Help I failed.... What do I need to do?
First, I bought an ebay bosch O2 sensor (BANK 1 SENSOR 1) about two yrs ago, just so u know, i cut the plug on it and one off the old so it fits, Didnt fit with the bosch one. Ran my car on it for two yrs. Now two yrs later I changed it to the one that fits even with plug (NGK) and so i went for emission and I failed. Could it be that i destroyed my cat converter? One mechanic says do a tunes up. What do i need for a tune up? Please advise!!!!
98 GS3 240k km
98 GS3 240k km
ok.. for one.. when you get aftermarket oxygen sensors they arent 100% identical to oem ones.. this could cause differences in readings when it comes to the stock computer. now after seeing this plenty of times at the dealership you can get away with changing the oxygen sensors for a time being.. but its sooner than later the cat will go (very common problem) honestly more than likely its the catalytic converters. (mines got the same problem) especially if it has a catalyst in efficiency code.
flyboyplo
05-09-14 08:30 AM
