Mark Levinson Speaker Size???
Does anyone confidently know the Speaker sizes located in the front doors. I called 2 Lexus dealers and they have no clue.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Really?? ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I have searched the forums and i am getting 4" and others have said 6.5". I was planning on pulling the trigger on some CDT 6.5" components but am now confused as i might get the wrong size.
This site states it's 6.5" speakers (http://www.metraonline.com/vfg) Crutchfield states its 4"... Now I'm really confused.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Also if it is 4" anyone know of a good adapter for this.
Thanks...
Thanks...
by silence.
Get off your tush, do some searching, and find the data for yourself in this forum. You've been given every bit of guidance to do just that.
So, they ARE 6.5"...ha. That's what I though- just wanted to make sure.
I will do that... yep. Might even run 5 and 1/4" components- whatever the better deal is.
THANKS AGAIN BRO
PS- Sakataj- I ordered a nice (used) front center channel speaker... ha, what should I DO with that situation, anyway. I can't run the OEM ML (3"?) front center channel speaker off an aftermarket amp, can I ?
Do you have any recommendations for what to use to replace the front center channel speaker with aftermarket? How did that Diamond Audio speaker or whatever that you used work ? (I think you said you just ending up disconnecting it though...it blew- AGAIN, right?)
I appreciate your help guys...
