Rebuilding 1uzfe VVT-I
So guys, here I am, the "tinker-thinker!"
I was curious to know what front cover items should I replace while I'm rebuilding this engine, if any!?
- Assuming cost wasn't an issue which is a lie, but what are some of the things/concerns fellow GS owners have done.
* My Current Plans, after the engine is inspected by a machine shop:
Repair/Replace Harness Connectors
Misc Hoses
PCV Valve
VAFC NEO - I have
Full Gasket Kit - I have
PPE headers - I'd like to buy
New T-belt
New CPS???
Water Pump
Oil Pump
Radiator
Slim fan
New Mounts
Replace/Rebuild starter - Best route? Best Replacement brand?
Upgraded ALT
* New rings
* New Bearings
If I missed anything feel free to school me, I'd appreciate it.
Misc Hoses
PCV Valve
VAFC NEO - I have
New T-belt
New CPS???
Water Pump
Oil Pump
Radiator
Slim fan
New Mounts
Upgraded ALT
* New rings
* New Bearings
I did a full build and it's documented in the performance section. If it's just a basic rebuild of the engine. then I think you have most everything.
Complete gasket kit (which will include all seals)
All bearings (main, rod, thrust)
Recondition the head (valve seals and seating)
change out engine mounts (these tend to crack)
If you are changing the radiator, the stock fan setup is great if you can leave it, otherwise I would only use SPAL fans. Believe me I've tried many and these are the only ones that really work.
If you're going for a fully built motor, my build thread may give you some ideas.
Hope this helps
Hope this helps
I didn't find the thread for your factory rebuild, maybe it's in the archives. If you happen to know the title, or would be able to link me to it faster than I can find it, I'd appreciate it.
Going to do a search on it when I get home. That TT build was a crazy one sir
The TT rebuild was essentially it. Just got a few different parts to replace stock ones.
go to his page and search threads he made or here....
https://www.clublexus.com/forums/per...pic-happy.html
its one of my fav threads....
except no updates in awhile..... turn the boost up rick and show us what she is really like
Thanks
Gents.
How's that for an update
Hoytenki
IS - 1st Gen (2001-2005)
10-24-17 08:05 PM
wadge22
Performance & Maintenance
05-24-16 01:47 PM
1uzfe, components, engine, gasket, kit, oil, performance, rebuild, rebuilding, replacement, starter, timing, valve, variable, vvti
