.62035232
SSR Type-C RS Forged 18x10.5 19.9 9.02648876
SSR Type-C RS Forged 18x7.5 17.6 7.98322624
SSR Type-C RS Forged 18x8 18 8.1646632
SSR Type-C RS Forged 18x8.5 19 8.6182556
SSR Type-C RS Forged 18x9 19.6 8.89041104
SSR Type-C RS Forged 18x9.5 18.8 8.52753712
SSR Type-C RS Forged 19x10.5 22.3 10.11511052
SSR Type-C RS Forged 19x8 20 9.071848
SSR Type-C RS Forged 19x8.5 20.8 9.43472192
SSR Type-C RS Forged 19x9.5 21.5 9.7522366
SSR Type-F Forged 17x10 17.7 8.02858548
SSR Type-F Forged 17x8 16.3 7.39355612
SSR Type-F Forged 17x8.5 16.6 7.52963384
SSR Type-F Forged 17x9 16.8 7.62035232
SSR Type-F Forged 17x9.5 16.9 7.66571156
SSR Type-F Forged 18x10.5 20 9.071848
SSR Type-F Forged 18x11 20.3 9.20792572
SSR Type-F Forged 18x7.5 16.9 7.66571156
SSR Type-F Forged 18x8 17.1 7.75643004
SSR Type-F Forged 18x8.5 17.8 8.07394472
SSR Type-F Forged 18x9 18.2 8.25538168
SSR Type-F Forged 18x9.5 18.8 8.52753712
SSR Type-M Forged 15x6.5 11 4.9895164
SSR Type-R Forged 16x7 11.5 5.2163126
SSR Type-V Forged 16x7 13 5.8967012
SSR Type-X Forged 15x6.5 10.5 4.7627202
SSR Vienna Forged/Spun 18x8.5 22.3 10.11511052
SSW S001 Blaze Cast 17x7.5 22 9.9790328
SSW S001 Blaze Cast 18x8 24.9 11.29445076
SSW S002 Inspire Cast 14x6 15.9 7.21211916
SSW S002 Inspire Cast 15x6.5 17 7.7110708
SSW S003 Inferno Cast 17x7.5 20.3 9.20792572
SSW S004 Raze Cast 17x7.5 20.9 9.48008116
SSW S004 Raze Cast 18x8 22 9.9790328
SSW S005 Flash Cast 17x7.5 22.5 10.205829
SSW S005 Flash Cast 18x8 23.8 10.79549912
SSW S006 Illusion Cast 18x8 27.8 12.60986872
SSW S007 Eternity Cast 15x6.5 15.4 6.98532296
SSW S007 Eternity Cast 16x7 16.3 7.39355612
SSW S007 Eternity Cast 17x7 18.1 8.21002244
SSW S008 Menace Cast 15x6.5 16.5 7.4842746
SSW S008 Menace Cast 16x7 19.4 8.79969256
SSW S008 Menace Cast 17x7 20.9 9.48008116
SSW S009 Fanatic Cast 18x8 24.3 11.02229532
SSW S010 Haste Cast 15x6.5 15.4 6.98532296
SSW S010 Haste Cast 16x7 18.5 8.3914594
SSW S010 Haste Cast 17x7 19 8.6182556
SSW S011 Cosmo Cast 15x6.5 16.3 7.39355612
SSW S011 Cosmo Cast 16x7 19.4 8.79969256
SSW S011 Cosmo Cast 17x7 20.9 9.48008116
SSW S012 Eclipse Cast 19x8 24.7 11.20373228
SSW S012 Eclipse Cast 20x7.5 27.3 12.38307252
SSW S013 Trex Cast 15x6.5 16.8 7.62035232
SSW S013 Trex Cast 16x7 18.7 8.48217788
SSW S013 Trex Cast 17x7 19.8 8.98112952
SSW S013 Trex Cast 18x8 22 9.9790328
SSW S014 Cyclone Cast 15x8 19.4 8.79969256
SSW S014 Cyclone Cast 16x8 20.3 9.20792572
SSW S015 Triton Cast 15x8 19 8.6182556
SSW S015 Triton Cast 16x8 19.8 8.98112952
SSW S016 Torque Cast 13x5.5 16.3 7.39355612
SSW S016 Torque Cast 14x6 16.5 7.4842746
SSW S016 Torque Cast 15x6.5 17 7.7110708
SSW S017 Zenith Cast 17x7 20.3 9.20792572
SSW S018 Infinitum Cast 20x9 30 13.607772
SSW S019 Multispoke Cast 18x8 27 12.2469948
SSW S019 Multispoke Cast 19x8.5 29 13.1541796
SSW S020 Quest Cast 13x5.5 15.2 6.89460448
SSW S020 Quest Cast 14x6 15.7 7.12140068
SSW S020 Quest Cast 15x6.5 16.1 7.30283764
SSW S021 Frost Cast 14x6 13.7 6.21421588
SSW S022 Cynik Cast 17x7 19 8.6182556
SSW S023 Rage Cast 14x6 13 5.8967012
SSW S025 Vigor Cast 18x7.5 22.7 10.29654748
Starcorp Racing Lite 5 Cast 15x6.5 11 4.9895164
Starcorp Racing Lite 5 Cast 16x7 13.2 5.98741968
Starcorp Racing Lite 5 Cast 17x7 15.4 6.98532296
Starcorp Racing Techno Cast 16x7 20.3 9.20792572
Starform Basel Cast 17x7 21.6 9.79759584
Starform Basel Cast 17x8 24.3 11.02229532
Starform Real Racing Model II Forged 17x7.5 13.4 6.07813816
Starform Real Racing Model II Forged 17x8.5 14.1 6.39565284
Starform Real Racing Model II Forged 17x9.5 15 6.803886
Starform Real Racing R2 Forged 15x6.5 9.7 4.39984628
Starform Real Racing R2 Forged 15x7 9.9 4.49056476
Starform Real Racing R2 Forged 17x7.5 14.1 6.39565284
Starform Real Racing R2 Forged 17x8.5 14.8 6.71316752
Starform Real Racing R2 Forged 17x9.5 15.7 7.12140068
Stark MS Forged 14x5 7.3 3.31122452
Stark MS Forged 15x6 9.5 4.3091278
Stark MS Forged 15x6.5 10.1 4.58128324
Stark MS Forged 17x7.5 14.6 6.62244904
Stern Aguzze-S07 Cast 15x7 13.4 6.07813816
Stern Aguzze-S07 Cast 16x7 14.8 6.71316752
Stern Aguzze-S07 Cast 16x8 16.1 7.30283764
Stern Aguzze-S07R Forged 17x7 14.3 6.48637132
Stern Aguzze-S07R Forged 17x7.5 14 6.3502936
Stern Aguzze-S07R Forged 17x8 14 6.3502936
Stern Aguzze-S07R Forged 17x9 15.3 6.93996372
Stern Aguzze-S07R Forged 18x7.5 16.5 7.4842746
Stern Aguzze-S07R Forged 18x8.5 16.5 7.4842746
Stern Aguzze-S07R Forged 18x9.5 16.8 7.62035232
Stern Axia Cast 19x9.5 31 14.0613644
Stern Intertouring Cast 17x8 23.5 10.6594214
Stern Leacher Cast 17x7 23.5 10.6594214
Stern Mach III Cast 15x7 13.5 6.1234974
Stern Mach III Cast 16x7 14.5 6.5770898
Stern Mach III Forged 17x7.5 14 6.3502936
Stern Sports Line LIIva Forged/Spun 17x7 21.5 9.7522366
Stern ST-1 Face III Beast Cast/Spun 18x8.5 26.9 12.20163556
Stern ST-2 Face II Touring Cast/Spun 18x8.5 28.1 12.74594644
Sti RS-Zero Forged 17x7.5 15.7 7.12140068
Stilauto 5 Cast 19x10 29 13.1541796
Stilauto Racing C Cast 17x7.5 24 10.8862176
Stillen GTV Cast 17x9 22.5 10.205829
Stillen GTV Cast 18x8 21.6 9.79759584
STR RS16 Cast 17x7 20.8 9.43472192
STR RS17 Cast 17x7 19.5 8.8450518
Subaru Impreza MY00/01 Cast 16x7 16.5 7.4842746
Subaru Impreza MY00/01 WRX STi Forged 17x7.5 19.8 8.98112952
Subaru Impreza MY02 WRX Cast 16x6.5 16.5 7.4842746
Subaru Impreza MY02 WRX (BBS) Forged 17x7 16 7.2574784
Subaru Impreza MY05 STi (JDM) Forged 17x7.5 18.6 8.43681864
Subaru Impreza MY06 WRX Cast 17x7 21 9.5254404
Subaru Impreza MY07 WRX STi Forged 17x8 18 8.1646632
Subaru Impreza MY08 WRX STi Cast 18x8.5 27.5 12.473791
Subaru Impreza MY08 WRX STi BBS Forged 18x8.5 18.5 8.3914594
Subaru Impreza MY98 Cast 16x7 17 7.7110708
Subaru Impreza MY99 Cast 16x7 17 7.7110708
Subaru Legacy Stamped Steel 15x6 19.5 8.8450518
Subaru Legacy (Enkei) Cast 15x6 16 7.2574784
Subaru Legacy GT-B (Japan) Forged 17x7 17.8 8.07394472
Subaru Legacy Outback (Topy) Cast 15x6 18 8.1646632
Subaru Legacy Spec B 06 Cast 18x7 18 8.1646632
Subary Impreza MY05 STi (BBS) Forged 17x8 19.2 8.70897408
Superlight Billet Billet/Spun 13x10 10.4 4.71736096
Superlight Billet Billet/Spun 13x10.5 10.6 4.80807944
Superlight Billet Billet/Spun 13x11 10.9 4.94415716
Superlight Billet Billet/Spun 13x11.5 11.2 5.08023488
Superlight Billet Billet/Spun 13x5 7.7 3.49266148
Superlight Billet Billet/Spun 13x5.5 8 3.6287392
Superlight Billet Billet/Spun 13x6 8.2 3.71945768
Superlight Billet Billet/Spun 13x6.5 8.5 3.8555354
Superlight Billet Billet/Spun 13x7 8.8 3.99161312
Superlight Billet Billet/Spun 13x7.5 9 4.0823316
Superlight Billet Billet/Spun 13x8 9.3 4.21840932
Superlight Billet Billet/Spun 13x8.5 9.6 4.35448704
Superlight Billet Billet/Spun 13x9 9.8 4.44520552
Superlight Billet Billet/Spun 13x9.5 10.1 4.58128324
Superlight Billet Billet/Spun 14x10 10.9 4.94415716
Superlight Billet Billet/Spun 14x10.5 11.2 5.08023488
Superlight Billet Billet/Spun 14x6 8.8 3.99161312
Superlight Billet Billet/Spun 14x6.5 9.1 4.12769084
Superlight Billet Billet/Spun 14x7 9.3 4.21840932
Superlight Billet Billet/Spun 14x7.5 9.6 4.35448704
Superlight Billet Billet/Spun 14x8 9.9 4.49056476
Superlight Billet Billet/Spun 14x8.5 10.1 4.58128324
Superlight Billet Billet/Spun 14x9 10.4 4.71736096
Superlight Billet Billet/Spun 14x9.5 10.7 4.85343868
Superlight Billet Billet/Spun 15x10 15.8 7.16675992
Superlight Billet Billet/Spun 15x10.5 16.1 7.30283764
Superlight Billet Billet/Spun 15x11 16.4 7.43891536
Superlight Billet Billet/Spun 15x6.5 13.2 5.98741968
Superlight Billet Billet/Spun 15x7 13.8 6.25957512
Superlight Billet Billet/Spun 15x7.5 14.1 6.39565284
Superlight Billet Billet/Spun 15x8 14.4 6.53173056
Superlight Billet Billet/Spun 15x8.5 14.8 6.71316752
Superlight Billet Billet/Spun 15x9 15.1 6.84924524
Superlight Billet Billet/Spun 15x9.5 15.4 6.98532296
Superlight Classic Cast 10x5 8.8 3.99161312
Superlight Classic Cast 12x5 9.6 4.35448704
Superlight Classic Cast 13x5.5 11.7 5.30703108
Superlight Classic Cast 13x6 12.3 5.57918652
Superlight Classic Cast 13x7 13.2 5.98741968
Superlight Classic Cast 13x8 13.4 6.07813816
Superlight Classic Cast 14x6 13.8 6.25957512
Superlight Classic Cast 15x6 18.8 8.52753712
Superlight Classic Cast 15x7 18.9 8.57289636
Superlight Classic Cast 15x8 20.5 9.2986442
Superlight ML Cast 13x5.5 12.8 5.80598272
Superlight ML Cast 13x7 13.2 5.98741968
Superlight ML Cast 13x8 13.9 6.30493436
Superlight ML Cast 14x6 15 6.803886
Superlight Sports Cast 10x4.5 7.9 3.58337996
Superlight Sports Cast 12x5 9 4.0823316
Superlight Sports Cast 13x6 10 4.535924
Superlight Sports Cast 13x7 11 4.9895164
Superlight Sports Cast 13x8 13 5.8967012
Superlight Sports Cast 14x6 14.3 6.48637132
Superlight Sports Cast 15x6 17.6 7.98322624
Superlight Sports Cast 15x7 19.6 8.89041104
Superlight Sports Cast 15x8 19.9 9.02648876
Superlight Sports Cast 16x7 22 9.9790328
Superlight Ultralight Cast/Spun 12x5 7.8 3.53802072
Superlight Ultralight Cast/Spun 12x5.5 8.3 3.76481692
Superlight Ultralight Cast/Spun 12x6 8.5 3.8555354
Superlight Ultralight Cast/Spun 13x10 11.6 5.26167184
Superlight Ultralight Cast/Spun 13x10.5 11.8 5.35239032
Superlight Ultralight Cast/Spun 13x11 12 5.4431088
Superlight Ultralight Cast/Spun 13x11.5 12.2 5.53382728
Superlight Ultralight Cast/Spun 13x5 8.7 3.94625388
Superlight Ultralight Cast/Spun 13x5.5 9 4.0823316
Superlight Ultralight Cast/Spun 13x6 9.3 4.21840932
Superlight Ultralight Cast/Spun 13x6.5 9.8 4.44520552
Superlight Ultralight Cast/Spun 13x7 9.9 4.49056476
Superlight Ultralight Cast/Spun 13x7.5 10.2 4.62664248
Superlight Ultralight Cast/Spun 13x8 10.5 4.7627202
Superlight Ultralight Cast/Spun 13x8.5 10.7 4.85343868
Superlight Ultralight Cast/Spun 13x9 11 4.9895164
Superlight Ultralight Cast/Spun 13x9.5 11.4 5.17095336
Superlight Ultralight Cast/Spun 14x10 14.7 6.66780828
Superlight Ultralight Cast/Spun 14x10.5 14.9 6.75852676
Superlight Ultralight Cast/Spun 14x6 11 4.9895164
Superlight Ultralight Cast/Spun 14x6.5 11.6 5.26167184
Superlight Ultralight Cast/Spun 14x7 12.2 5.53382728
Superlight Ultralight Cast/Spun 14x7.5 12.7 5.76062348
Superlight Ultralight Cast/Spun 14x8 13.1 5.94206044
Superlight Ultralight Cast/Spun 14x8.5 13.5 6.1234974
Superlight Ultralight Cast/Spun 14x9 13.9 6.30493436
Superlight Ultralight Cast/Spun 14x9.5 14.3 6.48637132
Superlight Ultralight Cast/Spun 15x10 17.1 7.75643004
Superlight Ultralight Cast/Spun 15x10.5 17.2 7.80178928
Superlight Ultralight Cast/Spun 15x6.5 15.2 6.89460448
Superlight Ultralight Cast/Spun 15x7 15.4 6.98532296
Superlight Ultralight Cast/Spun 15x7.5 15.9 7.21211916
Superlight Ultralight Cast/Spun 15x8 16.2 7.34819688
Superlight Ultralight Cast/Spun 15x8.5 16.4 7.43891536
Superlight Ultralight Cast/Spun 15x9 16.8 7.62035232
Superlight Ultralight Cast/Spun 16x10 19.4 8.79969256
Superlight Ultralight Cast/Spun 16x10.5 19.7 8.93577028
Superlight Ultralight Cast/Spun 16x11 20.2 9.16256648
Superlight Ultralight Cast/Spun 16x11.5 20.5 9.2986442
Superlight Ultralight Cast/Spun 16x12 20.9 9.48008116
Superlight Ultralight Cast/Spun 16x12.5 21.3 9.66151812
Superlight Ultralight Cast/Spun 16x6.5 17.4 7.89250776
Superlight Ultralight Cast/Spun 16x7 17.6 7.98322624
Superlight Ultralight Cast/Spun 16x7.5 18 8.1646632
Superlight Ultralight Cast/Spun 16x8 18.2 8.25538168
Superlight Ultralight Cast/Spun 16x8.5 18.4 8.34610016
Superlight Ultralight Cast/Spun 16x9 18.7 8.48217788
Superlight Ultralight Cast/Spun 16x9.5 19.1 8.66361484
Superlite Japan 2-Piece (very rare) Cast/Spun 15x6 16 7.2574784
Taylor 13x5.5 7 3.1751468
Team Dynamics Diablo Cast 17x7.5 20.9 9.48008116
Team Dynamics Diablo Cast 18x7.5 25.1 11.38516924
Team Dynamics DTM Cast 15x7 14 6.3502936
Team Dynamics DTM Cast 16x7.5 17.6 7.98322624
Team Dynamics Monza Cast 17x7 22.5 10.205829
Team Dynamics Motorsport Cast 16x7 19.8 8.98112952
Team Dynamics Motorsport Cast 17x7 23 10.4326252
Team Dynamics Motorsport Cast 18x8 24 10.8862176
Team Dynamics Phantom Cast 17x7 21.8 9.88831432
Team Dynamics Pro BTCC Cast 17x9 19.8 8.98112952
Team Dynamics Pro Comp 1 Cast 17x7 19.2 8.70897408
Team Dynamics Pro Comp 1 Cast 18x8 21.2 9.61615888
Team Dynamics Pro ETC Cast 17x9 19.8 8.98112952
Team Dynamics Pro Mag Cast Mg 17x11 19.8 8.98112952
Team Dynamics Pro Race 1 Cast 15x7 13.4 6.07813816
Team Dynamics Pro Race 1 Cast 16x7 16.5 7.4842746
Team Dynamics Pro Race 1 Cast 17x7 16.8 7.62035232
Team Dynamics Pro Race 1 Cast 17x7.5 18.3 8.30074092
Team Dynamics Pro Race 1 Cast 17x8 19.9 9.02648876
Team Dynamics Pro Race 1.2 Cast 14x7 12 5.4431088
Team Dynamics Pro Race 1.2 Cast 17x7.5 19.8 8.98112952
Team Dynamics Pro Race 2 Cast 15x7 14.1 6.39565284
Team Dynamics Pro Race 2 Cast 16x7 15.4 6.98532296
Team Dynamics Pro Race 2 Cast 17x7 16.5 7.4842746
Team Dynamics Pro Race 2 Cast 18x7.5 18.1 8.21002244
Team Dynamics Pro Rally Cast 15x6 17.2 7.80178928
Team Dynamics Pro Rally Cast 15x7 17.6 7.98322624
Team Dynamics Qualifier Cast 15x7 15 6.803886
Team Dynamics Qualifier Cast 18x8 21 9.5254404
Team Dynamics Raider Cast 17x7 24 10.8862176
Team Dynamics Rim 2000 Cast 17x7.5 21.5 9.7522366
Team Dynamics Sebring DTM Cast 17x7.5 22.5 10.205829
Team Dynamics Super Touring Cast 17x7.5 22 9.9790328
Team Dynamics Tornado Cast 17x7 19.8 8.98112952
Team Dynamics Visage Forged 18x8 17.9 8.11930396
Team Loco 142 Cast 16x7 22 9.9790328
Team Loco Kai Cast 17x7 23 10.4326252
Team Loco Shako Tan Cast 17x7 23 10.4326252
Team Toyota Europe GT-1 Cast 18x8 24 10.8862176
Tecnocast Corsia Forged 17x7 14.8 6.71316752
Tecnomagnesio Cast Mg 15x6.5 10.9 4.94415716
Tecnomagnesio MT 5B2 Cast Mg 16x7 15.4 6.98532296
Tecnomagnesio MT 5B2 Cast Mg 17x10 18 8.1646632
Tecnomagnesio MT 5B2 Cast Mg 17x8 16.3 7.39355612
Tecnomagnesio MT 5B2 Cast Mg 17x8.5 17.6 7.98322624
Tecnomagnesio MT 5B2 Cast Mg 18x10 20.5 9.2986442
Tecnomagnesio MT 6B3 Cast Mg 17x7 19 8.6182556
Tecnomagnesio MT 6B3 Cast Mg 17x8 19.4 8.79969256
Tecnomagnesio MT 6B3 Cast Mg 17x9 20.5 9.2986442
Tecnomagnesio MT 6B3 Cast Mg 18x10 22.7 10.29654748
Tecnomagnesio Sport Cast 15x6.5 17.6 7.98322624
Tecnomagnesio Sport Cast 16x7 19.6 8.89041104
Tecnomagnesio Sport Cast 17x7 24.8 11.24909152
Tenzo-R 2-Type Cast 17x7 20.8 9.43472192
Tenzo-R Apex-5 Cast 17x7 20.3 9.20792572
Tenzo-R Apex-5 Cast 18x7.5 23.9 10.84085836
Tenzo-R AV7 Cast 17x7 20 9.071848
Tenzo-R DC5 Cast 17x7 17.5 7.937867
Tenzo-R DC5 Cast 18x8 21.7 9.84295508
Tenzo-R DC5 Cast 19x10 26.4 11.97483936
Tenzo-R DC5 Cast 19x8.5 23.5 10.6594214
Tenzo-R DC5 v2 Cast 17x7 17.5 7.937867
Tenzo-R DC5 v2 Cast 18x8 21.7 9.84295508
Tenzo-R DC5 v2 Cast 19x10 26.4 11.97483936
Tenzo-R DC5 v2 Cast 19x8.5 23.5 10.6594214
Tenzo-R DC6 Cast 16x7 16.3 7.39355612
Tenzo-R DC6 Cast 17x7 17.8 8.07394472
Tenzo-R DC6 Cast 18x8 22.5 10.205829
Tenzo-R DC6 Cast 18x9.5 24.6 11.15837304
Tenzo-R DC6 v2 Cast 16x7 16.3 7.39355612
Tenzo-R DC6 v2 Cast 17x7 17.8 8.07394472
Tenzo-R DC6 v2 Cast 18x8 22.5 10.205829
Tenzo-R DC6 v2 Cast 18x9.5 24.6 11.15837304
Tenzo-R DriveX-7 Cast 17x7 18.7 8.48217788
Tenzo-R DriveX-7 Cast 18x7.5 21.1 9.57079964
Tenzo-R Formula-10 Cast 17x7 17.4 7.89250776
Tenzo-R Formula-10 Cast 18x7.5 21.5 9.7522366
Tenzo-R GF7 Cast 17x7 19.1 8.66361484
Tenzo-R GF7 Cast 18x7.5 22.3 10.11511052
Tenzo-R GF7 Cast 19x10 28.4 12.88202416
Tenzo-R GF7 Cast 19x8 25.4 11.52124696
Tenzo-R GT5 Cast 18x8 22.2 10.06975128
Tenzo-R GT5 Cast 19x8.5 26.9 12.20163556
Tenzo-R GT5 Cast 20x8.5 28.1 12.74594644
Tenzo-R GT6 Cast 17x7 19.4 8.79969256
Tenzo-R GT6 Cast 18x7.5 23.5 10.6594214
Tenzo-R GT6 Cast 19x10.5 32.1 14.56031604
Tenzo-R GT6 Cast 19x8.5 25.4 11.52124696
Tenzo-R Mach-10 Cast 17x7 19.2 8.70897408
Tenzo-R Mach-10 Cast 18x7.5 22.1 10.02439204
Tenzo-R Mean-6 Cast 17x7 21.7 9.84295508
Tenzo-R Mean-6 Cast 18x7.5 23.2 10.52334368
Tenzo-R Overdose Cast 17x7 22.6 10.25118824
Tenzo-R Overdose Cast 18x7.5 24.3 11.02229532
Tenzo-R Passion-5 Cast 17x7 17.9 8.11930396
Tenzo-R Passion-5 Cast 18x7.5 21 9.5254404
Tenzo-R Poke-10 Cast 17x7 20.9 9.48008116
Tenzo-R Poke-10 Cast 18x7.5 23 10.4326252
Tenzo-R Psycho Cast 17x7 19.5 8.8450518
Tenzo-R Psycho Cast 18x7.5 22.4 10.16046976
Tenzo-R Psycho Cast 19x8 23.5 10.6594214
Tenzo-R RS-5 Cast 17x7 20.3 9.20792572
Tenzo-R RS-5 Cast 18x7.5 22 9.9790328
Tenzo-R Shu-10 Cast 17x7 20.5 9.2986442
Tenzo-R Shu-10 Cast 18x7.5 23 10.4326252
Tenzo-R Shu-4 Cast 15x6.5 16.6 7.52963384
Tenzo-R Shu-4 Cast 17x7 21.2 9.61615888
Tenzo-R Shu-4 Cast 18x7.5 22.9 10.38726596
Tenzo-R Sinko Cast 15x6.5 12.3 5.57918652
Tenzo-R Sinko Cast 17x7 18.7 8.48217788
Tenzo-R Sinko Cast 18x7.5 21.7 9.84295508
Tenzo-R Sinko-R Cast 17x7 19.2 8.70897408
Tenzo-R Sinko-R Cast 18x7.5 21.3 9.66151812
Tenzo-R Tenzo-C Type Cast 17x7 21.8 9.88831432
Tenzo-R Type 2 Cast 17x7 21.6 9.79759584
Tenzo-R ZT-6 Cast 17x7 23.1 10.47798444
Tenzo-R ZT-6 Cast 18x7.5 25.5 11.5666062
TGF MX Cast 17x7 18.3 8.30074092
TIS 07 Cast 20x7.5 33 14.9685492
TMW GTV Cast 17x7 19.5 8.8450518
TMW RX Cast 17x7 20.3 9.20792572
TMW RX Cast 18x7.5 24 10.8862176
Tom Motorsports TCR Cast 17x7 24 10.8862176
TommyKaira ProR Forged 17x7 15.9 7.21211916
TOM's New Action Cast/Spun 14x6 11.1 5.03487564
TOM's New Action Cast/Spun 15x6.5 12.2 5.53382728
TOM's New Sports II Forged 18x7.5 15 6.803886
TOM's S2 Cast 18x8.5 23.8 10.79549912
TOM's S4 Spiker Cast 15x6.5 15.5 7.0306822
TOORA Monotoora (Erebuni) Cast 15x7 22 9.9790328
Toybox48 Hethel Forged 16x7 12.1 5.48846804
Toybox48 Hethel Forged 17x8 13.7 6.21421588
Toyota Altezza (Lexus IS300) Z-Edition Cast 17x7 22 9.9790328
Toyota Camry Steel 14x5.5 18.6 8.43681864
Toyota Celica GTS/Supra P 82-85 Cast 14x7 15 6.803886
Toyota Celica/Supra 82-84 Cast 14x5.5 14.5 6.5770898
Toyota Corolla 86-87 Cast 14x5.5 14.5 6.5770898
Toyota Corolla 93-97 Cast 14x5.5 19 8.6182556
Toyota Matrix Steel 15x6 18.1 8.21002244
Toyota MR2 Cast 15x6 14.5 6.5770898
Toyota MR2 Cast 15x6.5 15 6.803886
Toyota MR-S (front) Cast 15x6 14.6 6.62244904
Toyota Prius 01-03 Cast 14x5.5 13 5.8967012
Toyota Supra 86.5-89 Cast 16x7 23 10.4326252
Toyota Supra L 85 Cast 15x6 15 6.803886
Toyota Supra mk IV Cast 16x8 17.4 7.89250776
Toyota Supra mk IV Cast 16x9 20 9.071848
Toyota Tacoma 4x4 Xtra Cab - 99 Cast 15x7 21 9.5254404
Toyota Van Cast 14x5.5 17 7.7110708
Toyota Yaris Cast 15x6 16 7.2574784
TRD Sports SC430 Cast 18x8 28 12.7005872
TRD Sports T3 Forged 15x6.5 11.4 5.17095336
TRD Sports T3 Forged 16x7 14.9 6.75852676
TRD Sports T3 Forged 16x8 15.7 7.12140068
TRD Sports T3 Forged 17x7.5 18.5 8.3914594
TRD Sports T3 Forged 17x8 18.7 8.48217788
TRD Sports T3 Forged 17x8.5 19 8.6182556
TRM (Tire Rack Motorsports) BR5 Cast 17x7 21 9.5254404
TRM (Tire Rack Motorsports) F1 Forged 16x6.5 10.8 4.89879792
TRM (Tire Rack Motorsports) F1 Forged 17x7.5 12.3 5.57918652
TRM (Tire Rack Motorsports) MT1 Cast 17x8 17 7.7110708
TRM (Tire Rack Motorsports) MT1 Cast 17x8.5 17.5 7.937867
TRM (Tire Rack Motorsports) MT1 Cast 18x8 19 8.6182556
TRM (Tire Rack Motorsports) MT1 Cast 18x9.5 19.2 8.70897408
TRM (Tire Rack Motorsports) R2 Cast 16x6.5 20.3 9.20792572
TRM (Tire Rack Motorsports) R2 Cast 18x7 24.7 11.20373228
TRM (Tire Rack Motorsports) R5 Cast 18x7.5 24.7 11.20373228
TRM (Tire Rack Motorsports) RB5 Cast 15x6.5 17 7.7110708
TRM (Tire Rack Motorsports) RB5 Cast 16x6.5 18.8 8.52753712
TRM (Tire Rack Motorsports) Sniper Cast 18x9 27 12.2469948
TRM (Tire Rack Motorsports) Typhoon Cast 17x7 23 10.4326252
TRM (Tire Rack Motorsports) Typhoon Cast 18x9 26.5 12.0201986
TSW Alpine Cast 14x6 15.5 7.0306822
TSW Alpine Cast 15x6.5 19.4 8.79969256
TSW Avus R Cast 15x7 19.4 8.79969256
TSW Avus R Cast 16x7.5 21.7 9.84295508
TSW Big Deep Cast 17x7 23.3 10.56870292
TSW Blade Cast 16x7.5 21 9.5254404
TSW Bremma Cast 19x9.5 32 14.5149568
TSW Edge Cast 17x7 21.8 9.88831432
TSW Eurace Cast 17x7 24.3 11.02229532
TSW Evo Cast 15x7 17 7.7110708
TSW Evo Cast 16x7 20.4 9.25328496
TSW Fly Cast 15x7 18.5 8.3914594
TSW Fly Cast 16x7 20.7 9.38936268
TSW Fly Cast 17x7 22.8 10.34190672
TSW Fury Cast 15x6.5 16.5 7.4842746
TSW Hockenheim Cast 15x7 18.8 8.52753712
TSW Hockenheim Cast 17x8 23.8 10.79549912
TSW Hockenheim Cast 18x8 25.5 11.5666062
TSW Quad Cast 14x6 12.5 5.669905
TSW Quad Cast 15x6.5 15 6.803886
TSW Revo Cast 16x7 20.4 9.25328496
TSW Revo Cast 17x7 24.8 11.24909152
TSW SGV Cast 16x7 22 9.9790328
TSW SGV Cast 18x8 30.5 13.8345682
TSW Spirit Cast 18x8 27.5 12.473791
TSW Trophy Cast 15x7 19 8.6182556
TSW Turn 7 Cast 17x7 22 9.9790328
TSW Volcano Cast 18x8 21 9.5254404
TSW VX1 Cast 16x7 22.5 10.205829
TSW VX1 Cast 17x7 24 10.8862176
TSW VX1 Cast 18x8 27 12.2469948
TSW Zenon Cast 17x7 24 10.8862176
Ultra Wheels Cast 17x7.5 24.8 11.24909152
Ultra Wheels Cast 20x8.5 44.5 20.1848618
Ultra Wheels Koge Cast 17x7 25 11.33981
Veilside Andrew Racing eF Forged/Spun 18x10 27 12.2469948
Veilside Andrew Racing Pasha D Cast 17x7 22 9.9790328
Velocity Motoring VB3 (CSL replica) Cast 18x8.5 24 10.8862176
Velocity Motoring VB3 (CSL replica) Cast 18x9.5 24.4 11.06765456
Velocity Motoring VB3 (CSL replica) Cast 19x8.5 24.8 11.24909152
Velocity Motoring VB3 (CSL replica) Cast 19x9.5 25.3 11.47588772
Velox Drift Spec Cast 18x8.5 26 11.7934024
Velox Drift Spec Cast 18x9.5 28 12.7005872
Velox Hyperion Cast 20x8.5 29.4 13.33561656
Velox PG-5s Forged 17x7 12.5 5.669905
Velox PG-5s Forged 18x7.5 16.5 7.4842746
Velox PG-Rev10 Forged 17x7 11.5 5.2163126
Velox PG-Rev5 Forged 17x7 12.1 5.48846804
Velox VX-5 Cast 19x8 27 12.2469948
Velox VX-6 Cast 17x7 23 10.4326252
Velox VX-6 Cast 18x7.5 25.5 11.5666062
Velox VX-6r Cast 17x7 14.5 6.5770898
Velox VX-6r Cast 18x7.5 18 8.1646632
Velox VX-8 Cast 17x7.5 23 10.4326252
Velox VX-8 Cast 18x7.5 25.5 11.5666062
Velox VX-8r Cast 16x7 21 9.5254404
Velox VX-K Cast 17x7.5 23 10.4326252
Velox VX-K Cast 18x7.5 25.5 11.5666062
Velox VX-Nova Cast 17x7.5 23 10.4326252
Velox VX-Nova Cast 18x8.5 25.5 11.5666062
Velox VX-Scythe Cast 17x7.5 23 10.4326252
Velox VX-Scythe Cast 17x8.5 25.5 11.5666062
Velox Zeta 5 Cast 17x7.5 23 10.4326252
Velox Zeta 5 Cast 18x7.5 25.5 11.5666062
Velox Zeta K Cast 17x7.5 23 10.4326252
Velox Zeta K Cast 18x7.5 25.5 11.5666062
Vision 814 Cast 16x7 22 9.9790328
Vision 818 Cast 14x6 15 6.803886
Vision 818 Cast 16x7 21.3 9.66151812
Vision 96 Cast 16x7.5 22.8 10.34190672
Volk CE28N Forged 14x5.5 6.5 2.9483506
Volk CE28N Forged 15x5.5 7.7 3.49266148
Volk CE28N Forged 15x6.5 8.1 3.67409844
Volk CE28N Forged 15x7 9.1 4.12769084
Volk CE28N Forged 16x7 11.9 5.39774956
Volk CE28N Forged 16x8 12.9 5.85134196
Volk CE28N Forged 17x7.5 13.8 6.25957512
Volk CE28N Forged 17x9 14.8 6.71316752
Volk CE28N Forged 18x8 14.7 6.66780828
Volk CE28N Forged 18x8.5 16 7.2574784
Volk CE28N Forged 18x9.5 17 7.7110708
Volk CE28N Forged 19x8.5 19.4 8.79969256
Volk CE28N Time Attack Forged 17x8 15 6.803886
Volk CE28N Time Attack Forged 17x9 16.4 7.43891536
Volk Challenge Cast 17x8 19.5 8.8450518
Volk Daytona Speed Cast 17x8 24 10.8862176
Volk GTA Forged/Spun 17x9 21 9.5254404
Volk GTN Forged/Spun 18x7.5 18.5 8.3914594
Volk GTN Forged/Spun 18x8.5 19 8.6182556
Volk GTP Forged/Spun 17x9 19.5 8.8450518
Volk LE28N Forged 18x8.5 17 7.7110708
Volk LE37T Forged 18x7.5 17.3 7.84714852
Volk Progressiv ME Face-1 Forged 19x8.5 21.4 9.70687736
Volk Progressiv ME Face-1 Forged 19x9.5 22.3 10.11511052
Volk Progressiv Spoke Forged 18x7.5 20.9 9.48008116
Volk RE30 Forged 18x7.5 15.8 7.16675992
Volk RE30 Forged 18x8 16.2 7.34819688
Volk RE30 Forged 18x8.5 17 7.7110708
Volk SE37K Forged 17x7.5 14.3 6.48637132
Volk SE37K Forged 18x9.5 16.8 7.62035232
Volk Sebring ITC Cast 18x7.5 21.5 9.7522366
Volk SS Cast 18x7.5 25 11.33981
Volk TE37 Forged 13x5 7.4 3.35658376
Volk TE37 Forged 13x5.5 7.7 3.49266148
Volk TE37 Forged 13x6 7.5 3.401943
Volk TE37 Forged 13x8 8.3 3.76481692
Volk TE37 Forged 14x5 8.4 3.81017616
Volk TE37 Forged 14x5.5 8.5 3.8555354
Volk TE37 Forged 14x6 8.7 3.94625388
Volk TE37 Forged 14x6.5 8.9 4.03697236
Volk TE37 Forged 14x7 9.3 4.21840932
Volk TE37 Forged 15x5.5 7.9 3.58337996
Volk TE37 Forged 15x6 8.2 3.71945768
Volk TE37 Forged 15x6.5 8.8 3.99161312
Volk TE37 Forged 15x7 9.2 4.17305008
Volk TE37 Forged 15x7.5 10.6 4.80807944
Volk TE37 Forged 15x8 11.5 5.2163126
Volk TE37 Forged 16x7 11.2 5.08023488
Volk TE37 Forged 16x7.5 11.3 5.12559412
Volk TE37 Forged 16x8 13.3 6.03277892
Volk TE37 Forged 16x8.5 13.7 6.21421588
Volk TE37 Forged 17x7.5 15 6.803886
Volk TE37 Forged 17x8 16.3 7.39355612
Volk TE37 Forged 17x8.5 15.9 7.21211916
Volk TE37 Forged 17x9 17 7.7110708
Volk TE37 Forged 17x9.5 17.2 7.80178928
Volk TE37 Forged 18x10 19 8.6182556
Volk TE37 Forged 18x10.5 19.4 8.79969256
Volk TE37 Forged 18x7.5 17 7.7110708
Volk TE37 Forged 18x8 18.1 8.21002244
Volk TE37 Forged 18x8.5 17.2 7.80178928
Volk TE37 Forged 18x9 17.7 8.02858548
Volk TE37 Forged 18x9.5 18.3 8.30074092
Volk TE37 Forged 19x8 20 9.071848
Volk TE37 Forged 19x8.5 20.2 9.16256648
Volk TE37 Forged 19x9.5 20.9 9.48008116
Volk TE37 Gravel Forged 14x6 9.9 4.49056476
Volk TE37 Gravel Forged 15x6.5 11 4.9895164
Volk TE37 Gravel Forged 15x7 11.2 5.08023488
Volk TE37 Gravel Forged 16x6.5 13.1 5.94206044
Volk TE37 Mag Forged Mg 18x10 17.7 8.02858548
Volk TE37 Mag Forged Mg 18x8.5 16.1 7.30283764
Volk TE37 Mag Forged Mg 18x9.5 17.2 7.80178928
Volk TE37 Time Attack Forged 18x7.5 17 7.7110708
Volk TE37X Forged 16x5.5 13.8 6.25957512
Volk TE37X Forged 16x6.5 14.8 6.71316752
Volk TE37X Forged 16x7 14.6 6.62244904
Volk TE37X Forged 16x8 15.2 6.89460448
Volk Versus Tourismo Spada Cast 18x7.5 25.5 11.5666062
Volkswagen Avus (Snowflake) Cast 15x6.5 16.5 7.4842746
Volkswagen Bettle Cast 15x6 27 12.2469948
Volkswagen Bettle 06-07 Cast 16x6.5 19 8.6182556
Volkswagen Bettle Sport & Cabriolet Cast 17x7 24 10.8862176
Volkswagen Bravo Cast 17x7.5 22.5 10.205829
Volkswagen Cabriolet Cast 14x6 15.5 7.0306822
Volkswagen Corrado G60 Cast 15x6.5 19 8.6182556
Volkswagen Corrado SLC BBS Cast 15x6.5 18.5 8.3914594
Volkswagen EOS Cast 18x8 28 12.7005872
Volkswagen Golf (BBS RM 2-piece) Cast/Cast (very soft) 15x6.5 15 6.803886
Volkswagen Golf 03-05 Cast 15x6 20 9.071848
Volkswagen Jetta GLI Cast 17x7.5 20 9.071848
Volkswagen Golf GLS 03-06 Cast 15x6 17.5 7.937867
Volkswagen Golf GTI (BBS RS 3-piece) Forged/Cast 15x7 13.2 5.98741968
Volkswagen Golf GTI (Denver) Cast 17x7 28 12.7005872
Volkswagen Golf GTI (Huffeisen) Cast 18x7.5 29 13.1541796
Volkswagen Golf VR6 03-06 Cast 17x7.5 25 11.33981
Volkswagen Jetta 90-92 Cast 14x6 15.4 6.98532296
Volkswagen Golf GTI (Indianapolis) Cast 17x7 27 12.2469948
Volkswagen Jetta 99-04 Cast 15x6 16.5 7.4842746
Volkswagen Jetta 05-07 Cast 16x6.5 22 9.9790328
Volkswagen Jetta 06-07 Cast 17x7 22.5 10.205829
Volkswagen Passat 01-05 Cast 15x7 20 9.071848
Volkswagen Passat 98-02 Cast 16x7 18.5 8.3914594
Volkswagen Passat 98-02 (Montreal) Cast 16x6.5 17.5 7.937867
Volkswagen Passat 98-02 (Tango) Cast 16x6.5 22 9.9790328
Volkswagen Passat 01-06 Cast 16x7 22 9.9790328
Volkswagen Passat 06 Sport Cast 18x8 28 12.7005872
Volkswagen Passat 06 Sport (Euro) Cast 18x8 29 13.1541796
Volkswagen Passat 01-05 W8 Cast 17x7.5 25 11.33981
Volkwagen Phaeton Cast 18x8.5 27 12.2469948
Volkwagen Phaeton W12 Cast 18x8.5 28 12.7005872
Volkwagen Phaeton Cast 19x9 33 14.9685492
Volkwagen Phaeton Cast 19x8.5 31 14.0613644
Volkswagen R32 Cast 18x7.5 28 12.7005872
Volkswagen Siata Cast 17x7 21 9.5254404
Voxx Argus Cast 17x7 22.5 10.205829
Voxx Forza Cast 18x9 30.4 13.78920896
Voxx JB Cast 18x8 24.3 11.02229532
Voxx Matrix Cast 17x7 21 9.5254404
Voxx Scorze Cast 18x9 27.9 12.65522796
Voxx Saga Cast 17x7 20.9 9.48008116
Voxx Saga Cast 17x8 22.9 10.38726596
Voxx Saga Cast 18x8 25.6 11.61196544
Voxx Saga Cast 19x8 27.8 12.60986872
Voxx Scorze Cast 17x7 21.9 9.93367356
Voxx Scorze Cast 17x8 24 10.8862176
Voxx Scorze Cast 18x8 26.3 11.92948012
Voxx Scorze Cast 20x8 34 15.4221416
Voxx Scorze Cast 20x9 31.6 14.33351984
Voxx MG Cast 15x7 17.9 8.11930396
Voxx MG Cast 16x7 18.7 8.48217788
Voxx MG Cast 17x7 22.1 10.02439204
Voxx Toscana Cast 16x7 19.5 8.8450518
Voxx Toscana Cast 17x7 21.2 9.61615888
Voxx Ancona Cast 17x8 24 10.8862176
Voxx Ancona Cast 17x9 27 12.2469948
Voxx Ancona Cast 18x8 27 12.2469948
Voxx Ancona Cast 18x9 30 13.607772
Voxx Ancona Cast 20x8.5 36 16.3293264
Voxx Ancona Cast 20x9.5 38 17.2365112
Voxx Misano Cast 17x8 22 9.9790328
Voxx Misano Cast 17x9 25 11.33981
Voxx Misano Cast 18x8 27 12.2469948
Voxx Misano Cast 18x9 30 13.607772
Voxx Misano Cast 20x8.5 33 14.9685492
Voxx Misano Cast 20x9.5 35 15.875734
Voxx Monza Cast 15x7 18.7 8.48217788
Voxx Monza Cast 16x7 20.2 9.16256648
Voxx Monza Cast 17x7 21.2 9.61615888
VSMPO Alfa Cast 17x7.5 15.2 6.89460448
VSMPO Pallada R Cast 15x6.5 13.5 6.1234974
VSMPO Solaris Cast 15x6 11.5 5.2163126
VSMPO Vega R Cast 15x6.5 14.4 6.53173056
Wed's Celeb V2 Cast 16x7 19 8.6182556
Wed's RE-005 Cast 18x8 22 9.9790328
Wed's RE-005 Cast 19x8 24 10.8862176
Wed's RS-5 (Original design) Cast/Spun 15x6.5 13.5 6.1234974
Wed's RS-5 Super Street Cast 14x5 8.9 4.03697236
Wed's RS-5 Super Street Cast 15x5 9.2 4.17305008
Wed's RS-5 Super Street Cast 16x7 13.5 6.1234974
Wed's RS-5 Super Street Cast 17x7.5 15.6 7.07604144
Wed's SA-70 Cast 17x7.5 16.7 7.57499308
Wed's SA-70 Cast 17x9 17.8 8.07394472
Wed's SA-70 Cast 18x9 18.4 8.34610016
Wed's SA-90 Cast 15x7 17.4 7.89250776
Wed's SA-90 Cast 16x7 18.4 8.34610016
Wed's SA-90 Cast 17x7.5 20 9.071848
Wed's SA-90 Cast 17x8 20.8 9.43472192
Wed's TC-005 Forged 14x6 8.8 3.99161312
Wed's TC-005 Forged 15x6.5 10.2 4.62664248
Wed's TC-005 Forged 15x7 10.7 4.85343868
Wed's TC-005 Forged 15x7.5 11 4.9895164
Wed's TC-005 Forged 16x7 12.7 5.76062348
Wed's TC-005 Forged 16x7.5 13.2 5.98741968
Wed's TC-005 Forged 16x8 13.9 6.30493436
Wed's TC-005 Forged 17x7 13.8 6.25957512
Wed's TC-005 Forged 17x7.5 14.2 6.44101208
Wed's TC-005 Forged 17x8 14.9 6.75852676
Wed's TC-005 Forged 17x8.5 15.3 6.93996372
Wed's TC-005 Forged 17x9 15.8 7.16675992
Wed's TC-005 Forged 17x9.5 16.3 7.39355612
Wed's TC-005 Forged 18x10 18.9 8.57289636
Wed's TC-005 Forged 18x7.5 16.8 7.62035232
Wed's TC-005 Forged 18x8 17.7 8.02858548
Wed's TC-005 Forged 18x8.5 17.9 8.11930396
Wed's TC-005 Forged 18x9 18.6 8.43681864
Wed's TC-105N Forged 15x6.5 10.6 4.80807944
Wed's TC-105N Forged 15x7 11.2 5.08023488
Wed's TC-105N Forged 16x7 12.2 5.53382728
Wed's TC-105N Forged 17x8 14.9 6.75852676
Wed's TC-105N Forged 17x8.5 15.4 6.98532296
Wed's TC-105N Forged 17x9 15.8 7.16675992
Wed's TC-105N Forged 17x9.5 16.3 7.39355612
Wed's TC-105N Forged 18x10.5 18.4 8.34610016
Wed's TC-105N Forged 18x8 16.1 7.30283764
Wed's TC-105N Forged 18x8.5 17 7.7110708
Wed's TC-105N Forged 18x9.5 17.6 7.98322624
Weld (racing only) Cast 13x8 9.5 4.3091278
Weld (racing only) Cast 13x9 10 4.535924
Weld EVO Forged 16x8 16.2 7.34819688
Weld EVO Espada SL Forged 20x8.5 28.6 12.97274264
Weld EVO R-71 Forged 18x8 23 10.4326252
Weld EVO R-76 Forged 17x8 20 9.071848
Weld EVO SL-5 Forged 17x7 20 9.071848
Weld Magnum Import Drag Forged 13x8 8.6 3.90089464
Weld Type 76 Forged 15x7 15 6.803886
Western Turbine Cast 13x6 10 4.535924
Wolfrace ML Cast 15x7 17 7.7110708
Work CR-02 Cast 17x7 17.4 7.89250776
Work CR-03 Cast 18x8 20.9 9.48008116
Work Emotion Forged 17x7.5 15.3 6.93996372
Work Emotion Forged 17x8.5 16.2 7.34819688
Work Emotion Forged 18x7.5 16.7 7.57499308
Work Emotion Forged 18x8.5 17.4 7.89250776
Work Emotion CR Kai Cast 15x7 15 6.803886
Work Emotion CR Kai Cast 16x7 17 7.7110708
Work Emotion CR Kai Cast 17x7 19 8.6182556
Work Emotion CR Kai Cast 17x8 20 9.071848
Work Emotion CR Kai Cast 17x9 19 8.6182556
Work Emotion CR Kai Cast 18x7.5 21.4 9.70687736
Work Emotion CR Kai Cast 18x8.5 20.7 9.38936268
Work Equip 01 Cast 14x7 14.1 6.39565284
Work Equip 03 Cast 14x7 13.2 5.98741968
Work Ewing RS Beta 3-Piece Cast 15x6.5 15 6.803886
Work Meister S1 Cast/Spun 19x8.5 24 10.8862176
Work Meister S2R Forged/Spun 17x7 19.2 8.70897408
Work Meister S2R Forged/Spun 17x7.5 19 8.6182556
Work Meister S2R Forged/Spun 17x9 20.5 9.2986442
Work Meister S2R Forged/Spun 18x9 22.3 10.11511052
Work Rezax II Mag Forged Mg 18x8.5 19 8.6182556
Work Rezax III Mag Forged Mg 18x8 17.4 7.89250776
Work VS-XX Cast/Spun 15x6.5 15 6.803886
Work VS-XX Cast/Spun 15x7 15.5 7.0306822
Work VS-XX Cast/Spun 17x7 20 9.071848
Work VS-XX Cast/Spun 18x10 26 11.7934024
Work VS-XX Cast/Spun 18x8 24 10.8862176
Xenex Muse Cast 19x8 26.3 11.92948012
Zauber Genesis D-Six Cast 18x7.5 29.7 13.47169428
Zauber Genesis D-Six Cast 18x8 31.2 14.15208288
Zauber Glanzen Cast/Spun 17x7 24.1 10.93157684
Zauber Glanzen EV 3-Piece Cast/Spun 17x7.5 25.2 11.43052848
Zen Racing Matrix Cast 18x7.5 24 10.8862176
Zen Racing Race Cast 18x7.5 25.3 11.47588772
Zenetti Cast 18x8.5 24 10.8862176
Zenetti Cast 20x8.5 39.8 18.05297752
Zenetti Blade Cast 22x10 50 22.67962
Zinik Z15 Verona Cast 18x7.5 23.5 10.6594214
Zinik Z16 Duet Cast 18x8 28.5 12.9273834
Zinik Z17 Caroza Cast 18x7.5 26 11.7934024
Zinik Z18 Minardi Cast 18x7.5 23.5 10.6594214
Zinik Z20 Violi Cast 18x7.5 27.8 12.60986872
Zinik Z24 Risso Cast 17x7.5 23.5 10.6594214
Zinik Z24 Risso Cast 18x7.5 27 12.2469948
Zinik Z24 Risso Cast 19x8 30 13.607772
Zinik Z25 Luni Cast 18x7.5 27 12.2469948
Zinik Z27 Sofin Cast 18x7.5 27 12.2469948
Zinik Z5 Ikeda Cast 17x7.5 26 11.7934024
Zinik Z5 Ikeda Cast 18x7.5 28.5 12.9273834
Zinik Z7 Adrian Cast 17x7.5 21.8 9.88831432
Zinik Z7 Adrian Cast 18x7.5 26 11.7934024
Zinik Z9 Sabini Cast 18x7.5 27.1 12.29235404
Z-Speed Cast 15x6.5 12.3 5.57918652
LAST UPDATE: 6/29/10 total weights = 4495
You may send any additions/corrections to info@wheelweights.net
Please click on a Google ad or two to help me pay for part of my web hosting fees. Thanks.
