Fuel filter help, yeas I have searched!
#31
because that's a seperate issue. in that thread i'm asking how lexus goes about converting pnc numbers to part numbers. if i put that in this thread, i'll miss exposure to people who might have info on the topic but would never click this thread because they have never touched their fuel filter.
#32
JUST SAYING by putting it in here (or in the fuel filter thread where it should have gone lol) you gain exposure to all the people who HAVE actually done this and could actually be of help. even the people who might know how they convert the PNC #'s could be of help in there
i DO hope you get your issue resolved though as it seems ALL the 98-2000 people....who do this have issues with the o-rings and it would be of help to them...and as far as i have seen only OCH had on the 2001+ models
#33
^^^^^man, i just want help. i know someone has info on this process, but it seems like guys don't really try to add to the wealth of info on here anymore. people just are concerned about how low someone's car is or how wide their wheels are. i like that stuff too, but when i learn something that i think could help another user i try to post it here. people assume everything has been covered about these cars, but that isn't the case.
#34
SOMEONE HELP THIS GUY.....
#35
So, I went to Longo Lexus today to personally look into the PNC # situation. Unfortunately they couldn't help me get a number for the washer, but I have a new lead.
Anyone know of a Walbro distributor in the socal area? I believe the Walbro 400-765 fuel pump install kit for our car comes with a replacement washer. Will probably have to call in the morning though since Walbo doesn't even have a distibutor list on their website.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
#36
#37
i know i found that last night. that list is what's weak though, it only shows 3-4 distributors in socal. I called their headquarters in michigan this morning and had to call 2-3 other people before i found someone with it in stock. just got back from meeting them and wasting $25 because the kit doesn't have the washer or grommet that they picture in the ad. this is really starting to look like i'm going to have to buy a $100 used assembly just to get that washer.
And sak before you say i should've did my home work. i was desperate so i had to take the chance. the michigan guy over the department was on vacation so i couldn't ask him. 1st distribuutor another department gave didn't answer. 2nd distributor (a speed shop) said they had it but if i wanted to pick it up, i'd have to call another guy and get him to order it so he could see it to me for the same price.
Just met him at his condo to find out the crap is useless.
i really like the car, but i think i'm about to let it die slowly. i know an older car is going to have problems, but spending $100 for a plastic washer is ridiculous.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#38
i PROBABLY would have said that you should have DONE your homework and not the grammatical incorrect sentence you said ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
i'm def all for you getting some help man, lately i have seen alot of members with issues after doing theirs so if we can get a fix so no one else has to endure it, im all for it
....i just want them all together so people who claim to search can't/don't say they couldn't find it.
#39
Replaced the washer yesterday and let the car sit overnight. Started it this morning to check that the pressure was maintained. Car started right up, no stumble. l left it at home for the day. Just went to start it again and the thing stumbles again. I am totally lost, next guess is the regulator.
#40
Can someone post all the part# for all 3 o-rings if you have gotten them from Mcmaster Carr?
I change my fuel pump and fuel filter 2 months ago, got the pump from ebay, it came with one 0-ring which is the one going from the pump to the filter. The other two o-rings, one from the fuel filter outlet, and the one on the fuel pressure regulator, I just keep the old one in there, luckily, I don't have any problem, now I feel like I ought to change them out as well.
thanks million~
thanks million~
#41
thanks million~
thanks million~
YOU CANNOT GET THE BIG ONE FROM THE DEALER, SO YOU NEED TO USE MCMASTER OR SOME OTHER VENDOR. You're being lazy, but the Mcmaster p/n is 9263k765. But p/n's change all the time, so ensure that it is 10mm opening, 3.5 mm diameter and viton.
Relyas
12-05-17 04:43 PM
1JZPWRD
Performance & Maintenance
14
11-01-12 04:17 PM
