Where I can order these HID bulbs....
Okay, after endless researching, these are the light bulbs I want to order: http://www.philips.co.jp/lighting/pr...n_ultinon.html
Anyone know where in the US I can order them?
TX
TX
Call Jen Liu from http://www.suvlights.com
You can get his phone number on the site. Very knowledgeable fellow...He can and will answer any question you have. He sells the 6000K Ultinons and knows a ton about HID lighting.
don't forget www.autolamps-online.com...they will give you a special price too...just tell them you're from ClubLexus
Here's some places, not sure if they have exactly what you're looking for. I think the first one has the bulbs for sale.
http://www.hidsource.com/hid.htm
http://www.projectimport.com/xenon.htm
http://www.supremepowerparts.com/xenon.htm
http://www.autolamps-online.com/gasd...ge/ultinon.htm
http://www.xenontechnologies.com/
HID Bulb
Originally posted by rominl
250 shipped is the best i have heard so far. to fit d2s in the d2r housing, you need to use a dremel to make a little **** on the d2s bulbs
I've seen these at I think the suvlights.com site, and are available in the proper D2R configuration.
Even if you could modify the D2S bulbs to fit in your casing, they would not project properly. You must use D2R's unless you want to mod out your lights to be projector style.
The user Lex400sc had an excellent article posted recently that explains this in detail.
Re: HID Bulb
Originally posted by StylinGS300
Hi Guys, My 2002 GS300 came with HID. Does Lexus HID comes with 4100K or 6100K bulb? Is it a D2S or D2R housing? If it come with a 4100K bulb. Is it possible just to change the bulb to Phillip Ultinon 6000K and will it fit the GS housing? I like the blue look that's why I want to change my bulbs. Any info is appriciated.
TXSTYLE- are you going to be looking for any HIDs for the Z or is that still on hold for now???
exclusive matchup
Re: HID Bulb
all cars with hid come with 4100k, that's the legal limit. gs uses the d2r type bulbs. you can do direct swap for 6000k, the ballast will hold no problem
Re: Re: HID Bulb
Originally posted by sphereman
Hi TX
your car looks great.
did you have the car repainted by any chance?
also, would you mind posting some pics of your wood steering wheel?
thanks.
Hi TX
thanks.
Here's a good and up close pic of my interior.
