ABS chirping noise
Old 06-29-11, 06:45 AM
98SBF
98SBF's Avatar
Unhappy ABS chirping noise
Hello all I have a 98 gs400 and I have a chirping noise coming from the ABS pump. Anyone have a fix for this or experience this yet
Thanks, Steven
Old 06-29-11, 12:44 PM
sam430
sam430's Avatar
Thanks, Steven
never heard of chirps before. can you record it? if it's a never ending flatline noise, then it's the booster. (Very easy to replace) replace it with the 2001+ model if it's the brake booster.
Old 06-30-11, 12:02 PM
98SBF
98SBF's Avatar
I think its the ABS pump kicking in to maintain pressure. So im pretty sure im going to have to replace the entire brake booster/ABS system right there on the firewall.
Old 06-30-11, 07:21 PM
wcgorillaz
wcgorillaz's Avatar
Happens to me every so often.. then all of a sudden continuous beep like an alarm goes off and my vsc light comes on; ABS light; and the traction light all stay on only as long as the beep sound is on. And I hear that chirping sound like air is pumping?? I dunno but the brakes feel fine
Old 07-02-11, 04:06 PM
gs4ca
gs4ca's Avatar
Happened to me unfortunatly its expensive if.its what was wrong.with ny car you have to.replace the whole brake.booster abs unit basically the whole assembly under the hood.in the driver side corner.......Lexus dealer quote was $2100
Old 07-06-11, 08:04 AM
98SBF
98SBF's Avatar
Well its what i thought it was and yes its going to be expensive!! Thanks for all your input.
Old 07-15-11, 01:19 AM
hkvan
hkvan's Avatar
Find a used one at junk yard.
Old 07-19-11, 06:36 PM
92sc300nj
92sc300nj's Avatar
almost positive its your abs actuator.
Old 07-12-17, 06:17 AM
airahcaz
airahcaz's Avatar
Default ABS Actuator
Hi did you end up replacing the actuator?
Old 07-12-17, 09:09 PM
Tank
Tank's Avatar
Guys, there is plenty of information on here about the ABS issues that you have. Search the forums. Most of us have had this problem in one form or another.
pishta
Suspension and Brakes
05-09-19 07:20 AM
Gs400fast
02-06-14 04:50 PM
dansgs400
Maintenance
04-27-13 09:34 PM
wcgorillaz
03-02-11 12:24 PM
max payne
01-02-07 03:35 PM
Quick Reply: ABS chirping noise
