GS300 Fuel Pump 12V Mod
If the GS is anything like the MKIV Supra 2jz fuel system then there is no need, even for the MKIV supra it has been proven not to do a dam thing. All you will do is waste gas, the pump runs at a lower voltage for normal throttle, WOT the pump goes full bore when extra fuel is needed. Running full time 12v will not do anything in terms of power. I did this mod orginally to my Supra, nothing gained. Switched it back, if your boosted you will need a 2nd pump or more normally anyways and need to redo your relay. For normal GS3 you dont need this, for boosted ones you are in a different game anyways.
Like I said if you are running two pump you want to redo your anyways. Bigger power cable, new relays, etc... my response was for a single factory pump, in your case go to Supraforums and look up pump relay and see how people do it, there should be a DIY somewhere on there.
The GS Fuel Pump Controller (FPC) is behind the carpet in the trunk on the drivers side and has 6 wires going to it. Battery + and -, Fuel Pump + and -, and two small gauge ECU control wires DI and FPC.
Without saying what you should or should not do, what I think you are referring to is just connecting the Battery feed from the FPC and jump it to the Pump +. This does work and you would cut the Black/Red Battery + and the Blue/Red Pump + then just connect the two together. You could also do the same to the White/Black and Blue/Yellow wires for the Ground and then just disconnect the FPC completely.
This would be fine for the standard 12v mod on a single pump, which has good and bad opinions of doing this, so I won't comment either way.
But I will say the 25 amp fuse under the hood labeled EFI and the Black/Red wire coming from it to the trunk FPC are both too small for the amps that 2 pumps will pull. I would recommend coming up with a different power solution for the second pump. The 2 pumps should be on separate fuses as well.
