Lazy Throttle won't give me WOT ...
So i finally got an OBDII device that lets me view sensor data in realtime. However i've noticed that no matter what i do the throttle position never goes over 75%. This occurs in power mode and normal. From a stand still, brake torqued take off, 20mph roll-on, etc. Is this normal for a GS300 or do i have another issue?
On our car, we got a TPS that shows throttle angle and we got a "Throttle switch (TS)" that shows Wide Open Throttle (WOT). If you want to check if the TS has a problem, check the sensor, when the switch is "ON" it's at WOT, off its vice versa. You would need some T-pins and a DMM to do this.
i with him, i don't think you'll see 100% throttle, but i don't know is 75% is high enough. the link to the manual is around here somewhere. in the manual, it will give you the initial blade angle setting which is around 14.7-16.3% i think and it'll give you the resistance range the motor should fall in. they're expensive, like $260 i believe, so i would diagnose it before buying one cause it could be a cheaper sensor like the tps.
Cp2295
11-26-16 12:24 AM
4blizak4mn
02-09-15 08:33 AM
